I can't verify if this is an issue with the upcoming version of macOS High Sierra (I've noticed it across several public betas), but the cursor will begin to act odd after switching between apps and InDesign 2017.1. When switching between other apps and InDesign, the regular arrow mouse cursor becomes to a box that changes depending on the the interaction with the page elements. It takes a restart of InDesign to get the normal cursors/arrow back. Not sure if it's unique to switching between certain apps, but it's quite tricky to use once it acts up like this. No issues like this with any other Adobe apps. Anyone else on High Sierra have this issue?
Hi everyone,
This issue has been resolved with the MacOS 10.13 Supplemental Update released today. Please update your OS if you're experiencing this issue with High Sierra.
Wren
Yep, same here. Photoshop and Indesign seem okay so far, but Indesign's cursor is seriously jacked up. I'm running beta 17A358a.
I switched to High Sierra 10.13 Beta (17A362a), which is supposed to be the final release before next week's public release. But as far as InDesign is concerned, High Sierra has been the Mojave Desert. I've tried everything suggested in this forum, and I still have to quit out of InDesign and restart it every couple of files.
I originally switched to InDesign 1.0 back at the beginning of time because Quark was making us use those ridiculous dongles. What morons. Now I'm starting to feel the same thing about Adobe and InDesign. They should have had this taken care of a few weeks after it was first reported.
It's an Apple bug. Take it up with them.
Seriously? You mean Adobe isn't able to phone Apple and they haven't been able to find a solution for this in how many months? It's not like this is some obscure part of InDesign that people rarely use. This is the cursor.
As for being an apologist for Adobe, I feel no such need. I was the first publisher in the country to send a book to press that had been done in InDesign 1.0, back when people in the publishing world said I was nuts for doing so. I've been a strong backer of InDesign since the start. So if anyone has a right to say that Adobe has dropped the ball on this one, I think I'm in that group. And that's exactly what Adobe has done.
Dude... You're using pre-release software. You shouldn't be running a beta on a mission critical machine, and you should fully expect bugs. Adobe will release an update once the final version of High Sierra drops on the 25th. It makes sense for Adobe to wait until the final release of macOS before releasing any new versions of Adobe CC apps.
Dude, This would be the golden master of High Sierra five days before the public release. There are reasons I needed to upload it, otherwise, I would have waited. But I did a careful check first if there were problems with Adobe products and High Sierra, and the only one that kept coming up was Illustrator, which I don't need to use very often. The last thing I expected was the cursor to still be glitchy a few days before the public release in one of Adobe's top products--with the suggestions offered by an Adobe employee to fix it having no effect.
But hey, it's good to hear you've figured it all out, and thanks for the lecture!
We have isolated this issue, it is present on MAC OS 10.13, and can occur anytime whenever cursor related functionality being used like placing/drag-drop/selection etc.
We are actively working with Apple on this issue to get it resolved as soon as possible. However, it may not get fixed with the GM build of High Sierra (10.13), but a subsequent Dot Release.
We will surely let our customer know, once we have more information from Apple.
Currently the only workarounds are:
1) Restart InDesign.
2) Revert back to MAC OS 10.12.6
[Edited response]
-Aman
Yes, it's 10.13 and yes that fixed it. Thanks!
Actually that fixed it for a while, now it's back to doing it again. I think it only happens if I move between CC applications.
Yes, same here. I turned off the GPU option in Prefs, restarted the app and eventually the bad cursors appear again. Will share anything else I notice about it.
Same here, nothing seems to fix the problem, but looking forward to the fix. Thank you.
I have the exact same issue. I've tried turning off the GPU option but no joy. Filed a BR with Apple so maybe they can coordinate with Adobe to track it down. No problems so far with Photoshop or Illustrator.
If the above post did not solve the issue and now InDesign is difficult to work on(offcourse) then please revert to 10.12.5 temporarily.
I hope this is not much of a problem... we will soon be fixing this. (If it is not an Apple issue)
I have not seen this happen with GPU turned off.
-Aman
This is happening to me as well. I have to restart InDesign every 5-10 minutes to go back to a normal cursor, but then it comes back. Just FYI. Came here while searching for answers. Only InDesign, not seeing this in other Adobe CC apps (though I haven't tried many aside from Photoshop & Illustrator).
I'm also seeing this. Running latest version of InDesign CC on macOS 10.13 Beta (17A360a). Extremely frustrating. FWIW, my machine does not support GPU Performance - it's off by default and I am still seeing this issue.
I filed a bug report with Apple using the Feedback Assistant and detailed the problem best I could. Since it's only happening with Beta users, it should be something they can get to the bottom of.
Are any of you others, with the issue, noticing that it mostly happens when you switch between apps and come back to InDesign? Seems if I stay within InDesign, the cursor stays okay.
I tried and couldn't see any problems. There have been a few beta updates since the topic was started. Is it still happening for you in 10.13 Beta (17A360a)?
I'm running 17A360a and the bug is still present.
Yes. Moving between apps seems to cause this issue. Specifically, using mission control to switch apps seems to trigger the bug for me.
I have had this issue for a while now (also on the developer preview). Holding Ctrl + Alt + Command + Shift after clicking on InDesign clears the cache and seems to delay it happening a bit longer. I almost had a day without it! It is so annoying! Hopefully will be fixed soon.
Running MacOS 10.13 Beta (17A360a) here and I can report I'm having the same issue. Fingers crossed for a swift fix as it's becoming increasingly more frustrating.
While it may well be an InDesign issue, it may very well be an O/S issue. I suggest reporting it to Apple.
In messages 7 and 10 you can see that both people reported to Apple. Mr E38 could do so too.
Of course…the more the merrier.
