I need to mark up screenshots and want to dim everything around the rectangle, putting focus on what's highlighted. Example:
Add a solid fill layer or a normal layer filled with black. Adjust the "Fill" Opacity to your liking. You can then use stroke in the layer's effect panel.
I manage to dim the image and set the stroke options. I click the "OK" button and no rectangle appears? I just see a dimmed image.
You need to make a marquee of the area you want outlined and not dimmed, then fill the layer mask with black in the marquee.
Thanks. It worked!
For anyone wanting to know how to make the layer mask black:How to quickly fill a white layer mask w. black?
For some reason, the edges of the stroke are rounded. How do I make them square?
Do you have the stroke position on the outside?
Figured out the problem. You have to do the marquee tool after choosing/configuring the stroke settings. Thanks!
