Mercury Playback is greyed out.
My rig is z840 2x Xeon
7 x nvidia gtx 1080
Latest Nvidia Drivers (381.65)
I can't understand why Premiere does not see it / use it.
You have 7 videocards?
Moved to Hardware forum for expert advice.
Yes, I use GPU's for rendering (Octane).
1 1080 is in PCIe in motherboard, and the other 6 are in Cubix Xpanders.
However the fact that Mercury is not using even one of them is a bitter surprise.
Thanks for moving it to the correct forum.
Cheers
Run Adobe's GPUSniffer.exe in a CMD window and show us the results
As friend adviced me I got older Nvidia driver: 378.78
and now it's all working fine!
Crazy that newer drivers are not working well!
C
Hey guys, the problem is back... I don't know how or why but it's just greyed out again.
This is the gpusniffer info, please help:
Vendor: NVIDIA Corporation
Renderer: GeForce GTX 1080/PCIe/SSE2
OpenGL Version: 2.1.2 NVIDIA 378.78 21.21.13.7878
GLSL Version: 1.20 NVIDIA via Cg compiler
Monitors: 2
Monitor 0 properties -
Size: (0, 0, 2560, 1600)
Max texture size: 32768
Supports non-power of two: 1
Shaders 444: 1
Shaders 422: 1
Shaders 420: 1
Monitor 1 properties -
Size: (-2560, 274, 2560, 1080)
Shaders 444: 1
Shaders 422: 1
Shaders 420: 1
--- GPU Computation Info ---
Found 7 devices supporting GPU computation.
CUDA Device 0 -
Name: GeForce GTX 1080
Vendor: NVIDIA
Capability: 6.1
Driver: 8
Total Video Memory: 8192MB
CUDA Device 1 -
Vendor: NVIDIA
Capability: 6.1
Driver: 8
CUDA Device 2 -
Vendor: NVIDIA
Capability: 6.1
Driver: 8
CUDA Device 3 -
Vendor: NVIDIA
Capability: 6.1
Driver: 8
CUDA Device 4 -
Vendor: NVIDIA
Capability: 6.1
Driver: 8
* Not chosen because it exceeds the maximum device count.
CUDA Device 5 -
Vendor: NVIDIA
Capability: 6.1
Driver: 8
CUDA Device 6 -
Vendor: NVIDIA
Capability: 6.1
Driver: 8
I would just temporarily disconnect your second monitor and see if that might be your problem, it has occured with s few setups.
Thanks Bill,
What I did now is to switch off one monitor and detach one Cubix so I have 5 x1080 working. It has solved the problem, I can use the GPU's in Premiere and the playback of 4k material is very smooth.
However this is a problem since I use this workstation for GPU rendering as well and needles to say every additional render node saves precious time.
I can see that GPU sniffer says that only 4 GPUs can be supported by premiere, but this is still 5 GPUs.
I tried earlier to install the latest NVIDIA drivers and that just caused my entire system to crash, and I had to restore Windows.
I know it's not a common setup, but it would be helpful to have someone from official Adobe support to intervene on this. I'm sure I'm not the only one with multi-gpu rig.
Ced
have you tried setting nvidia control panel premiere.exe as primary gfx app for just 4 cards?
Hey guys,
Just to let you know that Mercury works in CC Premiere 2018. It is flying with different layers of 4k and lumetri. Finally...
Ced
