Whenever i start up after effects a tab pops up and says after effects is not working and that windows is checking for the problem, then another tab pop up and says a problem caused the program to stop working correctly. Windows will close the program and notify you if a solution is available. I have restarted my computer, uninstalled and reinstalled after effects but it still does not work. This is all on windows 10, I think its a problem with windows thinking it is a virus but if it is i don't know how to fix it. If anyone knows the problems please help!
You have not provided any useful information. Your post is generic and vague when exact system information adn possibly crash logs are required.
Mylenium
I fixed it, thank you
Hi equity123,
How did you fix it?
Cheers,
Kevin
I deleted every file relating to ae and then uninstalled it and reinstalled it, including my plugins which in hindsight were probably the problem
Hi equity123,
Sorry for this issue. Did you ever find a solution? Please let us know if you have or if you still need help.
Kevin
I have fixed the problem
