Adobe Flash - Error, "Access of Undefined Property"
Sep 25, 2017 Sep 25, 2017
How to fix an undefined property compiler error in Adobe Flash CS6?
2.2K
Also, need to know how to create a Mouse Click Event.
Ex:
Master.addEventListener(MouseEvent.CLICK, fl_MouseClickHandler_131);
function fl_MouseClickHandler_131(event:MouseEvent):void
  fscommand("exec", "Master_Supply_List.app");
Contributor ,
Something that is undefined, does not exist. So your code is trying to access something that doesn't exist. Could you paste the code you're using?
/* Stop at This Frame
The Flash timeline will stop/pause at the frame where you insert this code.
Can also be used to stop/pause the timeline of movieclips.
stop()
/* Mouse Click Event
Clicking on the specified symbol instance executes a function in which you can add your own custom code.
Instructions:
1. Add your custom code on a new line after the line that says "// Start your custom code" below.
The code will execute when the symbol instance is clicked.
MainMenu.addEventListener(MouseEvent.CLICK, fl_MouseClickHandler_100);
function fl_MouseClickHandler_100(event:MouseEvent):void
  gotoAndStop(1);
Instructions:
Song_1.addEventListener(MouseEvent.CLICK, fl_MouseClickHandler_101);
function fl_MouseClickHandler_101(event:MouseEvent):void
  fscommand("exec", "Song_1.app");
Contributor ,
For the error, does it say what line is causing it?
The error is trying to tell you that something in the code can't be found. The problem may not be a property, it may be an object. If you, for instance, put your code in frame 1 of the timeline and some object that is referenced, Song_1, for instance, doesn't appear in frame 1, then the Actionscript can't resolve the object with the code. Another common problem is a simple typo: Song_1 is not the same as song_1, to Actionscript for instance.
