Sometiems I need to massively shake up gradient fiils — make angles rounded and position stops at multiples of, for example, five.
I'm trying to conjure up a script for this, and immidiately stopped at this part:
var NewFill = Math.round(OldFill.rotate / 5) * 5;
OldFill.rotate(NewFill, 0, 0, 1, 0);
What is wrong with it?
Figured that out. RTFM.
...thisDocument = app.activeDocument;
docSelection = thisDocument.selection;
selectionLen = docSelection.length;
for (i = 0; i < selectionLen; i++) {
oldFill = docSelection;
if (oldFill.typename == "PathItem" || oldFill.typename == "CompoundPathItem") {
checkPath = oldFill;
if (oldFill.typename == "CompoundPathItem") {
checkPath = oldFill.pathItems[0];
if (checkPath.filled == true && checkPath.fillColor.typename == "GradientColor")
I'm a dumbass, I'm trying to divide a function.
Well, then, how to READ current angle of gradient fill with JS? I know well how to set it, but I need to know it first to change it.
if (checkPath.filled == true && checkPath.fillColor.typename == "GradientColor") {
if (checkPath.fillColor.gradient.type == GradientType.LINEAR) {
//make rotation multiple of 5
var angleVal = prompt("Make angle of gradients to be multiple of:","5","Gradient Angle")
var oldAngle = checkPath.fillColor.angle;
var newAngle = (Math.round(oldAngle / angleVal)) * angleVal;
var angleDiff = newAngle - oldAngle;
oldFill.rotate(angleDiff, 0, 0, 1, 0);
//make stops position at multiple of 5
var stopVal = prompt("Make gradient stops position at multiple of:","5","Gradient Stops")
var numOfStops = checkPath.fillColor.gradient.gradientStops.length;
for (k = 0; k < numOfStops; k++) {
var oldRamp = checkPath.fillColor.gradient.gradientStops
.rampPoint; var newRamp = (Math.round(oldRamp / stopVal)) * stopVal;
.rampPoint = newRamp; }
Glad we were able to help.
You know how this works sometimes
I certainly do. many times trying to explain an issue to someone who's never seen the project is enough to pull yourself out of whatever funk you're in and allow you to see a new perspective.
