We have ColdFusion 10 installed and notice that it crashes constantly with the following error:
Service Temporary Unavailable!
The server is temporary unable to service your request due to maintenance downtime or capacity problems. Please try again later.
Jakarta/ASAPI/isapi_redirector/1.2.32()
Copyright 1999-2011 Apache Foundation All Rights Reserved.
It did appear that Adobe have an update (fix) for the issue. We applied all updates to the server, but the problem still persist.
Can anyone help?
Can you take a look at the coldfusion-out.log, application.log, coldfusion-error.log etc
These will probably give you more information.
You can also look for the connector log if its enabled by going to the cf_root/config/wsconfig/<number> folder.
<number> is the the value the connector has assigned if you have multiple connections setup.
There is usually a isapi_redirect.log in there.
Thank you for responding...
The isapi_redirect.log stated the following.... (Do you know what is causing the errors?)
[Mon Sep 18 11:08:00.555 2017] [1896:2244] [error] isapi_write_client::jk_isapi_plugin.c (1261): WriteClient failed with 1229 (0x000004cd)
[Mon Sep 18 11:08:00.555 2017] [1896:2244] [info] ajp_process_callback::jk_ajp_common.c (1954): Writing to client aborted or client network problems
[Mon Sep 18 11:08:00.555 2017] [1896:2244] [info] ajp_service::jk_ajp_common.c (2629): (cfusion) sending request to tomcat failed (unrecoverable), because of client write error (attempt=1)
[Mon Sep 18 11:08:00.571 2017] [1896:2244] [info] HttpExtensionProc::jk_isapi_plugin.c (2268): service() failed because client aborted connection
[Mon Sep 18 11:08:22.540 2017] [1896:2596] [error] isapi_write_client::jk_isapi_plugin.c (1261): WriteClient failed with 1229 (0x000004cd)
[Mon Sep 18 11:08:22.540 2017] [1896:2596] [info] ajp_process_callback::jk_ajp_common.c (1954): Writing to client aborted or client network problems
[Mon Sep 18 11:08:22.555 2017] [1896:2596] [info] ajp_service::jk_ajp_common.c (2629): (cfusion) sending request to tomcat failed (unrecoverable), because of client write error (attempt=1)
[Mon Sep 18 11:08:22.555 2017] [1896:2596] [info] HttpExtensionProc::jk_isapi_plugin.c (2268): service() failed because client aborted connection
[Mon Sep 18 11:12:20.729 2017] [1896:2448] [error] isapi_write_client::jk_isapi_plugin.c (1261): WriteClient failed with 995 (0x000003e3)
[Mon Sep 18 11:12:20.729 2017] [1896:2448] [info] ajp_process_callback::jk_ajp_common.c (1954): Writing to client aborted or client network problems
[Mon Sep 18 11:12:20.729 2017] [1896:2448] [info] ajp_service::jk_ajp_common.c (2629): (cfusion) sending request to tomcat failed (unrecoverable), because of client write error (attempt=1)
[Mon Sep 18 11:12:20.729 2017] [1896:2448] [info] HttpExtensionProc::jk_isapi_plugin.c (2268): service() failed because client aborted connection
[Mon Sep 18 11:12:28.783 2017] [1896:2448] [error] isapi_write_client::jk_isapi_plugin.c (1261): WriteClient failed with 995 (0x000003e3)
[Mon Sep 18 11:12:28.799 2017] [1896:2448] [info] ajp_process_callback::jk_ajp_common.c (1954): Writing to client aborted or client network problems
[Mon Sep 18 11:12:28.799 2017] [1896:2448] [info] ajp_service::jk_ajp_common.c (2629): (cfusion) sending request to tomcat failed (unrecoverable), because of client write error (attempt=1)
[Mon Sep 18 11:12:28.799 2017] [1896:2448] [info] HttpExtensionProc::jk_isapi_plugin.c (2268): service() failed because client aborted connection
[Mon Sep 18 11:16:24.575 2017] [1896:3864] [error] isapi_write_client::jk_isapi_plugin.c (1261): WriteClient failed with 995 (0x000003e3)
[Mon Sep 18 11:16:24.575 2017] [1896:3864] [info] ajp_process_callback::jk_ajp_common.c (1954): Writing to client aborted or client network problems
[Mon Sep 18 11:16:24.575 2017] [1896:3864] [info] ajp_service::jk_ajp_common.c (2629): (cfusion) sending request to tomcat failed (unrecoverable), because of client write error (attempt=1)
[Mon Sep 18 11:16:24.575 2017] [1896:3864] [info] HttpExtensionProc::jk_isapi_plugin.c (2268): service() failed because client aborted connection
[Mon Sep 18 11:19:12.563 2017] [1896:2244] [error] isapi_write_client::jk_isapi_plugin.c (1261): WriteClient failed with 1229 (0x000004cd)
[Mon Sep 18 11:19:12.563 2017] [1896:2244] [info] ajp_process_callback::jk_ajp_common.c (1954): Writing to client aborted or client network problems
[Mon Sep 18 11:19:12.579 2017] [1896:2244] [info] ajp_service::jk_ajp_common.c (2629): (cfusion) sending request to tomcat failed (unrecoverable), because of client write error (attempt=1)
[Mon Sep 18 11:19:12.579 2017] [1896:2244] [info] HttpExtensionProc::jk_isapi_plugin.c (2268): service() failed because client aborted connection
These errors continuously repeat....
What update version of CF10 do you have?
Are you able to reproduce the error or is it random?
I haven't encountered this myself, but it sounds like a Tomcat problem reported here some years ago.
