I've created a document with multiple tables and when I use the data merge, page 1 is perfect. All of the additional pages remove the header rows. The header rows are static text that is not field elements. I've never run across this before and would appreciate any help.
PAGE 1
PAGE 2
I figured out a work around, which is remove the Header Rows and just put in static text. I would still like to know why this is happening.
This worked for me.
I see that there were tables that were being used. Have you tried installing the patch that fixes some minor issues in InDesign?
The patch and explanation can be found here: Troubleshoot issues after updating to InDesign CC 2017.1
I get an error applying that patch (Windows 10 64), but his fix does work.
