      • EspaƱol
      • FranƧais
      • PortuguĆŖs
  • ę—„ęœ¬čŖžć‚³ćƒŸćƒ„ćƒ‹ćƒ†ć‚£
  • ķ•œźµ­ ģ»¤ė®¤ė‹ˆķ‹°
Can someone help me with error code:1180&1120
Guest
Sep 26, 2017 Sep 26, 2017
Hi guys, I am new to Flash trying to learn website making by self. below are the error codes I am getting
Scene 1, Layer 'actions', Frame 1, Line 7 1180: Call to a possibly undefined method gotoAndstop.
Scene 1, Layer 'actions', Frame 1, Line 11 1180: Call to a possibly undefined method gotoAndstop.
Scene 1, Layer 'actions', Frame 1, Line 15 1180: Call to a possibly undefined method gotoAndstop.
Scene 1, Layer 'actions', Frame 1, Line 19 1180: Call to a possibly undefined method gotoAndstop.
Scene 1, Layer 'actions', Frame 1, Line 5 1120: Access of undefined property ourservices_button.
Scene 1, Layer 'actions', Frame 1, Line 9 1120: Access of undefined property products_button.
Scene 1, Layer 'actions', Frame 1, Line 13 1120: Access of undefined property aboutus_button.
Scene 1, Layer 'actions', Frame 1, Line 17 1120: Access of undefined property contactus_buttontn.
The script I am using
stop();
ourservices_button.addEventListener(MouseEvent.CLICK,goourservices);
function goourservices(Event:MouseEvent):void{
gotoAndstop(1);
products_button.addEventListener(MouseEvent.CLICK,goproducts);
function goproducts(Event:MouseEvent):void{
gotoAndstop(2);
aboutus_button.addEventListener(MouseEvent.CLICK,goaboutus);
function goaboutus(Event:MouseEvent):void{
gotoAndstop(3);
contactus_buttontn.addEventListener(MouseEvent.CLICK,gocontactus);
function gocontactus(Event:MouseEvent):void{
gotoAndstop(4);
Can someone help me with it, please? Thanks in Anticipation.
676
Community Expert , Sep 27, 2017 Sep 27, 2017
Here we go! I fixed it for you. https://goo.gl/KiCXkN
Please notice that I reorganized your layers and objects so it's cleaner and more effective now.
Elements that appear on more than one frame should be kept in only one keyframe and/or layer.
Also notice that if you don't want some states inside of a Button component, it's better to select them and make them invisible on the Properties panel (the visible property not the alpha).
I hope it helps.
Contributor ,
Are you using HTML5 Canvas? in that case you need to add "this." before each button.
For example: "this.ourservices_button".
Same with the gotoAndStop lines,  though that doesn't work as they're inside functions. So you would need some variable to store this in.
For example: "var main = this;"
Then you can replace this with main.
Edit:
It should be gotoAndStop instead of gotoAndstop.
He's not. MouseEvent.CLICK, Event:MouseEvent, and :void are all AS3 code.
gotoAndstop is missing a capital S. Should be gotoAndStop.
And make sure your buttons are named correctly.
Guest
Thank you for your help JoaoCesar,  but now I am getting an error for undefined property and I named all of them, don't know why it's not working, can you please help me with it? Thank you.
Scene 1, Layer 'actions', Frame 1, Line 6 1120: Access of undefined property ourservices_button.
Scene 1, Layer 'actions', Frame 1, Line 10 1120: Access of undefined property products_button.
Scene 1, Layer 'actions', Frame 1, Line 14 1120: Access of undefined property aboutus_button.
Scene 1, Layer 'actions', Frame 1, Line 18 1120: Access of undefined property contactus_buttontn.
Just make sure you are using instance names not the library names. To change a instance name, selece a button on the stage, press Ctrl + F3 (Cmd + F3) and change the first field on the Properties panel.
Anyway, here is a FLA with your example working: https://goo.gl/uB3TBV .
I hope it helps.
Please don't hesitate to ask if you have any further questions.
Guest
I tried Ctrl+F3, I think it's a wrong command for Flash Pro CS6 anyways this is the file I am working on buttons.fla - Google Drive can you please look at it and address the issues, Thank you.
Guest
oops! my bad that's not the right link sorry, this is the one myweb.fla - Google Drive
I hope it helps.
Guest
Thanks a lot
You can also call the Properties panel going to Window > Properties.
Isn't the example I uploaded to Google Drive working?
