50% grey
Filter > Artisitic > Sponge
Threshold, or levels or curves (I went with Threashold)
Some Gausian blur to smooth it up a bit, followed by levels, curves or threashold again. I actually gave it a low value Gassian blur after this to give it some antialiasing.
Scale it to suite, which means start with a big canvas if you want to end up with a tighter pattern.
Might be an overlaid reaction diffusion pattern, though reproducing the exact pattern might be a problem.
Google should provide links to tutorials under »photoshop reachtion diffusion«.
Such a Pattern could then be used as a Pattern Layer set to Blend Mode Hard Mix over a monochrome image.
Ohhh, this is fun!
What, is it the 60s again?
Yea, why not.
For white edges you could use an Inner Glow Layer Style.
Couldn't resist making more automated than an action. No error checking, so you have to be careful what you enter.
#target photoshop
var doc = activeDocument
var hipass
var thresh
var gBlur
var gBlur
var num
var dlg = new Window('dialog','Reaction Diffusion');
dlg.alignChildren = ['left','top'];
dlg.hiGp = dlg.add('group');
dlg.hiGp.stxt = dlg.hiGp.add('statictext',undefined,'Hipass Radius');
hipass = dlg.hiGp.add('edittext',undefined,10);
dlg.hiGp.stxt = dlg.hiGp.add('statictext',undefined,'Threshold');
thresh = dlg.hiGp.add('edittext',undefined,128);
dlg.blGp = dlg.add('group');
dlg.blGp.stxt = dlg.blGp.add('statictext',undefined,'Blur Radius');
gBlur = dlg.blGp.add('edittext',undefined,11);
dlg.numGp = dlg.add('group');
dlg.numGp.stxt = dlg.numGp.add('statictext',undefined,'Number of iterations');
num = dlg.numGp.add('edittext',undefined,90);
dlg.btn = dlg.add('button',undefined,'Okay');
dlg.btn.onClick = function(){dlg.close()};
dlg.show();
for(var i=0;i<parseInt(num.text);i++){
reaction ();
var idThrs = charIDToTypeID( "Thrs" );
var desc9 = new ActionDescriptor();
var idLvl = charIDToTypeID( "Lvl " );
desc9.putInteger( idLvl, parseFloat(thresh.text) );
executeAction( idThrs, desc9, DialogModes.ALL );
app.displayDialogs = DialogModes.NO;
function reaction(){
var idHghP = charIDToTypeID( "HghP" );
var desc5 = new ActionDescriptor();
var idRds = charIDToTypeID( "Rds " );
var idPxl = charIDToTypeID( "#Pxl" );
desc5.putUnitDouble( idRds, idPxl, parseFloat(hipass.text ));
executeAction( idHghP, desc5, DialogModes.NO );
executeAction( idThrs, desc9, DialogModes.NO );
var idGsnB = charIDToTypeID( "GsnB" );
var desc13 = new ActionDescriptor();
desc13.putUnitDouble( idRds, idPxl, parseFloat(gBlur.text) );
executeAction( idGsnB, desc13, DialogModes.NO );
50% grey
Thanks guys for all the replies and help
