Hi all,
I'm working on shortcut in ACTIONS --- a general way, instead of in a specific case, of making stamp layer.
The thing is, if there's only one layer "background", ctrl_shift_alt_E won't work, if the current layer is a adjusting layer, ctrl_J won't work.
So, is there any way to solve/consider the above two situcations at the same time?
What are you expecting on the new layer? Blank, a copy of the image, a composite of all layers, etc.
Thanks for the tip. I know now: new layer, then Apply Image.
I always record it this Alt+Ctrl+Shift+N+E that is actually two shortcuts combined together
Alt+Ctrl+Shift+N Add new layer without Prompt
Alt+Ctrl+Shift+E Stamp Visible layers
The layer may not get added to the top of the stack when the action is played. It depends on the document stack target. So I through in an insert menu Item Layer>Arrange>Bring to front.
If recording the action the stamp visible layer is not on top without stopping and inserting the menu item you can record its shortcut
Shift+Ctrl+]
