Applications for the 2024 Adobe Target Community Mentorship Program are open! Click to the right to learn more about participating as either an Aspirant, to professionally level up with a new Certification, or as a Mentor, to share your Adobe Target expertise and inspire through your leadership! Submit your application today.
SOLVED
How to target on browser Language using Expression Targets?
Avatar
Level 1
Hi there
I want to target base on browser language (ex. German) but are not sure how to create a correct Expression-Target for this?
Not sure if user.header or user.browser should be used and how the correct syntax should look like? Then there is also user.header('accept-language') and user.header('accept') which both seem to fit somehow?
I created these 3 Expression Targets but am not sure about which one is correct?
1.return user.header('accept-language')=="de";
2.return (user.header.indexOf('de') != -1);
3. return (user.browser.indexOf('de') != -1);
thanks for your help.
Nicolas
1 Accepted Solution
Avatar
Correct answer by
Level 10
Hi Nicolas,
Thank you for reaching out to Adobe Community.
I would request you to kindly try and use the below code and see if it helps:
return user.header('accept-language').indexOf('de') > -1
Avatar
Correct answer by
Level 10
Hi Nicolas,
Avatar
Level 1
Do you know when this list of languages will be increased as it is incredibly restricted.
Avatar
Level 10
Hi Mike,
Thanks for reaching out to Adobe Target community .
Can you please let us know the browser language on which you want to base your targeting activity?
Regards
Parit
Avatar
Level 2
Hello,
I am trying to do something similar, but with language and locale.
What exactly does the user.header('accept-language') get?  usually the accept language has locale and factor weighting included.  Accept-Language - HTTP | MDN
for example if i wanted to create a profile script differentiating england from united states for english, i would need to parse the language and locale.   would the user.header("accept-language") give me "en-gb" or "en-us"?
Does using console.log work for debugging these scripts?  It is difficult to use the built in target parameters without know exactly what it provides.
any help would be much appreciated!
Gyles Fohl
