Locked
Footer and header displaced after first breakpoint (but not in safari)
Sep 17, 2017 Sep 17, 2017
Hi community
I have big hopes that You can help me out, as i've ran out of ideas and failed to find any answer after many hours of trying.
So i have a header starting from the top of the page, on the bottom i have footer, both are just solid rectangles full width and a web font. Everything stays at place (or scales) properly until i add a breakpoint. Then after crossing that breakpoint i see no footer, as well as header rectangle and some of my headers text hangs from upper left corner. Some screenshots, first before breakpoint with all in place, second after;
Zrzut ekranu 2017-09-17 o 16.43.30.png Zrzut ekranu 2017-09-17 o 16.43.43.png
But this is the case for opera and firefox browsers – in design mode, preview and in safari everything is on place. So it gets me quite confused.
It doesent matter if its fluid or fixed, happens at both. I have same result with different placement of breakpoint.
If i remove white rectangle from the header type doesn't get displaced. Footer is missing even if I delete its rectangle.
Rest of the content behaves normally.
Any help would be much appreciated.
219
LEGEND , Sep 17, 2017 Sep 17, 2017
Have no idea so far. Do you use any 3rd Party widgets? Sounds strange, though.
Best Regards,
Uwe
Best Regards,
Uwe
Hi fotoroeder
I almost forgot im using In & Out Qoo Qee widget for side to fade in. After your question ive checked site and it works perfectly!
Thank You!
Lucky punch. Wish all question would be solved that easy.
Lucky sunday and wishing a successful week now.
Best Regards,
Uwe
