While viewing my project in premiere pro in the preview window, everything appears to be just fine. However, when I export the video it looks terrible and pixelated: I don't even have a word to describe what happens. If I pause the playback marker over the clip it also appears pixelated. The only time it doesn't is when playing back in premiere pro.
I know this isn't the footage I'm using because it has happened with all different types of video formats, frame rates, etc. It must be something with the project settings or something within premiere pro. Please see the screenshots below of what the video looks like vs. what it's supposed to look like. Please advise with how to fix.
And again here:
You have many issues going on there. Source video is 24p (23.976 frames per second) but Sequence is set up as 29.97fps (30p). Then you have interlaced video (lower) enabled. Not good. Change Sequence to 23.976fps and progressive, then also export as 24p. Keep things consistent for best results. You might also set audio to 48k to match source. Everything is wrong 😉
Jeff
Are you exporting your sequence at the same resolution as your source footage?
Also, are you exporting at a high enough bitrate?
Hey Jeff. Thanks for offering to help. I am exporting it as the same. I'm currently exporting at 30 bitrate and I exported it as a raw quicktime movie and it did the same thing. I'm thinking the issue is bigger than bitrate.
Can you post a screen shot of your export settings summary, like this example below:
MtD
You are exporting a square 1080 x 1080 interlaced file, is this your intention?
Interlaced material will not display correctly on computer screens which are progressive.
They will only playback correctly on interlaced devices such as tv sets, but your pixel dimensions are not a standardized format.
Premiere works around this by surpassing a field in the Program Monitor:
MtD
I am trying to export as a square, but it may be in the interlacing vs. progressive settings. How do I switch to exporting in progressive?
In the Exports Settings, set the Field Order to Progressive:
MtD
Changed it to progressive, still nothing. Changed the rendering settings to software only. Still nothing.
Keep in mind, in addition to when exported, it shows the pixelated preview when paused over the images in the program monitor, just not when it's playing.
Do you have Use Previews checked on your export settings?
I do not
Can you try starting a brand new project, import the entire project file that's not working, and see if the issue persists in the program monitor?
It does. My last three projects that I've worked on in premiere have all had this happen. Using different footage and different shoots and everything.
What are the properties of the source footage you are using?
You can click on a source clip in the Project Panel to select it, and once selected, right click (control click) on the selected clip and choose Properties . . .
If you could post a screen shot of the properties, please, like this example:
MtD
I'm not sure what the problem is, Maybe someone else can help you.
Can you post a screen shot of your sequence settings? (Menu Sequence > Sequence Settings)
MtD
I've only had the computer for a couple months, it's a $3,000 computer built specifically for video editing.
Follow Ann Bens advice to check your graphics card driver.
I would also uncheck the Maximum Bit Depth, Maximum Render Quality, and Composite in Linear Color.
MtD
Jeff
Update you graphiccard driver or roll one back.
Two things to try:
I was having the same issue and i switched performance to software encoding and it worked
Hi, the same happened to me, turns out the export video dimensions were different to the original. I had to increase the level and change them
