I signed up for the Adobe flash distribution program and have started deploying flash through GPO. Since then I have received several phone calls of people saying IE needs them to update flash to run a website. I remote to their computer and check installed programs and the latest version of Adobe is installed on their machine from the GPO yet it does not work in IE. If I reinstall flash on the users computer then it works fine.
Anyone else run into this issue? Any idea what I would be doing wrong? Below is my GPO.
Please provide the following information:
The verbose MSI log file and FlashInstall.log file(s) MUST be from the same machine for the same installation attempt.
Upload all log files to cloud.acrobat.com/send using the instructions at How to share a document and post the link to the uploaded files in your reply.
Thank you.
Maria
Does the Flash Player ActiveX GPO install succeed for some users but not others? If so, what percentage fails?
The software installs on all computers just fine the issue is that it seems it is not registering in internet explorer so even though it is install internet explorer says that it needs to be installed when you hit a site with flash.
Reproduce the issue while creating a verbose MSI log file with additional debugging option enabled (options x & v)
Please explain this, do you mean do this in the GPO by adding switches?
FlashInstall.log files saved at C:\Windows\System32\Macromed\Flash. If this is a 64-bit OS, the FlashInstall.log file from the C:\WIndows\SysWOW64\Macromed\Flash directory is also required.
I have attached these logs
Thank You,
Todd Welch
Please refer to the tech notes How do I create an installation log? and Fixing Group Policy problems by using log files: Group Policy for assistance in creating verbose log files. The logging options requested are v (verbose) and x (extra debugging information).
A few more questions:
The forums software do not accept attachments (except for images). Please upload the requested information to How to share a document and post the link to the files in your reply.
Maria
<edited to ask a few more questions>
Sorry for the late reply but I have those logs now and I have pasted them below. The install generated three logs related to the flash install.
Also here are the answers to you other questions.
Windows 7
Server 2008
It has never been successful just trying to get this working now, previously we did this manually.
====START==MSI21b9a.LOG=================
=== Verbose logging started: 2/15/2017 15:29:02 Build type: SHIP UNICODE 5.00.7601.00 Calling process: C:\windows\system32\svchost.exe ===
MSI (c) (E8:EC) [15:29:02:106]: User policy value 'DisableRollback' is 0
MSI (c) (E8:EC) [15:29:02:106]: Machine policy value 'DisableRollback' is 0
MSI (c) (E8:EC) [15:29:02:106]: Machine policy value 'DisableUserInstalls' is 0
MSI (c) (E8:EC) [15:29:02:153]: Note: 1: 1402 2: HKEY_LOCAL_MACHINE\Software\Microsoft\Windows\CurrentVersion\Installer\Rollback\Scripts 3: 2
MSI (c) (E8:EC) [15:29:02:153]: Executing op: Header(Signature=1397708873,Version=500,Timestamp=1233470159,LangId=1033,Platform=0,ScriptType=3,ScriptMajorVersion=21,ScriptMinorVersion=4,ScriptAttributes=0)
MSI (c) (E8:EC) [15:29:02:184]: Executing op: ProductInfo(ProductKey={559A2FA4-4858-46E7-BD02-68C15A31DF98},ProductName=Adobe Flash Player 23 ActiveX,PackageName=IE_install_flash_player_23_active_x.msi,Language=1033,Version=385875968,Assignment=0,ObsoleteArg=0,ProductIcon=ARPPRODUCTICON.exe,,PackageCode={3461021C-AFFA-45CA-802C-78D75C41BFEB},,,InstanceType=0,LUASetting=0,RemoteURTInstalls=0,ProductDeploymentFlags=3)
MSI (c) (E8:EC) [15:29:02:184]: Executing op: DialogInfo(Type=0,Argument=1033)
MSI (c) (E8:EC) [15:29:02:184]: Executing op: DialogInfo(Type=1,Argument=Adobe Flash Player 23 ActiveX)
MSI (c) (E8:EC) [15:29:02:184]: Executing op: RollbackInfo(,RollbackAction=Rollback,RollbackDescription=Rolling back action:,RollbackTemplate=[1],CleanupAction=RollbackCleanup,CleanupDescription=Removing backup files,CleanupTemplate=File: [1])
MSI (c) (E8:EC) [15:29:02:184]: Executing op: ActionStart(Name=CreateShortcuts,Description=Creating shortcuts,Template=Shortcut: [1])
MSI (c) (E8:EC) [15:29:02:184]: Executing op: IconCreate(Icon=ARPPRODUCTICON.exe,Data=BinaryData)
MSI (c) (E8:EC) [15:29:02:623]: Executing op: ActionStart(Name=PublishFeatures,Description=Publishing product features,Template=Feature: [1])
MSI (c) (E8:EC) [15:29:02:623]: Executing op: FeaturePublish(Feature=FlashPlayerAXInstaller,,Absent=0,)
MSI (c) (E8:EC) [15:29:02:639]: Executing op: FeaturePublish(Feature=WIFEAT00000003,,Absent=0,)
MSI (c) (E8:EC) [15:29:02:639]: Executing op: FeaturePublish(Feature=WIFEAT00000002,,Absent=0,)
MSI (c) (E8:EC) [15:29:02:639]: Executing op: FeaturePublish(Feature=WIFEAT00000001,,Absent=0,)
MSI (c) (E8:EC) [15:29:02:639]: Executing op: ActionStart(Name=PublishProduct,Description=Publishing product information,)
MSI (c) (E8:EC) [15:29:02:639]: Executing op: CleanupConfigData()
MSI (c) (E8:EC) [15:29:02:639]: Note: 1: 1402 2: HKEY_LOCAL_MACHINE\Software\Microsoft\Windows\CurrentVersion\Installer\UserData\S-1-5-18\Products\4AF2A95585847E64DB20861CA513FD89\Patches 3: 2
MSI (c) (E8:EC) [15:29:02:639]: Executing op: ProductPublish(PackageKey={3461021C-AFFA-45CA-802C-78D75C41BFEB})
MSI (c) (E8:EC) [15:29:02:639]: Note: 1: 1402 2: UNKNOWN\Installer\Products\4AF2A95585847E64DB20861CA513FD89 3: 2
MSI (c) (E8:EC) [15:29:02:654]: Executing op: UpgradeCodePublish(UpgradeCode={42463807-970B-4257-BC95-5C348D61DF1C})
MSI (c) (E8:EC) [15:29:02:654]: Executing op: SourceListPublish(,,DiskPromptTemplate=[1],,NumberOfDisks=1)
MSI (c) (E8:EC) [15:29:02:654]: Note: 1: 1402 2: UNKNOWN\Installer\Products\4AF2A95585847E64DB20861CA513FD89\SourceList 3: 2
MSI (c) (E8:EC) [15:29:02:670]: Executing op: ProductPublishClient(,,)
MSI (c) (E8:EC) [15:29:02:670]: Executing op: End(Checksum=0,ProgressTotalHDWord=0,ProgressTotalLDWord=0)
MSI (c) (E8:EC) [15:29:02:702]: Note: 1: 2318 2:
MSI (c) (E8:EC) [15:29:02:702]: DoAdvertiseScript is returning: 0
=== Verbose logging stopped: 2/15/2017 15:29:02 ===
====END==MSI21b9a.LOG=================
====START==MSI21b9c.LOG=================
MSI (c) (E8:A0) [15:29:02:733]: Resetting cached policy values
MSI (c) (E8:A0) [15:29:02:733]: Machine policy value 'Debug' is 3
MSI (c) (E8:A0) [15:29:02:733]: ******* RunEngine:
******* Product: {559a2fa4-4858-46e7-bd02-68c15a31df98}
******* Action:
******* CommandLine: **********
MSI (c) (E8:A0) [15:29:02:749]: Client-side and UI is none or basic: Running entire install on the server.
MSI (c) (E8:A0) [15:29:02:749]: Grabbed execution mutex.
MSI (c) (E8:A0) [15:29:03:172]: Cloaking enabled.
MSI (c) (E8:A0) [15:29:03:172]: Attempting to enable all disabled privileges before calling Install on Server
MSI (c) (E8:A0) [15:29:03:172]: Incrementing counter to disable shutdown. Counter after increment: 0
MSI (s) (20:0C) [15:29:03:187]: Running installation inside multi-package transaction {559a2fa4-4858-46e7-bd02-68c15a31df98}
MSI (s) (20:0C) [15:29:03:187]: Grabbed execution mutex.
MSI (s) (20:58) [15:29:03:187]: Resetting cached policy values
MSI (s) (20:58) [15:29:03:187]: Machine policy value 'Debug' is 3
MSI (s) (20:58) [15:29:03:187]: ******* RunEngine:
******* Action:
MSI (s) (20:58) [15:29:03:187]: Machine policy value 'DisableUserInstalls' is 0
MSI (s) (20:58) [15:29:03:203]: User policy value 'SearchOrder' is 'nmu'
MSI (s) (20:58) [15:29:03:203]: User policy value 'DisableMedia' is 0
MSI (s) (20:58) [15:29:03:203]: Machine policy value 'AllowLockdownMedia' is 0
MSI (s) (20:58) [15:29:03:203]: SOURCEMGMT: Media enabled only if package is safe.
MSI (s) (20:58) [15:29:03:203]: SOURCEMGMT: Looking for sourcelist for product {559a2fa4-4858-46e7-bd02-68c15a31df98}
MSI (s) (20:58) [15:29:03:203]: SOURCEMGMT: Adding {559a2fa4-4858-46e7-bd02-68c15a31df98}; to potential sourcelist list (pcode;disk;relpath).
MSI (s) (20:58) [15:29:03:203]: SOURCEMGMT: Now checking product {559a2fa4-4858-46e7-bd02-68c15a31df98}
MSI (s) (20:58) [15:29:03:203]: SOURCEMGMT: Media is enabled for product.
MSI (s) (20:58) [15:29:03:203]: SOURCEMGMT: Attempting to use LastUsedSource from source list.
MSI (s) (20:58) [15:29:03:203]: SOURCEMGMT: Processing net source list.
MSI (s) (20:58) [15:29:03:203]: SOURCEMGMT: Trying source \\cc-serverv03\it\Applications\Adobe\Flash\.
MSI (s) (20:58) [15:29:03:203]: Note: 1: 1402 2: HKEY_CURRENT_USER\Software\Microsoft\Windows\CurrentVersion\Policies\Explorer 3: 2
MSI (s) (20:58) [15:29:07:199]: Note: 1: 1314 2: \\cc-serverv03\it\Applications\Adobe\Flash\
MSI (s) (20:58) [15:29:07:199]: ConnectToSource: CreatePath/CreateFilePath failed with: -2147483648 1314 -2147483648
MSI (s) (20:58) [15:29:07:199]: ConnectToSource (con't): CreatePath/CreateFilePath failed with: -2147483648 -2147483648
MSI (s) (20:58) [15:29:07:199]: SOURCEMGMT: net source '\\cc-serverv03\it\Applications\Adobe\Flash\' is invalid.
MSI (s) (20:58) [15:29:07:199]: Note: 1: 1706 2: -2147483647 3: IE_install_flash_player_23_active_x.msi
MSI (s) (20:58) [15:29:07:199]: SOURCEMGMT: Processing media source list.
MSI (s) (20:58) [15:29:07:199]: Note: 1: 2203 2: 3: -2147287037
MSI (s) (20:58) [15:29:07:199]: SOURCEMGMT: Source is invalid due to missing/inaccessible package.
MSI (s) (20:58) [15:29:07:199]: SOURCEMGMT: Processing URL source list.
MSI (s) (20:58) [15:29:07:199]: Note: 1: 1402 2: UNKNOWN\URL 3: 2
MSI (s) (20:58) [15:29:07:199]: Note: 1: 1706 2: 3: IE_install_flash_player_23_active_x.msi
MSI (s) (20:58) [15:29:07:199]: SOURCEMGMT: Failed to resolve source
MSI (s) (20:58) [15:29:07:199]: MainEngineThread is returning 1612
MSI (s) (20:0C) [15:29:07:199]: User policy value 'DisableRollback' is 0
MSI (s) (20:0C) [15:29:07:199]: Machine policy value 'DisableRollback' is 0
MSI (s) (20:0C) [15:29:07:199]: Incrementing counter to disable shutdown. Counter after increment: 0
MSI (s) (20:0C) [15:29:07:199]: Note: 1: 1402 2: HKEY_LOCAL_MACHINE\Software\Microsoft\Windows\CurrentVersion\Installer\Rollback\Scripts 3: 2
MSI (s) (20:0C) [15:29:07:199]: Note: 1: 1402 2: HKEY_LOCAL_MACHINE\Software\Microsoft\Windows\CurrentVersion\Installer\InProgress 3: 2
MSI (s) (20:0C) [15:29:07:199]: Decrementing counter to disable shutdown. If counter >= 0, shutdown will be denied. Counter after decrement: -1
MSI (s) (20:0C) [15:29:07:199]: Restoring environment variables
MSI (c) (E8:A0) [15:29:07:215]: Decrementing counter to disable shutdown. If counter >= 0, shutdown will be denied. Counter after decrement: -1
MSI (c) (E8:A0) [15:29:07:215]: MainEngineThread is returning 1612
=== Verbose logging stopped: 2/15/2017 15:29:07 ===
====END==MSI21b9c.LOG=================
====START==MSI21b9d.LOG=================
=== Verbose logging started: 2/15/2017 15:29:07 Build type: SHIP UNICODE 5.00.7601.00 Calling process: C:\windows\system32\svchost.exe ===
MSI (c) (E8:70) [15:29:07:215]: User policy value 'DisableRollback' is 0
MSI (c) (E8:70) [15:29:07:215]: Machine policy value 'DisableRollback' is 0
MSI (c) (E8:70) [15:29:07:215]: Note: 1: 1402 2: HKEY_LOCAL_MACHINE\Software\Microsoft\Windows\CurrentVersion\Installer\Rollback\Scripts 3: 2
MSI (c) (E8:70) [15:29:07:215]: Executing op: Header(Signature=1397708873,Version=500,Timestamp=1233470159,LangId=1033,Platform=0,ScriptType=3,ScriptMajorVersion=21,ScriptMinorVersion=4,ScriptAttributes=0)
MSI (c) (E8:70) [15:29:07:215]: Executing op: ProductInfo(ProductKey={559A2FA4-4858-46E7-BD02-68C15A31DF98},ProductName=Adobe Flash Player 23 ActiveX,PackageName=IE_install_flash_player_23_active_x.msi,Language=1033,Version=385875968,Assignment=0,ObsoleteArg=0,ProductIcon=ARPPRODUCTICON.exe,,PackageCode={3461021C-AFFA-45CA-802C-78D75C41BFEB},,,InstanceType=0,LUASetting=0,RemoteURTInstalls=0,ProductDeploymentFlags=3)
MSI (c) (E8:70) [15:29:07:215]: Executing op: DialogInfo(Type=0,Argument=1033)
MSI (c) (E8:70) [15:29:07:215]: Executing op: DialogInfo(Type=1,Argument=Adobe Flash Player 23 ActiveX)
MSI (c) (E8:70) [15:29:07:215]: Executing op: RollbackInfo(,RollbackAction=Rollback,RollbackDescription=Rolling back action:,RollbackTemplate=[1],CleanupAction=RollbackCleanup,CleanupDescription=Removing backup files,CleanupTemplate=File: [1])
MSI (c) (E8:70) [15:29:07:215]: Executing op: ActionStart(Name=CreateShortcuts,Description=Creating shortcuts,Template=Shortcut: [1])
MSI (c) (E8:70) [15:29:07:215]: Executing op: IconCreate(Icon=ARPPRODUCTICON.exe,Data=BinaryData)
MSI (c) (E8:70) [15:29:07:215]: Scheduling file 'C:\windows\Installer\{559A2FA4-4858-46E7-BD02-68C15A31DF98}\ARPPRODUCTICON.exe' for deletion during post-install cleanup (not post-reboot).
MSI (c) (E8:70) [15:29:07:215]: Executing op: ActionStart(Name=PublishFeatures,Description=Publishing product features,Template=Feature: [1])
MSI (c) (E8:70) [15:29:07:215]: Executing op: FeaturePublish(Feature=FlashPlayerAXInstaller,,Absent=0,)
MSI (c) (E8:70) [15:29:07:215]: Executing op: FeaturePublish(Feature=WIFEAT00000003,,Absent=0,)
MSI (c) (E8:70) [15:29:07:215]: Executing op: FeaturePublish(Feature=WIFEAT00000002,,Absent=0,)
MSI (c) (E8:70) [15:29:07:215]: Executing op: FeaturePublish(Feature=WIFEAT00000001,,Absent=0,)
MSI (c) (E8:70) [15:29:07:215]: Executing op: ActionStart(Name=PublishProduct,Description=Publishing product information,)
MSI (c) (E8:70) [15:29:07:215]: Executing op: CleanupConfigData()
MSI (c) (E8:70) [15:29:07:215]: Executing op: ProductPublish(PackageKey={3461021C-AFFA-45CA-802C-78D75C41BFEB})
MSI (c) (E8:70) [15:29:07:215]: Machine policy value 'DisableUserInstalls' is 0
MSI (c) (E8:70) [15:29:07:230]: Note: 1: 1402 2: UNKNOWN\Installer\Features\4AF2A95585847E64DB20861CA513FD89 3: 2
MSI (c) (E8:70) [15:29:07:230]: Executing op: UpgradeCodePublish(UpgradeCode={42463807-970B-4257-BC95-5C348D61DF1C})
MSI (c) (E8:70) [15:29:07:230]: Executing op: SourceListPublish(,,DiskPromptTemplate=[1],,NumberOfDisks=1)
MSI (c) (E8:70) [15:29:07:230]: Note: 1: 1402 2: UNKNOWN\Installer\Products\4AF2A95585847E64DB20861CA513FD89\SourceList 3: 2
MSI (c) (E8:70) [15:29:07:230]: Executing op: ProductPublishClient(,,)
MSI (c) (E8:70) [15:29:07:230]: Note: 1: 1402 2: UNKNOWN\Installer\Products\4AF2A95585847E64DB20861CA513FD89 3: 2
MSI (c) (E8:70) [15:29:07:230]: Executing op: End(Checksum=0,ProgressTotalHDWord=0,ProgressTotalLDWord=0)
MSI (c) (E8:70) [15:29:07:230]: Note: 1: 2318 2:
MSI (c) (E8:70) [15:29:07:230]: Post-install cleanup: removing installer file 'C:\windows\Installer\{559A2FA4-4858-46E7-BD02-68C15A31DF98}\ARPPRODUCTICON.exe'
MSI (c) (E8:70) [15:29:07:230]: Post-install cleanup: removing installer folder 'C:\windows\Installer\{559A2FA4-4858-46E7-BD02-68C15A31DF98}\' (if empty)
MSI (c) (E8:70) [15:29:07:246]: DoAdvertiseScript is returning: 0
====END==MSI21b9d.LOG=================
Please try this to get Flash to install with GP: Install Adobe Flash Player 27 using Windows 7 Group Policy (100% Working Method)
