1 Reply Latest reply on Nov 17, 2008 7:55 AM by matthewmaday
    Uing check boxes
    Almudever
      Hello,
      I am searching information about check boxes for create test quetions. If need to have some examples.
      I would like one page to looking for them.
      Thank's
        • 1. Re: Uing check boxes
          matthewmaday
          I am not sure if you posted the other question as well but the answer is the same.
          -- To detect the state of a check box
          sprite(1).selected -- this will return boolean values (1 selected, 0 not selected)
          I created 3 functions for you which will show you how to work with check boxes.
          on QUESTION_multipleChoice pSelect, pStartSN, pEndSN
          -- this function will only allow the selection of one check box
          -- pSelect [INT] the number of the sprite that was just selected
          -- pStartSN [INT] the number of the first sprite in the range of check boxes
          -- pEndSN [INT] the number of the last sprite in the range of check boxes
          repeat with i = pStartSN to pEndSN
          sprite(i).selected = (i=pSelect)
          end repeat
          end
          on QUESTION_returnSelectedCheckboxes pStartSN, pEndSN
          -- this function will return all of the check boxes that are selected between the defined range
          pList = []
          if sprite(i).selected then append pList, i
          end repeat
          return pList
          end
          on QUESTION_clearSelectionBoxes pStartSN, pEndSN
          -- this function will set all of the check boxes, within a defined range, to not selected
          sprite(i).selected = 0
          end repeat
          end
