By a new document when I choose the "transparant", it does not work. I always get white background
Hi
If you are able to see the correct menu items but are not getting the expected result then I would reset Photoshop preferences
Press and hold Alt+Control+Shift (Windows) or Option+Command+Shift (Mac OS) as you start Photoshop. The timing can be a little tricky but if you get it right you will prompted to delete the current settings. New preferences files will then be created.
Dave
Hi
You have posted in the Lounge which is for non-technical discussions. We can move your post to an appropriate forum if you can tell us what application you are using (e.g. Illustrator, Photoshop..... etc)
Dave
Thank you for your Answer Dave. I am working with Photoshop CC 2014. I
already have done everything what I have read about " to get a transparant
background" but without getting this transparant...
Kind regards Eva
[email details removed ussnorway]
moved to Photoshop forum
Hi
For a brand new document you can start with a transparent background by choosing it from the New document dialogue
Once opened it will stay transparent as long as you save your document in a file format that supports transparency - such as PSD / TIFF /PNG. Note : Jpeg does not support transparency.
Dave
Thank you Dave but this is that problem I mean. If I choose tranparent it doesn´t work... I always get white. A few times PC or Photoshop started, but without any result... Eva
Hi
Dave
Yes, I got it! Lot of thanks Dave!
You're welcome
Dave
