Hi all,
Is there a keyboard shortcut for classic tween? Can't seem to find one anywhere.
Gwyneth
When making a Motion Tween you can right-click on something and it suddenly will be a symbol and will have a span of frames, ready for you to animate. With Classic tweens the steps are different. You Have a layer, then add some frames to the layer. In the last frame you make the layer be a keyframe. You right-click in the frames between the two keyframes, and that's where you set it to be a Classic Tween.
Thanks Colin. So there's no keyboard shortcut for this? I always have to right click?
under insert are the tweens shortcuts:
As kglad showed, the different options have an entry on the Insert menu too, which you could set a custom keystroke to trigger.
