Multifield dialog-
<?xml version="1.0" encoding="UTF-8"?>
<jcr:root xmlns:sling="http://sling.apache.org/jcr/sling/1.0" xmlns:cq="http://www.day.com/jcr/cq/1.0" xmlns:jcr="http://www.jcp.org/jcr/1.0" xmlns:nt="http://www.jcp.org/jcr/nt/1.0"
jcr:primaryType="nt:unstructured"
jcr:title="List Collection"
sling:resourceType="cq/gui/components/authoring/dialog">
<content
sling:resourceType="granite/ui/components/coral/foundation/container">
<items jcr:primaryType="nt:unstructured">
<tabs
sling:resourceType="granite/ui/components/coral/foundation/tabs"
maximized="{Boolean}true">
<Basic
jcr:title="Basic"
sling:resourceType="granite/ui/components/coral/foundation/fixedcolumns"
margin="{Boolean}false">
<column
<enterheadline
sling:resourceType="granite/ui/components/coral/foundation/form/textfield"
fieldDescription="Please enter headline"
fieldLabel="Enter Headline"
name="./headlineText"/>
<headingurl
sling:resourceType="granite/ui/components/coral/foundation/form/pathfield"
fieldDescription="Select Link Path"
fieldLabel="Link Url"
name="./headingUrl"/>
<menu
sling:resourceType="granite/ui/components/foundation/form/multifield"
composite="{Boolean}true"
fieldDescription="Click + to add a new page"
fieldLabel="Multifield collection"
name="./menu">
<field
sling:resourceType="granite/ui/components/foundation/form/fieldset"
multifield-nested=""
name="./items">
<layout
sling:resourceType="granite/ui/components/foundation/layouts/fixedcolumns"
method="absolute"/>
<column
sling:resourceType="granite/ui/components/foundation/container">
<linkurl
name="./linkUrl"/>
<enterlinktext
fieldDescription="Enter Link Text"
fieldLabel="Enter link text"
name="./linkText"/>
<submenu
fieldDescription="Add upto 14 links"
fieldLabel="Submenus"
name="./submenussss">
<field
name="./submenu">
<layout
method="absolute"/>
<column
<url
sling:resourceType="granite/ui/components/foundation/form/pathbrowser"
allowBlank="false"
fieldLabel="Provide navigation link for text"
key="url"
name="./subUrl"/>
<title
sling:resourceType="granite/ui/components/foundation/form/textfield"
allowBlank="false"
fieldLabel="Provide navigation text"
key="title"
maxLength="16"
maxLengthText="A maximum of 16 characters is allowed for navigation text"
name="./subTitle"/>
</items>
</column>
</items>
</field>
</submenu>
</items>
</column>
</items>
</field>
</menu>
</items>
</column>
</items>
</Basic>
</items>
</tabs>
</items>
</content>
</jcr:root>
navigation.js
"use strict";
use(function () {
var readJson = null;
var listArr = [];
if (this.fieldValue != '') {
readJson = this.fieldValue;
var count = 0;
if (readJson != null && readJson != "") {
readJson.forEach(function (entry) {
var itemJson = entry;
listArr[count++] = itemJson;
} else if (this.fieldName != '') {
readJson = granite.resource.properties[this.fieldName];
if (typeof readJson != "undefined" && readJson != null && readJson != "") {
if (readJson.length > 0) {
var count = 0;
var itemJson = JSON.parse(entry);
} else {
listArr[0] = JSON.parse(readJson);
return {
listJson: listArr
Sightly: somecomponent.html
<sly data-sly-use.menuInfo="${'navigation.js' @ fieldName = 'items',fieldValue = ''}">
<sly data-sly-list.menuDetails="${menuInfo.listJson}">
<li><a href="${menuDetails.linkUrl}">${menuDetails.linkText}</a>
<ul>
<sly data-sly-use.submenuInfo="${'navigation.js' @ fieldName = '',fieldValue = menuDetails.submenu}">
<sly data-sly-list.innerlistJson="${submenuInfo.listJson}">
${innerlistJson.subTitle}</span></a></li>
</sly>
</sly>
</ul>
</li>
</sly>
</sly>
I have created this without using ACS-common package. hope it will helpful for the community
Thanks for posting this.
Total Likes
thank you for this!! <3
Total Likes
the add button for multifield node which is menu
slingResourceType: granite/ui/components/foundation/form/multifield - add button not working
sling:resourceType="granite/ui/components/coral/foundation/form/multifield" - add button working but the Ok/Submit button not working
Total Likes
Are you using ACS common.?
Total Likes
(function () {
var DATA_NESTED = "data-multifield-nested";
var CFFW = ".coral-Form-fieldwrapper";
//reads multifield data from server, creates the nested composite multifields and fills them
function addDataInFields() {
$(document).on("dialog-ready", function () {
var $fieldSets = $("[" + DATA_NESTED + "][class='coral-Form-fieldset']");
if (_.isEmpty($fieldSets)) {
return;
var mNames = [];
$fieldSets.each(function (i, fieldSet) {
mNames.push($(fieldSet).data("name"));
mNames = _.uniq(mNames);
var actionUrl = $fieldSets.closest("form.foundation-form").attr("action") + ".json";
$.ajax(actionUrl).done(postProcess);
function postProcess(data) {
_.each(mNames, function (mName) {
buildMultiField(data, mName);
//creates & fills the nested multifield with data
function fillNestedFields($multifield, valueArr) {
_.each(valueArr, function (record, index) {
$multifield.find(".js-coral-Multifield-add").click();
//a setTimeout may be needed
_.each(record, function (value, key) {
var $field = $($multifield.find("[name='./" + key + "']")[index]);
$field.val(value);
function buildMultiField(data, mName) {
if (_.isEmpty(mName)) {
return;
$fieldSets = $("[data-name='" + mName + "']");
mName = mName.substring(2);
var mValues = data[mName], $field, name;
if (_.isString(mValues)) {
mValues = [JSON.parse(mValues)];
_.each(mValues, function (record, i) {
if (!record) {
return;
if (_.isString(record)) {
record = JSON.parse(record);
_.each(record, function (rValue, rKey) {
$field = $($fieldSets[i]).find("[name='./" + rKey + "']");
if (_.isArray(rValue) && !_.isEmpty(rValue)) {
fillNestedFields($($fieldSets[i]).find("[data-init='multifield']"), rValue);
} else {
$field.val(rValue);
function fillValue($field, record) {
var name = $field.attr("name");
if (!name) {
return;
//strip ./
if (name.indexOf("./") === 0) {
name = name.substring(2);
record[name] = $field.val();
//remove the field, so that individual values are not POSTed
//$field.remove();
//for getting the nested multifield data as js objects
function getRecordFromMultiField($multifield) {
var $fieldSets = $multifield.find("[class='coral-Form-fieldset']");
var records = [], record, $fields, name;
$fields = $(fieldSet).find("[name]");
record = {};
$fields.each(function (j, field) {
fillValue($(field), record);
if (!$.isEmptyObject(record)) {
records.push(record);
return records;
//collect data from widgets in multifield and POST them to CRX as JSON
function collectDataFromFields() {
$(document).on("click", ".cq-dialog-submit", function () {
var fieldd = $(".coral-Multifield");
var sizee = fieldd.attr("data-minlinksallowed");
if (sizee) {
var uii = $(window).adaptTo("foundation-ui");
var totalLinkCount = $(".coral-Multifield-list li").length;
if (totalLinkCount < sizee) {
uii.alert("Minimum " + sizee + " fields are required");
return false;
var $form = $(this).closest("form.foundation-form");
$form.find('input.input-mf-data').each(function(){
$(this).remove();
var record, $fields, $field, name, $nestedMultiField;
$fields = $(fieldSet).children().children(CFFW);
record = {};
$field = $(field);
//may be a nested multifield
$nestedMultiField = $field.find("[data-init='multifield']");
if ($nestedMultiField.length === 0) {
fillValue($field.find("[name]"), record);
} else {
name = $nestedMultiField.find("[class='coral-Form-fieldset']").data("name");
if (!name) {
return;
//strip ./
record[name] = getRecordFromMultiField($nestedMultiField);
if ($.isEmptyObject(record)) {
return;
//add the record JSON in a hidden field as string
$('<input />').attr('type', 'hidden')
.attr('class', 'input-mf-data')
.attr('name', $(fieldSet).data("name"))
.attr('value', JSON.stringify(record))
.appendTo($form);
return true;
$(document).ready(function () {
addDataInFields();
collectDataFromFields();
$(".js-coral-Multifield-add").click(function () {
var field = $(this).parent();
var size = field.attr("data-limit");
if (size) {
var ui = $(window).adaptTo("foundation-ui");
var totalLinkCount = $(this).prev('ol').children('li').length;
if (totalLinkCount >= size) {
ui.alert("Warning", "Only " + totalLinkCount + " fields are allowed!", "notice");
return false;
//extend otb multifield for adjusting event propagation when there are nested multifields
//for working around the nested multifield add and reorder
CUI.MultifieldProject = new Class({
toString: "Multifield",
extend: CUI.Multifield,
construct: function (options) {
this.script = this.$element.find(".js-coral-Multifield-input-template:last");
_addListeners: function () {
this.superClass._addListeners.call(this);
//otb coral event handler is added on selector .js-coral-Multifield-add
//any nested multifield add click events are propagated to the parent multifield
//to prevent adding a new composite field in both nested multifield and parent multifield
//when user clicks on add of nested multifield, stop the event propagation to parent multifield
this.$element.on("click", ".js-coral-Multifield-add", function (e) {
e.stopPropagation();
this.$element.on("drop", function (e) {
CUI.Widget.registry.register("multifield", CUI.MultifieldProject);
(function () {
return;
var mNames = [];
$field.val(value);
return;
if (!record) {
return;
} else {
$field.val(rValue);
if (!name) {
return;
//strip ./
//$field.remove();
record = {};
return records;
if (sizee) {
return false;
$(this).remove();
record = {};
$field = $(field);
} else {
if (!name) {
return;
//strip ./
return;
.appendTo($form);
return true;
addDataInFields();
if (size) {
return false;
Total Likes
This solution is not working in coral3 for aem6.3 migration. In coral 3 multifield tenplate is different so this js doesnt work.
Total Likes
In Coral3, multifields items are store as a node not as JSON, To make it work this with Js or Java, you can iterate through nodes and return as JSON array or java Arraylist.
Total Likes
Using aem 6.3 service pack and cummulative fix pack, multiield of 'n' number of levels can be added in AEM 6.3.
Total Likes
