What do I add to the following expression in order to make the source text count up in decimals, as follows.... 0.0, 0.5, 1.0, 1.5, 2.0 etc. etc.
effect("Slider Control")("Slider")
Here you go, courtesy of Colin Bailley;
Tutorial -- Overcoming limitations of the Numbers effect in After effects
Of course, if the Numbers effect does it for you then it may be enough?
Have you tried: parseFloat(thisComp.layer("your layer name").effect("Slider Control")).toFixed(1)
Thanks angie, but that's not working for me
OK, leave it with me
I followed that to the letter but I'm getting the error 'Couldn't find the layer name Controls. Expression disabled'
It's ok I have it sorted now, thanks!
If you change the Layer name it should work 🙂
