When I try Select and Mask I get a blank image in the Select and Mask screen. If I first Select the whole image, and then try Select and Mask, I then see the image in the Select and Mask screen (I have to use this same method with the Liquify tool), One I have the image viewable in the Select and Mask screen, when I try the Quick Select brush, the brush disappears while I'm pressing the mouse button to select areas. This make it almost impossible to use. When I release the mouse button I can see my brush and change the size.
Forst, why are you selecting the entire image. It's a lot easier to select the item then go into select and mask to refine it
Cyberwasp is right bro !
I was looking at the tutorial at the link below, and it didn't look like it was necessary to make a selection before using Select and Mask.
It is not necessary to make a selection first - although you do have more options outside to start off (channel selections etc)
Dave
Hi
The blank screen on opening could be caused by the transparency slider being set to 100% , however the issue with the brush is not normal. So try this:
In Select and Mask, go to the right of the options bar - click the down arrow then click on Reset Select and Mask
Dave
Thank you. I tried it and I could see my brush on the first selection, but the brush was not visible after the first use. Only my mouse arrow is visible.
Not sure if this is the problem I'm guessing..........Just try this: uncheck SHOW EDGE, uncheck SHOW ORIGINAL.
