I can import Robot.psd into AE with layers.
When I import VSdark....psd I don't get the layers. How come the format are slightly different...CMYK vs. RGB?
thanks
Have you converted a copy of the CMYK file to the appropriate RGB space and tried that yet? (Image > Mode > … or better Edit > Convert to Profile)
C.p, thanks for your reply. If I convert to RGB I LOOSE all my layers...I don't want to loose them.
That would seem to be true only if all your Layers are Adjustment Layers.
Edit: Or if you flattened on conversion, see the following post.
Please post a screenshot with the Layers Panel visible of before and after conversion.
How exactly do you convert to RGB?
Have you unchecked »Flatten Image to Preserve Appearance« in the conversion-dialog?
where are thee selections?
Once again:
that worked...thanks
