PS is currently set-up to import my pdfs in greyscale. Does anyone know how to change the default to CMYK?
I believe the open dialog defaults to the last used option. Open a PDF, change the color to CMYK, and then close the document. When you open the next PDF it should default to CMYK.
(Working on a Macintosh)
What do you mean by 'import'? Are you opening the PDF file in Ps with File>Open, or are you placing the PDF into an already open document?
File > Open
