I used to use Adobe Reader all the time to fill out documents, but recently I have not been able to sign and fill anything. including documents that I have done so with in the past. Someone, please help me.
Hi Kanniainenbs,
Sorry for the delay in response.
As per the issue description, you are unable to fill and sign pdf in Adobe Reader, is that correct?
Please try following troubleshooting steps:
1- Reboot the machine if you haven't already and try again.
2- Check if an update is available for Reader- launch Reader> click Help > select Check for Updates.
You may also visit these links discussing the issue similar to yours:
Fill & Sign does not load the file and displays blank screen
...Copy link to clipboard
Hi Kanniainenbs,
Unable to add text with Fill & Sign
Please confirm the dot version of Reader you have on the machine: Identify the product and its version for Acrobat and Reader DC
And, the operating system installed on the machine?
What happens when you Fill and Sign option in Reader? Is there any error message?
Shivam
