Hi
I'm working on this site:
http://jumpinghorses.businesscatalyst.com
In the Menue the word "Angebot" is "middle bold" but it should be "regular" like "Team" and "Kontakt".
The Textformat for all states (normal, rollover, active, click etc.) ist correct in Muse but why does the Browser show the wrong Textformat ?
Kind regards
Alain
Interesseting behaving in Muse:
First I tried again with the Muse-File I've uploaded - still the same wrong behaving.
The only difference between your and my tests was the text of the menuebuttons.
So renamed every Button to "Aktuelles" as in your working example (copy-paste the Text "Aktuelles").
To my surprise after this change it worked as well.
Then I rename every button to it's original name an it still works.
I my opinion this must be some Bug in Muse or some unproper textformat.
Anyway: Thanks f
...Copy link to clipboard
Could you please specify?
What I am seeing:
In normal state your menu entries are mixed: Open Sans regular, except „Kontakt": Open Sans 300
In rollover state: Open Sans regular, modified grey, except „Kontakt“: no change in rollover
In active state: Open Sans Bold, „Kontakt“: no change in active state.
What exactly is the issue?
As I said:
In the Menue the Textweight of the word "Angebot" should be "regular" like "Team" and "Kontakt" but is looks like "middle bold", but I'm sure I've set it to "regular".
In your Screenshots the Textweight of "Angebot" and "Team" looks wrong, they should look like "Kontakt".
An in the Textsettings in Muse all Menue-Item are set to the same Textformat - I've double checked this.
Could you please delete all content on all pages except the menu, and save this an extra .muse file. Then give us this .muse file for investigation by using Dropbox or a similar file sharing service. You may follow these instructions: https://forums.adobe.com/docs/DOC-8652
Would be fine, if you tell us exactly how the text formatting is defined in the single states of your menu.
I can’t see any issue.
Your definitions:
And exactly this is shown in browsers.
Here the screencast (I renamed the different menu entries all to „Aktuelles“ to be able to notice differences more easy):
Some annotations, not really related to your „issue“:
Anyway: Thanks for your fast support, I really appreciate this.
Definitely no bug! Why should it be? I tried exactly your menu construction, and it works correctly. I only renamed the items after that, to make it even more clear, that everything works fine.
I assume, you run into a browser cache issue.
