I'm new to Photoshop CC and i'm trying to replicate this:
but i can't figure out how to make the inverse text color effect. I'm sure the post has said to use the Exclusion blend mode, but it's grayed out and i have no idea what to do. Any help? !
You were correct about exclusion
Type in white and set the text layer to exclusion blend mode. Put the text and paint layers into a group and set the group blending mode to normal rather than pass through so that the text does not use the exclusion blend mode with the background
Dave
Dave
Dave, i tried this and i still couldn't select exclusion. Do you think there's something wrong with my settings?
What Image mode are you using ?
Exclusion does not work with 32 bits / channel - only 16 and 8
Dave
Is there a way to keep layers separate when changing to 16-bit?
Never mind, i didn't see the "Don't Merge" button.
Thanks, it works now.
You're welcome
Dave
