We are having an issue with InDesign crashing at launch, the only way we can open the application is set it to always run as an administrator. Here is the event log error:
Faulting application name: InDesign.exe, version: 12.1.0.56, time stamp: 0x58c988ec
Faulting module name: PMRuntime.dll, version: 5.0.0.191, time stamp: 0x58c9856e
Exception code: 0xc0000005
Fault offset: 0x0000000000007615
Faulting process id: 0xcdf0
Faulting application start time: 0x01d3322f34ab19d4
Faulting application path: C:\Program Files\Adobe\Adobe InDesign CC 2017\InDesign.exe
Faulting module path: C:\Program Files\Adobe\Adobe InDesign CC 2017\PMRuntime.dll
Report Id: 2312a870-577e-4507-9511-abb21fdfb575
Faulting package full name:
Faulting package-relative application ID:
If we open InDesign from the command prompt it works or if you launch it from the troubleshooting wizard it works fine. It just seems to be opening files in windows explorer that causes it to crash. Running it as an administrator if they launch a file from a share InDesign opens but the file itself does not, they have to click file then select open then navigate to the location to open the file.
[Here is the list of all Adobe forums... https://forums.adobe.com/welcome]
[Moved from CS6 and earlier Creative Suites forum to specific Program forum... Mod]
Which version of InDesign and OS?
Have you tried trashing your InDesign preferences?
InDesign version: 12.1.0.56
Windows 10 Version 1607
I have tried trashing InDeisng preferences, holding Shift+Ctrl+Alt but once I launch InDesign again from windows explorer it crashes.
In InDesign Preferences under the GPU Performance Tab try unticking GPU Performance. At least it works for some on a Mac, presumably you have a similar thing on Windows, if so, it's worth a try.
Try restarting InDesign from the Creative Cloud and also try reseting your preferences.
For InDesign
1. Exit the application
2. Press and hold Shift+Ctrl+Alt (Windows) or Shift+Option+Command+Control (macOS)
as you start InDesign. You are prompted to delete the current settings. The new
preferences files are created when you start the application.
Hi melissam,
Hope the issue is solved by steps suggested above, if not, please share some more details like:
Operation System (Exact Version of Windows).
You may Also try to reset preferences manually by following these steps:
Also, check how application works in safe mode( https://support.microsoft.com/en-in/help/12376/windows-10-start-your-pc-in-safe-mode )
or new user account (https://support.microsoft.com/en-in/help/4026923/windows-create-a-local-user-or-administrator-accoun... )
Please update the discussion if the issue is resolved or if you have any further query.
Regards
Srishti
we get the same problem any ideas doesn't even work whilst logged in with a corporate admin account unless you RUN AS ADMIN tick box is ticked on the icon on windows 10, indeisgn 2017, any ideas why you need admin rights, because this program is used my lots of people on our estate,
heres the error in event viewer
Hi trsiskot,
There could be multiple reasons for crash on launch.
Before we proceed to any conclusion I would request you to please share some details like:
Looking forward to your response.
Regards
Srishti
