Hello all,
A couple of months ago, I began experiencing a Photoshop bug that continues to drive me crazy. I participated in an earlier discussion that another user created to try and find a solution (Inverting a selection causes Photoshop to instantly crash & close, what could be causing this?, but in the hopes that a power user or someone from Adobe can weigh in, I wanted to start a new discussion.
Some specifics:
Photoshop crashes (not every time, but the majority of the time, usually after working for about 5 minutes) when I select a path and invert it. The program crashes just after I hit CMD+SHIFT+I (also while using the menu button) -- but *only* when my file is "rotated" using the "Rotate View Tool".
If I've reset the view so the file is not view rotated, the program does not crash when inverting the selection.
This occurs quite often, and I'd love to find a solution. I've already reset my Photoshop preferences and tried the usual troubleshooting, but it keeps happening.
Photoshop version: Photoshop CC 2017.0.1 (20161130.r.29. x64)
Computer: Mac Pro (Mid 2010), 2x2.66 Ghz 6-Core Intel Xeon, 64 GB 1333 MHz DDR3 ECC, NVIDIA GeForce GTX 980 TI 6144MB
Operating System: OS X El Capitan v10.11.6
Happy to answer all questions in the hopes that I can fix this -- thanks so much!
If you are having problem with Photoshop Crashing on your Mac. You should try posting your Mac crash report here. Some Mac user here may be able too see what your problem is and tell you what you need to do to correct the problem.
Thanks for the suggestion. Here is the crash report that is generated when I try to invert a selection while the file is "rotated" using the "Rotate View Tool":
Process: Adobe Photoshop CC 2017 [734]
Path: /Applications/Adobe Photoshop CC 2017/Adobe Photoshop CC 2017.app/Contents/MacOS/Adobe Photoshop CC 2017
Identifier: com.adobe.Photoshop
Version: 18.0.1 (18.0.1.29)
Code Type: X86-64 (Native)
Parent Process: ??? [1]
Responsible: Adobe Photoshop CC 2017 [734]
User ID: 501
Date/Time: 2017-09-29 14:15:09.011 -0700
OS Version: Mac OS X 10.11.6 (15G1611)
Report Version: 11
Anonymous UUID: 056FB863-13B4-6410-D572-383FF35796D5
Time Awake Since Boot: 230000 seconds
System Integrity Protection: enabled
Crashed Thread: 0 Dispatch queue: com.apple.main-thread
Exception Type: EXC_BAD_ACCESS (SIGBUS)
Exception Codes: KERN_PROTECTION_FAILURE at 0x00000001230a1100
Exception Note: EXC_CORPSE_NOTIFY
VM Regions Near 0x1230a1100:
__DATA 0000000123093000-0000000123095000 [ 8K] rw-/rwx SM=PRV /Applications/Adobe Photoshop CC 2017/Adobe Photoshop CC 2017.app/Contents/Frameworks/IMSLib.dylib
--> __LINKEDIT 0000000123095000-00000001230a4000 [ 60K] r--/rwx SM=COW /Applications/Adobe Photoshop CC 2017/Adobe Photoshop CC 2017.app/Contents/Frameworks/IMSLib.dylib
MALLOC_LARGE 00000001230a4000-00000001240a4000 [ 16.0M] rw-/rwx SM=PRV
Thread 0 Crashed:: Dispatch queue: com.apple.main-thread
0 MMXCore 0x00000001209fc506 0x1209df000 + 120070
1 com.adobe.Photoshop 0x000000010bfd3671 0x10b6a1000 + 9643633
2 com.adobe.Photoshop 0x000000010bfe66bf 0x10b6a1000 + 9721535
3 com.adobe.Photoshop 0x000000010be6e184 0x10b6a1000 + 8180100
4 com.adobe.Photoshop 0x000000010c30b0fa 0x10b6a1000 + 13017338
5 com.adobe.Photoshop 0x000000010b761c79 0x10b6a1000 + 789625
6 com.adobe.Photoshop 0x000000010b7406b0 0x10b6a1000 + 652976
7 com.adobe.Photoshop 0x000000010b740779 0x10b6a1000 + 653177
8 com.adobe.Photoshop 0x000000010d51d19d 0x10b6a1000 + 31965597
9 com.apple.Foundation 0x00007fff93a94e2c __NSFireTimer + 95
10 com.apple.CoreFoundation 0x00007fff97f46ae4 __CFRUNLOOP_IS_CALLING_OUT_TO_A_TIMER_CALLBACK_FUNCTION__ + 20
11 com.apple.CoreFoundation 0x00007fff97f46773 __CFRunLoopDoTimer + 1075
12 com.apple.CoreFoundation 0x00007fff97f462ca __CFRunLoopDoTimers + 298
13 com.apple.CoreFoundation 0x00007fff97f3d7c1 __CFRunLoopRun + 1841
14 com.apple.CoreFoundation 0x00007fff97f3ce28 CFRunLoopRunSpecific + 296
15 com.apple.HIToolbox 0x00007fff983a2935 RunCurrentEventLoopInMode + 235
16 com.apple.HIToolbox 0x00007fff983a276f ReceiveNextEventCommon + 432
17 com.apple.HIToolbox 0x00007fff983a25af _BlockUntilNextEventMatchingListInModeWithFilter + 71
18 com.apple.AppKit 0x00007fff8de42df6 _DPSNextEvent + 1067
19 com.apple.AppKit 0x00007fff8de42226 -[NSApplication _nextEventMatchingEventMask:untilDate:inMode:dequeue:] + 454
20 com.adobe.Photoshop 0x000000010d51be81 0x10b6a1000 + 31960705
21 com.apple.AppKit 0x00007fff8de36d80 -[NSApplication run] + 682
22 com.adobe.Photoshop 0x000000010d51cfb2 0x10b6a1000 + 31965106
23 com.adobe.Photoshop 0x000000010d51e3b3 0x10b6a1000 + 31970227
24 com.adobe.Photoshop 0x000000010b7421fd 0x10b6a1000 + 659965
25 com.adobe.Photoshop 0x000000010babc1db 0x10b6a1000 + 4305371
26 com.adobe.Photoshop 0x000000010babc529 0x10b6a1000 + 4306217
27 libdyld.dylib 0x00007fff93e2e5ad start + 1
Thread 1:: Dispatch queue: com.apple.libdispatch-manager
0 libsystem_kernel.dylib 0x00007fff91701efa kevent_qos + 10
1 libdispatch.dylib 0x00007fff8c57d165 _dispatch_mgr_invoke + 216
2 libdispatch.dylib 0x00007fff8c57cdcd _dispatch_mgr_thread + 52
Thread 2:: MPSupport Worker
0 libsystem_kernel.dylib 0x00007fff91700db6 __psynch_cvwait + 10
1 libsystem_pthread.dylib 0x00007fff93742728 _pthread_cond_wait + 767
2 MultiProcessor Support 0x0000000120b266db 0x120adf000 + 292571
3 MultiProcessor Support 0x0000000120b265fb 0x120adf000 + 292347
4 MultiProcessor Support 0x0000000120b48bcd 0x120adf000 + 433101
5 libsystem_pthread.dylib 0x00007fff9374199d _pthread_body + 131
6 libsystem_pthread.dylib 0x00007fff9374191a _pthread_start + 168
7 libsystem_pthread.dylib 0x00007fff9373f351 thread_start + 13
Thread 3:: MPSupport Worker
Thread 4:: MPSupport Worker
Thread 5:: MPSupport Worker
Thread 6:: MPSupport Worker
Thread 7:: MPSupport Worker
Thread 8:: MPSupport Worker
Thread 9:: MPSupport Worker
Thread 10:: MPSupport Worker
Thread 11:: MPSupport Worker
Thread 12:: MPSupport Worker
Thread 13:: MPSupport Worker
Thread 14:: MPSupport Worker
Thread 15:: MPSupport Worker
Thread 16:: MPSupport Worker
Thread 17:: MPSupport Worker
Thread 18:: MPSupport Worker
Thread 19:: MPSupport Worker
Thread 20:: MPSupport Worker
Thread 21:: MPSupport Worker
Thread 22:: MPSupport Worker
Thread 23:: MPSupport Worker
Thread 24:: MPSupport Worker
Thread 25:: VulcanMsgRecv
0 libsystem_kernel.dylib 0x00007fff91700fba __recvfrom + 10
1 VulcanMessage5.dylib 0x000000011712b308 vcfoundation::net::Bsd::Recv(int, void*, int, int) + 16
2 VulcanMessage5.dylib 0x000000011712a6cc vcfoundation::io::BSDNamedPipe::Read(void*, unsigned long) + 20
3 VulcanMessage5.dylib 0x00000001171299c4 vcfoundation::io::BufferedReader::InternalRead(char*, long) + 100
4 VulcanMessage5.dylib 0x0000000117129888 vcfoundation::io::BufferedReader::Read(void*, unsigned long) + 50
5 VulcanMessage5.dylib 0x00000001171244c7 vcfoundation::io::IVCChannel::ReadFully(void*, unsigned long) + 57
6 VulcanMessage5.dylib 0x0000000117124f56 vcfoundation::io::Serializer::InternalDeserialize() + 30
7 VulcanMessage5.dylib 0x00000001171248ef vcfoundation::io::Serializer::Deserialize() + 9
8 VulcanMessage5.dylib 0x0000000117128974 vcfoundation::ncomm::Connection::ReadIn() + 22
9 VulcanMessage5.dylib 0x00000001171283cd vcfoundation::ncomm::NCService::ReadResponse(vcfoundation::ncomm::INCRequest*, vcfoundation::ncomm::INCListener&, vcfoundation::ncomm::NCService::ConRef&) + 41
10 VulcanMessage5.dylib 0x00000001171280ba vcfoundation::ncomm::NCService::Execute(vcfoundation::ncomm::INCRequest*, vcfoundation::ncomm::INCListener&) + 166
11 VulcanMessage5.dylib 0x000000011712800d vcfoundation::ncomm::NCService::Execute(vcfoundation::ncomm::INCRequest*) + 29
12 VulcanMessage5.dylib 0x000000011711b848 adobe::vulcan::servicemgr::CSIRequest::Execute() + 50
13 VulcanMessage5.dylib 0x000000011711aa86 adobe::vulcan::servicemgr::RegisterForEventsRequest::Run() + 622
14 VulcanMessage5.dylib 0x000000011712920c vcfoundation::thread::AbstractThread::Run() + 72
15 VulcanMessage5.dylib 0x000000011712b109 vcfoundation::thread::Thread::ThreadProc(void*) + 9
16 libsystem_pthread.dylib 0x00007fff9374199d _pthread_body + 131
17 libsystem_pthread.dylib 0x00007fff9374191a _pthread_start + 168
18 libsystem_pthread.dylib 0x00007fff9373f351 thread_start + 13
Thread 26:
0 libsystem_kernel.dylib 0x00007fff916fafae semaphore_wait_trap + 10
1 libtbb.dylib 0x000000011307e100 tbb::internal::rml::private_worker::thread_routine(void*) + 448
2 libsystem_pthread.dylib 0x00007fff9374199d _pthread_body + 131
3 libsystem_pthread.dylib 0x00007fff9374191a _pthread_start + 168
4 libsystem_pthread.dylib 0x00007fff9373f351 thread_start + 13
Thread 27:
Thread 28:
Thread 29:
Thread 30:
Thread 31:
Thread 32:
Thread 33:
Thread 34:
Thread 35:
Thread 36:
Thread 37:
Thread 38:
Thread 39:
Thread 40:
Thread 41:
Thread 42:
Thread 43:
Thread 44:
Thread 45:
Thread 46:
Thread 47:
Thread 48:
Thread 49:: BridgeTalk
0 libsystem_kernel.dylib 0x00007fff9170110a __semwait_signal + 10
1 libsystem_c.dylib 0x00007fff9d126d0f nanosleep + 199
2 com.adobe.PSAutomate 0x000000011db85f48 0x11d9a9000 + 1953608
3 com.adobe.PSAutomate 0x000000011db67d0c 0x11d9a9000 + 1830156
4 com.adobe.PSAutomate 0x000000011db85ad1 0x11d9a9000 + 1952465
Thread 50:: Bristle Physics
2 com.adobe.Photoshop 0x000000010b6ab57b 0x10b6a1000 + 42363
3 com.adobe.Photoshop 0x000000010d3cc68b 0x10b6a1000 + 30586507
4 com.adobe.Photoshop 0x000000010d3c3ed3 0x10b6a1000 + 30551763
5 com.adobe.Photoshop 0x0000000110cf4e47 0x10b6a1000 + 90521159
Thread 51:: Font Initialization
2 com.adobe.Photoshop 0x000000010ba8a431 0x10b6a1000 + 4101169
3 com.adobe.Photoshop 0x000000010d8cade8 0x10b6a1000 + 35823080
4 com.adobe.Photoshop 0x000000010d8ca4fc 0x10b6a1000 + 35820796
5 com.adobe.Photoshop 0x000000010d8cbd96 0x10b6a1000 + 35827094
6 com.adobe.Photoshop 0x0000000110cf4e47 0x10b6a1000 + 90521159
7 libsystem_pthread.dylib 0x00007fff9374199d _pthread_body + 131
8 libsystem_pthread.dylib 0x00007fff9374191a _pthread_start + 168
9 libsystem_pthread.dylib 0x00007fff9373f351 thread_start + 13
Thread 52:: DeepFont
Thread 53:: com.apple.NSEventThread
0 libsystem_kernel.dylib 0x00007fff916faf72 mach_msg_trap + 10
1 libsystem_kernel.dylib 0x00007fff916fa3b3 mach_msg + 55
2 com.apple.CoreFoundation 0x00007fff97f3e114 __CFRunLoopServiceMachPort + 212
3 com.apple.CoreFoundation 0x00007fff97f3d5dc __CFRunLoopRun + 1356
5 com.apple.AppKit 0x00007fff8df98d95 _NSEventThread + 149
Thread 54:
2 com.adobe.headlights.LogSessionFramework 0x0000000116248ccc boost::condition_variable::do_wait_until(boost::unique_lock<boost::mutex>&, timespec const&) + 76
3 com.adobe.headlights.LogSessionFramework 0x00000001162475ef boost::this_thread::hiden::sleep_for(timespec const&) + 191
4 com.adobe.headlights.LogSessionFramework 0x00000001161f5059 void boost::this_thread::sleep_for<long long, boost::ratio<1l, 1l> >(boost::chrono::duration<long long, boost::ratio<1l, 1l> > const&) + 107
5 com.adobe.headlights.LogSessionFramework 0x00000001161c3cfb RealTimeProcessor::WorkerThread(int, int) + 3633
6 com.adobe.headlights.LogSessionFramework 0x0000000116246969 boost::(anonymous namespace)::thread_proxy(void*) + 185
Thread 55:: com.apple.NSURLConnectionLoader
5 com.apple.CFNetwork 0x00007fff9a4aca6d +[NSURLConnection(Loader) _resourceLoadLoop:] + 412
6 com.apple.Foundation 0x00007fff93a20c84 __NSThread__start__ + 1351
Thread 56:
2 com.adobe.headlights.LogSessionFramework 0x00000001161f6152 boost::condition_variable::wait_until(boost::unique_lock<boost::mutex>&, boost::chrono::time_point<boost::chrono::system_clock, boost::chrono::duration<long long, boost::ratio<1l, 1000000000l> > >) + 124
3 com.adobe.headlights.LogSessionFramework 0x00000001161f50db void boost::this_thread::sleep_until<boost::chrono::system_clock, boost::chrono::duration<long long, boost::ratio<1l, 1000000000l> > >(boost::chrono::time_point<boost::chrono::system_clock, boost::chrono::duration<long long, boost::ratio<1l, 1000000000l> > > const&) + 124
4 com.adobe.headlights.LogSessionFramework 0x00000001161f4bae IdleTimeLogger::IdleTimeWorkerThread() + 2804
5 com.adobe.headlights.LogSessionFramework 0x0000000116246969 boost::(anonymous namespace)::thread_proxy(void*) + 185
Thread 57:: General Background Service
Thread 58:: Update Activation Menu Items
2 com.adobe.Photoshop 0x000000010ba08b50 0x10b6a1000 + 3570512
3 com.adobe.Photoshop 0x0000000110cf4e47 0x10b6a1000 + 90521159
4 libsystem_pthread.dylib 0x00007fff9374199d _pthread_body + 131
5 libsystem_pthread.dylib 0x00007fff9374191a _pthread_start + 168
6 libsystem_pthread.dylib 0x00007fff9373f351 thread_start + 13
Thread 59:
3 com.adobe.Photoshop 0x000000010b6a695e 0x10b6a1000 + 22878
4 com.adobe.Photoshop 0x000000010b6a7e36 0x10b6a1000 + 28214
Thread 60:
Thread 61:
Thread 62:
Thread 63:: com.apple.CFSocket.private
0 libsystem_kernel.dylib 0x00007fff9170107a __select + 10
1 com.apple.CoreFoundation 0x00007fff97f7b45a __CFSocketManager + 762
Thread 64:: NetworkConfigWatcher
5 com.apple.Foundation 0x00007fff93a0fcf9 -[NSRunLoop(NSRunLoop) runMode:beforeDate:] + 270
6 org.chromium.ContentShell.framework 0x000000018411c564 0x183fe5000 + 1275236
7 org.chromium.ContentShell.framework 0x000000018411bd64 0x183fe5000 + 1273188
8 org.chromium.ContentShell.framework 0x00000001841533d3 0x183fe5000 + 1500115
9 org.chromium.ContentShell.framework 0x00000001841421fd 0x183fe5000 + 1430013
10 org.chromium.ContentShell.framework 0x0000000184173b3b 0x183fe5000 + 1633083
11 org.chromium.ContentShell.framework 0x000000018416fd2c 0x183fe5000 + 1617196
12 libsystem_pthread.dylib 0x00007fff9374199d _pthread_body + 131
13 libsystem_pthread.dylib 0x00007fff9374191a _pthread_start + 168
14 libsystem_pthread.dylib 0x00007fff9373f351 thread_start + 13
Thread 65:: DnsConfigService
0 libsystem_kernel.dylib 0x00007fff91701eca kevent + 10
1 org.chromium.ContentShell.framework 0x000000018419be97 0x183fe5000 + 1797783
2 org.chromium.ContentShell.framework 0x00000001841998ad 0x183fe5000 + 1788077
3 org.chromium.ContentShell.framework 0x000000018411afd1 0x183fe5000 + 1269713
4 org.chromium.ContentShell.framework 0x00000001841533d3 0x183fe5000 + 1500115
5 org.chromium.ContentShell.framework 0x00000001841421fd 0x183fe5000 + 1430013
6 org.chromium.ContentShell.framework 0x0000000184173b3b 0x183fe5000 + 1633083
7 org.chromium.ContentShell.framework 0x000000018416fd2c 0x183fe5000 + 1617196
8 libsystem_pthread.dylib 0x00007fff9374199d _pthread_body + 131
9 libsystem_pthread.dylib 0x00007fff9374191a _pthread_start + 168
10 libsystem_pthread.dylib 0x00007fff9373f351 thread_start + 13
Thread 66:: Chrome_DBThread
5 org.chromium.ContentShell.framework 0x000000018411c2df 0x183fe5000 + 1274591
6 org.chromium.ContentShell.framework 0x000000018411bd64 0x183fe5000 + 1273188
7 org.chromium.ContentShell.framework 0x00000001841533d3 0x183fe5000 + 1500115
8 org.chromium.ContentShell.framework 0x00000001841421fd 0x183fe5000 + 1430013
9 org.chromium.ContentShell.framework 0x0000000186cf47a8 0x183fe5000 + 47249320
10 org.chromium.ContentShell.framework 0x0000000186cf4af6 0x183fe5000 + 47250166
11 org.chromium.ContentShell.framework 0x0000000184173b3b 0x183fe5000 + 1633083
12 org.chromium.ContentShell.framework 0x000000018416fd2c 0x183fe5000 + 1617196
13 libsystem_pthread.dylib 0x00007fff9374199d _pthread_body + 131
14 libsystem_pthread.dylib 0x00007fff9374191a _pthread_start + 168
15 libsystem_pthread.dylib 0x00007fff9373f351 thread_start + 13
Thread 67:: Chrome_FileThread
6 org.chromium.ContentShell.framework 0x0000000186cf4828 0x183fe5000 + 47249448
7 org.chromium.ContentShell.framework 0x0000000186cf4b03 0x183fe5000 + 47250179
8 org.chromium.ContentShell.framework 0x0000000184173b3b 0x183fe5000 + 1633083
9 org.chromium.ContentShell.framework 0x000000018416fd2c 0x183fe5000 + 1617196
10 libsystem_pthread.dylib 0x00007fff9374199d _pthread_body + 131
11 libsystem_pthread.dylib 0x00007fff9374191a _pthread_start + 168
12 libsystem_pthread.dylib 0x00007fff9373f351 thread_start + 13
Thread 68:: Chrome_FileUserBlockingThread
9 org.chromium.ContentShell.framework 0x0000000186cf48a8 0x183fe5000 + 47249576
10 org.chromium.ContentShell.framework 0x0000000186cf4b10 0x183fe5000 + 47250192
Thread 69:: Chrome_ProcessLauncherThread
9 org.chromium.ContentShell.framework 0x0000000186cf4928 0x183fe5000 + 47249704
10 org.chromium.ContentShell.framework 0x0000000186cf4b1d 0x183fe5000 + 47250205
Thread 70:: Chrome_CacheThread
3 org.chromium.ContentShell.framework 0x000000018411afb9 0x183fe5000 + 1269689
6 org.chromium.ContentShell.framework 0x0000000186cf49a8 0x183fe5000 + 47249832
7 org.chromium.ContentShell.framework 0x0000000186cf4b2a 0x183fe5000 + 47250218
Thread 71:: Chrome_IOThread
6 org.chromium.ContentShell.framework 0x0000000186cf4a28 0x183fe5000 + 47249960
7 org.chromium.ContentShell.framework 0x0000000186cf4b37 0x183fe5000 + 47250231
Thread 72:: IndexedDB
9 org.chromium.ContentShell.framework 0x0000000184173b3b 0x183fe5000 + 1633083
10 org.chromium.ContentShell.framework 0x000000018416fd2c 0x183fe5000 + 1617196
11 libsystem_pthread.dylib 0x00007fff9374199d _pthread_body + 131
12 libsystem_pthread.dylib 0x00007fff9374191a _pthread_start + 168
13 libsystem_pthread.dylib 0x00007fff9373f351 thread_start + 13
Thread 73:: CompositorTileWorker1/133635
2 org.chromium.ContentShell.framework 0x0000000185cf61f9 0x183fe5000 + 30478841
3 org.chromium.ContentShell.framework 0x0000000184173002 0x183fe5000 + 1630210
4 org.chromium.ContentShell.framework 0x000000018416fd2c 0x183fe5000 + 1617196
Thread 74:: AudioThread
Thread 75:: BrowserBlockingWorker1/136467
2 org.chromium.ContentShell.framework 0x0000000184170bd6 0x183fe5000 + 1620950
3 org.chromium.ContentShell.framework 0x0000000184170243 0x183fe5000 + 1618499
4 org.chromium.ContentShell.framework 0x0000000184173002 0x183fe5000 + 1630210
5 org.chromium.ContentShell.framework 0x000000018416fd2c 0x183fe5000 + 1617196
Thread 76:: NetworkConfigWatcher
Thread 77:: Chrome_DevToolsHandlerThread
Thread 78:: handle-watcher-thread
2 org.chromium.ContentShell.framework 0x00000001865a9738 0x183fe5000 + 39601976
3 org.chromium.ContentShell.framework 0x0000000186594498 0x183fe5000 + 39515288
4 org.chromium.ContentShell.framework 0x0000000186594776 0x183fe5000 + 39516022
5 org.chromium.ContentShell.framework 0x000000018658cc03 0x183fe5000 + 39484419
6 org.chromium.ContentShell.framework 0x00000001865875ab 0x183fe5000 + 39462315
7 org.chromium.ContentShell.framework 0x0000000186587363 0x183fe5000 + 39461731
8 org.chromium.ContentShell.framework 0x00000001865872ee 0x183fe5000 + 39461614
9 org.chromium.ContentShell.framework 0x00000001841533d3 0x183fe5000 + 1500115
10 org.chromium.ContentShell.framework 0x00000001841421fd 0x183fe5000 + 1430013
Thread 79:: BrowserBlockingWorker2/141575
Thread 80:: BrowserBlockingWorker3/140563
Thread 81:: CachePoolWorker1/141323
Thread 82:
5 com.apple.Foundation 0x00007fff93b27f99 -[NSConnection run] + 149
Thread 83:: CEPMonitorThread
5 com.apple.Foundation 0x00007fff93ab9dda -[NSConcreteTask waitUntilExit] + 205
6 com.adobe.PlugPlugOwl 0x0000000113807c4b -[HtmlEngineMonitor monitorThreadProc] + 160
7 com.apple.Foundation 0x00007fff93a20c84 __NSThread__start__ + 1351
Thread 84:: Generator
0 libsystem_kernel.dylib 0x00007fff91701582 __wait4 + 10
1 com.adobe.Photoshop 0x000000010da363b0 0x10b6a1000 + 37311408
2 com.adobe.Photoshop 0x000000010da34b9e 0x10b6a1000 + 37305246
Thread 85:: GeneratorReadPipe
0 libsystem_kernel.dylib 0x00007fff91702362 read + 10
1 com.adobe.Photoshop 0x000000010d614275 0x10b6a1000 + 32977525
2 com.adobe.Photoshop 0x0000000110cf4e47 0x10b6a1000 + 90521159
Thread 86:: GeneratorWritePipe
1 libtbb.dylib 0x0000000113070cf4 tbb::internal::concurrent_queue_base_v3::internal_pop(void*) + 580
2 com.adobe.Photoshop 0x000000010d6144b5 0x10b6a1000 + 32978101
Thread 87:
Thread 88:: CEPMonitorThread
Thread 89:: Background Save
3 com.adobe.Photoshop 0x000000010d61016a 0x10b6a1000 + 32960874
4 com.adobe.Photoshop 0x000000010d60ddd9 0x10b6a1000 + 32951769
Thread 90:: cr_scratch
2 com.adobe.CameraRaw 0x0000000bcc48203c 0xbcba48000 + 10723388
3 com.adobe.CameraRaw 0x0000000bcc3f5d1b 0xbcba48000 + 10149147
4 com.adobe.CameraRaw 0x0000000bcc11fd41 0xbcba48000 + 7175489
Thread 91:: Transform Tile Locking
2 com.adobe.Photoshop 0x000000010c8e54c3 0x10b6a1000 + 19154115
Thread 92:
1 libsystem_pthread.dylib 0x00007fff9374275e _pthread_cond_wait + 821
2 com.apple.CoreServices.CarbonCore 0x00007fff9d217a93 TSWaitOnConditionTimedRelative + 147
3 com.apple.CoreServices.CarbonCore 0x00007fff9d21766e TSWaitOnSemaphoreCommon + 406
4 com.apple.CoreServices.CarbonCore 0x00007fff9d1de6ea AsyncFileThread(void*) + 275
Thread 93:
0 libsystem_kernel.dylib 0x00007fff917015e2 __workq_kernreturn + 10
1 libsystem_pthread.dylib 0x00007fff93741578 _pthread_wqthread + 1283
2 libsystem_pthread.dylib 0x00007fff9373f341 start_wqthread + 13
Thread 94:
Thread 95:
Thread 96:
Thread 97:
Thread 98:
Thread 99:
Thread 100:
Thread 101:
Thread 102:
Thread 103:
Thread 104:
Thread 105:
Thread 106:
Thread 107:
Thread 108:
Thread 109:
Thread 110:: Dispatch queue: NSCGSDisableUpdates
2 com.apple.CoreGraphics 0x00007fff874aaa42 _CGSReenableUpdateForConnection + 92
3 com.apple.CoreGraphics 0x00007fff874aa70d CGSReenableUpdateToken + 469
4 libdispatch.dylib 0x00007fff8c58293d _dispatch_call_block_and_release + 12
5 libdispatch.dylib 0x00007fff8c57740b _dispatch_client_callout + 8
6 libdispatch.dylib 0x00007fff8c57c03b _dispatch_queue_drain + 754
7 libdispatch.dylib 0x00007fff8c582707 _dispatch_queue_invoke + 549
8 libdispatch.dylib 0x00007fff8c57740b _dispatch_client_callout + 8
9 libdispatch.dylib 0x00007fff8c57b29b _dispatch_root_queue_drain + 1890
10 libdispatch.dylib 0x00007fff8c57ab00 _dispatch_worker_thread3 + 91
11 libsystem_pthread.dylib 0x00007fff937414de _pthread_wqthread + 1129
12 libsystem_pthread.dylib 0x00007fff9373f341 start_wqthread + 13
Thread 111:
Thread 112:
Thread 113:
Thread 114:
Thread 115:
Thread 0 crashed with X86 Thread State (64-bit):
rax: 0x0000000000000001 rbx: 0x0000000000000000 rcx: 0xffffffffffffd100 rdx: 0x0000000000000001
rdi: 0x00000001230a1100 rsi: 0x0000000000000aee rbp: 0x0000000000000000 rsp: 0x00007fff5455b968
r8: 0x0000000000000000 r9: 0x0000000000000001 r10: 0x0000000000000000 r11: 0x0000000000001000
r12: 0x0000000000000001 r13: 0x00000001230a1100 r14: 0x00000000ffffd100 r15: 0xffffffffffffd0fe
rip: 0x00000001209fc506 rfl: 0x0000000000010297 cr2: 0x00000001230a1100
Logical CPU: 20
Error Code: 0x00000006
Trap Number: 14
Binary Images:
0x10b6a1000 - 0x111ee7f4f +com.adobe.Photoshop (18.0.1 - 18.0.1.29) <AE656ED1-6240-34A2-83CA-258C4A18157C> /Applications/Adobe Photoshop CC 2017/Adobe Photoshop CC 2017.app/Contents/MacOS/Adobe Photoshop CC 2017
0x11306f000 - 0x1130a6fef +libtbb.dylib (0) <3441EB5B-2632-3B4C-B76C-9AE5849E7353> /Applications/Adobe Photoshop CC 2017/Adobe Photoshop CC 2017.app/Contents/Frameworks/libtbb.dylib
0x1130e9000 - 0x11310cfe7 +libtbbmalloc.dylib (0) <81117D6A-D8E4-37C2-9766-0DC0BF86C06C> /Applications/Adobe Photoshop CC 2017/Adobe Photoshop CC 2017.app/Contents/Frameworks/libtbbmalloc.dylib
0x113144000 - 0x113242ff3 +ZXPSignLib-minimal-dylib.dylib (0) <B50C7884-6179-3925-AF15-0013257D0F6B> /Applications/Adobe Photoshop CC 2017/Adobe Photoshop CC 2017.app/Contents/Frameworks/ZXPSignLib-minimal-dylib.dylib
0x113271000 - 0x1132e0ff7 +com.adobe.manta (Adobe Manta Library 2.0.00.1 - 2.0.00.1) <B1AD98B3-6ED3-34CE-90A3-F2D798BB0439> /Applications/Adobe Photoshop CC 2017/Adobe Photoshop CC 2017.app/Contents/Frameworks/manta.framework/Versions/A/manta
0x11336c000 - 0x1134f6fff +com.adobe.aif (Adobe Image Foundation Library 6.0.00.1 - 6.0.00.1) <FED42048-AA7F-35D5-87AC-03BB1B9DB306> /Applications/Adobe Photoshop CC 2017/Adobe Photoshop CC 2017.app/Contents/Frameworks/aif.framework/Versions/A/aif
0x113650000 - 0x113753fff +com.adobe.amtlib (10.0.0.47 - 10.0.0.47) <AD7B1E56-04A5-355A-AD70-DA2464879FC3> /Applications/Adobe Photoshop CC 2017/Adobe Photoshop CC 2017.app/Contents/Frameworks/amtlib.framework/Versions/A/amtlib
0x11376e000 - 0x1139e4ff3 +com.adobe.PlugPlugOwl (7.0.0.67 - 7.0.0.67) <255982DC-96E4-3C40-AF5A-B46F23B5D372> /Applications/Adobe Photoshop CC 2017/Adobe Photoshop CC 2017.app/Contents/Frameworks/PlugPlugOwl.framework/Versions/A/PlugPlugOwl
0x113cb8000 - 0x113d57ff7 +com.adobe.AdobeScCore (ScCore 4.5.6 - 4.5.6.4) <A75C85DD-5C39-343D-91A1-B6601FF46C32> /Applications/Adobe Photoshop CC 2017/Adobe Photoshop CC 2017.app/Contents/Frameworks/AdobeScCore.framework/Versions/A/AdobeScCore
0x113da8000 - 0x113e51fff +com.adobe.AdobeExtendScript (ExtendScript 4.5.6 - 4.5.6.4) <1B9BAF47-DDB1-35DB-8CD1-7231566F3C88> /Applications/Adobe Photoshop CC 2017/Adobe Photoshop CC 2017.app/Contents/Frameworks/AdobeExtendScript.framework/Versions/A/AdobeExtendScript
0x113eb1000 - 0x113f27fff +com.adobe.AdobeSVGAGM (1.0.0 - 1.0.0.37447) <4756E8D2-6541-3A34-9A40-FED989F1B05D> /Applications/Adobe Photoshop CC 2017/Adobe Photoshop CC 2017.app/Contents/Frameworks/AdobeSVGAGM.framework/Versions/A/AdobeSVGAGM
0x114013000 - 0x1140bcff7 +com.adobe.ICUConverter (4.0 - 3.61) <E20E390A-9BAF-3454-BA16-7B9CCD4CA8F0> /Applications/Adobe Photoshop CC 2017/Adobe Photoshop CC 2017.app/Contents/Frameworks/ICUConverter.framework/Versions/4.0/ICUConverter
0x1140ec000 - 0x1140f1fff org.twain.dsm (1.9.5 - 1.9.5) <F7AA3C5E-4FB0-379D-8F79-AD06669D087E> /System/Library/Frameworks/TWAIN.framework/Versions/A/TWAIN
0x1140fb000 - 0x114117fff +com.adobe.ahclientframework (2.0.0.1 - 2.0.0.1) <075BD455-9D2E-3B8A-8C83-8B40D3059A55> /Applications/Adobe Photoshop CC 2017/Adobe Photoshop CC 2017.app/Contents/Frameworks/ahclient.framework/Versions/A/ahclient
0x114124000 - 0x114128fff com.apple.agl (3.3.1 - AGL-3.3.1) <2FC3E30C-5370-3369-B8D1-1C7050A4A85A> /System/Library/Frameworks/AGL.framework/Versions/A/AGL
0x114130000 - 0x114131fff libCyrillicConverter.dylib (68) <79F5CFEF-92E4-30FE-A650-41F07B6D31B9> /System/Library/CoreServices/Encodings/libCyrillicConverter.dylib
0x114136000 - 0x1142c9ff7 +com.adobe.owl (AdobeOwl version 5.2.11 - 5.2.11) <C849EDD6-B535-3200-A418-817EB0D29B0C> /Applications/Adobe Photoshop CC 2017/Adobe Photoshop CC 2017.app/Contents/Frameworks/AdobeOwl.framework/Versions/A/AdobeOwl
0x114315000 - 0x11467bff3 +com.adobe.MPS (AdobeMPS 5.8.1.37174 - 5.8.1.37174) <88508A43-6228-39B1-9377-B49EC9BBE1DE> /Applications/Adobe Photoshop CC 2017/Adobe Photoshop CC 2017.app/Contents/Frameworks/AdobeMPS.framework/Versions/A/AdobeMPS
0x1146f0000 - 0x114714fff +VulcanControl.dylib (5.3.0.16 - 5.3.0.16 Copyright 2016, Adobe Systems Incorporated. All rights reserved.) <32AA6861-E0A7-37F8-8CE9-FCE97E3BFD07> /Applications/Adobe Photoshop CC 2017/Adobe Photoshop CC 2017.app/Contents/Frameworks/VulcanControl.dylib
0x114740000 - 0x114a07ff7 +com.adobe.AGM (AdobeAGM 4.30.60.37447 - 4.30.60.37447) <71B74E67-BF19-3C2A-A843-8FC82C183138> /Applications/Adobe Photoshop CC 2017/Adobe Photoshop CC 2017.app/Contents/Frameworks/AdobeAGM.framework/Versions/A/AdobeAGM
0x114a79000 - 0x114d76ff7 +com.adobe.CoolType (AdobeCoolType 5.15.00.37447 - 5.15.00.37447) <7BAD2049-203D-3A5F-B7CE-4F11C7361100> /Applications/Adobe Photoshop CC 2017/Adobe Photoshop CC 2017.app/Contents/Frameworks/AdobeCoolType.framework/Versions/A/AdobeCoolType
0x114dc6000 - 0x114de9ff3 +com.adobe.BIBUtils (AdobeBIBUtils 1.1.01 - 1.1.01) <B71D4C22-E568-3088-AED2-7D14B810D74A> /Applications/Adobe Photoshop CC 2017/Adobe Photoshop CC 2017.app/Contents/Frameworks/AdobeBIBUtils.framework/Versions/A/AdobeBIBUtils
0x114df6000 - 0x114e1aff7 +com.adobe.AXE8SharedExpat (AdobeAXE8SharedExpat 3.8.0.34320 - 3.8.0.34320) <674F1792-D790-3E12-8C0F-85CAF9D848B1> /Applications/Adobe Photoshop CC 2017/Adobe Photoshop CC 2017.app/Contents/Frameworks/AdobeAXE8SharedExpat.framework/Versions/A/AdobeAXE8SharedExpat
0x114e40000 - 0x114f6aff7 +com.winsoft.wrservices (WRServices 12.0.0 - 12.0.0) <DC848A40-2FD7-3C18-8653-242100970FF6> /Applications/Adobe Photoshop CC 2017/Adobe Photoshop CC 2017.app/Contents/Frameworks/WRServices.framework/Versions/A/WRServices
0x114fbe000 - 0x115107ffb +com.adobe.ACE (AdobeACE 2.20.02.37447 - 2.20.02.37447) <A8CFE20B-3A58-3337-9BDC-1B623999BFFC> /Applications/Adobe Photoshop CC 2017/Adobe Photoshop CC 2017.app/Contents/Frameworks/AdobeACE.framework/Versions/A/AdobeACE
0x115121000 - 0x11513dffb +com.adobe.BIB (AdobeBIB 1.2.03.37447 - 1.2.03.37447) <28247879-8E7A-3B40-9012-FF1E849D7236> /Applications/Adobe Photoshop CC 2017/Adobe Photoshop CC 2017.app/Contents/Frameworks/AdobeBIB.framework/Versions/A/AdobeBIB
0x115149000 - 0x115209ff7 +com.adobe.JP2K (1.2.2 - 1.2.2.36529) <578A7A58-7F7D-3727-9D9A-4748CA20C1B2> /Applications/Adobe Photoshop CC 2017/Adobe Photoshop CC 2017.app/Contents/Frameworks/AdobeJP2K.framework/Versions/A/AdobeJP2K
0x115253000 - 0x1153cdfff +com.adobe.AdobeXMPCore (Adobe XMP Core 5.6 -c 138 - 79.159824) <A870682F-0A58-38CB-B15E-E983C131AC32> /Applications/Adobe Photoshop CC 2017/Adobe Photoshop CC 2017.app/Contents/Frameworks/AdobeXMP.framework/Versions/A/AdobeXMP
0x115525000 - 0x115a7dfef +com.nvidia.cg (2.2.0006 - 0) /Applications/Adobe Photoshop CC 2017/Adobe Photoshop CC 2017.app/Contents/Frameworks/Cg.framework/Cg
0x1160f0000 - 0x11628afff +com.adobe.headlights.LogSessionFramework (7.4.1.60.45263) <2116CCCF-BA38-366C-8BCE-91827BA52E6D> /Applications/Adobe Photoshop CC 2017/Adobe Photoshop CC 2017.app/Contents/Frameworks/LogSession.framework/Versions/A/LogSession
0x116362000 - 0x1170a7fff +com.adobe.ICUData (4.0 - 3.61) <B9864D01-126E-3C56-B04C-993F9890F6AD> /Applications/Adobe Photoshop CC 2017/Adobe Photoshop CC 2017.app/Contents/Frameworks/ICUData.framework/Versions/4.0/ICUData
0x1170bb000 - 0x1170e4ff7 +com.adobe.PDFSettings (AdobePDFSettings 1.04.0 - 1.4) <E07D101E-E47A-392A-8A44-005B49393DEC> /Applications/Adobe Photoshop CC 2017/Adobe Photoshop CC 2017.app/Contents/Frameworks/AdobePDFSettings.framework/Versions/A/AdobePDFSettings
0x1170fe000 - 0x117101fff +com.adobe.AdobeCrashReporter (7.3 - 7.3.2) <F09CBDBF-D0F2-3E8B-A039-EC311CD1CCA1> /Applications/Adobe Photoshop CC 2017/Adobe Photoshop CC 2017.app/Contents/Frameworks/AdobeCrashReporter.framework/Versions/A/AdobeCrashReporter
0x11710d000 - 0x117148ff7 +VulcanMessage5.dylib (5.3.0.16 - 5.3.0.16 Copyright 2016, Adobe Systems Incorporated. All rights reserved.) <4B054DF8-614C-39A7-AC19-CBBA847B9014> /Applications/Adobe Photoshop CC 2017/Adobe Photoshop CC 2017.app/Contents/Frameworks/VulcanMessage5.dylib
0x117194000 - 0x117290fff +com.adobe.AXEDOMCore (AdobeAXEDOMCore 3.8.0.34320 - 3.8.0.34320) <AFDCC2CF-EF73-323E-A2FA-3034F26F97B9> /Applications/Adobe Photoshop CC 2017/Adobe Photoshop CC 2017.app/Contents/Frameworks/AdobeAXEDOMCore.framework/Versions/A/AdobeAXEDOMCore
0x11733f000 - 0x1174a3ff7 +com.adobe.linguistic.LinguisticManager (9.0.0 - 21429) <F35C19E3-EADE-3DCD-A487-394A474895CE> /Applications/Adobe Photoshop CC 2017/Adobe Photoshop CC 2017.app/Contents/Frameworks/AdobeLinguistic.framework/Versions/3/AdobeLinguistic
0x1174f7000 - 0x1175f1ff7 +com.adobe.adobe_caps (adobe_caps 10.0.0.6 - 10.0.0.6) <F42B5047-A935-3B78-9F9A-F4841C6DEE88> /Applications/Adobe Photoshop CC 2017/Adobe Photoshop CC 2017.app/Contents/Frameworks/adobe_caps.framework/Versions/A/adobe_caps
0x117608000 - 0x11770bff7 +com.adobe.ICUUnicode (4.0 - 3.61) <CE487901-E84A-3E54-95AB-91F2EAF57F6A> /Applications/Adobe Photoshop CC 2017/Adobe Photoshop CC 2017.app/Contents/Frameworks/ICUUnicode.framework/Versions/4.0/ICUUnicode
0x11775b000 - 0x1178a2fef +com.adobe.PM (AdbePM 2.5.00.377243 - 2.5.00.377243) <BA6D73F8-6235-30DA-81C9-A5CA7F54A963> /Applications/Adobe Photoshop CC 2017/Adobe Photoshop CC 2017.app/Contents/Frameworks/AdbePM.framework/Versions/A/AdbePM
0x1179fe000 - 0x117a19fff +CITThreading (???) <36EB8576-8BCB-3E23-8191-D1CA3E2DC6C5> /Applications/Adobe Photoshop CC 2017/Adobe Photoshop CC 2017.app/Contents/Frameworks/CITThreading.framework/Versions/A/CITThreading
0x117a5a000 - 0x117c7cff7 +libopencv_core.2.4.9.dylib (0) <305D6C41-9F88-3A40-97D4-DAF5BA2D46EF> /Applications/Adobe Photoshop CC 2017/Adobe Photoshop CC 2017.app/Contents/Frameworks/libopencv_core.2.4.9.dylib
0x117cd6000 - 0x117eb3ff7 +libopencv_imgproc.2.4.9.dylib (0) <E5EE040B-2890-35B2-89DB-AA4DADBFDC03> /Applications/Adobe Photoshop CC 2017/Adobe Photoshop CC 2017.app/Contents/Frameworks/libopencv_imgproc.2.4.9.dylib
0x117f9d000 - 0x11822fffb +com.adobe.SVGRE (AdobeSVGRE 6.0 - 6.0) <B5655C08-3BF8-3F17-A990-54E52F392CB3> /Applications/Adobe Photoshop CC 2017/Adobe Photoshop CC 2017.app/Contents/Frameworks/AdobeSVGRE.framework/Versions/A/AdobeSVGRE
0x1182b5000 - 0x1183e9fff +com.adobe.AIDE (1.5.0 - 1.5.0.36540) <0E2D02C2-0459-3C81-B9F4-AA5D9A2F9000> /Applications/Adobe Photoshop CC 2017/Adobe Photoshop CC 2017.app/Contents/Frameworks/AIDE.framework/Versions/A/AIDE
0x118685000 - 0x118687ff7 com.apple.textencoding.unicode (3.0 - 3.0) <B8CEE380-5919-3519-8088-119C65562EE9> /System/Library/TextEncodings/Unicode Encodings.bundle/Contents/MacOS/Unicode Encodings
0x11d6ed000 - 0x11d8e0fff com.nvidia.web.GeForceMTLDriverWeb (10.11.14 - 10.1.1) <293ED998-72BF-33D0-AC42-282B8122F6A1> /System/Library/Extensions/GeForceMTLDriverWeb.bundle/Contents/MacOS/GeForceMTLDriverWeb
0x11d9a9000 - 0x11dde6ff7 +com.adobe.PSAutomate (18.0.1 - 18.0.1) <CB76414A-5F97-3773-88A0-E2AFCA58AEDC> /Applications/Adobe Photoshop CC 2017/Adobe Photoshop CC 2017.app/Contents/Required/Plug-Ins/Extensions/ScriptingSupport.plugin/Contents/MacOS/ScriptingSupport
0x11e0d8000 - 0x11e1d8ff3 +com.adobe.ps.spaces (18.0.1 - 18.0.1) <57CC47E2-045B-38B6-AD41-A431AE4DAD09> /Applications/Adobe Photoshop CC 2017/Adobe Photoshop CC 2017.app/Contents/Required/Plug-Ins/Spaces/Spaces.plugin/Contents/MacOS/Spaces
0x11e207000 - 0x11e23efff com.apple.audio.midi.CoreMIDI (1.10 - 88) <51E79766-51D8-3A95-A7FD-18E7E11528F3> /System/Library/Frameworks/CoreMIDI.framework/Versions/A/CoreMIDI
0x11e267000 - 0x11e280fff libexpat.1.dylib (12.60.1) <6BF318AC-F90F-3F16-99C2-6ADDE404E280> /usr/lib/libexpat.1.dylib
0x11ee2c000 - 0x11ee47fff com.apple.security.csparser (3.0 - 57337.60.3) <1E3D798B-2878-3486-84EE-14D609B88A36> /System/Library/Frameworks/Security.framework/PlugIns/csparser.bundle/Contents/MacOS/csparser
0x11fc24000 - 0x11fc40ff7 libJapaneseConverter.dylib (68) <D80D1583-1F6F-32A5-A683-F504A0DF973A> /System/Library/CoreServices/Encodings/libJapaneseConverter.dylib
0x11fc46000 - 0x11fc68ff7 libKoreanConverter.dylib (68) <F29010B7-FABC-3CDA-95F5-85DC12B6C91B> /System/Library/CoreServices/Encodings/libKoreanConverter.dylib
0x11fc6d000 - 0x11fc7cff7 libSimplifiedChineseConverter.dylib (68) <DCFEA0D3-593E-3E5C-B311-53B8ACF8A318> /System/Library/CoreServices/Encodings/libSimplifiedChineseConverter.dylib
0x11fc81000 - 0x11fc93fff libTraditionalChineseConverter.dylib (68) <62CEE84C-366B-3E43-821B-EE072DBF33D7> /System/Library/CoreServices/Encodings/libTraditionalChineseConverter.dylib
0x120481000 - 0x120485fff libFontRegistryUI.dylib (155.2) <8346E80E-5832-3944-A750-FBB9D328C2FE> /System/Library/Frameworks/ApplicationServices.framework/Frameworks/ATS.framework/Resources/libFontRegistryUI.dylib
0x120782000 - 0x1207c5ff7 +com.adobe.AAM.AdobeUpdaterNotificationFramework (UpdaterNotifications 10.0.0.1 - 10.0.0.1) <624E6E8F-ACC9-3802-83A3-51970E64F769> /Applications/Adobe Photoshop CC 2017/Adobe Photoshop CC 2017.app/Contents/Frameworks/UpdaterNotifications.framework/Versions/A/UpdaterNotifications
0x1207e1000 - 0x1207e9fff +FastCore (18.0.1 - 18.0.1) <323940C3-8650-399F-838E-DEDABD28C89E> /Applications/Adobe Photoshop CC 2017/Adobe Photoshop CC 2017.app/Contents/Required/Plug-Ins/Extensions/FastCore.plugin/Contents/MacOS/FastCore
0x1209df000 - 0x120a5bfe7 +MMXCore (18.0.1 - 18.0.1) <BF90AFD4-7412-3D3D-B3CE-3B9F9D02B340> /Applications/Adobe Photoshop CC 2017/Adobe Photoshop CC 2017.app/Contents/Required/Plug-Ins/Extensions/MMXCore.plugin/Contents/MacOS/MMXCore
0x120adf000 - 0x120b56ff7 +MultiProcessor Support (18.0.1 - 18.0.1) <C655E4E8-B03F-3CBA-9CC3-8F213B73C1EE> /Applications/Adobe Photoshop CC 2017/Adobe Photoshop CC 2017.app/Contents/Required/Plug-Ins/Extensions/MultiProcessor Support.plugin/Contents/MacOS/MultiProcessor Support
0x122f34000 - 0x123083fff +IMSLib.dylib (10.0.0.1 - 10.0.0.1) <65AFDE5C-E1BB-3EC0-B59E-2F73453AA996> /Applications/Adobe Photoshop CC 2017/Adobe Photoshop CC 2017.app/Contents/Frameworks/IMSLib.dylib
0x128608000 - 0x1286adfff ColorSyncDeprecated.dylib (470.3) <A30CB963-667F-39D0-8537-66FCC820F5A6> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ColorSync.framework/Versions/A/Resources/ColorSyncDeprecated.dylib
0x18160f000 - 0x181621ff7 +MeasurementCore (18.0.1 - 18.0.1) <6DE40DF3-1951-3226-BAFB-F5C751520A64> /Applications/Adobe Photoshop CC 2017/Adobe Photoshop CC 2017.app/Contents/Required/Plug-Ins/Measurements/MeasurementCore.plugin/Contents/MacOS/MeasurementCore
0x181b31000 - 0x181babff7 com.apple.xquery (1.3.1 - 30) <C1020441-B131-3995-86D9-9D0B725D3FAD> /System/Library/PrivateFrameworks/XQuery.framework/XQuery
0x183fe5000 - 0x188812fb7 +org.chromium.ContentShell.framework (47.0.2526.16 - 2526.16) <7B368F04-4BDD-3D3C-9BF7-F015293D4368> /Applications/Adobe Photoshop CC 2017/Adobe Photoshop CC 2017.app/Contents/Required/Plug-Ins/Spaces/Frameworks/Chromium Embedded Framework.framework/Chromium Embedded Framework
0x18906a000 - 0x1899d7fff com.nvidia.web.GeForceGLDriverWeb (10.11.14 - 10.1.1) <0D0C682E-CE22-3724-B251-05A6736FC883> /System/Library/Extensions/GeForceGLDriverWeb.bundle/Contents/MacOS/GeForceGLDriverWeb
0x18a4dd000 - 0x18afeaff7 libclhWeb.dylib (0) <4FB1DBC0-6E02-3B9A-A6B4-F225B0CDCD75> /System/Library/Extensions/GeForceGLDriverWeb.bundle/Contents/MacOS/libclhWeb.dylib
0x18b7c8000 - 0x18b7faff7 +com.adobe.pip (7.4.1.60.45263) <B0E15E67-5403-3159-8A4F-6D3BDB11D77C> /Applications/Adobe Photoshop CC 2017/Adobe Photoshop CC 2017.app/Contents/Frameworks/AdobePIP.framework/AdobePIP
0x18b806000 - 0x18b82ffff +libSLCacheWrapper.dylib (1) <AB5FD9B1-D26B-3599-820A-6E1238597C86> /Applications/Adobe Photoshop CC 2017/Adobe Photoshop CC 2017.app/Contents/Frameworks/LogSession.framework/Libraries/libSLCacheWrapper.dylib
0x18d443000 - 0x18d443ff7 +cl_kernels (???) <EA673946-537D-49E6-9B7C-D8DBDEEB2D06> cl_kernels
0xbcba48000 - 0xbcf00ffe7 +com.adobe.CameraRaw (9.12 [784] - 9.12f784) <03C19329-CEF8-3314-84E3-DDD76A674910> /Library/Application Support/Adobe/*/Camera Raw.plugin/Contents/MacOS/Camera Raw
0xbd3e43000 - 0xbd46e7ff7 com.nvidia.web.GeForceAIRPluginWeb (10.11.14 - 10.1.1) <C932D9E8-289A-30BD-AB3B-C54948201D3E> /System/Library/Extensions/GeForceAIRPluginWeb.bundle/Contents/MacOS/GeForceAIRPluginWeb
0xbda200000 - 0xbda8f8ffb libairptxasWeb.dylib (0) <DED23148-9DF7-30AC-8D64-9FB4676C9D40> /System/Library/Extensions/GeForceAIRPluginWeb.bundle/Contents/MacOS/libairptxasWeb.dylib
0xbdbd4f000 - 0xbdbe3702f + (???) <2E1BD5A6-F029-3BA0-8966-2467A20C855F>
0x7fff66e6a000 - 0x7fff66ea1a47 dyld (360.22) <C8E77F6D-CE86-3C5B-8576-2584A799B51E> /usr/lib/dyld
0x7fff8722e000 - 0x7fff8723afff com.apple.SpeechRecognitionCore (2.2.7 - 2.2.7) <6BA06290-D4A3-351C-87F9-B61EF61FF055> /System/Library/PrivateFrameworks/SpeechRecognitionCore.framework/Versions/A/SpeechRecognitionCore
0x7fff8723b000 - 0x7fff87448fff libicucore.A.dylib (551.51.5) <2D3634CA-A87A-37A9-A3F4-C3E3106C2A33> /usr/lib/libicucore.A.dylib
0x7fff87449000 - 0x7fff886affff com.apple.CoreGraphics (1.600.0 - 960.7) <82D77440-30B2-3DCF-9414-88EC57CAD6CD> /System/Library/Frameworks/CoreGraphics.framework/Versions/A/CoreGraphics
0x7fff886de000 - 0x7fff88785fff com.apple.LanguageModeling (1.0 - 1) <58C18A47-BDE7-3CBE-81C0-797029D170A1> /System/Library/PrivateFrameworks/LanguageModeling.framework/Versions/A/LanguageModeling
0x7fff88786000 - 0x7fff88798fff libsasl2.2.dylib (209) <11C7D200-0CA5-30F4-A19A-178CA81D48FE> /usr/lib/libsasl2.2.dylib
0x7fff888f1000 - 0x7fff8894ffff com.apple.SystemConfiguration (1.14 - 1.14) <ACAEDA14-FAA0-3F14-B476-DE492A52D383> /System/Library/Frameworks/SystemConfiguration.framework/Versions/A/SystemConfiguration
0x7fff88a79000 - 0x7fff88ab3ff7 com.apple.DebugSymbols (132 - 132) <23A42C53-B941-3871-9EE2-4C87A46005B5> /System/Library/PrivateFrameworks/DebugSymbols.framework/Versions/A/DebugSymbols
0x7fff88b11000 - 0x7fff88d32ff7 com.apple.CoreImage (11.4.0 - 366.4.20) <7721BA55-A10E-3425-8392-C5D7C510EAAB> /System/Library/Frameworks/CoreImage.framework/Versions/A/CoreImage
0x7fff88d92000 - 0x7fff88d95ff7 com.apple.AppleSystemInfo (3.1.5 - 3.1.5) <6932B5EC-0EA9-333D-BF7E-665047392FEC> /System/Library/PrivateFrameworks/AppleSystemInfo.framework/Versions/A/AppleSystemInfo
0x7fff88ea0000 - 0x7fff88fcdfff com.apple.CoreText (352.0 - 494.14) <93E0D8C3-D5DD-3EBB-9CC1-831C46572133> /System/Library/Frameworks/CoreText.framework/Versions/A/CoreText
0x7fff8902f000 - 0x7fff8904aff7 libCRFSuite.dylib (34) <078B4CD8-6A8C-3067-B2BA-0C2A0BAB8AC3> /usr/lib/libCRFSuite.dylib
0x7fff8904b000 - 0x7fff890dafff com.apple.CorePDF (4.0 - 4) <849BBFF6-0700-3ED1-98DF-A6E93B9B707F> /System/Library/PrivateFrameworks/CorePDF.framework/Versions/A/CorePDF
0x7fff8916b000 - 0x7fff8916bfff com.apple.Cocoa (6.11 - 22) <807787AB-D231-3F51-A99B-A9314623C571> /System/Library/Frameworks/Cocoa.framework/Versions/A/Cocoa
0x7fff893bc000 - 0x7fff8940efff com.apple.CloudDocs (1.0 - 383.13) <5FD9138D-09D9-3B97-BBAD-5692E1687F30> /System/Library/PrivateFrameworks/CloudDocs.framework/Versions/A/CloudDocs
0x7fff89414000 - 0x7fff89464ff7 com.apple.Symbolication (1.4 - 58044) <F70BF765-FBE9-3F1E-85CA-BB2F8E53E8C2> /System/Library/PrivateFrameworks/Symbolication.framework/Versions/A/Symbolication
0x7fff89467000 - 0x7fff894c5fff com.apple.CoreServices.OSServices (728.13 - 728.13) <477EA3F9-D13E-3D83-ABAD-4DC7DB134CF0> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/OSServices.framework/Versions/A/OSServices
0x7fff894f2000 - 0x7fff89500fff com.apple.IntlPreferences (2.0 - 192) <388C5784-7713-36B0-B08B-5163E6B04002> /System/Library/PrivateFrameworks/IntlPreferences.framework/Versions/A/IntlPreferences
0x7fff89501000 - 0x7fff89503ff7 libquarantine.dylib (80) <B3B7B630-9012-3DA3-9458-5C009625E606> /usr/lib/system/libquarantine.dylib
0x7fff89538000 - 0x7fff898abfff com.apple.FinderKit (1.4.4 - 1.4.4) <76E52C7F-CA82-337E-BF8E-9961F11C4B8D> /System/Library/PrivateFrameworks/FinderKit.framework/Versions/A/FinderKit
0x7fff8994a000 - 0x7fff8aa33ff3 com.apple.WebCore (11601 - 11601.7.5) <9153DA7E-1625-382A-8257-8D4293F06F7F> /System/Library/Frameworks/WebKit.framework/Versions/A/Frameworks/WebCore.framework/Versions/A/WebCore
0x7fff8aa34000 - 0x7fff8ae0cfef com.apple.CoreAUC (214.0.0 - 214.0.0) <F80C19CA-6CD0-3052-9C22-0288A257CCC8> /System/Library/PrivateFrameworks/CoreAUC.framework/Versions/A/CoreAUC
0x7fff8ae0d000 - 0x7fff8ae5cff7 com.apple.opencl (2.7.0 - 2.7.0) <DAEC71D4-E0E7-3E24-BB44-C977A798C575> /System/Library/Frameworks/OpenCL.framework/Versions/A/OpenCL
0x7fff8ae5d000 - 0x7fff8aea9ff7 com.apple.corelocation (1486.17 - 1615.38) <6336CFC5-9D7D-3B76-B263-56DD6EBD0B8D> /System/Library/Frameworks/CoreLocation.framework/Versions/A/CoreLocation
0x7fff8aeaa000 - 0x7fff8aeb4fff com.apple.NetAuth (6.0 - 6.0) <D692B1EF-534F-3892-8E2F-2BBA7C8AFD74> /System/Library/PrivateFrameworks/NetAuth.framework/Versions/A/NetAuth
0x7fff8aeb6000 - 0x7fff8aec1fff com.apple.CrashReporterSupport (10.11 - 718) <05892B57-F2CD-3C84-B984-0417F6B361DB> /System/Library/PrivateFrameworks/CrashReporterSupport.framework/Versions/A/CrashReporterSupport
0x7fff8aef0000 - 0x7fff8aef0fff com.apple.audio.units.AudioUnit (1.13 - 1.13) <378B5292-F216-32AB-B628-8C33A72D7052> /System/Library/Frameworks/AudioUnit.framework/Versions/A/AudioUnit
0x7fff8aef1000 - 0x7fff8af58fff com.apple.framework.CoreWiFi (11.0 - 1101.20) <993592F1-B3F1-3FAD-87BD-EA83C361BCCF> /System/Library/PrivateFrameworks/CoreWiFi.framework/Versions/A/CoreWiFi
0x7fff8af6c000 - 0x7fff8af6dfff liblangid.dylib (122) <9CC4F0D1-5C51-3B69-BC8F-EE3A51FD0822> /usr/lib/liblangid.dylib
0x7fff8af6e000 - 0x7fff8af71ff7 com.apple.help (1.3.3 - 46) <35DA4D48-0BC2-35A1-8D7C-40905CDF4F64> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Help.framework/Versions/A/Help
0x7fff8af72000 - 0x7fff8af80ff7 libbz2.1.0.dylib (38) <28E54258-C0FE-38D4-AB76-1734CACCB344> /usr/lib/libbz2.1.0.dylib
0x7fff8afaf000 - 0x7fff8b44affb com.apple.GeoServices (1.0 - 1151.49.1) <2D887517-B73D-30FF-91DC-AF6AD91F96B9> /System/Library/PrivateFrameworks/GeoServices.framework/Versions/A/GeoServices
0x7fff8b44b000 - 0x7fff8b53dff7 libiconv.2.dylib (44) <F05A0A5A-92A9-3668-8F20-F27CBDA26BE9> /usr/lib/libiconv.2.dylib
0x7fff8b599000 - 0x7fff8b599ff7 libunc.dylib (29) <DDB1E947-C775-33B8-B461-63E5EB698F0E> /usr/lib/system/libunc.dylib
0x7fff8b5a2000 - 0x7fff8b5a9ff7 com.apple.phonenumbers (1.1.1 - 105) <A616AFB5-2336-385A-B058-16A423D2B21B> /System/Library/PrivateFrameworks/PhoneNumbers.framework/Versions/A/PhoneNumbers
0x7fff8b667000 - 0x7fff8b9d2657 libobjc.A.dylib (680) <D55D5807-1FBE-32A5-9105-44D7AFE68C27> /usr/lib/libobjc.A.dylib
0x7fff8b9d3000 - 0x7fff8b9e9fff com.apple.CoreMediaAuthoring (2.2 - 953) <A8F1B6EE-8ABE-3DC2-9829-A268D016648E> /System/Library/PrivateFrameworks/CoreMediaAuthoring.framework/Versions/A/CoreMediaAuthoring
0x7fff8baec000 - 0x7fff8bd7effb com.apple.RawCamera.bundle (6.21 - 879) <4F0A10FB-7C96-31E8-9A70-E30F615B2565> /System/Library/CoreServices/RawCamera.bundle/Contents/MacOS/RawCamera
0x7fff8bd7f000 - 0x7fff8bd81fff libsystem_coreservices.dylib (19.2) <1B3F5AFC-FFCD-3ECB-8B9A-5538366FB20D> /usr/lib/system/libsystem_coreservices.dylib
0x7fff8bd82000 - 0x7fff8bd84fff libCVMSPluginSupport.dylib (12.1) <20BA72AF-C7C5-3551-8F59-E1AED5FC69F0> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libCVMSPluginSupport.dylib
0x7fff8be08000 - 0x7fff8be2afff com.apple.IconServices (68.1 - 68.1) <CDEEDBE6-F53B-3BA1-82D4-23BCA3DD8949> /System/Library/PrivateFrameworks/IconServices.framework/Versions/A/IconServices
0x7fff8be2b000 - 0x7fff8be4dff7 com.apple.Sharing (442.13.6 - 442.13.6) <DDD2811C-6ECB-32F2-8EE1-69BF9657B4A8> /System/Library/PrivateFrameworks/Sharing.framework/Versions/A/Sharing
0x7fff8c18a000 - 0x7fff8c2cffff com.apple.QTKit (7.7.3 - 2943.13) <3E3DB3DD-8D7E-3478-B020-F975CCAAE522> /System/Library/Frameworks/QTKit.framework/Versions/A/QTKit
0x7fff8c2d4000 - 0x7fff8c2dfff7 libkxld.dylib (3248.70.3) <BAD04BB1-5BFE-3D88-ADDE-23FED2DD2942> /usr/lib/system/libkxld.dylib
0x7fff8c2e0000 - 0x7fff8c2e4fff libGIF.dylib (1463) <3F84E60B-18E5-3897-8494-DFB1ACE76829> /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libGIF.dylib
0x7fff8c54a000 - 0x7fff8c54aff7 liblaunch.dylib (765.70.1) <96D7C3EE-82E2-39AB-870F-B317A030E86D> /usr/lib/system/liblaunch.dylib
0x7fff8c54b000 - 0x7fff8c567ff7 libextension.dylib (78) <FD952DA6-BBEC-3CB6-98B3-E1D111C5C54E> /usr/lib/libextension.dylib
0x7fff8c575000 - 0x7fff8c5a2fff libdispatch.dylib (501.40.12) <C7499857-61A5-3D7D-A5EA-65DCC8C3DF92> /usr/lib/system/libdispatch.dylib
0x7fff8c5a3000 - 0x7fff8c5b1fff libxar.1.dylib (302) <03207F66-2C4A-3DBD-8D81-70F4C85903C4> /usr/lib/libxar.1.dylib
0x7fff8c5c8000 - 0x7fff8c5e4fff com.apple.GenerationalStorage (2.0 - 239.1) <8C821448-4294-3736-9CEF-467C93785CB9> /System/Library/PrivateFrameworks/GenerationalStorage.framework/Versions/A/GenerationalStorage
0x7fff8c5e5000 - 0x7fff8c626ff7 libGLU.dylib (12.1) <CD7A5916-3E3C-3EF3-A275-B281016B99CB> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGLU.dylib
0x7fff8c77e000 - 0x7fff8d0b2f5f libLLVMContainer.dylib (119.5) <09A35A20-7CDD-3E5A-94B4-5F1E5CFBC3D9> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libLLVMContainer.dylib
0x7fff8d0b3000 - 0x7fff8d106ff7 libc++.1.dylib (120.1) <8FC3D139-8055-3498-9AC5-6467CB7F4D14> /usr/lib/libc++.1.dylib
0x7fff8d107000 - 0x7fff8d219fef libvDSP.dylib (563.5) <5702650E-DF08-3D58-B16F-9EF0A28702B3> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libvDSP.dylib
0x7fff8d21a000 - 0x7fff8d220ff7 com.apple.speech.recognition.framework (5.1.1 - 5.1.1) <9E5A980A-F455-32D5-BBEE-3BD6018CC45E> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/SpeechRecognition.framework/Versions/A/SpeechRecognition
0x7fff8d2f4000 - 0x7fff8d2f8fff com.apple.CommonPanels (1.2.6 - 96) <4AE7E5AE-55B3-37FA-9BDE-B23147ADA2E9> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/CommonPanels.framework/Versions/A/CommonPanels
0x7fff8d302000 - 0x7fff8d303ff3 com.apple.print.framework.Print (10.0 - 266) <3E85F70C-D7D4-34E1-B88A-C1F503F99CDA> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Print.framework/Versions/A/Print
0x7fff8d340000 - 0x7fff8d4befff com.apple.UIFoundation (1.0 - 436.1) <AABB5267-E7B7-3D75-B051-E665BDA8DEF4> /System/Library/PrivateFrameworks/UIFoundation.framework/Versions/A/UIFoundation
0x7fff8d5f2000 - 0x7fff8d661fff com.apple.SearchKit (1.4.0 - 1.4.0) <F159A888-34CA-36F1-AC8E-EB1B38C9DFB3> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/SearchKit.framework/Versions/A/SearchKit
0x7fff8d662000 - 0x7fff8d77ffff libsqlite3.dylib (216.4) <DC3D59E7-91A3-374F-957C-6699729CD82B> /usr/lib/libsqlite3.dylib
0x7fff8d7b0000 - 0x7fff8dcd2fff com.apple.QuartzComposer (5.1 - 334) <80235264-CA1B-3E3F-96F7-5F6F52FDC5B6> /System/Library/Frameworks/Quartz.framework/Versions/A/Frameworks/QuartzComposer.framework/Versions/A/QuartzComposer
0x7fff8dcd3000 - 0x7fff8dcd8fff com.apple.MediaAccessibility (1.0 - 79) <C5E61B45-1967-3602-A48C-31E132B998B2> /System/Library/Frameworks/MediaAccessibility.framework/Versions/A/MediaAccessibility
0x7fff8dd55000 - 0x7fff8dda7fff com.apple.AppleVAFramework (5.0.32 - 5.0.32) <4F5F5CD6-631F-3C97-AA62-7DF19BD5EC15> /System/Library/PrivateFrameworks/AppleVA.framework/Versions/A/AppleVA
0x7fff8dda8000 - 0x7fff8ddf9fff com.apple.audio.CoreAudio (4.3.0 - 4.3.0) <EA7D4F3B-062B-3C81-A98C-C89264D00D48> /System/Library/Frameworks/CoreAudio.framework/Versions/A/CoreAudio
0x7fff8ddfa000 - 0x7fff8ea23ff7 com.apple.AppKit (6.9 - 1404.47) <F3411F6E-DD87-34D0-8C68-C69B2205E41D> /System/Library/Frameworks/AppKit.framework/Versions/C/AppKit
0x7fff8ea24000 - 0x7fff8ea25ff7 libodfde.dylib (23) <F84CB160-D638-3190-B6F5-A262E9AF09F6> /usr/lib/libodfde.dylib
0x7fff8ea26000 - 0x7fff8eadfff7 libvMisc.dylib (563.5) <BF612F7D-FA3B-3F9F-8BE7-8D1BCB21ECC5> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libvMisc.dylib
0x7fff8eb78000 - 0x7fff8eba6ff7 com.apple.CoreServicesInternal (248.2 - 248.2) <6E111F0A-D7F1-3738-ADE7-CF983BD4EC8B> /System/Library/PrivateFrameworks/CoreServicesInternal.framework/Versions/A/CoreServicesInternal
0x7fff8ed58000 - 0x7fff8ed95ff3 com.apple.bom (14.0 - 193.7) <9B8AE30B-24A3-37AB-B04E-4CE67AED4775> /System/Library/PrivateFrameworks/Bom.framework/Versions/A/Bom
0x7fff8ed96000 - 0x7fff8ee41fff com.apple.PDFKit (3.1 - 3.1) <27AF3C85-1C0B-389C-856C-2E527620C195> /System/Library/Frameworks/Quartz.framework/Versions/A/Frameworks/PDFKit.framework/Versions/A/PDFKit
0x7fff8eea4000 - 0x7fff8eec3ff7 com.apple.framework.Apple80211 (11.0 - 1121.34.2) <90477FAE-B835-3931-80FB-FDFF02B21D9D> /System/Library/PrivateFrameworks/Apple80211.framework/Versions/A/Apple80211
0x7fff8eec4000 - 0x7fff8eeedff7 libxpc.dylib (765.70.1) <4FB1311F-4032-3F56-BF0B-CFF45D78FB01> /usr/lib/system/libxpc.dylib
0x7fff8eeee000 - 0x7fff8efceff7 unorm8_rgba.dylib (2.7.3) <9EB6C346-CFF6-32D7-B4A1-2409DFBCB216> /System/Library/Frameworks/OpenCL.framework/Versions/A/Libraries/ImageFormats/unorm8_rgba.dylib
0x7fff8efcf000 - 0x7fff8f0beff7 libxml2.2.dylib (29.14) <02077D26-0AB0-347A-8AF2-FADE3CFC296C> /usr/lib/libxml2.2.dylib
0x7fff8f0bf000 - 0x7fff8f0f2ff7 com.apple.MediaKit (16 - 809) <BF8032FE-6645-37F6-A622-BC7EEE3EAABF> /System/Library/PrivateFrameworks/MediaKit.framework/Versions/A/MediaKit
0x7fff8f128000 - 0x7fff8f130fff com.apple.AppleSRP (5.0 - 1) <840A5C20-6452-36BB-ACF7-29BA6CBF7C48> /System/Library/PrivateFrameworks/AppleSRP.framework/Versions/A/AppleSRP
0x7fff8f134000 - 0x7fff8f13cfff libcopyfile.dylib (127) <A48637BC-F3F2-34F2-BB68-4C65FD012832> /usr/lib/system/libcopyfile.dylib
0x7fff8f140000 - 0x7fff8f146fff com.apple.IOAccelerator (205.11 - 205.11) <3E86AB1B-C1CF-307D-900F-385C8D8C534A> /System/Library/PrivateFrameworks/IOAccelerator.framework/Versions/A/IOAccelerator
0x7fff8f147000 - 0x7fff8f15cff3 libCGInterfaces.dylib (317.9) <473434E1-5269-3077-A047-D05E024AE631> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vImage.framework/Versions/A/Libraries/libCGInterfaces.dylib
0x7fff8f15d000 - 0x7fff8f177ff3 liblzma.5.dylib (10) <CC03591B-FA57-3CA5-AC81-0D76033AC0CE> /usr/lib/liblzma.5.dylib
0x7fff8f17a000 - 0x7fff8f17cfff libCGXType.A.dylib (970) <A931200A-B248-39EF-8A8B-311D881BE372> /System/Library/Frameworks/CoreGraphics.framework/Versions/A/Resources/libCGXType.A.dylib
0x7fff8f18e000 - 0x7fff8f19cfff com.apple.opengl (12.1.0 - 12.1.0) <12EBDE6A-2F44-3429-8337-2BB36870BFD8> /System/Library/Frameworks/OpenGL.framework/Versions/A/OpenGL
0x7fff8f1ae000 - 0x7fff8f4ecff7 com.apple.WebKit (11601 - 11601.7.8) <58A8B070-2AE4-3909-AE1D-7A7DF34AA268> /System/Library/Frameworks/WebKit.framework/Versions/A/WebKit
0x7fff8f51e000 - 0x7fff8f56afff com.apple.print.framework.PrintCore (11.2 - 472.2) <5AE8AA6B-CE09-397D-B0D4-0F9CCBF1F77D> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/PrintCore.framework/Versions/A/PrintCore
0x7fff8f56b000 - 0x7fff8f7d8fff com.apple.imageKit (2.6 - 932) <FAE317B8-DF15-3096-AFAC-464913BF2F3B> /System/Library/Frameworks/Quartz.framework/Versions/A/Frameworks/ImageKit.framework/Versions/A/ImageKit
0x7fff8f7d9000 - 0x7fff8f7eaff7 libz.1.dylib (61.20.1) <B3EBB42F-48E3-3287-9F0D-308E04D407AC> /usr/lib/libz.1.dylib
0x7fff8f7eb000 - 0x7fff8f7ebfff com.apple.ApplicationServices (48 - 48) <ADD57D3A-142F-3EF5-BFD8-EACD82164884> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/ApplicationServices
0x7fff8f7ec000 - 0x7fff8f81eff7 libTrueTypeScaler.dylib (158.7) <020536E5-C032-30B5-864C-920D5F7DB6DA> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framework/Versions/A/Resources/libTrueTypeScaler.dylib
0x7fff8f81f000 - 0x7fff8f836ff7 libsystem_coretls.dylib (83.40.5) <C90DAE38-4082-381C-A185-2A6A8B677628> /usr/lib/system/libsystem_coretls.dylib
0x7fff8fad3000 - 0x7fff8ff01fff com.apple.vision.FaceCore (3.3.1 - 3.3.1) <E54028EA-4217-3078-A2B1-C52E4214D59E> /System/Library/PrivateFrameworks/FaceCore.framework/Versions/A/FaceCore
0x7fff8ff02000 - 0x7fff8ff33ff7 libtidy.A.dylib (15.17) <6859415D-7A43-384E-ABDD-AA6B2AA9FDCD> /usr/lib/libtidy.A.dylib
0x7fff8ff6b000 - 0x7fff8ff6cfff libsystem_blocks.dylib (65) <1244D9D5-F6AA-35BB-B307-86851C24B8E5> /usr/lib/system/libsystem_blocks.dylib
0x7fff8ff6d000 - 0x7fff8ff78fff libGL.dylib (12.1) <70D51643-04AC-3400-8F11-A6FC25985289> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGL.dylib
0x7fff90078000 - 0x7fff9007dfff com.apple.DiskArbitration (2.7 - 2.7) <8CB47F4A-0FD2-343A-93C8-965174F6F24F> /System/Library/Frameworks/DiskArbitration.framework/Versions/A/DiskArbitration
0x7fff9007e000 - 0x7fff90093fff com.apple.ToneKit (1.0 - 1) <6D5AD263-308F-3F70-8D86-7027569D2694> /System/Library/PrivateFrameworks/ToneKit.framework/Versions/A/ToneKit
0x7fff90094000 - 0x7fff900faff7 libsystem_network.dylib (583.50.1) <B52DAB73-92DC-3DA7-B9F4-B899D66445C1> /usr/lib/system/libsystem_network.dylib
0x7fff900fb000 - 0x7fff900fbfff com.apple.CoreServices (728.13 - 728.13) <CFE3EE73-A3F5-3824-9210-0790C07120F3> /System/Library/Frameworks/CoreServices.framework/Versions/A/CoreServices
0x7fff900fc000 - 0x7fff9010bfe7 com.apple.AppleFSCompression (81.20.2 - 1.0) <2FE122A9-5265-320A-9600-FFC5CE4DE197> /System/Library/PrivateFrameworks/AppleFSCompression.framework/Versions/A/AppleFSCompression
0x7fff9010f000 - 0x7fff90118fff com.apple.icloud.FindMyDevice (1.0 - 1) <B9C741F2-6FAC-3BA7-B6E0-9A910C6E8D4E> /System/Library/PrivateFrameworks/FindMyDevice.framework/Versions/A/FindMyDevice
0x7fff90131000 - 0x7fff901c7fff com.apple.ColorSync (4.9.0 - 4.9.0) <8FC37E20-6579-3CB2-9D49-BC39FC38DF87> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ColorSync.framework/Versions/A/ColorSync
0x7fff907bc000 - 0x7fff90860fff com.apple.Bluetooth (4.4.6 - 4.4.6f1) <D8ED953B-AD7D-3FE2-8631-E9CBCF6EBAB9> /System/Library/Frameworks/IOBluetooth.framework/Versions/A/IOBluetooth
0x7fff90861000 - 0x7fff90861fff libmetal_timestamp.dylib (600.0.44.2) <DEEA1127-7A5D-3EF2-A4B2-AE125CBA5DB5> /System/Library/PrivateFrameworks/GPUCompiler.framework/libmetal_timestamp.dylib
0x7fff90862000 - 0x7fff90868fff com.apple.XPCService (2.0 - 1) <5E2122D6-FFA2-3552-BF16-9FD3F36B40DB> /System/Library/PrivateFrameworks/XPCService.framework/Versions/A/XPCService
0x7fff908b4000 - 0x7fff90a7dff7 com.apple.ImageIO.framework (3.3.0 - 1462) <1D8FF28C-5DBB-3D23-8CF0-75269C1CE84D> /System/Library/Frameworks/ImageIO.framework/Versions/A/ImageIO
0x7fff90a7e000 - 0x7fff90a9aff7 libsystem_malloc.dylib (67.40.1) <5748E8B2-F81C-34C6-8B13-456213127678> /usr/lib/system/libsystem_malloc.dylib
0x7fff90add000 - 0x7fff90adefff libsystem_secinit.dylib (20) <32B1A8C6-DC84-3F4F-B8CE-9A52B47C3E6B> /usr/lib/system/libsystem_secinit.dylib
0x7fff90adf000 - 0x7fff90ae4fff com.apple.ImageCapture (9.0 - 9.0) <ACECF0B7-7D92-3A22-BF47-E8FADF4C5378> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/ImageCapture.framework/Versions/A/ImageCapture
0x7fff90b53000 - 0x7fff90b7ffff com.apple.framework.SystemAdministration (1.0 - 1.0) <1318B6A5-FFC3-3615-914D-95CBFE5BA727> /System/Library/PrivateFrameworks/SystemAdministration.framework/Versions/A/SystemAdministration
0x7fff90b80000 - 0x7fff90b8cfff com.apple.CacheDelete (1.0 - 1) <678B521D-5B50-3137-A972-33F2DF1D7A5A> /System/Library/PrivateFrameworks/CacheDelete.framework/Versions/A/CacheDelete
0x7fff90ba6000 - 0x7fff90babff7 libmacho.dylib (875.1) <318264FA-58F1-39D8-8285-1F6254EE410E> /usr/lib/system/libmacho.dylib
0x7fff90c33000 - 0x7fff90c8eff7 libTIFF.dylib (1463) <5C02D055-02D3-37FE-AABC-487301080941> /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libTIFF.dylib
0x7fff90c9e000 - 0x7fff90ca7ff3 libsystem_notify.dylib (150.40.1) <D48BDE34-0F7E-34CA-A0FF-C578E39987CC> /usr/lib/system/libsystem_notify.dylib
0x7fff90d48000 - 0x7fff90d50fff com.apple.CoreServices.FSEvents (1223.10.1 - 1223.10.1) <7F5B7A23-BC1D-3FA9-A9B8-D534F1E1979A> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/FSEvents.framework/Versions/A/FSEvents
0x7fff90d51000 - 0x7fff90da3fff com.apple.ImageCaptureCore (7.0 - 7.0) <9F3123D8-29D2-332F-AD6B-AB9BF1A58022> /System/Library/Frameworks/ImageCaptureCore.framework/Versions/A/ImageCaptureCore
0x7fff90da4000 - 0x7fff90dacfef libcldcpuengine.dylib (2.7.3) <745C41A3-CEC0-3BF5-91DC-FCB140A3DACE> /System/Library/Frameworks/OpenCL.framework/Versions/A/Libraries/libcldcpuengine.dylib
0x7fff90dad000 - 0x7fff90dafff7 libRadiance.dylib (1463) <11392BBE-6DAC-3ADD-A0C0-CD653B9AEDE3> /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libRadiance.dylib
0x7fff90db0000 - 0x7fff90dc0fff libSparseBLAS.dylib (1162.2) <6F591A0F-80D0-384D-8304-B035C4ED1BBD> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libSparseBLAS.dylib
0x7fff90df2000 - 0x7fff90e20ff7 libsandbox.1.dylib (460.60.3) <C8B9F633-EA0C-35CF-9207-1AFDF694EEAD> /usr/lib/libsandbox.1.dylib
0x7fff90e86000 - 0x7fff90ea3ff7 com.apple.pluginkit.framework (1.0 - 1) <0BA96479-0451-3DA9-A2AC-FE1D86D383AB> /System/Library/PrivateFrameworks/PlugInKit.framework/Versions/A/PlugInKit
0x7fff90ea8000 - 0x7fff90ec3fff com.apple.aps.framework (4.0 - 4.0) <CAD47B6E-A581-3B35-885B-67B206F41D5E> /System/Library/PrivateFrameworks/ApplePushService.framework/Versions/A/ApplePushService
0x7fff91134000 - 0x7fff9113cfff com.apple.frameworks.CoreDaemon (1.3 - 1.3) <CC53DC12-9231-3C4F-921B-9A770D463323> /System/Library/PrivateFrameworks/CoreDaemon.framework/Versions/B/CoreDaemon
0x7fff91181000 - 0x7fff91186ff3 libunwind.dylib (35.3) <F6EB48E5-4D12-359A-AB54-C937FBBE9043> /usr/lib/system/libunwind.dylib
0x7fff91187000 - 0x7fff911b0ff7 libxslt.1.dylib (14.5) <8E03110E-1529-3BE8-B5F4-052A47A1674C> /usr/lib/libxslt.1.dylib
0x7fff91325000 - 0x7fff9144cfff com.apple.LaunchServices (728.13 - 728.13) <91147A89-9D0D-3272-AD05-48E2835BD8D5> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/LaunchServices.framework/Versions/A/LaunchServices
0x7fff9144d000 - 0x7fff9144efff libDiagnosticMessagesClient.dylib (100) <4243B6B4-21E9-355B-9C5A-95A216233B96> /usr/lib/libDiagnosticMessagesClient.dylib
0x7fff9144f000 - 0x7fff916e9ff3 com.apple.security (7.0 - 57337.60.3) <4BF5CF26-6E34-35EC-8D41-58ED65F9BFB8> /System/Library/Frameworks/Security.framework/Versions/A/Security
0x7fff916ea000 - 0x7fff91708ff7 libsystem_kernel.dylib (3248.70.3) <69D68230-7793-3D11-B49E-BA3A6D5137B8> /usr/lib/system/libsystem_kernel.dylib
0x7fff918ca000 - 0x7fff918f5ff7 com.apple.AddressBook.ContactsFoundation (8.0 - 2137.1) <BAE70E9D-BCC8-3650-B554-6D646388EDEF> /System/Library/PrivateFrameworks/ContactsFoundation.framework/Versions/A/ContactsFoundation
0x7fff918f6000 - 0x7fff91901ff7 libcommonCrypto.dylib (60075.50.1) <93732261-34B4-3914-B7A2-90A81A182DBA> /usr/lib/system/libcommonCrypto.dylib
0x7fff91908000 - 0x7fff91937ffb libsystem_m.dylib (3105) <08E1A4B2-6448-3DFE-A58C-ACC7335BE7E4> /usr/lib/system/libsystem_m.dylib
0x7fff91c5b000 - 0x7fff91e1bffb libBLAS.dylib (1162.2) <B4C21826-5EB3-3C6D-B75D-CA4886E2B6A6> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libBLAS.dylib
0x7fff91e48000 - 0x7fff91e53ff7 libChineseTokenizer.dylib (16) <79B8C67A-3061-3C78-92CD-4650719E68D4> /usr/lib/libChineseTokenizer.dylib
0x7fff91e54000 - 0x7fff91ec2ff7 com.apple.ApplicationServices.ATS (377 - 394.4) <CB64C2B7-828A-3C4C-8F3C-72B78630CD94> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framework/Versions/A/ATS
0x7fff91ec3000 - 0x7fff91eeeffb libarchive.2.dylib (33.20.2.1.1) <BC764A1E-573A-3D95-A3CC-1758935ADC56> /usr/lib/libarchive.2.dylib
0x7fff91eef000 - 0x7fff91f00ff7 libsystem_trace.dylib (201.10.3) <4F626911-011B-3E9C-8D61-C5EBA79013F0> /usr/lib/system/libsystem_trace.dylib
0x7fff91f0a000 - 0x7fff91f20ff7 libLinearAlgebra.dylib (1162.2) <FFE54EDF-F06F-3C0A-864A-4CA7BBFD4B2D> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libLinearAlgebra.dylib
0x7fff91f21000 - 0x7fff91f23ff7 libsystem_configuration.dylib (802.40.13) <3DEB7DF9-6804-37E1-BC83-0166882FF0FF> /usr/lib/system/libsystem_configuration.dylib
0x7fff91f24000 - 0x7fff91f27fff libspindump.dylib (197.1) <B86EE257-4429-32E9-B98D-B12BFF2A373B> /usr/lib/libspindump.dylib
0x7fff91f28000 - 0x7fff91f76fff libcurl.4.dylib (90) <12E01E4B-24C9-394C-9D2C-85CF85D5F459> /usr/lib/libcurl.4.dylib
0x7fff91f77000 - 0x7fff91f79fff com.apple.SecCodeWrapper (4.0 - 261.40.2) <1F832591-59A8-3B3F-943F-D6D827463782> /System/Library/PrivateFrameworks/SecCodeWrapper.framework/Versions/A/SecCodeWrapper
0x7fff91f7a000 - 0x7fff91fa4ff7 GLRendererFloat (12.1) <0412B850-BB25-33B1-AF0D-8E6297D4620E> /System/Library/Frameworks/OpenGL.framework/Versions/A/Resources/GLRendererFloat.bundle/GLRendererFloat
0x7fff91fe7000 - 0x7fff9200cff7 libPng.dylib (1463) <17F67BF3-4A78-3587-AAE4-E50A71BDD4CB> /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libPng.dylib
0x7fff9200d000 - 0x7fff9200ffff com.apple.EFILogin (2.0 - 2) <38150198-DD7F-3C73-BCAA-C74BB376393A> /System/Library/PrivateFrameworks/EFILogin.framework/Versions/A/EFILogin
0x7fff92010000 - 0x7fff92037fff com.apple.ChunkingLibrary (167 - 167) <AD7F285C-005E-36BB-98A3-5826413533BE> /System/Library/PrivateFrameworks/ChunkingLibrary.framework/Versions/A/ChunkingLibrary
0x7fff92064000 - 0x7fff9206cfef libsystem_platform.dylib (74.40.2) <29A905EF-6777-3C33-82B0-6C3A88C4BA15> /usr/lib/system/libsystem_platform.dylib
0x7fff9206d000 - 0x7fff92084ff7 libsystem_asl.dylib (323.50.1) <41F8E11F-1BD0-3F1D-BA3A-AA1577ED98A9> /usr/lib/system/libsystem_asl.dylib
0x7fff92127000 - 0x7fff924a5ff3 com.apple.VideoToolbox (1.0 - 1731.15.207) <6C7C261F-CB65-3AF1-92E7-16ACAD371EF4> /System/Library/Frameworks/VideoToolbox.framework/Versions/A/VideoToolbox
0x7fff9250a000 - 0x7fff9251bfff libcmph.dylib (6) <BA4BF2C6-7F4E-33B8-9DD7-619C9EB83ECF> /usr/lib/libcmph.dylib
0x7fff92524000 - 0x7fff92541ff7 com.apple.AppleVPAFramework (2.1.2 - 2.1.2) <707C6ED6-B8C0-38D4-B45A-7F2F689BD157> /System/Library/PrivateFrameworks/AppleVPA.framework/Versions/A/AppleVPA
0x7fff92813000 - 0x7fff9296eff3 com.apple.WebKitLegacy (11601 - 11601.7.8) <F41E6CAF-1157-3868-9FAC-D074FCE74BB9> /System/Library/Frameworks/WebKit.framework/Versions/A/Frameworks/WebKitLegacy.framework/Versions/A/WebKitLegacy
0x7fff9330e000 - 0x7fff93353ff7 com.apple.coreservices.SharedFileList (24.4 - 24.5) <1D2AD77B-778F-3253-A295-3D0A32A8121C> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/SharedFileList.framework/Versions/A/SharedFileList
0x7fff93354000 - 0x7fff933cbfeb libcorecrypto.dylib (335.50.1) <B5C05FD7-A540-345A-87BF-8E41848A3C17> /usr/lib/system/libcorecrypto.dylib
0x7fff933cc000 - 0x7fff933ccfff com.apple.Accelerate (1.10 - Accelerate 1.10) <5831771A-C1C3-3625-9FE9-2CCB6B2E7EE1> /System/Library/Frameworks/Accelerate.framework/Versions/A/Accelerate
0x7fff933cd000 - 0x7fff933d8fff libcsfde.dylib (517.50.1) <52F0DB6A-13B8-355E-ADFD-72834D3CA183> /usr/lib/libcsfde.dylib
0x7fff933d9000 - 0x7fff93523ff7 com.apple.coreui (2.1 - 366.1) <8138636F-A0A7-31C7-896C-5F5747FA1B2A> /System/Library/PrivateFrameworks/CoreUI.framework/Versions/A/CoreUI
0x7fff93529000 - 0x7fff9361bff7 libJP2.dylib (1463) <D107FF52-7FD6-3A5E-B40E-F3D0F1FF651D> /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libJP2.dylib
0x7fff9361c000 - 0x7fff9361cfff com.apple.Accelerate.vecLib (3.10 - vecLib 3.10) <848125D3-AF14-3526-8745-FFCDB200CD76> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/vecLib
0x7fff9361d000 - 0x7fff93630fff com.apple.SafariServices.framework (11604 - 11604.1.38.1.7) <5B649F4B-09D3-3AAC-9801-B6084B91E7D7> /System/Library/PrivateFrameworks/SafariServices.framework/Versions/A/SafariServices
0x7fff9373e000 - 0x7fff93747ff7 libsystem_pthread.dylib (138.10.4) <3DD1EF4C-1D1B-3ABF-8CC6-B3B1CEEE9559> /usr/lib/system/libsystem_pthread.dylib
0x7fff93748000 - 0x7fff939defff libmecabra.dylib (696.5) <EF6C0BD4-5FE8-34FB-8ADF-69A53CEC97A9> /usr/lib/libmecabra.dylib
0x7fff939eb000 - 0x7fff93d3fff7 com.apple.Foundation (6.9 - 1259.31) <EBB5BE3F-1FE9-3231-B53B-149CDEE8BCA9> /System/Library/Frameworks/Foundation.framework/Versions/C/Foundation
0x7fff93d8e000 - 0x7fff93e16fff com.apple.CoreSymbolication (3.1 - 58048.1) <C1A1A8DB-8A51-3A21-865A-3CEF22A0E67A> /System/Library/PrivateFrameworks/CoreSymbolication.framework/Versions/A/CoreSymbolication
0x7fff93e2b000 - 0x7fff93e2effb libdyld.dylib (360.22) <7C1BBC59-FA8A-3BDF-B209-02167832E7D1> /usr/lib/system/libdyld.dylib
0x7fff93e2f000 - 0x7fff93fbbff7 libGLProgrammability.dylib (12.1) <6D4C193C-5F7B-3E82-81D9-D14D25BBD962> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGLProgrammability.dylib
0x7fff93fe4000 - 0x7fff93fedff7 com.apple.CommonAuth (4.0 - 2.0) <4B8673E1-3697-3FE2-8D30-AC7AC5D4F8BF> /System/Library/PrivateFrameworks/CommonAuth.framework/Versions/A/CommonAuth
0x7fff93fee000 - 0x7fff94001fff com.apple.contacts.ContactsPersistence (1.0 - 2137.1) <71232F20-11BD-370D-9F43-F262BFE46C93> /System/Library/PrivateFrameworks/ContactsPersistence.framework/Versions/A/ContactsPersistence
0x7fff94002000 - 0x7fff9401bfe7 libcompression.dylib (28) <F83F421D-115D-3457-A9AA-1BEB5070A30B> /usr/lib/libcompression.dylib
0x7fff9401c000 - 0x7fff94027fff com.apple.AppSandbox (4.0 - 261.40.2) <52766210-B6EB-3B73-AB1B-42E0A9AD2EE8> /System/Library/PrivateFrameworks/AppSandbox.framework/Versions/A/AppSandbox
0x7fff94832000 - 0x7fff94835ffb libScreenReader.dylib (426.42) <16FC79D1-4573-3E90-945F-CBA22D5185FD> /usr/lib/libScreenReader.dylib
0x7fff94836000 - 0x7fff9483efff libMatch.1.dylib (27) <3AC0BFB8-7E69-3DBE-A175-7F3946FC4554> /usr/lib/libMatch.1.dylib
0x7fff94840000 - 0x7fff94919fff com.apple.CoreMedia (1.0 - 1731.15.207) <70CAD4A7-3F8B-3767-A420-98BE1062C230> /System/Library/Frameworks/CoreMedia.framework/Versions/A/CoreMedia
0x7fff95179000 - 0x7fff951c7ff7 libstdc++.6.dylib (104.1) <76E2AFB1-07E5-3F19-B692-F6E21B7E470D> /usr/lib/libstdc++.6.dylib
0x7fff95422000 - 0x7fff95960ff7 com.apple.MediaToolbox (1.0 - 1731.15.207) <63AD3FB7-BAD3-3040-8A99-843033F24CF6> /System/Library/Frameworks/MediaToolbox.framework/Versions/A/MediaToolbox
0x7fff95983000 - 0x7fff95b2fff7 com.apple.avfoundation (2.0 - 1046.9.12) <41BDD03F-5545-3B9F-8DD7-7106485BAE8B> /System/Library/Frameworks/AVFoundation.framework/Versions/A/AVFoundation
0x7fff95b35000 - 0x7fff95b59ff7 libJPEG.dylib (1463) <11227D36-EA80-3D5B-A7D3-F2AC6C7497EC> /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libJPEG.dylib
0x7fff95cc7000 - 0x7fff95dadff7 libcrypto.0.9.8.dylib (59.60.1) <D68067AD-D1E0-3196-9796-51BE9B969C8E> /usr/lib/libcrypto.0.9.8.dylib
0x7fff95dae000 - 0x7fff95e0efff com.apple.QuickLookFramework (5.0 - 696.7) <ECD33169-5EB1-3783-AF9E-1AB9240F8358> /System/Library/Frameworks/QuickLook.framework/Versions/A/QuickLook
0x7fff96029000 - 0x7fff96042fff com.apple.openscripting (1.7.1 - 169.1) <36EBF6A7-334A-3197-838F-E8C7B27FCDBB> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/OpenScripting.framework/Versions/A/OpenScripting
0x7fff96049000 - 0x7fff96095ffb com.apple.HIServices (1.22 - 550) <6B76B41C-CF5A-34C4-89F4-EFD7CA3D1C9D> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/HIServices.framework/Versions/A/HIServices
0x7fff96096000 - 0x7fff960b0fff com.apple.Kerberos (3.0 - 1) <1B4744BF-E5AE-38E2-AA56-E22D3270F2E8> /System/Library/Frameworks/Kerberos.framework/Versions/A/Kerberos
0x7fff960b1000 - 0x7fff960d8fff com.apple.shortcut (2.16 - 93) <2BA6DF3E-04C7-39C8-B311-3413E9FC9022> /System/Library/PrivateFrameworks/Shortcut.framework/Versions/A/Shortcut
0x7fff9610d000 - 0x7fff96122fff com.apple.AppContainer (4.0 - 261.40.2) <F220E702-1C00-3BD2-9943-C7E75C3B4418> /System/Library/PrivateFrameworks/AppContainer.framework/Versions/A/AppContainer
0x7fff96123000 - 0x7fff961dcff7 com.apple.cloudkit.CloudKit (482.29 - 482.29) <E235B37E-1491-3857-BDE8-38450D4FE8D0> /System/Library/Frameworks/CloudKit.framework/Versions/A/CloudKit
0x7fff9623d000 - 0x7fff962ccff7 libCoreStorage.dylib (517.50.1) <E6283FE9-B5AC-3110-8D4C-8E2BF185983E> /usr/lib/libCoreStorage.dylib
0x7fff96337000 - 0x7fff9637cff3 libFontRegistry.dylib (155.2) <A70DD497-35F3-34DA-9C19-F4B90080E961> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framework/Versions/A/Resources/libFontRegistry.dylib
0x7fff9638a000 - 0x7fff967b4fff com.apple.ModelIO (1.0 - 1) <8838E0E1-ACB3-3CE8-ABDC-C787D8B3F247> /System/Library/Frameworks/ModelIO.framework/Versions/A/ModelIO
0x7fff967b7000 - 0x7fff967cefff libmarisa.dylib (4) <E4919B03-D9BD-3AF8-B436-C415C98E3F0A> /usr/lib/libmarisa.dylib
0x7fff967d4000 - 0x7fff96884fff com.apple.backup.framework (1.7.4 - 1.7.4) <F304E9D1-991A-379E-9659-BF85C35B4808> /System/Library/PrivateFrameworks/Backup.framework/Versions/A/Backup
0x7fff968c1000 - 0x7fff968e0ff7 com.apple.contacts.vCard (1.0 - 2137.1) <41529BD9-1BCC-3A62-92BA-2A7110867355> /System/Library/PrivateFrameworks/vCard.framework/Versions/A/vCard
0x7fff968ec000 - 0x7fff96af7fff libFosl_dynamic.dylib (16.24) <5F9DB82D-FD4B-3952-8531-CE020F93ED49> /usr/lib/libFosl_dynamic.dylib
0x7fff96af8000 - 0x7fff96b21fff com.apple.ProtectedCloudStorage (1.0 - 1) <7436B2B3-943A-3500-B099-80F133B3E002> /System/Library/PrivateFrameworks/ProtectedCloudStorage.framework/Versions/A/ProtectedCloudStorage
0x7fff96c6c000 - 0x7fff96c70fff com.apple.LoginUICore (3.2 - 3.2) <5524E4BC-4700-39F4-AF06-E53322712EE0> /System/Library/PrivateFrameworks/LoginUIKit.framework/Versions/A/Frameworks/LoginUICore.framework/Versions/A/LoginUICore
0x7fff96c96000 - 0x7fff96cc7fff com.apple.GSS (4.0 - 2.0) <B490333A-3B3E-397A-AD75-68846E9A9140> /System/Library/Frameworks/GSS.framework/Versions/A/GSS
0x7fff96cc8000 - 0x7fff96cd4fff com.apple.speech.synthesis.framework (5.4.12 - 5.4.12) <71DA00B8-5EA2-326B-8814-59DB25512F65> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/SpeechSynthesis.framework/Versions/A/SpeechSynthesis
0x7fff96cd7000 - 0x7fff96e82ffb GLEngine (12.1) <278B3208-B0D0-3FAE-AC23-A4FA06837311> /System/Library/Frameworks/OpenGL.framework/Versions/A/Resources/GLEngine.bundle/GLEngine
0x7fff96e83000 - 0x7fff96e83fff com.apple.Carbon (154 - 157) <8F6ED602-5943-3E29-A793-BC331E2C183D> /System/Library/Frameworks/Carbon.framework/Versions/A/Carbon
0x7fff96e84000 - 0x7fff96e92fff com.apple.ToneLibrary (1.0 - 1) <AF05AF34-9BC4-3BA6-81C1-7420F22C9D7D> /System/Library/PrivateFrameworks/ToneLibrary.framework/Versions/A/ToneLibrary
0x7fff96ea1000 - 0x7fff96ed1ff3 com.apple.CoreAVCHD (5.8.0 - 5800.4.2) <4AAFB1C4-3708-30F9-ACFA-90564347204C> /System/Library/PrivateFrameworks/CoreAVCHD.framework/Versions/A/CoreAVCHD
0x7fff97893000 - 0x7fff978d1ff7 libGLImage.dylib (12.1) <BB1F1A93-5101-3906-AB17-8D83FCB200F9> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGLImage.dylib
0x7fff978d2000 - 0x7fff97947fff com.apple.framework.IOKit (2.0.2 - 1179.50.2) <A509D3AE-9D48-31B7-89C7-326A7A2007B2> /System/Library/Frameworks/IOKit.framework/Versions/A/IOKit
0x7fff9794b000 - 0x7fff979ebfff com.apple.ViewBridge (159 - 159) <D8131B7E-DFC9-3FDD-9D56-49821C1D1521> /System/Library/PrivateFrameworks/ViewBridge.framework/Versions/A/ViewBridge
0x7fff97c05000 - 0x7fff97c07fff com.apple.loginsupport (1.0 - 1) <9B2F5F9B-ED38-313F-B798-D2B667BCD6B5> /System/Library/PrivateFrameworks/login.framework/Versions/A/Frameworks/loginsupport.framework/Versions/A/loginsupport
0x7fff97c08000 - 0x7fff97c11ff7 com.apple.DisplayServicesFW (3.0 - 378) <45BE1B99-8E10-32F0-A180-A6B6CB5883AE> /System/Library/PrivateFrameworks/DisplayServices.framework/Versions/A/DisplayServices
0x7fff97c12000 - 0x7fff97c63ff7 libcups.2.dylib (435.2) <91584A40-214D-33E8-A613-CE22289037C8> /usr/lib/libcups.2.dylib
0x7fff97c64000 - 0x7fff97c64fff libenergytrace.dylib (10.40.1) <0A491CA7-3451-3FD5-999A-58AB4362682B> /usr/lib/libenergytrace.dylib
0x7fff97c7f000 - 0x7fff97cb3ff7 com.apple.CoreVideo (1.8 - 191.3) <1AA24A1B-CB84-3F6B-B6DE-11494542649C> /System/Library/Frameworks/CoreVideo.framework/Versions/A/CoreVideo
0x7fff97cb4000 - 0x7fff97cb6ff7 com.apple.xpc.ServiceManagement (1.0 - 1) <B4181284-D588-3A20-93F3-B4FA882BC9A8> /System/Library/Frameworks/ServiceManagement.framework/Versions/A/ServiceManagement
0x7fff97cb7000 - 0x7fff97d0cfff com.apple.AE (701 - 701) <AD492742-F884-386B-A450-FAC281B9FFA4> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/AE.framework/Versions/A/AE
0x7fff97d0d000 - 0x7fff97d4fff7 com.apple.Metal (56.6 - 56.6) <30518711-8D00-3759-AA19-800D3C88E693> /System/Library/Frameworks/Metal.framework/Versions/A/Metal
0x7fff97d50000 - 0x7fff97d51ffb libremovefile.dylib (41) <552EF39E-14D7-363E-9059-4565AC2F894E> /usr/lib/system/libremovefile.dylib
0x7fff97d76000 - 0x7fff97d78ffb libutil.dylib (43) <4C9BFE8B-563B-3EEA-A323-8F4F14E0A46C> /usr/lib/libutil.dylib
0x7fff97d86000 - 0x7fff97d88fff com.apple.CoreDuetDebugLogging (1.0 - 1) <7C932160-AC9C-3173-900F-98138E829CB3> /System/Library/PrivateFrameworks/CoreDuetDebugLogging.framework/Versions/A/CoreDuetDebugLogging
0x7fff97d89000 - 0x7fff97de5fff com.apple.Suggestions (5.0 - 180) <450BCB58-786F-37DC-9AC7-2E3D13198032> /System/Library/PrivateFrameworks/Suggestions.framework/Versions/A/Suggestions
0x7fff97de6000 - 0x7fff97deafff libcache.dylib (75) <9548AAE9-2AB7-3525-9ECE-A2A7C4688447> /usr/lib/system/libcache.dylib
0x7fff97eb4000 - 0x7fff9832afff com.apple.CoreFoundation (6.9 - 1259.11) <B8056BE3-151B-3003-91C9-6720CF04937B> /System/Library/Frameworks/CoreFoundation.framework/Versions/A/CoreFoundation
0x7fff9832b000 - 0x7fff9832eff7 libCoreFSCache.dylib (119.5) <2389D7DA-B8EF-3EB4-AAAF-FBEDE01CDECA> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libCoreFSCache.dylib
0x7fff9832f000 - 0x7fff98343fff com.apple.CoreDuetDaemonProtocol (1.0 - 1) <1D60D60C-914A-3BAB-8607-79F68F4C712E> /System/Library/PrivateFrameworks/CoreDuetDaemonProtocol.framework/Versions/A/CoreDuetDaemonProtocol
0x7fff98371000 - 0x7fff98371fff libOpenScriptingUtil.dylib (169.1) <AD0DAC8A-9849-3077-999F-9AEC6112BDAB> /usr/lib/libOpenScriptingUtil.dylib
0x7fff98372000 - 0x7fff98667fff com.apple.HIToolbox (2.1.1 - 807.2) <36413C45-36AF-34EF-9C0E-F18B31D1E565> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/HIToolbox.framework/Versions/A/HIToolbox
0x7fff98668000 - 0x7fff98670ffb libsystem_dnssd.dylib (625.60.4) <80189998-32B0-316C-B5C5-53857486713D> /usr/lib/system/libsystem_dnssd.dylib
0x7fff98671000 - 0x7fff98747ffb com.apple.DiskImagesFramework (10.11.4 - 417.4) <FB30D069-648F-3FB2-AA55-FC603606C49E> /System/Library/PrivateFrameworks/DiskImages.framework/Versions/A/DiskImages
0x7fff98748000 - 0x7fff98757ffb com.apple.LangAnalysis (1.7.0 - 1.7.0) <18D21123-A3E7-3851-974A-08E5D4540475> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/LangAnalysis.framework/Versions/A/LangAnalysis
0x7fff98e47000 - 0x7fff98e52fff com.apple.DirectoryService.Framework (10.11 - 194) <6F827D0E-0F02-3B09-B2A8-252865EECA7F> /System/Library/Frameworks/DirectoryService.framework/Versions/A/DirectoryService
0x7fff98e6c000 - 0x7fff98e6ffff com.apple.IOSurface (108.2.4 - 108.2.4) <E7A63C0D-2FDA-3BC6-947D-07E3C4A13110> /System/Library/Frameworks/IOSurface.framework/Versions/A/IOSurface
0x7fff9907a000 - 0x7fff9908dfff com.apple.CoreBluetooth (1.0 - 1) <E54CA9A2-A5C6-30C5-9D6E-8472DBA9371E> /System/Library/Frameworks/CoreBluetooth.framework/Versions/A/CoreBluetooth
0x7fff99095000 - 0x7fff9909dfff libsystem_networkextension.dylib (385.40.36) <66095DC7-6539-38F2-95EE-458F15F6D014> /usr/lib/system/libsystem_networkextension.dylib
0x7fff9909e000 - 0x7fff99127ff7 com.apple.PerformanceAnalysis (1.0 - 1) <9C57BB91-46D6-3FB6-A5A2-8DB1CFE86B72> /System/Library/PrivateFrameworks/PerformanceAnalysis.framework/Versions/A/PerformanceAnalysis
0x7fff99128000 - 0x7fff99224fff libFontParser.dylib (158.7) <393EFEA3-42B7-38DA-99DA-D01DEAA734CF> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framework/Versions/A/Resources/libFontParser.dylib
0x7fff993c4000 - 0x7fff9943bff7 com.apple.MMCS (1.3 - 357.1) <549FBEFC-55F7-3101-BF51-A0B1F7CF2B46> /System/Library/PrivateFrameworks/MMCS.framework/Versions/A/MMCS
0x7fff9943c000 - 0x7fff99adbffb com.apple.JavaScriptCore (11601 - 11601.7.8) <38585ADC-1AD4-3BD2-8972-B90344CE57C0> /System/Library/Frameworks/JavaScriptCore.framework/Versions/A/JavaScriptCore
0x7fff99adc000 - 0x7fff99aecff3 com.apple.ProtocolBuffer (1 - 243) <BAE5E5C9-DD59-3BB8-9741-EEFC5E3046EE> /System/Library/PrivateFrameworks/ProtocolBuffer.framework/Versions/A/ProtocolBuffer
0x7fff99b16000 - 0x7fff99b50fff com.apple.QD (3.12 - 302) <0FE53180-2895-3D14-A1E7-F82DE1D106E1> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/QD.framework/Versions/A/QD
0x7fff99f74000 - 0x7fff99f79fff com.apple.TCC (1.0 - 1) <F5EEB2D3-9517-3975-97BE-22CB8E11B8A3> /System/Library/PrivateFrameworks/TCC.framework/Versions/A/TCC
0x7fff99f7a000 - 0x7fff99fa4ff7 libc++abi.dylib (307.4) <D24E06BF-6522-3C4A-BD0C-11C42BA4D8E8> /usr/lib/libc++abi.dylib
0x7fff99fb5000 - 0x7fff99fe4fff com.apple.securityinterface (10.0 - 55065.40.1) <1BB39B19-DD74-347E-A344-0E6781773577> /System/Library/Frameworks/SecurityInterface.framework/Versions/A/SecurityInterface
0x7fff99ff4000 - 0x7fff9a081dd7 com.apple.AppleJPEG (1.0 - 1) <BF7EDBDB-A52D-37F7-BDE4-EAD49310D7A9> /System/Library/PrivateFrameworks/AppleJPEG.framework/Versions/A/AppleJPEG
0x7fff9a082000 - 0x7fff9a190ff3 com.apple.desktopservices (1.10.3 - 1.10.3) <3A6906D4-C0B8-30D1-B589-0466E5E42B69> /System/Library/PrivateFrameworks/DesktopServicesPriv.framework/Versions/A/DesktopServicesPriv
0x7fff9a191000 - 0x7fff9a196ff7 com.apple.AssetCacheServices (14.1 - 14.1) <5F249F84-660A-3E94-B073-6729E7ED56D9> /System/Library/PrivateFrameworks/AssetCacheServices.framework/Versions/A/AssetCacheServices
0x7fff9a197000 - 0x7fff9a1a3fff com.apple.HelpData (2.1.4 - 90) <10608EEC-B613-309C-96E6-5A40AB951FA4> /System/Library/PrivateFrameworks/HelpData.framework/Versions/A/HelpData
0x7fff9a1a4000 - 0x7fff9a372ff3 com.apple.QuartzCore (1.11 - 410.14) <06A2BE20-38CB-3A89-9629-A782829DF977> /System/Library/Frameworks/QuartzCore.framework/Versions/A/QuartzCore
0x7fff9a373000 - 0x7fff9a3e7ff7 com.apple.Heimdal (4.0 - 2.0) <5D365381-8B5E-3259-8867-FC4A7D307BDE> /System/Library/PrivateFrameworks/Heimdal.framework/Versions/A/Heimdal
0x7fff9a3e8000 - 0x7fff9a3ebfff libsystem_sandbox.dylib (460.60.3) <2DDCB4AF-3037-34E5-A451-6846AFB9B85C> /usr/lib/system/libsystem_sandbox.dylib
0x7fff9a3ec000 - 0x7fff9a432ff7 libauto.dylib (186) <999E610F-41FC-32A3-ADCA-5EC049B65DFB> /usr/lib/libauto.dylib
0x7fff9a4a5000 - 0x7fff9a72cfff com.apple.CFNetwork (760.6.5 - 760.6.5) <8A36BBA6-F100-3F39-9711-2FA49D412987> /System/Library/Frameworks/CFNetwork.framework/Versions/A/CFNetwork
0x7fff9a740000 - 0x7fff9a744fff libpam.2.dylib (20) <CFCD19BD-87BC-3F2B-BB1C-4C23E8E55F1A> /usr/lib/libpam.2.dylib
0x7fff9a74e000 - 0x7fff9a834fef unorm8_bgra.dylib (2.7.3) <B315AE9C-9E09-3D9F-9513-EC2195908516> /System/Library/Frameworks/OpenCL.framework/Versions/A/Libraries/ImageFormats/unorm8_bgra.dylib
0x7fff9a835000 - 0x7fff9a8a0ff7 com.apple.framework.CoreWLAN (11.0 - 1101.20) <3B35C543-7FCE-333F-80C1-432FA41DDCDE> /System/Library/Frameworks/CoreWLAN.framework/Versions/A/CoreWLAN
0x7fff9a9ac000 - 0x7fff9adaefff libLAPACK.dylib (1162.2) <42238ED4-6B7A-39D0-BFF2-304A0C287213> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libLAPACK.dylib
0x7fff9adaf000 - 0x7fff9ae67ff7 com.apple.CoreDuet (1.0 - 1) <FC1EAEE1-73A4-3B13-A634-1D2A94D0C0B7> /System/Library/PrivateFrameworks/CoreDuet.framework/Versions/A/CoreDuet
0x7fff9ae68000 - 0x7fff9ae8cfff com.apple.quartzfilters (1.10.0 - 1.10.0) <F5C482E2-5AFB-3959-8C01-C149D48E7583> /System/Library/Frameworks/Quartz.framework/Versions/A/Frameworks/QuartzFilters.framework/Versions/A/QuartzFilters
0x7fff9aec2000 - 0x7fff9afadff7 com.apple.QuickLookUIFramework (5.0 - 696.7) <5A4AAFEC-D38C-3DA0-9361-CBF1D4C6B376> /System/Library/Frameworks/Quartz.framework/Versions/A/Frameworks/QuickLookUI.framework/Versions/A/QuickLookUI
0x7fff9afae000 - 0x7fff9afaffff com.apple.TrustEvaluationAgent (2.0 - 25) <0239494E-FEFE-39BC-9FC7-E251BA5128F1> /System/Library/PrivateFrameworks/TrustEvaluationAgent.framework/Versions/A/TrustEvaluationAgent
0x7fff9afb0000 - 0x7fff9afccff3 libresolv.9.dylib (60) <A650B5C8-1950-36A0-86D1-0B2465318BFA> /usr/lib/libresolv.9.dylib
0x7fff9b02d000 - 0x7fff9b064ff7 com.apple.LDAPFramework (2.4.28 - 194.5) <9AE33BF2-FB17-342D-8F1E-5F83C6E6EB69> /System/Library/Frameworks/LDAP.framework/Versions/A/LDAP
0x7fff9b0d0000 - 0x7fff9b0d3fff libCoreVMClient.dylib (119.5) <560D70FB-709F-3030-96C9-F249FCB7DA6D> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libCoreVMClient.dylib
0x7fff9b0d4000 - 0x7fff9b592fcf com.apple.vImage (8.0 - 8.0) <85FB412E-EB30-3433-A79B-B3970FC83580> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vImage.framework/Versions/A/vImage
0x7fff9b597000 - 0x7fff9b5c6ff7 com.apple.DictionaryServices (1.2 - 250.3) <30250542-CBAA-39C1-91AA-B57A5DE17594> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/DictionaryServices.framework/Versions/A/DictionaryServices
0x7fff9b64a000 - 0x7fff9b65afff libbsm.0.dylib (34) <7E14504C-A8B0-3574-B6EB-5D5FABC72926> /usr/lib/libbsm.0.dylib
0x7fff9b65b000 - 0x7fff9b6cfff3 com.apple.securityfoundation (6.0 - 55126) <3FF6D6E0-0C5D-385A-A97E-441D3947EFAB> /System/Library/Frameworks/SecurityFoundation.framework/Versions/A/SecurityFoundation
0x7fff9b6d0000 - 0x7fff9b6f4fff com.apple.MultitouchSupport.framework (304.12 - 304.12) <598A8689-E97E-3C8D-AACD-8A0EB1956CA6> /System/Library/PrivateFrameworks/MultitouchSupport.framework/Versions/A/MultitouchSupport
0x7fff9b6f5000 - 0x7fff9b72dff7 com.apple.RemoteViewServices (2.0 - 101) <B2881449-8CFE-3D1C-B4BF-155640392533> /System/Library/PrivateFrameworks/RemoteViewServices.framework/Versions/A/RemoteViewServices
0x7fff9b730000 - 0x7fff9b73cff7 com.apple.OpenDirectory (10.11 - 194) <31A67AD5-5CC2-350A-96D7-821DF4BC4196> /System/Library/Frameworks/OpenDirectory.framework/Versions/A/OpenDirectory
0x7fff9b760000 - 0x7fff9b789ffb libRIP.A.dylib (970) <BA17C96B-83CC-3835-8AFD-CB5A69D3D26F> /System/Library/Frameworks/CoreGraphics.framework/Versions/A/Resources/libRIP.A.dylib
0x7fff9b7c6000 - 0x7fff9b7c6fff com.apple.quartzframework (1.5 - 21) <5DC3D0D9-9E3F-3AA5-92F1-F229907A49B9> /System/Library/Frameworks/Quartz.framework/Versions/A/Quartz
0x7fff9b7c7000 - 0x7fff9c6cff67 libLLVMContainer.dylib (4) <61555A24-0AF4-30F6-B3A2-B3A5FF6D1847> /System/Library/PrivateFrameworks/GPUCompiler.framework/Versions/A/Libraries/libLLVMContainer.dylib
0x7fff9c6d0000 - 0x7fff9c6d8fff com.apple.NetFS (6.0 - 4.0) <842A5346-24C3-3F22-9ECF-E586A10EA1F2> /System/Library/Frameworks/NetFS.framework/Versions/A/NetFS
0x7fff9c6d9000 - 0x7fff9c925ff7 com.apple.AddressBook.framework (9.0 - 1679.10) <24F823D3-C3FC-3AF9-B8B3-C166539DBD11> /System/Library/Frameworks/AddressBook.framework/Versions/A/AddressBook
0x7fff9c947000 - 0x7fff9c976ffb com.apple.datadetectors (5.0 - 308) <1949868C-BDCD-3772-BDBD-D7E9F2CC1451> /System/Library/PrivateFrameworks/DataDetectors.framework/Versions/A/DataDetectors
0x7fff9c977000 - 0x7fff9c977ff7 libkeymgr.dylib (28) <8371CE54-5FDD-3CE9-B3DF-E98C761B6FE0> /usr/lib/system/libkeymgr.dylib
0x7fff9c978000 - 0x7fff9ca0dfff com.apple.ink.framework (10.9 - 214) <1F76CF36-3F79-36B8-BC37-C540AF34B338> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Ink.framework/Versions/A/Ink
0x7fff9cb72000 - 0x7fff9cb9bfff libsystem_info.dylib (477.50.4) <FAA9226D-64DE-3769-A6D8-6CABA4B7FF4D> /usr/lib/system/libsystem_info.dylib
0x7fff9ce3c000 - 0x7fff9cef6fff com.apple.DiscRecording (9.0.1 - 9010.4.3) <540853B2-B123-3560-8023-C92EE229051A> /System/Library/Frameworks/DiscRecording.framework/Versions/A/DiscRecording
0x7fff9cef7000 - 0x7fff9d09dff7 com.apple.audio.toolbox.AudioToolbox (1.13 - 1.13) <370E95BC-956C-3962-86CC-0A14CF6A0389> /System/Library/Frameworks/AudioToolbox.framework/Versions/A/AudioToolbox
0x7fff9d09e000 - 0x7fff9d0a6fff libGFXShared.dylib (12.1) <22F78420-D92E-3B5F-BA86-918A34289FCD> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGFXShared.dylib
0x7fff9d0a7000 - 0x7fff9d134fef libsystem_c.dylib (1082.60.1) <28733D22-553E-3CBC-8D2C-EDCEB46E46AF> /usr/lib/system/libsystem_c.dylib
0x7fff9d172000 - 0x7fff9d457ffb com.apple.CoreServices.CarbonCore (1136.2 - 1136.2) <2DBAFC9A-6CD6-351D-B1F4-87D81AA6D640> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/CarbonCore.framework/Versions/A/CarbonCore
0x7fff9d4bc000 - 0x7fff9d507ff7 com.apple.CoreMediaIO (703.0 - 4791) <E49D0C36-295A-311A-9470-706455EA6F80> /System/Library/Frameworks/CoreMediaIO.framework/Versions/A/CoreMediaIO
0x7fff9d508000 - 0x7fff9d50dff7 libheimdal-asn1.dylib (453.40.10) <981DE40B-FA16-36F7-BE92-8C8A115D6CD9> /usr/lib/libheimdal-asn1.dylib
0x7fff9d514000 - 0x7fff9d7baff7 com.apple.CoreData (120 - 641.3) <A29A5491-6169-372B-828F-84EE0CFD4BC4> /System/Library/Frameworks/CoreData.framework/Versions/A/CoreData
0x7fff9d7d9000 - 0x7fff9d879fff com.apple.Metadata (10.7.0 - 972.34) <B0137597-158A-3503-85C8-F55DB5D21BE1> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/Metadata.framework/Versions/A/Metadata
0x7fff9d8e7000 - 0x7fff9d8e8ffb libSystem.B.dylib (1226.10.1) <160608FD-B79D-3B49-AFEA-53A10C0C86B3> /usr/lib/libSystem.B.dylib
0x7fff9d8e9000 - 0x7fff9d8f0ff7 libcompiler_rt.dylib (62) <A13ECF69-F59F-38AE-8609-7B731450FBCD> /usr/lib/system/libcompiler_rt.dylib
0x7fff9d906000 - 0x7fff9d975fff com.apple.datadetectorscore (7.0 - 460) <233A8FBF-B22F-3177-A328-781588D95D69> /System/Library/PrivateFrameworks/DataDetectorsCore.framework/Versions/A/DataDetectorsCore
0x7fff9d9db000 - 0x7fff9da3efff libAVFAudio.dylib (161.2) <1A98DBF3-490B-37FB-928A-AB1E36E6E5DD> /System/Library/Frameworks/AVFoundation.framework/Versions/A/Resources/libAVFAudio.dylib
0x7fff9da99000 - 0x7fff9daa4fff libGPUSupportMercury.dylib (12.1) <97C7C8A3-234B-3C7C-8777-611E3D3EE63D> /System/Library/PrivateFrameworks/GPUSupport.framework/Versions/A/Libraries/libGPUSupportMercury.dylib
0x7fff9daa5000 - 0x7fff9daa7ff7 com.apple.securityhi (9.0 - 55006) <AC151C58-A7AD-3ECF-B15D-5E09FF94FC23> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/SecurityHI.framework/Versions/A/SecurityHI
0x7fff9daa8000 - 0x7fff9dac1fff com.apple.CFOpenDirectory (10.11 - 194) <11F95672-55E0-3F9D-9171-5E8C56AEE948> /System/Library/Frameworks/OpenDirectory.framework/Versions/A/Frameworks/CFOpenDirectory.framework/Versions/A/CFOpenDirectory
0x7fff9db3a000 - 0x7fff9db62fff com.apple.GLKit (1.0 - 56) <820F61C9-B74D-3604-BA6E-F20235E2E5B4> /System/Library/Frameworks/GLKit.framework/Versions/A/GLKit
0x7fff9db95000 - 0x7fff9db98fff com.apple.Mangrove (1.0 - 1) <2D86B3AD-64C3-3BB4-BC66-1CFD0C90E844> /System/Library/PrivateFrameworks/Mangrove.framework/Versions/A/Mangrove
External Modification Summary:
Calls made by other processes targeting this process:
task_for_pid: 426
thread_create: 0
thread_set_state: 0
Calls made by this process:
task_for_pid: 0
thread_create: 0
thread_set_state: 0
Calls made by all processes on this machine:
task_for_pid: 127896
thread_create: 0
thread_set_state: 0
VM Region Summary:
ReadOnly portion of Libraries: Total=694.2M resident=0K(0%) swapped_out_or_unallocated=694.2M(100%)
Writable regions: Total=43.1G written=0K(0%) resident=0K(0%) swapped_out=0K(0%) unallocated=43.1G(100%)
VIRTUAL REGION
REGION TYPE SIZE COUNT (non-coalesced)
ATS (font support) 32.3M 7
ATS (font support) (reserved) 8K 3 reserved VM address space (unallocated)
Accelerate.framework 256K 3
Activity Tracing 2048K 2
CG backing stores 39.3M 20
CG image 196.8M 153
CG shared images 1008K 21
CoreAnimation 756K 151
CoreUI image data 2940K 34
CoreUI image file 320K 5
Dispatch continuations 48.0M 2
Foundation 24K 3
Image IO 1336K 111
Kernel Alloc Once 8K 3
MALLOC 1.1G 3586
MALLOC guard page 32K 7
MALLOC_LARGE (reserved) 1080K 4 reserved VM address space (unallocated)
Memory Tag 242 12K 2
Memory Tag 251 12K 2
OpenCL 8K 2
OpenGL GLSL 256K 4
Process Corpse Info 2048K 2
STACK GUARD 56.4M 117
Stack 281.5M 127
VM_ALLOCATE 41.4G 45
__DATA 86.3M 394
__GLSLBUILTINS 2588K 2
__IMAGE 528K 2
__LINKEDIT 120.4M 79
__TEXT 573.8M 364
__TEXT0 800K 2
__UNICODE 552K 2
mapped file 234.0M 98
shared memory 16.4M 12
TOTAL 44.2G 5337
TOTAL, minus reserved VM space 44.2G 5337
Model: MacPro5,1, BootROM MP51.007F.B03, 12 processors, 6-Core Intel Xeon, 2.66 GHz, 64 GB, SMC 1.39f11
Graphics: NVIDIA GeForce GTX 980 TI, NVIDIA GeForce GTX 980 TI, PCIe, 6144 MB
Memory Module: DIMM 1, 8 GB, DDR3 ECC, 1333 MHz, 0x857F, 0x463732314752363546393333334700000000
Memory Module: DIMM 2, 8 GB, DDR3 ECC, 1333 MHz, 0x857F, 0x463732314752363546393333334700000000
Memory Module: DIMM 3, 8 GB, DDR3 ECC, 1333 MHz, 0x857F, 0x463732314752363546393333334700000000
Memory Module: DIMM 4, 8 GB, DDR3 ECC, 1333 MHz, 0x857F, 0x463732314752363546393333334700000000
Memory Module: DIMM 5, 8 GB, DDR3 ECC, 1333 MHz, 0x857F, 0x463732314752363546393333334700000000
Memory Module: DIMM 6, 8 GB, DDR3 ECC, 1333 MHz, 0x857F, 0x463732314752363546393333334700000000
Memory Module: DIMM 7, 8 GB, DDR3 ECC, 1333 MHz, 0x857F, 0x463732314752363546393333334700000000
Memory Module: DIMM 8, 8 GB, DDR3 ECC, 1333 MHz, 0x857F, 0x463732314752363546393333334700000000
AirPort: spairport_wireless_card_type_airport_extreme (0x14E4, 0x8E), Broadcom BCM43xx 1.0 (5.106.98.100.24)
Bluetooth: Version 4.4.6f1 17910, 3 services, 27 devices, 1 incoming serial ports
Network Service: Ethernet 1, Ethernet, en0
PCI Card: NVIDIA GeForce GTX 980 TI, Display Controller, Slot-1
PCI Card: NVIDIA GeForce GTX 980 TI, NVDA,Parent, Slot-1
PCI Card: pci10b5,8609, Slot-2
PCI Card: pci1b21,1142, USB eXtensible Host Controller, Slot-2@11,0,0
PCI Card: pci1b4b,9230, AHCI Controller, Slot-3
PCI Card: pci1b4b,9230, AHCI Controller, Slot-4
PCI Card: pci1b4b,9120, AHCI Controller, Slot-2@8,0,0
PCI Card: pci1b4b,91a4, IDE Controller, Slot-2@8,0,1
PCI Card: pci1b4b,9120, AHCI Controller, Slot-2@9,0,0
PCI Card: pci1b21,1142, USB eXtensible Host Controller, Slot-2@10,0,0
PCI Card: pci1b4b,91a4, IDE Controller, Slot-2@9,0,1
Serial ATA Device: HL-DT-ST DVD-RW GH41N
Serial ATA Device: HL-DT-ST BD-RE WH16NS40
Serial ATA Device: Samsung SSD 850 PRO 2TB, 2.05 TB
Serial ATA Device: Samsung SSD 840 EVO 1TB, 1 TB
Serial ATA Device: ElitePro Qx2, 9 TB
Serial ATA Device: 2.74 TB HD Glyph, 3 TB
Serial ATA Device: OWC Mercury Accelsior PCIe SSD, 960.04 GB
Serial ATA Device: MARVELL VIRTUAL
USB Device: USB Bus
USB Device: USB Bus
USB Device: USB Bus
USB Device: BRCM2046 Hub
USB Device: Bluetooth USB Host Controller
USB Device: USB Bus
USB Device: USB Bus
USB Device: Intuos5 touch L
USB Device: USB Bus
USB Device: USB 2.0 Bus
USB Device: HZD
USB Device: USB2.0 Hub
USB Device: Apple Watch Magnetic Charging Cable
USB Device: GL3220
USB Device: SoundSticks
USB Device: Hub
USB Device: Keyboard Hub
USB Device: USB Flash Memory
USB Device: Apple Keyboard
USB Device: Apple LED Cinema Display
USB Device: Display iSight
USB Device: Display Audio
USB Device: USB 3.0 Bus
FireWire Device: built-in_hub, Up to 800 Mb/sec
Thunderbolt Bus:
I'm not a mac user but it looks like you may be missing thes second cc 2017 update or it failed to install. It lie like Photoshop is avr version 18.0.1.29. On my system I see CC 2017 is at version 18.1.1 and CC 2017 system info shows many of the plugins are also a version 18.1.1
Hi JJMack,
Thanks so much for the suggestion. For some reason, my Adobe Creative Cloud was not updating Photoshop, so I uninstalled 18.0.1.29 and installed the latest version available to me (18.1.1.252).
Sadly, Photoshop is still crashing when I invert the selection and hit "delete" while the view is rotated. The behavior is the same every time -- I can invert the selection and delete while the view is rotated for the first 5-10 minutes when the program is open, but after 5-10 minutes, hitting "delete" crashes the software. It's baffling.
Here is the crash report:
Process: Adobe Photoshop CC 2017 [960]
Path: /Applications/Adobe Photoshop CC 2017/Adobe Photoshop CC 2017.app/Contents/MacOS/Adobe Photoshop CC 2017
Identifier: com.adobe.Photoshop
Version: 18.1.1 (18.1.1.252)
Code Type: X86-64 (Native)
Parent Process: ??? [1]
Responsible: Adobe Photoshop CC 2017 [960]
User ID: 501
Date/Time: 2017-09-30 11:36:23.625 -0700
OS Version: Mac OS X 10.11.6 (15G1611)
Report Version: 11
Anonymous UUID: 056FB863-13B4-6410-D572-383FF35796D5
Time Awake Since Boot: 2000 seconds
System Integrity Protection: enabled
Crashed Thread: 0 Dispatch queue: com.apple.main-thread
Exception Type: EXC_BAD_ACCESS (SIGBUS)
Exception Codes: KERN_PROTECTION_FAILURE at 0x000000012196ad80
Exception Note: EXC_CORPSE_NOTIFY
VM Regions Near 0x12196ad80:
CG backing stores 00000001218d4000-000000012190b000 [ 220K] rw-/rw- SM=PRV
--> mapped file 000000012190b000-0000000121c1e000 [ 3148K] r--/rwx SM=COW
CoreUI image file 0000000121c1e000-0000000121c3e000 [ 128K] rw-/rwx SM=PRV
Thread 0 Crashed:: Dispatch queue: com.apple.main-thread
0 MMXCore 0x000000011eac8431 0x11eaab000 + 119857
1 com.adobe.Photoshop 0x000000010a2e74f7 0x1099b1000 + 9659639
2 com.adobe.Photoshop 0x000000010a2fb1ff 0x1099b1000 + 9740799
3 com.adobe.Photoshop 0x000000010a1787ed 0x1099b1000 + 8157165
4 com.adobe.Photoshop 0x000000010a63303a 0x1099b1000 + 13115450
5 com.adobe.Photoshop 0x0000000109a7679a 0x1099b1000 + 808858
6 com.adobe.Photoshop 0x0000000109a4eb70 0x1099b1000 + 646000
7 com.adobe.Photoshop 0x0000000109a4ec39 0x1099b1000 + 646201
8 com.adobe.Photoshop 0x000000010b8f278d 0x1099b1000 + 32774029
9 com.apple.Foundation 0x00007fff9783ce2c __NSFireTimer + 95
10 com.apple.CoreFoundation 0x00007fff9bceeae4 __CFRUNLOOP_IS_CALLING_OUT_TO_A_TIMER_CALLBACK_FUNCTION__ + 20
11 com.apple.CoreFoundation 0x00007fff9bcee773 __CFRunLoopDoTimer + 1075
12 com.apple.CoreFoundation 0x00007fff9bcee2ca __CFRunLoopDoTimers + 298
13 com.apple.CoreFoundation 0x00007fff9bce57c1 __CFRunLoopRun + 1841
14 com.apple.CoreFoundation 0x00007fff9bce4e28 CFRunLoopRunSpecific + 296
15 com.apple.HIToolbox 0x00007fff9c14a935 RunCurrentEventLoopInMode + 235
16 com.apple.HIToolbox 0x00007fff9c14a76f ReceiveNextEventCommon + 432
17 com.apple.HIToolbox 0x00007fff9c14a5af _BlockUntilNextEventMatchingListInModeWithFilter + 71
18 com.apple.AppKit 0x00007fff91beadf6 _DPSNextEvent + 1067
19 com.apple.AppKit 0x00007fff91bea226 -[NSApplication _nextEventMatchingEventMask:untilDate:inMode:dequeue:] + 454
20 com.adobe.Photoshop 0x000000010b8f1441 0x1099b1000 + 32769089
21 com.apple.AppKit 0x00007fff91bded80 -[NSApplication run] + 682
22 com.adobe.Photoshop 0x000000010b8f25a2 0x1099b1000 + 32773538
23 com.adobe.Photoshop 0x000000010b8f3928 0x1099b1000 + 32778536
24 com.adobe.Photoshop 0x0000000109a5068d 0x1099b1000 + 652941
25 com.adobe.Photoshop 0x0000000109dc87df 0x1099b1000 + 4290527
26 com.adobe.Photoshop 0x0000000109dc8a69 0x1099b1000 + 4291177
27 libdyld.dylib 0x00007fff97bd65ad start + 1
Thread 1:: Dispatch queue: com.apple.libdispatch-manager
0 libsystem_kernel.dylib 0x00007fff954a9efa kevent_qos + 10
1 libdispatch.dylib 0x00007fff90325165 _dispatch_mgr_invoke + 216
2 libdispatch.dylib 0x00007fff90324dcd _dispatch_mgr_thread + 52
Thread 2:: MPSupport Worker
0 libsystem_kernel.dylib 0x00007fff954a8db6 __psynch_cvwait + 10
1 libsystem_pthread.dylib 0x00007fff974ea728 _pthread_cond_wait + 767
2 MultiProcessor Support 0x000000011ebf50fb 0x11ebab000 + 303355
3 MultiProcessor Support 0x000000011ebf501b 0x11ebab000 + 303131
4 MultiProcessor Support 0x000000011ec167a6 0x11ebab000 + 440230
5 libsystem_pthread.dylib 0x00007fff974e999d _pthread_body + 131
6 libsystem_pthread.dylib 0x00007fff974e991a _pthread_start + 168
7 libsystem_pthread.dylib 0x00007fff974e7351 thread_start + 13
Thread 3:: MPSupport Worker
Thread 4:: MPSupport Worker
Thread 5:: MPSupport Worker
Thread 6:: MPSupport Worker
Thread 7:: MPSupport Worker
Thread 8:: MPSupport Worker
Thread 9:: MPSupport Worker
Thread 10:: MPSupport Worker
Thread 11:: MPSupport Worker
Thread 12:: MPSupport Worker
Thread 13:: MPSupport Worker
Thread 14:: MPSupport Worker
Thread 15:: MPSupport Worker
Thread 16:: MPSupport Worker
Thread 17:: MPSupport Worker
Thread 18:: MPSupport Worker
Thread 19:: MPSupport Worker
Thread 20:: MPSupport Worker
Thread 21:: MPSupport Worker
Thread 22:: MPSupport Worker
Thread 23:: MPSupport Worker
Thread 24:: MPSupport Worker
Thread 25:: VulcanMsgRecv
0 libsystem_kernel.dylib 0x00007fff954a8fba __recvfrom + 10
1 VulcanMessage5.dylib 0x00000001152b7308 vcfoundation::net::Bsd::Recv(int, void*, int, int) + 16
2 VulcanMessage5.dylib 0x00000001152b66cc vcfoundation::io::BSDNamedPipe::Read(void*, unsigned long) + 20
3 VulcanMessage5.dylib 0x00000001152b59c4 vcfoundation::io::BufferedReader::InternalRead(char*, long) + 100
4 VulcanMessage5.dylib 0x00000001152b5888 vcfoundation::io::BufferedReader::Read(void*, unsigned long) + 50
5 VulcanMessage5.dylib 0x00000001152b04c7 vcfoundation::io::IVCChannel::ReadFully(void*, unsigned long) + 57
6 VulcanMessage5.dylib 0x00000001152b0f56 vcfoundation::io::Serializer::InternalDeserialize() + 30
7 VulcanMessage5.dylib 0x00000001152b08ef vcfoundation::io::Serializer::Deserialize() + 9
8 VulcanMessage5.dylib 0x00000001152b4974 vcfoundation::ncomm::Connection::ReadIn() + 22
9 VulcanMessage5.dylib 0x00000001152b43cd vcfoundation::ncomm::NCService::ReadResponse(vcfoundation::ncomm::INCRequest*, vcfoundation::ncomm::INCListener&, vcfoundation::ncomm::NCService::ConRef&) + 41
10 VulcanMessage5.dylib 0x00000001152b40ba vcfoundation::ncomm::NCService::Execute(vcfoundation::ncomm::INCRequest*, vcfoundation::ncomm::INCListener&) + 166
11 VulcanMessage5.dylib 0x00000001152b400d vcfoundation::ncomm::NCService::Execute(vcfoundation::ncomm::INCRequest*) + 29
12 VulcanMessage5.dylib 0x00000001152a7848 adobe::vulcan::servicemgr::CSIRequest::Execute() + 50
13 VulcanMessage5.dylib 0x00000001152a6a86 adobe::vulcan::servicemgr::RegisterForEventsRequest::Run() + 622
14 VulcanMessage5.dylib 0x00000001152b520c vcfoundation::thread::AbstractThread::Run() + 72
15 VulcanMessage5.dylib 0x00000001152b7109 vcfoundation::thread::Thread::ThreadProc(void*) + 9
16 libsystem_pthread.dylib 0x00007fff974e999d _pthread_body + 131
17 libsystem_pthread.dylib 0x00007fff974e991a _pthread_start + 168
18 libsystem_pthread.dylib 0x00007fff974e7351 thread_start + 13
Thread 26:
0 libsystem_kernel.dylib 0x00007fff954a2fae semaphore_wait_trap + 10
1 libtbb.dylib 0x000000011118f100 tbb::internal::rml::private_worker::thread_routine(void*) + 448
2 libsystem_pthread.dylib 0x00007fff974e999d _pthread_body + 131
3 libsystem_pthread.dylib 0x00007fff974e991a _pthread_start + 168
4 libsystem_pthread.dylib 0x00007fff974e7351 thread_start + 13
Thread 27:
Thread 28:
Thread 29:
Thread 30:
Thread 31:
Thread 32:
Thread 33:
Thread 34:
Thread 35:
Thread 36:
Thread 37:
Thread 38:
Thread 39:
Thread 40:
Thread 41:
Thread 42:
Thread 43:
Thread 44:
Thread 45:
Thread 46:
Thread 47:
Thread 48:
Thread 49:: BridgeTalk
0 libsystem_kernel.dylib 0x00007fff954a910a __semwait_signal + 10
1 libsystem_c.dylib 0x00007fffa0eced0f nanosleep + 199
2 com.adobe.PSAutomate 0x000000015429ece8 0x1540cb000 + 1916136
3 com.adobe.PSAutomate 0x0000000154280b5c 0x1540cb000 + 1792860
4 com.adobe.PSAutomate 0x000000015429e871 0x1540cb000 + 1914993
Thread 50:: com.apple.NSEventThread
0 libsystem_kernel.dylib 0x00007fff954a2f72 mach_msg_trap + 10
1 libsystem_kernel.dylib 0x00007fff954a23b3 mach_msg + 55
2 com.apple.CoreFoundation 0x00007fff9bce6114 __CFRunLoopServiceMachPort + 212
3 com.apple.CoreFoundation 0x00007fff9bce55dc __CFRunLoopRun + 1356
5 com.apple.AppKit 0x00007fff91d40d95 _NSEventThread + 149
Thread 51:
2 com.adobe.headlights.LogSessionFramework 0x00000001143cbccc boost::condition_variable::do_wait_until(boost::unique_lock<boost::mutex>&, timespec const&) + 76
3 com.adobe.headlights.LogSessionFramework 0x00000001143ca5ef boost::this_thread::hiden::sleep_for(timespec const&) + 191
4 com.adobe.headlights.LogSessionFramework 0x0000000114378059 void boost::this_thread::sleep_for<long long, boost::ratio<1l, 1l> >(boost::chrono::duration<long long, boost::ratio<1l, 1l> > const&) + 107
5 com.adobe.headlights.LogSessionFramework 0x0000000114346cfb RealTimeProcessor::WorkerThread(int, int) + 3633
6 com.adobe.headlights.LogSessionFramework 0x00000001143c9969 boost::(anonymous namespace)::thread_proxy(void*) + 185
7 libsystem_pthread.dylib 0x00007fff974e999d _pthread_body + 131
8 libsystem_pthread.dylib 0x00007fff974e991a _pthread_start + 168
9 libsystem_pthread.dylib 0x00007fff974e7351 thread_start + 13
Thread 52:: com.apple.NSURLConnectionLoader
5 com.apple.CFNetwork 0x00007fff9e254a6d +[NSURLConnection(Loader) _resourceLoadLoop:] + 412
6 com.apple.Foundation 0x00007fff977c8c84 __NSThread__start__ + 1351
Thread 53:
2 com.adobe.headlights.LogSessionFramework 0x0000000114379152 boost::condition_variable::wait_until(boost::unique_lock<boost::mutex>&, boost::chrono::time_point<boost::chrono::system_clock, boost::chrono::duration<long long, boost::ratio<1l, 1000000000l> > >) + 124
3 com.adobe.headlights.LogSessionFramework 0x00000001143780db void boost::this_thread::sleep_until<boost::chrono::system_clock, boost::chrono::duration<long long, boost::ratio<1l, 1000000000l> > >(boost::chrono::time_point<boost::chrono::system_clock, boost::chrono::duration<long long, boost::ratio<1l, 1000000000l> > > const&) + 124
4 com.adobe.headlights.LogSessionFramework 0x0000000114377bae IdleTimeLogger::IdleTimeWorkerThread() + 2804
5 com.adobe.headlights.LogSessionFramework 0x00000001143c9969 boost::(anonymous namespace)::thread_proxy(void*) + 185
Thread 54:: Update Activation Menu Items
2 com.adobe.Photoshop 0x0000000109d143a2 0x1099b1000 + 3552162
3 CITThreading 0x000000011183c05e boost::(anonymous namespace)::thread_proxy(void*) + 130
4 libsystem_pthread.dylib 0x00007fff974e999d _pthread_body + 131
5 libsystem_pthread.dylib 0x00007fff974e991a _pthread_start + 168
6 libsystem_pthread.dylib 0x00007fff974e7351 thread_start + 13
Thread 55:
2 libc++.1.dylib 0x00007fff90e6268f std::__1::condition_variable::wait(std::__1::unique_lock<std::__1::mutex>&) + 47
3 com.adobe.Photoshop 0x00000001099b62fd 0x1099b1000 + 21245
4 com.adobe.Photoshop 0x00000001099b6f5b 0x1099b1000 + 24411
5 com.adobe.Photoshop 0x00000001099b6d4e 0x1099b1000 + 23886
Thread 56:
Thread 57:
Thread 58:
Thread 59:: com.apple.CFSocket.private
0 libsystem_kernel.dylib 0x00007fff954a907a __select + 10
1 com.apple.CoreFoundation 0x00007fff9bd2345a __CFSocketManager + 762
Thread 60:: NetworkConfigWatcher
5 com.apple.Foundation 0x00007fff977b7cf9 -[NSRunLoop(NSRunLoop) runMode:beforeDate:] + 270
6 org.chromium.ContentShell.framework 0x0000000155e95eee 0x1548f5000 + 22679278
7 org.chromium.ContentShell.framework 0x0000000155e9572c 0x1548f5000 + 22677292
8 org.chromium.ContentShell.framework 0x0000000155eae113 0x1548f5000 + 22778131
9 org.chromium.ContentShell.framework 0x0000000155ed17d2 0x1548f5000 + 22923218
10 org.chromium.ContentShell.framework 0x0000000155ecd2f7 0x1548f5000 + 22905591
11 libsystem_pthread.dylib 0x00007fff974e999d _pthread_body + 131
12 libsystem_pthread.dylib 0x00007fff974e991a _pthread_start + 168
13 libsystem_pthread.dylib 0x00007fff974e7351 thread_start + 13
Thread 61:: DnsConfigService
0 libsystem_kernel.dylib 0x00007fff954a9eca kevent + 10
1 org.chromium.ContentShell.framework 0x0000000155f053e7 0x1548f5000 + 23135207
2 org.chromium.ContentShell.framework 0x0000000155f02ebd 0x1548f5000 + 23125693
3 org.chromium.ContentShell.framework 0x0000000155e94e2f 0x1548f5000 + 22674991
4 org.chromium.ContentShell.framework 0x0000000155eae113 0x1548f5000 + 22778131
5 org.chromium.ContentShell.framework 0x0000000155ed17d2 0x1548f5000 + 22923218
6 org.chromium.ContentShell.framework 0x0000000155ecd2f7 0x1548f5000 + 22905591
Thread 62:: Chrome_DBThread
5 org.chromium.ContentShell.framework 0x0000000155e95c4f 0x1548f5000 + 22678607
6 org.chromium.ContentShell.framework 0x0000000155e9572c 0x1548f5000 + 22677292
7 org.chromium.ContentShell.framework 0x0000000155eae113 0x1548f5000 + 22778131
8 org.chromium.ContentShell.framework 0x00000001555cb354 0x1548f5000 + 13460308
9 org.chromium.ContentShell.framework 0x00000001555cb4c3 0x1548f5000 + 13460675
10 org.chromium.ContentShell.framework 0x0000000155ed17d2 0x1548f5000 + 22923218
11 org.chromium.ContentShell.framework 0x0000000155ecd2f7 0x1548f5000 + 22905591
12 libsystem_pthread.dylib 0x00007fff974e999d _pthread_body + 131
13 libsystem_pthread.dylib 0x00007fff974e991a _pthread_start + 168
14 libsystem_pthread.dylib 0x00007fff974e7351 thread_start + 13
Thread 63:: Chrome_FileThread
5 org.chromium.ContentShell.framework 0x00000001555cb384 0x1548f5000 + 13460356
6 org.chromium.ContentShell.framework 0x00000001555cb4d0 0x1548f5000 + 13460688
7 org.chromium.ContentShell.framework 0x0000000155ed17d2 0x1548f5000 + 22923218
8 org.chromium.ContentShell.framework 0x0000000155ecd2f7 0x1548f5000 + 22905591
9 libsystem_pthread.dylib 0x00007fff974e999d _pthread_body + 131
10 libsystem_pthread.dylib 0x00007fff974e991a _pthread_start + 168
11 libsystem_pthread.dylib 0x00007fff974e7351 thread_start + 13
Thread 64:: Chrome_FileUserBlockingThread
8 org.chromium.ContentShell.framework 0x00000001555cb3b4 0x1548f5000 + 13460404
9 org.chromium.ContentShell.framework 0x00000001555cb4dd 0x1548f5000 + 13460701
Thread 65:: Chrome_ProcessLauncherThread
8 org.chromium.ContentShell.framework 0x00000001555cb3e4 0x1548f5000 + 13460452
9 org.chromium.ContentShell.framework 0x00000001555cb4ea 0x1548f5000 + 13460714
Thread 66:: Chrome_CacheThread
8 org.chromium.ContentShell.framework 0x00000001555cb414 0x1548f5000 + 13460500
9 org.chromium.ContentShell.framework 0x00000001555cb4f7 0x1548f5000 + 13460727
Thread 67:: Chrome_IOThread
5 org.chromium.ContentShell.framework 0x00000001555cb444 0x1548f5000 + 13460548
6 org.chromium.ContentShell.framework 0x00000001555cb504 0x1548f5000 + 13460740
Thread 68:: BrowserBlockingWorker1/152579
2 org.chromium.ContentShell.framework 0x0000000155ece2cf 0x1548f5000 + 22909647
3 org.chromium.ContentShell.framework 0x0000000155ecd976 0x1548f5000 + 22907254
4 org.chromium.ContentShell.framework 0x0000000155ed0c5d 0x1548f5000 + 22920285
5 org.chromium.ContentShell.framework 0x0000000155ecd2f7 0x1548f5000 + 22905591
Thread 69:: IndexedDB
8 org.chromium.ContentShell.framework 0x0000000155ed17d2 0x1548f5000 + 22923218
9 org.chromium.ContentShell.framework 0x0000000155ecd2f7 0x1548f5000 + 22905591
10 libsystem_pthread.dylib 0x00007fff974e999d _pthread_body + 131
11 libsystem_pthread.dylib 0x00007fff974e991a _pthread_start + 168
12 libsystem_pthread.dylib 0x00007fff974e7351 thread_start + 13
Thread 70:: CompositorTileWorker1/154371
2 org.chromium.ContentShell.framework 0x0000000155f84698 0x1548f5000 + 23656088
3 org.chromium.ContentShell.framework 0x0000000155ed0c5d 0x1548f5000 + 22920285
4 org.chromium.ContentShell.framework 0x0000000155ecd2f7 0x1548f5000 + 22905591
Thread 71:: AudioThread
Thread 72:: BrowserBlockingWorker2/158979
Thread 73:: NetworkConfigWatcher
Thread 74:: Chrome_DevToolsHandlerThread
Thread 75:
5 com.apple.Foundation 0x00007fff978cff99 -[NSConnection run] + 149
Thread 76:: CEPMonitorThread
5 com.apple.Foundation 0x00007fff97861dda -[NSConcreteTask waitUntilExit] + 205
6 com.adobe.PlugPlugOwl 0x0000000111b66c4b -[HtmlEngineMonitor monitorThreadProc] + 160
7 com.apple.Foundation 0x00007fff977c8c84 __NSThread__start__ + 1351
8 libsystem_pthread.dylib 0x00007fff974e999d _pthread_body + 131
9 libsystem_pthread.dylib 0x00007fff974e991a _pthread_start + 168
10 libsystem_pthread.dylib 0x00007fff974e7351 thread_start + 13
Thread 77:: General Background Service
2 com.adobe.Photoshop 0x0000000109d93fb1 0x1099b1000 + 4075441
3 com.adobe.Photoshop 0x000000010bc9d81c 0x1099b1000 + 36620316
4 com.adobe.Photoshop 0x000000010bc9ccac 0x1099b1000 + 36617388
5 com.adobe.Photoshop 0x000000010bc9eba6 0x1099b1000 + 36625318
6 CITThreading 0x000000011183c05e boost::(anonymous namespace)::thread_proxy(void*) + 130
Thread 78:
Thread 79:: CEPMonitorThread
Thread 80:: BrowserBlockingWorker3/202047
Thread 81:: CachePoolWorker1/202595
Thread 82:
Thread 83:: CEPMonitorThread
Thread 84:: Bristle Physics
2 com.adobe.Photoshop 0x000000010a3f648b 0x1099b1000 + 10769547
3 com.adobe.Photoshop 0x000000010b78cc65 0x1099b1000 + 31308901
4 com.adobe.Photoshop 0x000000010b784583 0x1099b1000 + 31274371
5 CITThreading 0x000000011183c05e boost::(anonymous namespace)::thread_proxy(void*) + 130
Thread 85:: Font Initialization
Thread 86:: DeepFont
Thread 87:: Background Save
3 com.adobe.Photoshop 0x000000010b9db98c 0x1099b1000 + 33728908
4 com.adobe.Photoshop 0x000000010b9d96a9 0x1099b1000 + 33719977
Thread 88:
0 libsystem_kernel.dylib 0x00007fff954a95e2 __workq_kernreturn + 10
1 libsystem_pthread.dylib 0x00007fff974e9578 _pthread_wqthread + 1283
2 libsystem_pthread.dylib 0x00007fff974e7341 start_wqthread + 13
Thread 89:
Thread 90:
Thread 91:
Thread 92:
Thread 93:
Thread 94:
Thread 95:
Thread 96:
Thread 97:
Thread 98:
Thread 99:
Thread 100:
Thread 101:
Thread 102:
Thread 103:
Thread 104:
Thread 105:
Thread 106:
Thread 107:
Thread 108:
Thread 109:
Thread 110:
1 libsystem_pthread.dylib 0x00007fff974ea75e _pthread_cond_wait + 821
2 com.apple.CoreServices.CarbonCore 0x00007fffa0fbfa93 TSWaitOnConditionTimedRelative + 147
3 com.apple.CoreServices.CarbonCore 0x00007fffa0fbf66e TSWaitOnSemaphoreCommon + 406
4 com.apple.CoreServices.CarbonCore 0x00007fffa0f866ea AsyncFileThread(void*) + 275
Thread 111:
Thread 0 crashed with X86 Thread State (64-bit):
rax: 0x000000000000099d rbx: 0x0000000000000000 rcx: 0x00000000000009a0 rdx: 0x0000000000000000
rdi: 0x000000012196ad80 rsi: 0x0000000000000001 rbp: 0x0000000000000001 rsp: 0x00007fff5624b928
r8: 0x0000000000000990 r9: 0x000000000000099d r10: 0x0000000000000001 r11: 0x000000000000000d
r12: 0x000000000000099d r13: 0x000000012196ad80 r14: 0x000000000000004c r15: 0x0000000000000000
rip: 0x000000011eac8431 rfl: 0x0000000000010202 cr2: 0x000000012196ad80
Logical CPU: 12
Error Code: 0x00000006
Trap Number: 14
Binary Images:
0x1099b1000 - 0x11019ef87 +com.adobe.Photoshop (18.1.1 - 18.1.1.252) <B684F32F-915C-3BEA-B7EC-8B5F5820FAAC> /Applications/Adobe Photoshop CC 2017/Adobe Photoshop CC 2017.app/Contents/MacOS/Adobe Photoshop CC 2017
0x111180000 - 0x1111b7fef +libtbb.dylib (0) <3441EB5B-2632-3B4C-B76C-9AE5849E7353> /Applications/Adobe Photoshop CC 2017/Adobe Photoshop CC 2017.app/Contents/Frameworks/libtbb.dylib
0x1111f9000 - 0x11121cfe7 +libtbbmalloc.dylib (0) <81117D6A-D8E4-37C2-9766-0DC0BF86C06C> /Applications/Adobe Photoshop CC 2017/Adobe Photoshop CC 2017.app/Contents/Frameworks/libtbbmalloc.dylib
0x111255000 - 0x1112fdfff +com.adobe.AdobeExtendScript (ExtendScript 4.5.6 - 4.5.6.5) <0AE6FE3B-AD77-3C9E-AD1B-CEE881FEF5C2> /Applications/Adobe Photoshop CC 2017/Adobe Photoshop CC 2017.app/Contents/Frameworks/AdobeExtendScript.framework/Versions/A/AdobeExtendScript
0x11135d000 - 0x1113fbfff +com.adobe.AdobeScCore (ScCore 4.5.6 - 4.5.6.5) <678BE576-32AB-3958-9C04-2504856330E5> /Applications/Adobe Photoshop CC 2017/Adobe Photoshop CC 2017.app/Contents/Frameworks/AdobeScCore.framework/Versions/A/AdobeScCore
0x11144b000 - 0x1115ceff7 +com.adobe.aif (Adobe Image Foundation Library 6.0.00.1 - 6.0.00.1) <EB941620-7550-301A-98C4-69CDB0577834> /Applications/Adobe Photoshop CC 2017/Adobe Photoshop CC 2017.app/Contents/Frameworks/aif.framework/Versions/A/aif
0x111729000 - 0x111798ff7 +com.adobe.manta (Adobe Manta Library 2.0.00.1 - 2.0.00.1) <48E3C4F3-461F-3F9F-B83A-11BC5D103508> /Applications/Adobe Photoshop CC 2017/Adobe Photoshop CC 2017.app/Contents/Frameworks/manta.framework/Versions/A/manta
0x11182c000 - 0x111845fff +CITThreading (???) <F6746740-68D1-3F47-9714-94B42B132BD9> /Applications/Adobe Photoshop CC 2017/Adobe Photoshop CC 2017.app/Contents/Frameworks/CITThreading.framework/Versions/A/CITThreading
0x111886000 - 0x111984ff3 +ZXPSignLib-minimal-dylib.dylib (0) <B50C7884-6179-3925-AF15-0013257D0F6B> /Applications/Adobe Photoshop CC 2017/Adobe Photoshop CC 2017.app/Contents/Frameworks/ZXPSignLib-minimal-dylib.dylib
0x1119b3000 - 0x111ab9fff +com.adobe.amtlib (10.0.0.119 - 10.0.0.119) <53139645-73AD-3787-AEE6-579FABE39250> /Applications/Adobe Photoshop CC 2017/Adobe Photoshop CC 2017.app/Contents/Frameworks/amtlib.framework/Versions/A/amtlib
0x111acd000 - 0x111d43ff3 +com.adobe.PlugPlugOwl (7.0.0.67 - 7.0.0.67) <255982DC-96E4-3C40-AF5A-B46F23B5D372> /Applications/Adobe Photoshop CC 2017/Adobe Photoshop CC 2017.app/Contents/Frameworks/PlugPlugOwl.framework/Versions/A/PlugPlugOwl
0x112019000 - 0x11208ffff +com.adobe.AdobeSVGAGM (1.0.0 - 1.0.0.37848) <387CF9B9-B873-35B7-8D5E-7ACB4EA61AE7> /Applications/Adobe Photoshop CC 2017/Adobe Photoshop CC 2017.app/Contents/Frameworks/AdobeSVGAGM.framework/Versions/A/AdobeSVGAGM
0x11217b000 - 0x112224ff7 +com.adobe.ICUConverter (4.0 - 3.61) <E20E390A-9BAF-3454-BA16-7B9CCD4CA8F0> /Applications/Adobe Photoshop CC 2017/Adobe Photoshop CC 2017.app/Contents/Frameworks/ICUConverter.framework/Versions/4.0/ICUConverter
0x11224d000 - 0x112252fff org.twain.dsm (1.9.5 - 1.9.5) <F7AA3C5E-4FB0-379D-8F79-AD06669D087E> /System/Library/Frameworks/TWAIN.framework/Versions/A/TWAIN
0x11225a000 - 0x112278fff +com.adobe.ahclientframework (2.2.0.1 - 2.2.0.1) <78C9396E-DBAE-3C68-9B67-95B28F2BEC76> /Applications/Adobe Photoshop CC 2017/Adobe Photoshop CC 2017.app/Contents/Frameworks/ahclient.framework/Versions/A/ahclient
0x112291000 - 0x112295fff com.apple.agl (3.3.1 - AGL-3.3.1) <2FC3E30C-5370-3369-B8D1-1C7050A4A85A> /System/Library/Frameworks/AGL.framework/Versions/A/AGL
0x1122a2000 - 0x112434ff7 +com.adobe.owl (AdobeOwl version 5.2.11 - 5.2.11) <CDF9E325-6035-3EF9-8E03-980CD33D6582> /Applications/Adobe Photoshop CC 2017/Adobe Photoshop CC 2017.app/Contents/Frameworks/AdobeOwl.framework/Versions/A/AdobeOwl
0x112485000 - 0x1127ebff3 +com.adobe.MPS (AdobeMPS 5.8.1.37174 - 5.8.1.37174) <88508A43-6228-39B1-9377-B49EC9BBE1DE> /Applications/Adobe Photoshop CC 2017/Adobe Photoshop CC 2017.app/Contents/Frameworks/AdobeMPS.framework/Versions/A/AdobeMPS
0x112863000 - 0x112887fff +VulcanControl.dylib (5.3.0.16 - 5.3.0.16 Copyright 2016, Adobe Systems Incorporated. All rights reserved.) <32AA6861-E0A7-37F8-8CE9-FCE97E3BFD07> /Applications/Adobe Photoshop CC 2017/Adobe Photoshop CC 2017.app/Contents/Frameworks/VulcanControl.dylib
0x1128b3000 - 0x112b7cffb +com.adobe.AGM (AdobeAGM 4.30.87.37848 - 4.30.87.37848) <7DAE22B9-2F91-385B-B4EA-9EC75CBEE0EF> /Applications/Adobe Photoshop CC 2017/Adobe Photoshop CC 2017.app/Contents/Frameworks/AdobeAGM.framework/Versions/A/AdobeAGM
0x112bee000 - 0x112eebffb +com.adobe.CoolType (AdobeCoolType 5.15.00.37848 - 5.15.00.37848) <46381E3C-77F9-3842-8A13-33BDEFA6E1D7> /Applications/Adobe Photoshop CC 2017/Adobe Photoshop CC 2017.app/Contents/Frameworks/AdobeCoolType.framework/Versions/A/AdobeCoolType
0x112f3d000 - 0x112f60ff3 +com.adobe.BIBUtils (AdobeBIBUtils 1.1.01 - 1.1.01) <B71D4C22-E568-3088-AED2-7D14B810D74A> /Applications/Adobe Photoshop CC 2017/Adobe Photoshop CC 2017.app/Contents/Frameworks/AdobeBIBUtils.framework/Versions/A/AdobeBIBUtils
0x112f69000 - 0x112f6afff libCyrillicConverter.dylib (68) <79F5CFEF-92E4-30FE-A650-41F07B6D31B9> /System/Library/CoreServices/Encodings/libCyrillicConverter.dylib
0x112f70000 - 0x112f94ff7 +com.adobe.AXE8SharedExpat (AdobeAXE8SharedExpat 3.8.0.34320 - 3.8.0.34320) <674F1792-D790-3E12-8C0F-85CAF9D848B1> /Applications/Adobe Photoshop CC 2017/Adobe Photoshop CC 2017.app/Contents/Frameworks/AdobeAXE8SharedExpat.framework/Versions/A/AdobeAXE8SharedExpat
0x112fbd000 - 0x1130e7ff7 +com.winsoft.wrservices (WRServices 12.1.0 - 12.1.0) <75B95734-75E4-3E7E-B8E3-DB51C053E4DC> /Applications/Adobe Photoshop CC 2017/Adobe Photoshop CC 2017.app/Contents/Frameworks/WRServices.framework/Versions/A/WRServices
0x11313c000 - 0x113286ff7 +com.adobe.ACE (AdobeACE 2.20.02.37848 - 2.20.02.37848) <3236E6F5-C286-3C46-AD03-9838AFE1D751> /Applications/Adobe Photoshop CC 2017/Adobe Photoshop CC 2017.app/Contents/Frameworks/AdobeACE.framework/Versions/A/AdobeACE
0x1132a1000 - 0x1132bdffb +com.adobe.BIB (AdobeBIB 1.2.03.37848 - 1.2.03.37848) <28247879-8E7A-3B40-9012-FF1E849D7236> /Applications/Adobe Photoshop CC 2017/Adobe Photoshop CC 2017.app/Contents/Frameworks/AdobeBIB.framework/Versions/A/AdobeBIB
0x1132c6000 - 0x113386ff7 +com.adobe.JP2K (1.2.2 - 1.2.2.38234) <FA7EDCFB-62E7-33C2-89C9-8D745921518F> /Applications/Adobe Photoshop CC 2017/Adobe Photoshop CC 2017.app/Contents/Frameworks/AdobeJP2K.framework/Versions/A/AdobeJP2K
0x1133d2000 - 0x11354cfff +com.adobe.AdobeXMPCore (Adobe XMP Core 5.6 -c 138 - 79.159824) <A870682F-0A58-38CB-B15E-E983C131AC32> /Applications/Adobe Photoshop CC 2017/Adobe Photoshop CC 2017.app/Contents/Frameworks/AdobeXMP.framework/Versions/A/AdobeXMP
0x1136a1000 - 0x1136a1ff7 +cl_kernels (???) <EA673946-537D-49E6-9B7C-D8DBDEEB2D06> cl_kernels
0x1136a6000 - 0x113bfefef +com.nvidia.cg (2.2.0006 - 0) /Applications/Adobe Photoshop CC 2017/Adobe Photoshop CC 2017.app/Contents/Frameworks/Cg.framework/Cg
0x114273000 - 0x11440dfff +com.adobe.headlights.LogSessionFramework (7.4.1.60.45263) <2116CCCF-BA38-366C-8BCE-91827BA52E6D> /Applications/Adobe Photoshop CC 2017/Adobe Photoshop CC 2017.app/Contents/Frameworks/LogSession.framework/Versions/A/LogSession
0x1144e5000 - 0x11522afff +com.adobe.ICUData (4.0 - 3.61) <B9864D01-126E-3C56-B04C-993F9890F6AD> /Applications/Adobe Photoshop CC 2017/Adobe Photoshop CC 2017.app/Contents/Frameworks/ICUData.framework/Versions/4.0/ICUData
0x11523f000 - 0x115268ff7 +com.adobe.PDFSettings (AdobePDFSettings 1.04.0 - 1.4) <E07D101E-E47A-392A-8A44-005B49393DEC> /Applications/Adobe Photoshop CC 2017/Adobe Photoshop CC 2017.app/Contents/Frameworks/AdobePDFSettings.framework/Versions/A/AdobePDFSettings
0x115287000 - 0x11528afff +com.adobe.AdobeCrashReporter (7.3 - 7.3.2) <F09CBDBF-D0F2-3E8B-A039-EC311CD1CCA1> /Applications/Adobe Photoshop CC 2017/Adobe Photoshop CC 2017.app/Contents/Frameworks/AdobeCrashReporter.framework/Versions/A/AdobeCrashReporter
0x115299000 - 0x1152d4ff7 +VulcanMessage5.dylib (5.3.0.16 - 5.3.0.16 Copyright 2016, Adobe Systems Incorporated. All rights reserved.) <4B054DF8-614C-39A7-AC19-CBBA847B9014> /Applications/Adobe Photoshop CC 2017/Adobe Photoshop CC 2017.app/Contents/Frameworks/VulcanMessage5.dylib
0x11531d000 - 0x115419fff +com.adobe.AXEDOMCore (AdobeAXEDOMCore 3.8.0.34320 - 3.8.0.34320) <AFDCC2CF-EF73-323E-A2FA-3034F26F97B9> /Applications/Adobe Photoshop CC 2017/Adobe Photoshop CC 2017.app/Contents/Frameworks/AdobeAXEDOMCore.framework/Versions/A/AdobeAXEDOMCore
0x1154c4000 - 0x115613ff3 +com.adobe.linguistic.LinguisticManager (10.1.0 - 22175) <CEC41C30-5517-3C8E-9998-A2F72308D548> /Applications/Adobe Photoshop CC 2017/Adobe Photoshop CC 2017.app/Contents/Frameworks/AdobeLinguistic.framework/Versions/3/AdobeLinguistic
0x11566a000 - 0x115764ff7 +com.adobe.adobe_caps (adobe_caps 10.0.0.6 - 10.0.0.6) <F42B5047-A935-3B78-9F9A-F4841C6DEE88> /Applications/Adobe Photoshop CC 2017/Adobe Photoshop CC 2017.app/Contents/Frameworks/adobe_caps.framework/Versions/A/adobe_caps
0x115778000 - 0x11587bff7 +com.adobe.ICUUnicode (4.0 - 3.61) <CE487901-E84A-3E54-95AB-91F2EAF57F6A> /Applications/Adobe Photoshop CC 2017/Adobe Photoshop CC 2017.app/Contents/Frameworks/ICUUnicode.framework/Versions/4.0/ICUUnicode
0x1158ca000 - 0x115a11fef +com.adobe.PM (AdbePM 2.5.00.377243 - 2.5.00.377243) <BA6D73F8-6235-30DA-81C9-A5CA7F54A963> /Applications/Adobe Photoshop CC 2017/Adobe Photoshop CC 2017.app/Contents/Frameworks/AdbePM.framework/Versions/A/AdbePM
0x115b6e000 - 0x115d90ff7 +libopencv_core.2.4.9.dylib (0) <305D6C41-9F88-3A40-97D4-DAF5BA2D46EF> /Applications/Adobe Photoshop CC 2017/Adobe Photoshop CC 2017.app/Contents/Frameworks/libopencv_core.2.4.9.dylib
0x115dea000 - 0x115fc7ff7 +libopencv_imgproc.2.4.9.dylib (0) <E5EE040B-2890-35B2-89DB-AA4DADBFDC03> /Applications/Adobe Photoshop CC 2017/Adobe Photoshop CC 2017.app/Contents/Frameworks/libopencv_imgproc.2.4.9.dylib
0x1160b1000 - 0x116343ffb +com.adobe.SVGRE (AdobeSVGRE 6.0 - 6.0) <6A2AF438-1448-33BB-81F2-7058E8E3E1F2> /Applications/Adobe Photoshop CC 2017/Adobe Photoshop CC 2017.app/Contents/Frameworks/AdobeSVGRE.framework/Versions/A/AdobeSVGRE
0x1163c7000 - 0x1164fbfff +com.adobe.AIDE (1.5.0 - 1.5.0.36540) <0E2D02C2-0459-3C81-B9F4-AA5D9A2F9000> /Applications/Adobe Photoshop CC 2017/Adobe Photoshop CC 2017.app/Contents/Frameworks/AIDE.framework/Versions/A/AIDE
0x116797000 - 0x116799ff7 com.apple.textencoding.unicode (3.0 - 3.0) <B8CEE380-5919-3519-8088-119C65562EE9> /System/Library/TextEncodings/Unicode Encodings.bundle/Contents/MacOS/Unicode Encodings
0x11dd28000 - 0x11dd44ff7 libJapaneseConverter.dylib (68) <D80D1583-1F6F-32A5-A683-F504A0DF973A> /System/Library/CoreServices/Encodings/libJapaneseConverter.dylib
0x11dd4a000 - 0x11dd6cff7 libKoreanConverter.dylib (68) <F29010B7-FABC-3CDA-95F5-85DC12B6C91B> /System/Library/CoreServices/Encodings/libKoreanConverter.dylib
0x11dd71000 - 0x11dd80ff7 libSimplifiedChineseConverter.dylib (68) <DCFEA0D3-593E-3E5C-B311-53B8ACF8A318> /System/Library/CoreServices/Encodings/libSimplifiedChineseConverter.dylib
0x11dd85000 - 0x11dd97fff libTraditionalChineseConverter.dylib (68) <62CEE84C-366B-3E43-821B-EE072DBF33D7> /System/Library/CoreServices/Encodings/libTraditionalChineseConverter.dylib
0x11dea0000 - 0x11dee3ff7 +com.adobe.AAM.AdobeUpdaterNotificationFramework (UpdaterNotifications 10.0.0.1 - 10.0.0.1) <624E6E8F-ACC9-3802-83A3-51970E64F769> /Applications/Adobe Photoshop CC 2017/Adobe Photoshop CC 2017.app/Contents/Frameworks/UpdaterNotifications.framework/Versions/A/UpdaterNotifications
0x11deff000 - 0x11df07fff +FastCore (18.1.1 - 18.1.1) <F20E2338-3B28-3C34-BB07-CE946978B58B> /Applications/Adobe Photoshop CC 2017/Adobe Photoshop CC 2017.app/Contents/Required/Plug-Ins/Extensions/FastCore.plugin/Contents/MacOS/FastCore
0x11e6fc000 - 0x11e700fff libFontRegistryUI.dylib (155.2) <8346E80E-5832-3944-A750-FBB9D328C2FE> /System/Library/Frameworks/ApplicationServices.framework/Frameworks/ATS.framework/Resources/libFontRegistryUI.dylib
0x11eaab000 - 0x11eb27fef +MMXCore (18.1.1 - 18.1.1) <A6B54ABB-D74E-39C7-A606-35B8F3FCDAF4> /Applications/Adobe Photoshop CC 2017/Adobe Photoshop CC 2017.app/Contents/Required/Plug-Ins/Extensions/MMXCore.plugin/Contents/MacOS/MMXCore
0x11ebab000 - 0x11ec24ff7 +MultiProcessor Support (18.1.1 - 18.1.1) <A53DC4D5-BB48-3608-94A6-6C839B409A51> /Applications/Adobe Photoshop CC 2017/Adobe Photoshop CC 2017.app/Contents/Required/Plug-Ins/Extensions/MultiProcessor Support.plugin/Contents/MacOS/MultiProcessor Support
0x120f31000 - 0x12107cfff +IMSLib.dylib (10.0.0.11 - 10.0.0.11) <21D0C981-4447-364F-AAAA-F64A310F55B4> /Applications/Adobe Photoshop CC 2017/Adobe Photoshop CC 2017.app/Contents/Frameworks/IMSLib.dylib
0x1215f9000 - 0x1217ecfff com.nvidia.web.GeForceMTLDriverWeb (10.11.14 - 10.1.1) <293ED998-72BF-33D0-AC42-282B8122F6A1> /System/Library/Extensions/GeForceMTLDriverWeb.bundle/Contents/MacOS/GeForceMTLDriverWeb
0x1276b5000 - 0x12775afff ColorSyncDeprecated.dylib (470.3) <A30CB963-667F-39D0-8537-66FCC820F5A6> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ColorSync.framework/Versions/A/Resources/ColorSyncDeprecated.dylib
0x153e80000 - 0x153e91ff7 +MeasurementCore (18.1.1 - 18.1.1) <E5DCB5F1-79E2-3B56-B4A9-6A650EE8B6B4> /Applications/Adobe Photoshop CC 2017/Adobe Photoshop CC 2017.app/Contents/Required/Plug-Ins/Measurements/MeasurementCore.plugin/Contents/MacOS/MeasurementCore
0x1540cb000 - 0x154500fff +com.adobe.PSAutomate (18.1.1 - 18.1.1) <54B32ED4-0367-3E12-837F-06413A5FF034> /Applications/Adobe Photoshop CC 2017/Adobe Photoshop CC 2017.app/Contents/Required/Plug-Ins/Extensions/ScriptingSupport.plugin/Contents/MacOS/ScriptingSupport
0x1547ed000 - 0x1548cdff7 +com.adobe.ps.spaces (18.1.1 - 18.1.1) <976B6154-C2DD-39C4-BF65-9A8AA2EAEB34> /Applications/Adobe Photoshop CC 2017/Adobe Photoshop CC 2017.app/Contents/Required/Plug-Ins/Spaces/Spaces.plugin/Contents/MacOS/Spaces
0x1548f5000 - 0x15a377faf +org.chromium.ContentShell.framework (99.77.34.5 - 34.5) <42663479-0F87-37B7-8694-E2701B2A59B6> /Applications/Adobe Photoshop CC 2017/Adobe Photoshop CC 2017.app/Contents/Required/Plug-Ins/Spaces/Frameworks/Chromium Embedded Framework.framework/Chromium Embedded Framework
0x15aa77000 - 0x15aaaefff com.apple.audio.midi.CoreMIDI (1.10 - 88) <51E79766-51D8-3A95-A7FD-18E7E11528F3> /System/Library/Frameworks/CoreMIDI.framework/Versions/A/CoreMIDI
0x15aad7000 - 0x15aaeaff7 com.apple.GameController (1.0 - 1) <5B98EABB-D27C-3381-9487-21B1C91BF9E8> /System/Library/Frameworks/GameController.framework/Versions/A/GameController
0x15aafc000 - 0x15ab15fff libexpat.1.dylib (12.60.1) <6BF318AC-F90F-3F16-99C2-6ADDE404E280> /usr/lib/libexpat.1.dylib
0x15ade2000 - 0x15adedfff com.apple.iokit.IOHIDLib (2.0.0 - 2.0.0) <B46E04B4-EB85-3436-82C4-158DF1A2AB36> /System/Library/Extensions/IOHIDFamily.kext/Contents/PlugIns/IOHIDLib.plugin/Contents/MacOS/IOHIDLib
0x15cb9f000 - 0x15cbd1ff7 +com.adobe.pip (7.4.1.60.45263) <B0E15E67-5403-3159-8A4F-6D3BDB11D77C> /Applications/Adobe Photoshop CC 2017/Adobe Photoshop CC 2017.app/Contents/Frameworks/AdobePIP.framework/AdobePIP
0x15cbdd000 - 0x15cc06fff +libSLCacheWrapper.dylib (1) <AB5FD9B1-D26B-3599-820A-6E1238597C86> /Applications/Adobe Photoshop CC 2017/Adobe Photoshop CC 2017.app/Contents/Frameworks/LogSession.framework/Libraries/libSLCacheWrapper.dylib
0x15cc20000 - 0x15cc9aff7 com.apple.xquery (1.3.1 - 30) <C1020441-B131-3995-86D9-9D0B725D3FAD> /System/Library/PrivateFrameworks/XQuery.framework/XQuery
0x15ea19000 - 0x15f386fff com.nvidia.web.GeForceGLDriverWeb (10.11.14 - 10.1.1) <0D0C682E-CE22-3724-B251-05A6736FC883> /System/Library/Extensions/GeForceGLDriverWeb.bundle/Contents/MacOS/GeForceGLDriverWeb
0x15fe8c000 - 0x160999ff7 libclhWeb.dylib (0) <4FB1DBC0-6E02-3B9A-A6B4-F225B0CDCD75> /System/Library/Extensions/GeForceGLDriverWeb.bundle/Contents/MacOS/libclhWeb.dylib
0x7fff63b22000 - 0x7fff63b59a47 dyld (360.22) <C8E77F6D-CE86-3C5B-8576-2584A799B51E> /usr/lib/dyld
0x7fff8afd6000 - 0x7fff8afe2fff com.apple.SpeechRecognitionCore (2.2.7 - 2.2.7) <6BA06290-D4A3-351C-87F9-B61EF61FF055> /System/Library/PrivateFrameworks/SpeechRecognitionCore.framework/Versions/A/SpeechRecognitionCore
0x7fff8afe3000 - 0x7fff8b1f0fff libicucore.A.dylib (551.51.5) <2D3634CA-A87A-37A9-A3F4-C3E3106C2A33> /usr/lib/libicucore.A.dylib
0x7fff8b1f1000 - 0x7fff8c457fff com.apple.CoreGraphics (1.600.0 - 960.7) <82D77440-30B2-3DCF-9414-88EC57CAD6CD> /System/Library/Frameworks/CoreGraphics.framework/Versions/A/CoreGraphics
0x7fff8c486000 - 0x7fff8c52dfff com.apple.LanguageModeling (1.0 - 1) <58C18A47-BDE7-3CBE-81C0-797029D170A1> /System/Library/PrivateFrameworks/LanguageModeling.framework/Versions/A/LanguageModeling
0x7fff8c52e000 - 0x7fff8c540fff libsasl2.2.dylib (209) <11C7D200-0CA5-30F4-A19A-178CA81D48FE> /usr/lib/libsasl2.2.dylib
0x7fff8c699000 - 0x7fff8c6f7fff com.apple.SystemConfiguration (1.14 - 1.14) <ACAEDA14-FAA0-3F14-B476-DE492A52D383> /System/Library/Frameworks/SystemConfiguration.framework/Versions/A/SystemConfiguration
0x7fff8c821000 - 0x7fff8c85bff7 com.apple.DebugSymbols (132 - 132) <23A42C53-B941-3871-9EE2-4C87A46005B5> /System/Library/PrivateFrameworks/DebugSymbols.framework/Versions/A/DebugSymbols
0x7fff8c8b9000 - 0x7fff8cadaff7 com.apple.CoreImage (11.4.0 - 366.4.20) <7721BA55-A10E-3425-8392-C5D7C510EAAB> /System/Library/Frameworks/CoreImage.framework/Versions/A/CoreImage
0x7fff8cb3a000 - 0x7fff8cb3dff7 com.apple.AppleSystemInfo (3.1.5 - 3.1.5) <6932B5EC-0EA9-333D-BF7E-665047392FEC> /System/Library/PrivateFrameworks/AppleSystemInfo.framework/Versions/A/AppleSystemInfo
0x7fff8cc48000 - 0x7fff8cd75fff com.apple.CoreText (352.0 - 494.14) <93E0D8C3-D5DD-3EBB-9CC1-831C46572133> /System/Library/Frameworks/CoreText.framework/Versions/A/CoreText
0x7fff8cdd7000 - 0x7fff8cdf2ff7 libCRFSuite.dylib (34) <078B4CD8-6A8C-3067-B2BA-0C2A0BAB8AC3> /usr/lib/libCRFSuite.dylib
0x7fff8cdf3000 - 0x7fff8ce82fff com.apple.CorePDF (4.0 - 4) <849BBFF6-0700-3ED1-98DF-A6E93B9B707F> /System/Library/PrivateFrameworks/CorePDF.framework/Versions/A/CorePDF
0x7fff8cf13000 - 0x7fff8cf13fff com.apple.Cocoa (6.11 - 22) <807787AB-D231-3F51-A99B-A9314623C571> /System/Library/Frameworks/Cocoa.framework/Versions/A/Cocoa
0x7fff8d164000 - 0x7fff8d1b6fff com.apple.CloudDocs (1.0 - 383.13) <5FD9138D-09D9-3B97-BBAD-5692E1687F30> /System/Library/PrivateFrameworks/CloudDocs.framework/Versions/A/CloudDocs
0x7fff8d1bc000 - 0x7fff8d20cff7 com.apple.Symbolication (1.4 - 58044) <F70BF765-FBE9-3F1E-85CA-BB2F8E53E8C2> /System/Library/PrivateFrameworks/Symbolication.framework/Versions/A/Symbolication
0x7fff8d20f000 - 0x7fff8d26dfff com.apple.CoreServices.OSServices (728.13 - 728.13) <477EA3F9-D13E-3D83-ABAD-4DC7DB134CF0> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/OSServices.framework/Versions/A/OSServices
0x7fff8d29a000 - 0x7fff8d2a8fff com.apple.IntlPreferences (2.0 - 192) <388C5784-7713-36B0-B08B-5163E6B04002> /System/Library/PrivateFrameworks/IntlPreferences.framework/Versions/A/IntlPreferences
0x7fff8d2a9000 - 0x7fff8d2abff7 libquarantine.dylib (80) <B3B7B630-9012-3DA3-9458-5C009625E606> /usr/lib/system/libquarantine.dylib
0x7fff8d6f2000 - 0x7fff8e7dbff3 com.apple.WebCore (11601 - 11601.7.5) <9153DA7E-1625-382A-8257-8D4293F06F7F> /System/Library/Frameworks/WebKit.framework/Versions/A/Frameworks/WebCore.framework/Versions/A/WebCore
0x7fff8e7dc000 - 0x7fff8ebb4fef com.apple.CoreAUC (214.0.0 - 214.0.0) <F80C19CA-6CD0-3052-9C22-0288A257CCC8> /System/Library/PrivateFrameworks/CoreAUC.framework/Versions/A/CoreAUC
0x7fff8ebb5000 - 0x7fff8ec04ff7 com.apple.opencl (2.7.0 - 2.7.0) <DAEC71D4-E0E7-3E24-BB44-C977A798C575> /System/Library/Frameworks/OpenCL.framework/Versions/A/OpenCL
0x7fff8ec05000 - 0x7fff8ec51ff7 com.apple.corelocation (1486.17 - 1615.38) <6336CFC5-9D7D-3B76-B263-56DD6EBD0B8D> /System/Library/Frameworks/CoreLocation.framework/Versions/A/CoreLocation
0x7fff8ec52000 - 0x7fff8ec5cfff com.apple.NetAuth (6.0 - 6.0) <D692B1EF-534F-3892-8E2F-2BBA7C8AFD74> /System/Library/PrivateFrameworks/NetAuth.framework/Versions/A/NetAuth
0x7fff8ec5e000 - 0x7fff8ec69fff com.apple.CrashReporterSupport (10.11 - 718) <05892B57-F2CD-3C84-B984-0417F6B361DB> /System/Library/PrivateFrameworks/CrashReporterSupport.framework/Versions/A/CrashReporterSupport
0x7fff8ec98000 - 0x7fff8ec98fff com.apple.audio.units.AudioUnit (1.13 - 1.13) <378B5292-F216-32AB-B628-8C33A72D7052> /System/Library/Frameworks/AudioUnit.framework/Versions/A/AudioUnit
0x7fff8ec99000 - 0x7fff8ed00fff com.apple.framework.CoreWiFi (11.0 - 1101.20) <993592F1-B3F1-3FAD-87BD-EA83C361BCCF> /System/Library/PrivateFrameworks/CoreWiFi.framework/Versions/A/CoreWiFi
0x7fff8ed14000 - 0x7fff8ed15fff liblangid.dylib (122) <9CC4F0D1-5C51-3B69-BC8F-EE3A51FD0822> /usr/lib/liblangid.dylib
0x7fff8ed16000 - 0x7fff8ed19ff7 com.apple.help (1.3.3 - 46) <35DA4D48-0BC2-35A1-8D7C-40905CDF4F64> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Help.framework/Versions/A/Help
0x7fff8ed1a000 - 0x7fff8ed28ff7 libbz2.1.0.dylib (38) <28E54258-C0FE-38D4-AB76-1734CACCB344> /usr/lib/libbz2.1.0.dylib
0x7fff8ed57000 - 0x7fff8f1f2ffb com.apple.GeoServices (1.0 - 1151.49.1) <2D887517-B73D-30FF-91DC-AF6AD91F96B9> /System/Library/PrivateFrameworks/GeoServices.framework/Versions/A/GeoServices
0x7fff8f1f3000 - 0x7fff8f2e5ff7 libiconv.2.dylib (44) <F05A0A5A-92A9-3668-8F20-F27CBDA26BE9> /usr/lib/libiconv.2.dylib
0x7fff8f341000 - 0x7fff8f341ff7 libunc.dylib (29) <DDB1E947-C775-33B8-B461-63E5EB698F0E> /usr/lib/system/libunc.dylib
0x7fff8f34a000 - 0x7fff8f351ff7 com.apple.phonenumbers (1.1.1 - 105) <A616AFB5-2336-385A-B058-16A423D2B21B> /System/Library/PrivateFrameworks/PhoneNumbers.framework/Versions/A/PhoneNumbers
0x7fff8f40f000 - 0x7fff8f77a657 libobjc.A.dylib (680) <D55D5807-1FBE-32A5-9105-44D7AFE68C27> /usr/lib/libobjc.A.dylib
0x7fff8f77b000 - 0x7fff8f791fff com.apple.CoreMediaAuthoring (2.2 - 953) <A8F1B6EE-8ABE-3DC2-9829-A268D016648E> /System/Library/PrivateFrameworks/CoreMediaAuthoring.framework/Versions/A/CoreMediaAuthoring
0x7fff8f894000 - 0x7fff8fb26ffb com.apple.RawCamera.bundle (6.21 - 879) <4F0A10FB-7C96-31E8-9A70-E30F615B2565> /System/Library/CoreServices/RawCamera.bundle/Contents/MacOS/RawCamera
0x7fff8fb27000 - 0x7fff8fb29fff libsystem_coreservices.dylib (19.2) <1B3F5AFC-FFCD-3ECB-8B9A-5538366FB20D> /usr/lib/system/libsystem_coreservices.dylib
0x7fff8fb2a000 - 0x7fff8fb2cfff libCVMSPluginSupport.dylib (12.1) <20BA72AF-C7C5-3551-8F59-E1AED5FC69F0> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libCVMSPluginSupport.dylib
0x7fff8fbb0000 - 0x7fff8fbd2fff com.apple.IconServices (68.1 - 68.1) <CDEEDBE6-F53B-3BA1-82D4-23BCA3DD8949> /System/Library/PrivateFrameworks/IconServices.framework/Versions/A/IconServices
0x7fff8fbd3000 - 0x7fff8fbf5ff7 com.apple.Sharing (442.13.6 - 442.13.6) <DDD2811C-6ECB-32F2-8EE1-69BF9657B4A8> /System/Library/PrivateFrameworks/Sharing.framework/Versions/A/Sharing
0x7fff8ff32000 - 0x7fff90077fff com.apple.QTKit (7.7.3 - 2943.13) <3E3DB3DD-8D7E-3478-B020-F975CCAAE522> /System/Library/Frameworks/QTKit.framework/Versions/A/QTKit
0x7fff9007c000 - 0x7fff90087ff7 libkxld.dylib (3248.70.3) <BAD04BB1-5BFE-3D88-ADDE-23FED2DD2942> /usr/lib/system/libkxld.dylib
0x7fff90088000 - 0x7fff9008cfff libGIF.dylib (1463) <3F84E60B-18E5-3897-8494-DFB1ACE76829> /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libGIF.dylib
0x7fff902f2000 - 0x7fff902f2ff7 liblaunch.dylib (765.70.1) <96D7C3EE-82E2-39AB-870F-B317A030E86D> /usr/lib/system/liblaunch.dylib
0x7fff902f3000 - 0x7fff9030fff7 libextension.dylib (78) <FD952DA6-BBEC-3CB6-98B3-E1D111C5C54E> /usr/lib/libextension.dylib
0x7fff9031d000 - 0x7fff9034afff libdispatch.dylib (501.40.12) <C7499857-61A5-3D7D-A5EA-65DCC8C3DF92> /usr/lib/system/libdispatch.dylib
0x7fff9034b000 - 0x7fff90359fff libxar.1.dylib (302) <03207F66-2C4A-3DBD-8D81-70F4C85903C4> /usr/lib/libxar.1.dylib
0x7fff90370000 - 0x7fff9038cfff com.apple.GenerationalStorage (2.0 - 239.1) <8C821448-4294-3736-9CEF-467C93785CB9> /System/Library/PrivateFrameworks/GenerationalStorage.framework/Versions/A/GenerationalStorage
0x7fff9038d000 - 0x7fff903ceff7 libGLU.dylib (12.1) <CD7A5916-3E3C-3EF3-A275-B281016B99CB> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGLU.dylib
0x7fff90526000 - 0x7fff90e5af5f libLLVMContainer.dylib (119.5) <09A35A20-7CDD-3E5A-94B4-5F1E5CFBC3D9> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libLLVMContainer.dylib
0x7fff90e5b000 - 0x7fff90eaeff7 libc++.1.dylib (120.1) <8FC3D139-8055-3498-9AC5-6467CB7F4D14> /usr/lib/libc++.1.dylib
0x7fff90eaf000 - 0x7fff90fc1fef libvDSP.dylib (563.5) <5702650E-DF08-3D58-B16F-9EF0A28702B3> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libvDSP.dylib
0x7fff90fc2000 - 0x7fff90fc8ff7 com.apple.speech.recognition.framework (5.1.1 - 5.1.1) <9E5A980A-F455-32D5-BBEE-3BD6018CC45E> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/SpeechRecognition.framework/Versions/A/SpeechRecognition
0x7fff9109c000 - 0x7fff910a0fff com.apple.CommonPanels (1.2.6 - 96) <4AE7E5AE-55B3-37FA-9BDE-B23147ADA2E9> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/CommonPanels.framework/Versions/A/CommonPanels
0x7fff910aa000 - 0x7fff910abff3 com.apple.print.framework.Print (10.0 - 266) <3E85F70C-D7D4-34E1-B88A-C1F503F99CDA> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Print.framework/Versions/A/Print
0x7fff910e8000 - 0x7fff91266fff com.apple.UIFoundation (1.0 - 436.1) <AABB5267-E7B7-3D75-B051-E665BDA8DEF4> /System/Library/PrivateFrameworks/UIFoundation.framework/Versions/A/UIFoundation
0x7fff9139a000 - 0x7fff91409fff com.apple.SearchKit (1.4.0 - 1.4.0) <F159A888-34CA-36F1-AC8E-EB1B38C9DFB3> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/SearchKit.framework/Versions/A/SearchKit
0x7fff9140a000 - 0x7fff91527fff libsqlite3.dylib (216.4) <DC3D59E7-91A3-374F-957C-6699729CD82B> /usr/lib/libsqlite3.dylib
0x7fff91558000 - 0x7fff91a7afff com.apple.QuartzComposer (5.1 - 334) <80235264-CA1B-3E3F-96F7-5F6F52FDC5B6> /System/Library/Frameworks/Quartz.framework/Versions/A/Frameworks/QuartzComposer.framework/Versions/A/QuartzComposer
0x7fff91a7b000 - 0x7fff91a80fff com.apple.MediaAccessibility (1.0 - 79) <C5E61B45-1967-3602-A48C-31E132B998B2> /System/Library/Frameworks/MediaAccessibility.framework/Versions/A/MediaAccessibility
0x7fff91afd000 - 0x7fff91b4ffff com.apple.AppleVAFramework (5.0.32 - 5.0.32) <4F5F5CD6-631F-3C97-AA62-7DF19BD5EC15> /System/Library/PrivateFrameworks/AppleVA.framework/Versions/A/AppleVA
0x7fff91b50000 - 0x7fff91ba1fff com.apple.audio.CoreAudio (4.3.0 - 4.3.0) <EA7D4F3B-062B-3C81-A98C-C89264D00D48> /System/Library/Frameworks/CoreAudio.framework/Versions/A/CoreAudio
0x7fff91ba2000 - 0x7fff927cbff7 com.apple.AppKit (6.9 - 1404.47) <F3411F6E-DD87-34D0-8C68-C69B2205E41D> /System/Library/Frameworks/AppKit.framework/Versions/C/AppKit
0x7fff927ce000 - 0x7fff92887ff7 libvMisc.dylib (563.5) <BF612F7D-FA3B-3F9F-8BE7-8D1BCB21ECC5> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libvMisc.dylib
0x7fff92920000 - 0x7fff9294eff7 com.apple.CoreServicesInternal (248.2 - 248.2) <6E111F0A-D7F1-3738-ADE7-CF983BD4EC8B> /System/Library/PrivateFrameworks/CoreServicesInternal.framework/Versions/A/CoreServicesInternal
0x7fff92b3e000 - 0x7fff92be9fff com.apple.PDFKit (3.1 - 3.1) <27AF3C85-1C0B-389C-856C-2E527620C195> /System/Library/Frameworks/Quartz.framework/Versions/A/Frameworks/PDFKit.framework/Versions/A/PDFKit
0x7fff92c4c000 - 0x7fff92c6bff7 com.apple.framework.Apple80211 (11.0 - 1121.34.2) <90477FAE-B835-3931-80FB-FDFF02B21D9D> /System/Library/PrivateFrameworks/Apple80211.framework/Versions/A/Apple80211
0x7fff92c6c000 - 0x7fff92c95ff7 libxpc.dylib (765.70.1) <4FB1311F-4032-3F56-BF0B-CFF45D78FB01> /usr/lib/system/libxpc.dylib
0x7fff92c96000 - 0x7fff92d76ff7 unorm8_rgba.dylib (2.7.3) <9EB6C346-CFF6-32D7-B4A1-2409DFBCB216> /System/Library/Frameworks/OpenCL.framework/Versions/A/Libraries/ImageFormats/unorm8_rgba.dylib
0x7fff92d77000 - 0x7fff92e66ff7 libxml2.2.dylib (29.14) <02077D26-0AB0-347A-8AF2-FADE3CFC296C> /usr/lib/libxml2.2.dylib
0x7fff92e67000 - 0x7fff92e9aff7 com.apple.MediaKit (16 - 809) <BF8032FE-6645-37F6-A622-BC7EEE3EAABF> /System/Library/PrivateFrameworks/MediaKit.framework/Versions/A/MediaKit
0x7fff92ed0000 - 0x7fff92ed8fff com.apple.AppleSRP (5.0 - 1) <840A5C20-6452-36BB-ACF7-29BA6CBF7C48> /System/Library/PrivateFrameworks/AppleSRP.framework/Versions/A/AppleSRP
0x7fff92edc000 - 0x7fff92ee4fff libcopyfile.dylib (127) <A48637BC-F3F2-34F2-BB68-4C65FD012832> /usr/lib/system/libcopyfile.dylib
0x7fff92ee8000 - 0x7fff92eeefff com.apple.IOAccelerator (205.11 - 205.11) <3E86AB1B-C1CF-307D-900F-385C8D8C534A> /System/Library/PrivateFrameworks/IOAccelerator.framework/Versions/A/IOAccelerator
0x7fff92eef000 - 0x7fff92f04ff3 libCGInterfaces.dylib (317.9) <473434E1-5269-3077-A047-D05E024AE631> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vImage.framework/Versions/A/Libraries/libCGInterfaces.dylib
0x7fff92f05000 - 0x7fff92f1fff3 liblzma.5.dylib (10) <CC03591B-FA57-3CA5-AC81-0D76033AC0CE> /usr/lib/liblzma.5.dylib
0x7fff92f22000 - 0x7fff92f24fff libCGXType.A.dylib (970) <A931200A-B248-39EF-8A8B-311D881BE372> /System/Library/Frameworks/CoreGraphics.framework/Versions/A/Resources/libCGXType.A.dylib
0x7fff92f36000 - 0x7fff92f44fff com.apple.opengl (12.1.0 - 12.1.0) <12EBDE6A-2F44-3429-8337-2BB36870BFD8> /System/Library/Frameworks/OpenGL.framework/Versions/A/OpenGL
0x7fff92f56000 - 0x7fff93294ff7 com.apple.WebKit (11601 - 11601.7.8) <58A8B070-2AE4-3909-AE1D-7A7DF34AA268> /System/Library/Frameworks/WebKit.framework/Versions/A/WebKit
0x7fff932c6000 - 0x7fff93312fff com.apple.print.framework.PrintCore (11.2 - 472.2) <5AE8AA6B-CE09-397D-B0D4-0F9CCBF1F77D> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/PrintCore.framework/Versions/A/PrintCore
0x7fff93313000 - 0x7fff93580fff com.apple.imageKit (2.6 - 932) <FAE317B8-DF15-3096-AFAC-464913BF2F3B> /System/Library/Frameworks/Quartz.framework/Versions/A/Frameworks/ImageKit.framework/Versions/A/ImageKit
0x7fff93581000 - 0x7fff93592ff7 libz.1.dylib (61.20.1) <B3EBB42F-48E3-3287-9F0D-308E04D407AC> /usr/lib/libz.1.dylib
0x7fff93593000 - 0x7fff93593fff com.apple.ApplicationServices (48 - 48) <ADD57D3A-142F-3EF5-BFD8-EACD82164884> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/ApplicationServices
0x7fff93594000 - 0x7fff935c6ff7 libTrueTypeScaler.dylib (158.7) <020536E5-C032-30B5-864C-920D5F7DB6DA> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framework/Versions/A/Resources/libTrueTypeScaler.dylib
0x7fff935c7000 - 0x7fff935deff7 libsystem_coretls.dylib (83.40.5) <C90DAE38-4082-381C-A185-2A6A8B677628> /usr/lib/system/libsystem_coretls.dylib
0x7fff9387b000 - 0x7fff93ca9fff com.apple.vision.FaceCore (3.3.1 - 3.3.1) <E54028EA-4217-3078-A2B1-C52E4214D59E> /System/Library/PrivateFrameworks/FaceCore.framework/Versions/A/FaceCore
0x7fff93caa000 - 0x7fff93cdbff7 libtidy.A.dylib (15.17) <6859415D-7A43-384E-ABDD-AA6B2AA9FDCD> /usr/lib/libtidy.A.dylib
0x7fff93d13000 - 0x7fff93d14fff libsystem_blocks.dylib (65) <1244D9D5-F6AA-35BB-B307-86851C24B8E5> /usr/lib/system/libsystem_blocks.dylib
0x7fff93d15000 - 0x7fff93d20fff libGL.dylib (12.1) <70D51643-04AC-3400-8F11-A6FC25985289> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGL.dylib
0x7fff93e20000 - 0x7fff93e25fff com.apple.DiskArbitration (2.7 - 2.7) <8CB47F4A-0FD2-343A-93C8-965174F6F24F> /System/Library/Frameworks/DiskArbitration.framework/Versions/A/DiskArbitration
0x7fff93e26000 - 0x7fff93e3bfff com.apple.ToneKit (1.0 - 1) <6D5AD263-308F-3F70-8D86-7027569D2694> /System/Library/PrivateFrameworks/ToneKit.framework/Versions/A/ToneKit
0x7fff93e3c000 - 0x7fff93ea2ff7 libsystem_network.dylib (583.50.1) <B52DAB73-92DC-3DA7-B9F4-B899D66445C1> /usr/lib/system/libsystem_network.dylib
0x7fff93ea3000 - 0x7fff93ea3fff com.apple.CoreServices (728.13 - 728.13) <CFE3EE73-A3F5-3824-9210-0790C07120F3> /System/Library/Frameworks/CoreServices.framework/Versions/A/CoreServices
0x7fff93eb7000 - 0x7fff93ec0fff com.apple.icloud.FindMyDevice (1.0 - 1) <B9C741F2-6FAC-3BA7-B6E0-9A910C6E8D4E> /System/Library/PrivateFrameworks/FindMyDevice.framework/Versions/A/FindMyDevice
0x7fff93ed9000 - 0x7fff93f6ffff com.apple.ColorSync (4.9.0 - 4.9.0) <8FC37E20-6579-3CB2-9D49-BC39FC38DF87> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ColorSync.framework/Versions/A/ColorSync
0x7fff94564000 - 0x7fff94608fff com.apple.Bluetooth (4.4.6 - 4.4.6f1) <D8ED953B-AD7D-3FE2-8631-E9CBCF6EBAB9> /System/Library/Frameworks/IOBluetooth.framework/Versions/A/IOBluetooth
0x7fff94609000 - 0x7fff94609fff libmetal_timestamp.dylib (600.0.44.2) <DEEA1127-7A5D-3EF2-A4B2-AE125CBA5DB5> /System/Library/PrivateFrameworks/GPUCompiler.framework/libmetal_timestamp.dylib
0x7fff9460a000 - 0x7fff94610fff com.apple.XPCService (2.0 - 1) <5E2122D6-FFA2-3552-BF16-9FD3F36B40DB> /System/Library/PrivateFrameworks/XPCService.framework/Versions/A/XPCService
0x7fff9465c000 - 0x7fff94825ff7 com.apple.ImageIO.framework (3.3.0 - 1462) <1D8FF28C-5DBB-3D23-8CF0-75269C1CE84D> /System/Library/Frameworks/ImageIO.framework/Versions/A/ImageIO
0x7fff94826000 - 0x7fff94842ff7 libsystem_malloc.dylib (67.40.1) <5748E8B2-F81C-34C6-8B13-456213127678> /usr/lib/system/libsystem_malloc.dylib
0x7fff94885000 - 0x7fff94886fff libsystem_secinit.dylib (20) <32B1A8C6-DC84-3F4F-B8CE-9A52B47C3E6B> /usr/lib/system/libsystem_secinit.dylib
0x7fff94887000 - 0x7fff9488cfff com.apple.ImageCapture (9.0 - 9.0) <ACECF0B7-7D92-3A22-BF47-E8FADF4C5378> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/ImageCapture.framework/Versions/A/ImageCapture
0x7fff9494e000 - 0x7fff94953ff7 libmacho.dylib (875.1) <318264FA-58F1-39D8-8285-1F6254EE410E> /usr/lib/system/libmacho.dylib
0x7fff949db000 - 0x7fff94a36ff7 libTIFF.dylib (1463) <5C02D055-02D3-37FE-AABC-487301080941> /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libTIFF.dylib
0x7fff94a46000 - 0x7fff94a4fff3 libsystem_notify.dylib (150.40.1) <D48BDE34-0F7E-34CA-A0FF-C578E39987CC> /usr/lib/system/libsystem_notify.dylib
0x7fff94af0000 - 0x7fff94af8fff com.apple.CoreServices.FSEvents (1223.10.1 - 1223.10.1) <7F5B7A23-BC1D-3FA9-A9B8-D534F1E1979A> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/FSEvents.framework/Versions/A/FSEvents
0x7fff94af9000 - 0x7fff94b4bfff com.apple.ImageCaptureCore (7.0 - 7.0) <9F3123D8-29D2-332F-AD6B-AB9BF1A58022> /System/Library/Frameworks/ImageCaptureCore.framework/Versions/A/ImageCaptureCore
0x7fff94b4c000 - 0x7fff94b54fef libcldcpuengine.dylib (2.7.3) <745C41A3-CEC0-3BF5-91DC-FCB140A3DACE> /System/Library/Frameworks/OpenCL.framework/Versions/A/Libraries/libcldcpuengine.dylib
0x7fff94b55000 - 0x7fff94b57ff7 libRadiance.dylib (1463) <11392BBE-6DAC-3ADD-A0C0-CD653B9AEDE3> /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libRadiance.dylib
0x7fff94b58000 - 0x7fff94b68fff libSparseBLAS.dylib (1162.2) <6F591A0F-80D0-384D-8304-B035C4ED1BBD> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libSparseBLAS.dylib
0x7fff94b9a000 - 0x7fff94bc8ff7 libsandbox.1.dylib (460.60.3) <C8B9F633-EA0C-35CF-9207-1AFDF694EEAD> /usr/lib/libsandbox.1.dylib
0x7fff94c50000 - 0x7fff94c6bfff com.apple.aps.framework (4.0 - 4.0) <CAD47B6E-A581-3B35-885B-67B206F41D5E> /System/Library/PrivateFrameworks/ApplePushService.framework/Versions/A/ApplePushService
0x7fff94edc000 - 0x7fff94ee4fff com.apple.frameworks.CoreDaemon (1.3 - 1.3) <CC53DC12-9231-3C4F-921B-9A770D463323> /System/Library/PrivateFrameworks/CoreDaemon.framework/Versions/B/CoreDaemon
0x7fff94f29000 - 0x7fff94f2eff3 libunwind.dylib (35.3) <F6EB48E5-4D12-359A-AB54-C937FBBE9043> /usr/lib/system/libunwind.dylib
0x7fff94f2f000 - 0x7fff94f58ff7 libxslt.1.dylib (14.5) <8E03110E-1529-3BE8-B5F4-052A47A1674C> /usr/lib/libxslt.1.dylib
0x7fff950cd000 - 0x7fff951f4fff com.apple.LaunchServices (728.13 - 728.13) <91147A89-9D0D-3272-AD05-48E2835BD8D5> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/LaunchServices.framework/Versions/A/LaunchServices
0x7fff951f5000 - 0x7fff951f6fff libDiagnosticMessagesClient.dylib (100) <4243B6B4-21E9-355B-9C5A-95A216233B96> /usr/lib/libDiagnosticMessagesClient.dylib
0x7fff951f7000 - 0x7fff95491ff3 com.apple.security (7.0 - 57337.60.3) <4BF5CF26-6E34-35EC-8D41-58ED65F9BFB8> /System/Library/Frameworks/Security.framework/Versions/A/Security
0x7fff95492000 - 0x7fff954b0ff7 libsystem_kernel.dylib (3248.70.3) <69D68230-7793-3D11-B49E-BA3A6D5137B8> /usr/lib/system/libsystem_kernel.dylib
0x7fff95672000 - 0x7fff9569dff7 com.apple.AddressBook.ContactsFoundation (8.0 - 2137.1) <BAE70E9D-BCC8-3650-B554-6D646388EDEF> /System/Library/PrivateFrameworks/ContactsFoundation.framework/Versions/A/ContactsFoundation
0x7fff9569e000 - 0x7fff956a9ff7 libcommonCrypto.dylib (60075.50.1) <93732261-34B4-3914-B7A2-90A81A182DBA> /usr/lib/system/libcommonCrypto.dylib
0x7fff956b0000 - 0x7fff956dfffb libsystem_m.dylib (3105) <08E1A4B2-6448-3DFE-A58C-ACC7335BE7E4> /usr/lib/system/libsystem_m.dylib
0x7fff95a03000 - 0x7fff95bc3ffb libBLAS.dylib (1162.2) <B4C21826-5EB3-3C6D-B75D-CA4886E2B6A6> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libBLAS.dylib
0x7fff95bf0000 - 0x7fff95bfbff7 libChineseTokenizer.dylib (16) <79B8C67A-3061-3C78-92CD-4650719E68D4> /usr/lib/libChineseTokenizer.dylib
0x7fff95bfc000 - 0x7fff95c6aff7 com.apple.ApplicationServices.ATS (377 - 394.4) <CB64C2B7-828A-3C4C-8F3C-72B78630CD94> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framework/Versions/A/ATS
0x7fff95c6b000 - 0x7fff95c96ffb libarchive.2.dylib (33.20.2.1.1) <BC764A1E-573A-3D95-A3CC-1758935ADC56> /usr/lib/libarchive.2.dylib
0x7fff95c97000 - 0x7fff95ca8ff7 libsystem_trace.dylib (201.10.3) <4F626911-011B-3E9C-8D61-C5EBA79013F0> /usr/lib/system/libsystem_trace.dylib
0x7fff95cb2000 - 0x7fff95cc8ff7 libLinearAlgebra.dylib (1162.2) <FFE54EDF-F06F-3C0A-864A-4CA7BBFD4B2D> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libLinearAlgebra.dylib
0x7fff95cc9000 - 0x7fff95ccbff7 libsystem_configuration.dylib (802.40.13) <3DEB7DF9-6804-37E1-BC83-0166882FF0FF> /usr/lib/system/libsystem_configuration.dylib
0x7fff95ccc000 - 0x7fff95ccffff libspindump.dylib (197.1) <B86EE257-4429-32E9-B98D-B12BFF2A373B> /usr/lib/libspindump.dylib
0x7fff95cd0000 - 0x7fff95d1efff libcurl.4.dylib (90) <12E01E4B-24C9-394C-9D2C-85CF85D5F459> /usr/lib/libcurl.4.dylib
0x7fff95d1f000 - 0x7fff95d21fff com.apple.SecCodeWrapper (4.0 - 261.40.2) <1F832591-59A8-3B3F-943F-D6D827463782> /System/Library/PrivateFrameworks/SecCodeWrapper.framework/Versions/A/SecCodeWrapper
0x7fff95d22000 - 0x7fff95d4cff7 GLRendererFloat (12.1) <0412B850-BB25-33B1-AF0D-8E6297D4620E> /System/Library/Frameworks/OpenGL.framework/Versions/A/Resources/GLRendererFloat.bundle/GLRendererFloat
0x7fff95d8f000 - 0x7fff95db4ff7 libPng.dylib (1463) <17F67BF3-4A78-3587-AAE4-E50A71BDD4CB> /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libPng.dylib
0x7fff95db5000 - 0x7fff95db7fff com.apple.EFILogin (2.0 - 2) <38150198-DD7F-3C73-BCAA-C74BB376393A> /System/Library/PrivateFrameworks/EFILogin.framework/Versions/A/EFILogin
0x7fff95db8000 - 0x7fff95ddffff com.apple.ChunkingLibrary (167 - 167) <AD7F285C-005E-36BB-98A3-5826413533BE> /System/Library/PrivateFrameworks/ChunkingLibrary.framework/Versions/A/ChunkingLibrary
0x7fff95e0c000 - 0x7fff95e14fef libsystem_platform.dylib (74.40.2) <29A905EF-6777-3C33-82B0-6C3A88C4BA15> /usr/lib/system/libsystem_platform.dylib
0x7fff95e15000 - 0x7fff95e2cff7 libsystem_asl.dylib (323.50.1) <41F8E11F-1BD0-3F1D-BA3A-AA1577ED98A9> /usr/lib/system/libsystem_asl.dylib
0x7fff95ecf000 - 0x7fff9624dff3 com.apple.VideoToolbox (1.0 - 1731.15.207) <6C7C261F-CB65-3AF1-92E7-16ACAD371EF4> /System/Library/Frameworks/VideoToolbox.framework/Versions/A/VideoToolbox
0x7fff962b2000 - 0x7fff962c3fff libcmph.dylib (6) <BA4BF2C6-7F4E-33B8-9DD7-619C9EB83ECF> /usr/lib/libcmph.dylib
0x7fff962cc000 - 0x7fff962e9ff7 com.apple.AppleVPAFramework (2.1.2 - 2.1.2) <707C6ED6-B8C0-38D4-B45A-7F2F689BD157> /System/Library/PrivateFrameworks/AppleVPA.framework/Versions/A/AppleVPA
0x7fff965bb000 - 0x7fff96716ff3 com.apple.WebKitLegacy (11601 - 11601.7.8) <F41E6CAF-1157-3868-9FAC-D074FCE74BB9> /System/Library/Frameworks/WebKit.framework/Versions/A/Frameworks/WebKitLegacy.framework/Versions/A/WebKitLegacy
0x7fff970b6000 - 0x7fff970fbff7 com.apple.coreservices.SharedFileList (24.4 - 24.5) <1D2AD77B-778F-3253-A295-3D0A32A8121C> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/SharedFileList.framework/Versions/A/SharedFileList
0x7fff970fc000 - 0x7fff97173feb libcorecrypto.dylib (335.50.1) <B5C05FD7-A540-345A-87BF-8E41848A3C17> /usr/lib/system/libcorecrypto.dylib
0x7fff97174000 - 0x7fff97174fff com.apple.Accelerate (1.10 - Accelerate 1.10) <5831771A-C1C3-3625-9FE9-2CCB6B2E7EE1> /System/Library/Frameworks/Accelerate.framework/Versions/A/Accelerate
0x7fff97175000 - 0x7fff97180fff libcsfde.dylib (517.50.1) <52F0DB6A-13B8-355E-ADFD-72834D3CA183> /usr/lib/libcsfde.dylib
0x7fff97181000 - 0x7fff972cbff7 com.apple.coreui (2.1 - 366.1) <8138636F-A0A7-31C7-896C-5F5747FA1B2A> /System/Library/PrivateFrameworks/CoreUI.framework/Versions/A/CoreUI
0x7fff972d1000 - 0x7fff973c3ff7 libJP2.dylib (1463) <D107FF52-7FD6-3A5E-B40E-F3D0F1FF651D> /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libJP2.dylib
0x7fff973c4000 - 0x7fff973c4fff com.apple.Accelerate.vecLib (3.10 - vecLib 3.10) <848125D3-AF14-3526-8745-FFCDB200CD76> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/vecLib
0x7fff973c5000 - 0x7fff973d8fff com.apple.SafariServices.framework (11604 - 11604.1.38.1.7) <5B649F4B-09D3-3AAC-9801-B6084B91E7D7> /System/Library/PrivateFrameworks/SafariServices.framework/Versions/A/SafariServices
0x7fff974e6000 - 0x7fff974efff7 libsystem_pthread.dylib (138.10.4) <3DD1EF4C-1D1B-3ABF-8CC6-B3B1CEEE9559> /usr/lib/system/libsystem_pthread.dylib
0x7fff974f0000 - 0x7fff97786fff libmecabra.dylib (696.5) <EF6C0BD4-5FE8-34FB-8ADF-69A53CEC97A9> /usr/lib/libmecabra.dylib
0x7fff97793000 - 0x7fff97ae7ff7 com.apple.Foundation (6.9 - 1259.31) <EBB5BE3F-1FE9-3231-B53B-149CDEE8BCA9> /System/Library/Frameworks/Foundation.framework/Versions/C/Foundation
0x7fff97b36000 - 0x7fff97bbefff com.apple.CoreSymbolication (3.1 - 58048.1) <C1A1A8DB-8A51-3A21-865A-3CEF22A0E67A> /System/Library/PrivateFrameworks/CoreSymbolication.framework/Versions/A/CoreSymbolication
0x7fff97bd3000 - 0x7fff97bd6ffb libdyld.dylib (360.22) <7C1BBC59-FA8A-3BDF-B209-02167832E7D1> /usr/lib/system/libdyld.dylib
0x7fff97bd7000 - 0x7fff97d63ff7 libGLProgrammability.dylib (12.1) <6D4C193C-5F7B-3E82-81D9-D14D25BBD962> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGLProgrammability.dylib
0x7fff97d8c000 - 0x7fff97d95ff7 com.apple.CommonAuth (4.0 - 2.0) <4B8673E1-3697-3FE2-8D30-AC7AC5D4F8BF> /System/Library/PrivateFrameworks/CommonAuth.framework/Versions/A/CommonAuth
0x7fff97d96000 - 0x7fff97da9fff com.apple.contacts.ContactsPersistence (1.0 - 2137.1) <71232F20-11BD-370D-9F43-F262BFE46C93> /System/Library/PrivateFrameworks/ContactsPersistence.framework/Versions/A/ContactsPersistence
0x7fff97daa000 - 0x7fff97dc3fe7 libcompression.dylib (28) <F83F421D-115D-3457-A9AA-1BEB5070A30B> /usr/lib/libcompression.dylib
0x7fff97dc4000 - 0x7fff97dcffff com.apple.AppSandbox (4.0 - 261.40.2) <52766210-B6EB-3B73-AB1B-42E0A9AD2EE8> /System/Library/PrivateFrameworks/AppSandbox.framework/Versions/A/AppSandbox
0x7fff985da000 - 0x7fff985ddffb libScreenReader.dylib (426.42) <16FC79D1-4573-3E90-945F-CBA22D5185FD> /usr/lib/libScreenReader.dylib
0x7fff985de000 - 0x7fff985e6fff libMatch.1.dylib (27) <3AC0BFB8-7E69-3DBE-A175-7F3946FC4554> /usr/lib/libMatch.1.dylib
0x7fff985e8000 - 0x7fff986c1fff com.apple.CoreMedia (1.0 - 1731.15.207) <70CAD4A7-3F8B-3767-A420-98BE1062C230> /System/Library/Frameworks/CoreMedia.framework/Versions/A/CoreMedia
0x7fff98f21000 - 0x7fff98f6fff7 libstdc++.6.dylib (104.1) <76E2AFB1-07E5-3F19-B692-F6E21B7E470D> /usr/lib/libstdc++.6.dylib
0x7fff991ca000 - 0x7fff99708ff7 com.apple.MediaToolbox (1.0 - 1731.15.207) <63AD3FB7-BAD3-3040-8A99-843033F24CF6> /System/Library/Frameworks/MediaToolbox.framework/Versions/A/MediaToolbox
0x7fff9972b000 - 0x7fff998d7ff7 com.apple.avfoundation (2.0 - 1046.9.12) <41BDD03F-5545-3B9F-8DD7-7106485BAE8B> /System/Library/Frameworks/AVFoundation.framework/Versions/A/AVFoundation
0x7fff998dd000 - 0x7fff99901ff7 libJPEG.dylib (1463) <11227D36-EA80-3D5B-A7D3-F2AC6C7497EC> /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libJPEG.dylib
0x7fff99a6f000 - 0x7fff99b55ff7 libcrypto.0.9.8.dylib (59.60.1) <D68067AD-D1E0-3196-9796-51BE9B969C8E> /usr/lib/libcrypto.0.9.8.dylib
0x7fff99b56000 - 0x7fff99bb6fff com.apple.QuickLookFramework (5.0 - 696.7) <ECD33169-5EB1-3783-AF9E-1AB9240F8358> /System/Library/Frameworks/QuickLook.framework/Versions/A/QuickLook
0x7fff99dd1000 - 0x7fff99deafff com.apple.openscripting (1.7.1 - 169.1) <36EBF6A7-334A-3197-838F-E8C7B27FCDBB> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/OpenScripting.framework/Versions/A/OpenScripting
0x7fff99df1000 - 0x7fff99e3dffb com.apple.HIServices (1.22 - 550) <6B76B41C-CF5A-34C4-89F4-EFD7CA3D1C9D> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/HIServices.framework/Versions/A/HIServices
0x7fff99e3e000 - 0x7fff99e58fff com.apple.Kerberos (3.0 - 1) <1B4744BF-E5AE-38E2-AA56-E22D3270F2E8> /System/Library/Frameworks/Kerberos.framework/Versions/A/Kerberos
0x7fff99e59000 - 0x7fff99e80fff com.apple.shortcut (2.16 - 93) <2BA6DF3E-04C7-39C8-B311-3413E9FC9022> /System/Library/PrivateFrameworks/Shortcut.framework/Versions/A/Shortcut
0x7fff99eb5000 - 0x7fff99ecafff com.apple.AppContainer (4.0 - 261.40.2) <F220E702-1C00-3BD2-9943-C7E75C3B4418> /System/Library/PrivateFrameworks/AppContainer.framework/Versions/A/AppContainer
0x7fff99ecb000 - 0x7fff99f84ff7 com.apple.cloudkit.CloudKit (482.29 - 482.29) <E235B37E-1491-3857-BDE8-38450D4FE8D0> /System/Library/Frameworks/CloudKit.framework/Versions/A/CloudKit
0x7fff99fe5000 - 0x7fff9a074ff7 libCoreStorage.dylib (517.50.1) <E6283FE9-B5AC-3110-8D4C-8E2BF185983E> /usr/lib/libCoreStorage.dylib
0x7fff9a0df000 - 0x7fff9a124ff3 libFontRegistry.dylib (155.2) <A70DD497-35F3-34DA-9C19-F4B90080E961> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framework/Versions/A/Resources/libFontRegistry.dylib
0x7fff9a132000 - 0x7fff9a55cfff com.apple.ModelIO (1.0 - 1) <8838E0E1-ACB3-3CE8-ABDC-C787D8B3F247> /System/Library/Frameworks/ModelIO.framework/Versions/A/ModelIO
0x7fff9a55f000 - 0x7fff9a576fff libmarisa.dylib (4) <E4919B03-D9BD-3AF8-B436-C415C98E3F0A> /usr/lib/libmarisa.dylib
0x7fff9a57c000 - 0x7fff9a62cfff com.apple.backup.framework (1.7.4 - 1.7.4) <F304E9D1-991A-379E-9659-BF85C35B4808> /System/Library/PrivateFrameworks/Backup.framework/Versions/A/Backup
0x7fff9a669000 - 0x7fff9a688ff7 com.apple.contacts.vCard (1.0 - 2137.1) <41529BD9-1BCC-3A62-92BA-2A7110867355> /System/Library/PrivateFrameworks/vCard.framework/Versions/A/vCard
0x7fff9a694000 - 0x7fff9a89ffff libFosl_dynamic.dylib (16.24) <5F9DB82D-FD4B-3952-8531-CE020F93ED49> /usr/lib/libFosl_dynamic.dylib
0x7fff9a8a0000 - 0x7fff9a8c9fff com.apple.ProtectedCloudStorage (1.0 - 1) <7436B2B3-943A-3500-B099-80F133B3E002> /System/Library/PrivateFrameworks/ProtectedCloudStorage.framework/Versions/A/ProtectedCloudStorage
0x7fff9aa3e000 - 0x7fff9aa6ffff com.apple.GSS (4.0 - 2.0) <B490333A-3B3E-397A-AD75-68846E9A9140> /System/Library/Frameworks/GSS.framework/Versions/A/GSS
0x7fff9aa70000 - 0x7fff9aa7cfff com.apple.speech.synthesis.framework (5.4.12 - 5.4.12) <71DA00B8-5EA2-326B-8814-59DB25512F65> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/SpeechSynthesis.framework/Versions/A/SpeechSynthesis
0x7fff9aa7f000 - 0x7fff9ac2affb GLEngine (12.1) <278B3208-B0D0-3FAE-AC23-A4FA06837311> /System/Library/Frameworks/OpenGL.framework/Versions/A/Resources/GLEngine.bundle/GLEngine
0x7fff9ac2b000 - 0x7fff9ac2bfff com.apple.Carbon (154 - 157) <8F6ED602-5943-3E29-A793-BC331E2C183D> /System/Library/Frameworks/Carbon.framework/Versions/A/Carbon
0x7fff9ac2c000 - 0x7fff9ac3afff com.apple.ToneLibrary (1.0 - 1) <AF05AF34-9BC4-3BA6-81C1-7420F22C9D7D> /System/Library/PrivateFrameworks/ToneLibrary.framework/Versions/A/ToneLibrary
0x7fff9ac49000 - 0x7fff9ac79ff3 com.apple.CoreAVCHD (5.8.0 - 5800.4.2) <4AAFB1C4-3708-30F9-ACFA-90564347204C> /System/Library/PrivateFrameworks/CoreAVCHD.framework/Versions/A/CoreAVCHD
0x7fff9b63b000 - 0x7fff9b679ff7 libGLImage.dylib (12.1) <BB1F1A93-5101-3906-AB17-8D83FCB200F9> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGLImage.dylib
0x7fff9b67a000 - 0x7fff9b6effff com.apple.framework.IOKit (2.0.2 - 1179.50.2) <A509D3AE-9D48-31B7-89C7-326A7A2007B2> /System/Library/Frameworks/IOKit.framework/Versions/A/IOKit
0x7fff9b6f3000 - 0x7fff9b793fff com.apple.ViewBridge (159 - 159) <D8131B7E-DFC9-3FDD-9D56-49821C1D1521> /System/Library/PrivateFrameworks/ViewBridge.framework/Versions/A/ViewBridge
0x7fff9b9ad000 - 0x7fff9b9affff com.apple.loginsupport (1.0 - 1) <9B2F5F9B-ED38-313F-B798-D2B667BCD6B5> /System/Library/PrivateFrameworks/login.framework/Versions/A/Frameworks/loginsupport.framework/Versions/A/loginsupport
0x7fff9b9b0000 - 0x7fff9b9b9ff7 com.apple.DisplayServicesFW (3.0 - 378) <45BE1B99-8E10-32F0-A180-A6B6CB5883AE> /System/Library/PrivateFrameworks/DisplayServices.framework/Versions/A/DisplayServices
0x7fff9b9ba000 - 0x7fff9ba0bff7 libcups.2.dylib (435.2) <91584A40-214D-33E8-A613-CE22289037C8> /usr/lib/libcups.2.dylib
0x7fff9ba0c000 - 0x7fff9ba0cfff libenergytrace.dylib (10.40.1) <0A491CA7-3451-3FD5-999A-58AB4362682B> /usr/lib/libenergytrace.dylib
0x7fff9ba27000 - 0x7fff9ba5bff7 com.apple.CoreVideo (1.8 - 191.3) <1AA24A1B-CB84-3F6B-B6DE-11494542649C> /System/Library/Frameworks/CoreVideo.framework/Versions/A/CoreVideo
0x7fff9ba5c000 - 0x7fff9ba5eff7 com.apple.xpc.ServiceManagement (1.0 - 1) <B4181284-D588-3A20-93F3-B4FA882BC9A8> /System/Library/Frameworks/ServiceManagement.framework/Versions/A/ServiceManagement
0x7fff9ba5f000 - 0x7fff9bab4fff com.apple.AE (701 - 701) <AD492742-F884-386B-A450-FAC281B9FFA4> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/AE.framework/Versions/A/AE
0x7fff9bab5000 - 0x7fff9baf7ff7 com.apple.Metal (56.6 - 56.6) <30518711-8D00-3759-AA19-800D3C88E693> /System/Library/Frameworks/Metal.framework/Versions/A/Metal
0x7fff9baf8000 - 0x7fff9baf9ffb libremovefile.dylib (41) <552EF39E-14D7-363E-9059-4565AC2F894E> /usr/lib/system/libremovefile.dylib
0x7fff9bb1e000 - 0x7fff9bb20ffb libutil.dylib (43) <4C9BFE8B-563B-3EEA-A323-8F4F14E0A46C> /usr/lib/libutil.dylib
0x7fff9bb2e000 - 0x7fff9bb30fff com.apple.CoreDuetDebugLogging (1.0 - 1) <7C932160-AC9C-3173-900F-98138E829CB3> /System/Library/PrivateFrameworks/CoreDuetDebugLogging.framework/Versions/A/CoreDuetDebugLogging
0x7fff9bb8e000 - 0x7fff9bb92fff libcache.dylib (75) <9548AAE9-2AB7-3525-9ECE-A2A7C4688447> /usr/lib/system/libcache.dylib
0x7fff9bc5c000 - 0x7fff9c0d2fff com.apple.CoreFoundation (6.9 - 1259.11) <B8056BE3-151B-3003-91C9-6720CF04937B> /System/Library/Frameworks/CoreFoundation.framework/Versions/A/CoreFoundation
0x7fff9c0d3000 - 0x7fff9c0d6ff7 libCoreFSCache.dylib (119.5) <2389D7DA-B8EF-3EB4-AAAF-FBEDE01CDECA> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libCoreFSCache.dylib
0x7fff9c0d7000 - 0x7fff9c0ebfff com.apple.CoreDuetDaemonProtocol (1.0 - 1) <1D60D60C-914A-3BAB-8607-79F68F4C712E> /System/Library/PrivateFrameworks/CoreDuetDaemonProtocol.framework/Versions/A/CoreDuetDaemonProtocol
0x7fff9c119000 - 0x7fff9c119fff libOpenScriptingUtil.dylib (169.1) <AD0DAC8A-9849-3077-999F-9AEC6112BDAB> /usr/lib/libOpenScriptingUtil.dylib
0x7fff9c11a000 - 0x7fff9c40ffff com.apple.HIToolbox (2.1.1 - 807.2) <36413C45-36AF-34EF-9C0E-F18B31D1E565> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/HIToolbox.framework/Versions/A/HIToolbox
0x7fff9c410000 - 0x7fff9c418ffb libsystem_dnssd.dylib (625.60.4) <80189998-32B0-316C-B5C5-53857486713D> /usr/lib/system/libsystem_dnssd.dylib
0x7fff9c419000 - 0x7fff9c4efffb com.apple.DiskImagesFramework (10.11.4 - 417.4) <FB30D069-648F-3FB2-AA55-FC603606C49E> /System/Library/PrivateFrameworks/DiskImages.framework/Versions/A/DiskImages
0x7fff9c4f0000 - 0x7fff9c4ffffb com.apple.LangAnalysis (1.7.0 - 1.7.0) <18D21123-A3E7-3851-974A-08E5D4540475> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/LangAnalysis.framework/Versions/A/LangAnalysis
0x7fff9cbef000 - 0x7fff9cbfafff com.apple.DirectoryService.Framework (10.11 - 194) <6F827D0E-0F02-3B09-B2A8-252865EECA7F> /System/Library/Frameworks/DirectoryService.framework/Versions/A/DirectoryService
0x7fff9cc14000 - 0x7fff9cc17fff com.apple.IOSurface (108.2.4 - 108.2.4) <E7A63C0D-2FDA-3BC6-947D-07E3C4A13110> /System/Library/Frameworks/IOSurface.framework/Versions/A/IOSurface
0x7fff9ce22000 - 0x7fff9ce35fff com.apple.CoreBluetooth (1.0 - 1) <E54CA9A2-A5C6-30C5-9D6E-8472DBA9371E> /System/Library/Frameworks/CoreBluetooth.framework/Versions/A/CoreBluetooth
0x7fff9ce3d000 - 0x7fff9ce45fff libsystem_networkextension.dylib (385.40.36) <66095DC7-6539-38F2-95EE-458F15F6D014> /usr/lib/system/libsystem_networkextension.dylib
0x7fff9ce46000 - 0x7fff9cecfff7 com.apple.PerformanceAnalysis (1.0 - 1) <9C57BB91-46D6-3FB6-A5A2-8DB1CFE86B72> /System/Library/PrivateFrameworks/PerformanceAnalysis.framework/Versions/A/PerformanceAnalysis
0x7fff9ced0000 - 0x7fff9cfccfff libFontParser.dylib (158.7) <393EFEA3-42B7-38DA-99DA-D01DEAA734CF> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framework/Versions/A/Resources/libFontParser.dylib
0x7fff9d16c000 - 0x7fff9d1e3ff7 com.apple.MMCS (1.3 - 357.1) <549FBEFC-55F7-3101-BF51-A0B1F7CF2B46> /System/Library/PrivateFrameworks/MMCS.framework/Versions/A/MMCS
0x7fff9d1e4000 - 0x7fff9d883ffb com.apple.JavaScriptCore (11601 - 11601.7.8) <38585ADC-1AD4-3BD2-8972-B90344CE57C0> /System/Library/Frameworks/JavaScriptCore.framework/Versions/A/JavaScriptCore
0x7fff9d884000 - 0x7fff9d894ff3 com.apple.ProtocolBuffer (1 - 243) <BAE5E5C9-DD59-3BB8-9741-EEFC5E3046EE> /System/Library/PrivateFrameworks/ProtocolBuffer.framework/Versions/A/ProtocolBuffer
0x7fff9d8be000 - 0x7fff9d8f8fff com.apple.QD (3.12 - 302) <0FE53180-2895-3D14-A1E7-F82DE1D106E1> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/QD.framework/Versions/A/QD
0x7fff9dd1c000 - 0x7fff9dd21fff com.apple.TCC (1.0 - 1) <F5EEB2D3-9517-3975-97BE-22CB8E11B8A3> /System/Library/PrivateFrameworks/TCC.framework/Versions/A/TCC
0x7fff9dd22000 - 0x7fff9dd4cff7 libc++abi.dylib (307.4) <D24E06BF-6522-3C4A-BD0C-11C42BA4D8E8> /usr/lib/libc++abi.dylib
0x7fff9dd5d000 - 0x7fff9dd8cfff com.apple.securityinterface (10.0 - 55065.40.1) <1BB39B19-DD74-347E-A344-0E6781773577> /System/Library/Frameworks/SecurityInterface.framework/Versions/A/SecurityInterface
0x7fff9dd9c000 - 0x7fff9de29dd7 com.apple.AppleJPEG (1.0 - 1) <BF7EDBDB-A52D-37F7-BDE4-EAD49310D7A9> /System/Library/PrivateFrameworks/AppleJPEG.framework/Versions/A/AppleJPEG
0x7fff9de2a000 - 0x7fff9df38ff3 com.apple.desktopservices (1.10.3 - 1.10.3) <3A6906D4-C0B8-30D1-B589-0466E5E42B69> /System/Library/PrivateFrameworks/DesktopServicesPriv.framework/Versions/A/DesktopServicesPriv
0x7fff9df39000 - 0x7fff9df3eff7 com.apple.AssetCacheServices (14.1 - 14.1) <5F249F84-660A-3E94-B073-6729E7ED56D9> /System/Library/PrivateFrameworks/AssetCacheServices.framework/Versions/A/AssetCacheServices
0x7fff9df3f000 - 0x7fff9df4bfff com.apple.HelpData (2.1.4 - 90) <10608EEC-B613-309C-96E6-5A40AB951FA4> /System/Library/PrivateFrameworks/HelpData.framework/Versions/A/HelpData
0x7fff9df4c000 - 0x7fff9e11aff3 com.apple.QuartzCore (1.11 - 410.14) <06A2BE20-38CB-3A89-9629-A782829DF977> /System/Library/Frameworks/QuartzCore.framework/Versions/A/QuartzCore
0x7fff9e11b000 - 0x7fff9e18fff7 com.apple.Heimdal (4.0 - 2.0) <5D365381-8B5E-3259-8867-FC4A7D307BDE> /System/Library/PrivateFrameworks/Heimdal.framework/Versions/A/Heimdal
0x7fff9e190000 - 0x7fff9e193fff libsystem_sandbox.dylib (460.60.3) <2DDCB4AF-3037-34E5-A451-6846AFB9B85C> /usr/lib/system/libsystem_sandbox.dylib
0x7fff9e194000 - 0x7fff9e1daff7 libauto.dylib (186) <999E610F-41FC-32A3-ADCA-5EC049B65DFB> /usr/lib/libauto.dylib
0x7fff9e24d000 - 0x7fff9e4d4fff com.apple.CFNetwork (760.6.5 - 760.6.5) <8A36BBA6-F100-3F39-9711-2FA49D412987> /System/Library/Frameworks/CFNetwork.framework/Versions/A/CFNetwork
0x7fff9e4e8000 - 0x7fff9e4ecfff libpam.2.dylib (20) <CFCD19BD-87BC-3F2B-BB1C-4C23E8E55F1A> /usr/lib/libpam.2.dylib
0x7fff9e4f6000 - 0x7fff9e5dcfef unorm8_bgra.dylib (2.7.3) <B315AE9C-9E09-3D9F-9513-EC2195908516> /System/Library/Frameworks/OpenCL.framework/Versions/A/Libraries/ImageFormats/unorm8_bgra.dylib
0x7fff9e5dd000 - 0x7fff9e648ff7 com.apple.framework.CoreWLAN (11.0 - 1101.20) <3B35C543-7FCE-333F-80C1-432FA41DDCDE> /System/Library/Frameworks/CoreWLAN.framework/Versions/A/CoreWLAN
0x7fff9e754000 - 0x7fff9eb56fff libLAPACK.dylib (1162.2) <42238ED4-6B7A-39D0-BFF2-304A0C287213> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libLAPACK.dylib
0x7fff9eb57000 - 0x7fff9ec0fff7 com.apple.CoreDuet (1.0 - 1) <FC1EAEE1-73A4-3B13-A634-1D2A94D0C0B7> /System/Library/PrivateFrameworks/CoreDuet.framework/Versions/A/CoreDuet
0x7fff9ec10000 - 0x7fff9ec34fff com.apple.quartzfilters (1.10.0 - 1.10.0) <F5C482E2-5AFB-3959-8C01-C149D48E7583> /System/Library/Frameworks/Quartz.framework/Versions/A/Frameworks/QuartzFilters.framework/Versions/A/QuartzFilters
0x7fff9ec6a000 - 0x7fff9ed55ff7 com.apple.QuickLookUIFramework (5.0 - 696.7) <5A4AAFEC-D38C-3DA0-9361-CBF1D4C6B376> /System/Library/Frameworks/Quartz.framework/Versions/A/Frameworks/QuickLookUI.framework/Versions/A/QuickLookUI
0x7fff9ed56000 - 0x7fff9ed57fff com.apple.TrustEvaluationAgent (2.0 - 25) <0239494E-FEFE-39BC-9FC7-E251BA5128F1> /System/Library/PrivateFrameworks/TrustEvaluationAgent.framework/Versions/A/TrustEvaluationAgent
0x7fff9ed58000 - 0x7fff9ed74ff3 libresolv.9.dylib (60) <A650B5C8-1950-36A0-86D1-0B2465318BFA> /usr/lib/libresolv.9.dylib
0x7fff9edd5000 - 0x7fff9ee0cff7 com.apple.LDAPFramework (2.4.28 - 194.5) <9AE33BF2-FB17-342D-8F1E-5F83C6E6EB69> /System/Library/Frameworks/LDAP.framework/Versions/A/LDAP
0x7fff9ee78000 - 0x7fff9ee7bfff libCoreVMClient.dylib (119.5) <560D70FB-709F-3030-96C9-F249FCB7DA6D> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libCoreVMClient.dylib
0x7fff9ee7c000 - 0x7fff9f33afcf com.apple.vImage (8.0 - 8.0) <85FB412E-EB30-3433-A79B-B3970FC83580> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vImage.framework/Versions/A/vImage
0x7fff9f33f000 - 0x7fff9f36eff7 com.apple.DictionaryServices (1.2 - 250.3) <30250542-CBAA-39C1-91AA-B57A5DE17594> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/DictionaryServices.framework/Versions/A/DictionaryServices
0x7fff9f3f2000 - 0x7fff9f402fff libbsm.0.dylib (34) <7E14504C-A8B0-3574-B6EB-5D5FABC72926> /usr/lib/libbsm.0.dylib
0x7fff9f403000 - 0x7fff9f477ff3 com.apple.securityfoundation (6.0 - 55126) <3FF6D6E0-0C5D-385A-A97E-441D3947EFAB> /System/Library/Frameworks/SecurityFoundation.framework/Versions/A/SecurityFoundation
0x7fff9f478000 - 0x7fff9f49cfff com.apple.MultitouchSupport.framework (304.12 - 304.12) <598A8689-E97E-3C8D-AACD-8A0EB1956CA6> /System/Library/PrivateFrameworks/MultitouchSupport.framework/Versions/A/MultitouchSupport
0x7fff9f49d000 - 0x7fff9f4d5ff7 com.apple.RemoteViewServices (2.0 - 101) <B2881449-8CFE-3D1C-B4BF-155640392533> /System/Library/PrivateFrameworks/RemoteViewServices.framework/Versions/A/RemoteViewServices
0x7fff9f4d8000 - 0x7fff9f4e4ff7 com.apple.OpenDirectory (10.11 - 194) <31A67AD5-5CC2-350A-96D7-821DF4BC4196> /System/Library/Frameworks/OpenDirectory.framework/Versions/A/OpenDirectory
0x7fff9f508000 - 0x7fff9f531ffb libRIP.A.dylib (970) <BA17C96B-83CC-3835-8AFD-CB5A69D3D26F> /System/Library/Frameworks/CoreGraphics.framework/Versions/A/Resources/libRIP.A.dylib
0x7fff9f56e000 - 0x7fff9f56efff com.apple.quartzframework (1.5 - 21) <5DC3D0D9-9E3F-3AA5-92F1-F229907A49B9> /System/Library/Frameworks/Quartz.framework/Versions/A/Quartz
0x7fffa0478000 - 0x7fffa0480fff com.apple.NetFS (6.0 - 4.0) <842A5346-24C3-3F22-9ECF-E586A10EA1F2> /System/Library/Frameworks/NetFS.framework/Versions/A/NetFS
0x7fffa0481000 - 0x7fffa06cdff7 com.apple.AddressBook.framework (9.0 - 1679.10) <24F823D3-C3FC-3AF9-B8B3-C166539DBD11> /System/Library/Frameworks/AddressBook.framework/Versions/A/AddressBook
0x7fffa06ef000 - 0x7fffa071effb com.apple.datadetectors (5.0 - 308) <1949868C-BDCD-3772-BDBD-D7E9F2CC1451> /System/Library/PrivateFrameworks/DataDetectors.framework/Versions/A/DataDetectors
0x7fffa071f000 - 0x7fffa071fff7 libkeymgr.dylib (28) <8371CE54-5FDD-3CE9-B3DF-E98C761B6FE0> /usr/lib/system/libkeymgr.dylib
0x7fffa0720000 - 0x7fffa07b5fff com.apple.ink.framework (10.9 - 214) <1F76CF36-3F79-36B8-BC37-C540AF34B338> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Ink.framework/Versions/A/Ink
0x7fffa091a000 - 0x7fffa0943fff libsystem_info.dylib (477.50.4) <FAA9226D-64DE-3769-A6D8-6CABA4B7FF4D> /usr/lib/system/libsystem_info.dylib
0x7fffa0be4000 - 0x7fffa0c9efff com.apple.DiscRecording (9.0.1 - 9010.4.3) <540853B2-B123-3560-8023-C92EE229051A> /System/Library/Frameworks/DiscRecording.framework/Versions/A/DiscRecording
0x7fffa0c9f000 - 0x7fffa0e45ff7 com.apple.audio.toolbox.AudioToolbox (1.13 - 1.13) <370E95BC-956C-3962-86CC-0A14CF6A0389> /System/Library/Frameworks/AudioToolbox.framework/Versions/A/AudioToolbox
0x7fffa0e46000 - 0x7fffa0e4efff libGFXShared.dylib (12.1) <22F78420-D92E-3B5F-BA86-918A34289FCD> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGFXShared.dylib
0x7fffa0e4f000 - 0x7fffa0edcfef libsystem_c.dylib (1082.60.1) <28733D22-553E-3CBC-8D2C-EDCEB46E46AF> /usr/lib/system/libsystem_c.dylib
0x7fffa0f1a000 - 0x7fffa11ffffb com.apple.CoreServices.CarbonCore (1136.2 - 1136.2) <2DBAFC9A-6CD6-351D-B1F4-87D81AA6D640> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/CarbonCore.framework/Versions/A/CarbonCore
0x7fffa1264000 - 0x7fffa12afff7 com.apple.CoreMediaIO (703.0 - 4791) <E49D0C36-295A-311A-9470-706455EA6F80> /System/Library/Frameworks/CoreMediaIO.framework/Versions/A/CoreMediaIO
0x7fffa12b0000 - 0x7fffa12b5ff7 libheimdal-asn1.dylib (453.40.10) <981DE40B-FA16-36F7-BE92-8C8A115D6CD9> /usr/lib/libheimdal-asn1.dylib
0x7fffa12bc000 - 0x7fffa1562ff7 com.apple.CoreData (120 - 641.3) <A29A5491-6169-372B-828F-84EE0CFD4BC4> /System/Library/Frameworks/CoreData.framework/Versions/A/CoreData
0x7fffa1581000 - 0x7fffa1621fff com.apple.Metadata (10.7.0 - 972.34) <B0137597-158A-3503-85C8-F55DB5D21BE1> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/Metadata.framework/Versions/A/Metadata
0x7fffa168f000 - 0x7fffa1690ffb libSystem.B.dylib (1226.10.1) <160608FD-B79D-3B49-AFEA-53A10C0C86B3> /usr/lib/libSystem.B.dylib
0x7fffa1691000 - 0x7fffa1698ff7 libcompiler_rt.dylib (62) <A13ECF69-F59F-38AE-8609-7B731450FBCD> /usr/lib/system/libcompiler_rt.dylib
0x7fffa16ae000 - 0x7fffa171dfff com.apple.datadetectorscore (7.0 - 460) <233A8FBF-B22F-3177-A328-781588D95D69> /System/Library/PrivateFrameworks/DataDetectorsCore.framework/Versions/A/DataDetectorsCore
0x7fffa1783000 - 0x7fffa17e6fff libAVFAudio.dylib (161.2) <1A98DBF3-490B-37FB-928A-AB1E36E6E5DD> /System/Library/Frameworks/AVFoundation.framework/Versions/A/Resources/libAVFAudio.dylib
0x7fffa1841000 - 0x7fffa184cfff libGPUSupportMercury.dylib (12.1) <97C7C8A3-234B-3C7C-8777-611E3D3EE63D> /System/Library/PrivateFrameworks/GPUSupport.framework/Versions/A/Libraries/libGPUSupportMercury.dylib
0x7fffa184d000 - 0x7fffa184fff7 com.apple.securityhi (9.0 - 55006) <AC151C58-A7AD-3ECF-B15D-5E09FF94FC23> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/SecurityHI.framework/Versions/A/SecurityHI
0x7fffa1850000 - 0x7fffa1869fff com.apple.CFOpenDirectory (10.11 - 194) <11F95672-55E0-3F9D-9171-5E8C56AEE948> /System/Library/Frameworks/OpenDirectory.framework/Versions/A/Frameworks/CFOpenDirectory.framework/Versions/A/CFOpenDirectory
0x7fffa18e2000 - 0x7fffa190afff com.apple.GLKit (1.0 - 56) <820F61C9-B74D-3604-BA6E-F20235E2E5B4> /System/Library/Frameworks/GLKit.framework/Versions/A/GLKit
0x7fffa193d000 - 0x7fffa1940fff com.apple.Mangrove (1.0 - 1) <2D86B3AD-64C3-3BB4-BC66-1CFD0C90E844> /System/Library/PrivateFrameworks/Mangrove.framework/Versions/A/Mangrove
External Modification Summary:
Calls made by other processes targeting this process:
task_for_pid: 3
thread_create: 0
thread_set_state: 0
Calls made by this process:
task_for_pid: 0
thread_create: 0
thread_set_state: 0
Calls made by all processes on this machine:
task_for_pid: 2043
thread_create: 0
thread_set_state: 0
VM Region Summary:
ReadOnly portion of Libraries: Total=618.8M resident=0K(0%) swapped_out_or_unallocated=618.8M(100%)
Writable regions: Total=9.7G written=0K(0%) resident=0K(0%) swapped_out=0K(0%) unallocated=9.7G(100%)
VIRTUAL REGION
REGION TYPE SIZE COUNT (non-coalesced)
ATS (font support) 32.3M 8
ATS (font support) (reserved) 8K 3 reserved VM address space (unallocated)
Accelerate.framework 256K 3
Activity Tracing 2048K 2
CG backing stores 38.1M 16
CG image 195.7M 60
CG shared images 1040K 21
CoreAnimation 224K 43
CoreUI image data 2084K 20
CoreUI image file 320K 5
Dispatch continuations 48.0M 2
Foundation 24K 3
Image IO 584K 48
Kernel Alloc Once 8K 3
MALLOC 876.9M 868
MALLOC guard page 48K 11
MALLOC_LARGE (reserved) 5432K 38 reserved VM address space (unallocated)
Memory Tag 242 12K 2
OpenCL 8K 2
OpenGL GLSL 256K 4
Process Corpse Info 2048K 2
STACK GUARD 56.4M 113
Stack 272.0M 121
VM_ALLOCATE 8.2G 57
__DATA 70.9M 379
__GLSLBUILTINS 2588K 2
__IMAGE 528K 2
__LINKEDIT 116.9M 76
__TEXT 501.9M 351
__UNICODE 552K 2
mapped file 220.7M 59
shared memory 16.4M 12
TOTAL 10.6G 2306
TOTAL, minus reserved VM space 10.6G 2306
Model: MacPro5,1, BootROM MP51.007F.B03, 12 processors, 6-Core Intel Xeon, 2.66 GHz, 64 GB, SMC 1.39f11
Graphics: NVIDIA GeForce GTX 980 TI, NVIDIA GeForce GTX 980 TI, PCIe, 6144 MB
Memory Module: DIMM 1, 8 GB, DDR3 ECC, 1333 MHz, 0x857F, 0x463732314752363546393333334700000000
Memory Module: DIMM 2, 8 GB, DDR3 ECC, 1333 MHz, 0x857F, 0x463732314752363546393333334700000000
Memory Module: DIMM 3, 8 GB, DDR3 ECC, 1333 MHz, 0x857F, 0x463732314752363546393333334700000000
Memory Module: DIMM 4, 8 GB, DDR3 ECC, 1333 MHz, 0x857F, 0x463732314752363546393333334700000000
Memory Module: DIMM 5, 8 GB, DDR3 ECC, 1333 MHz, 0x857F, 0x463732314752363546393333334700000000
Memory Module: DIMM 6, 8 GB, DDR3 ECC, 1333 MHz, 0x857F, 0x463732314752363546393333334700000000
Memory Module: DIMM 7, 8 GB, DDR3 ECC, 1333 MHz, 0x857F, 0x463732314752363546393333334700000000
Memory Module: DIMM 8, 8 GB, DDR3 ECC, 1333 MHz, 0x857F, 0x463732314752363546393333334700000000
AirPort: spairport_wireless_card_type_airport_extreme (0x14E4, 0x8E), Broadcom BCM43xx 1.0 (5.106.98.100.24)
Bluetooth: Version 4.4.6f1 17910, 3 services, 27 devices, 1 incoming serial ports
Network Service: Ethernet 1, Ethernet, en0
PCI Card: NVIDIA GeForce GTX 980 TI, Display Controller, Slot-1
PCI Card: NVIDIA GeForce GTX 980 TI, NVDA,Parent, Slot-1
PCI Card: pci10b5,8609, Slot-2
PCI Card: pci1b21,1142, USB eXtensible Host Controller, Slot-2@11,0,0
PCI Card: pci1b21,1142, USB eXtensible Host Controller, Slot-2@10,0,0
PCI Card: pci1b4b,9230, AHCI Controller, Slot-3
PCI Card: pci1b4b,9230, AHCI Controller, Slot-4
PCI Card: pci1b4b,9120, AHCI Controller, Slot-2@9,0,0
PCI Card: pci1b4b,9120, AHCI Controller, Slot-2@8,0,0
PCI Card: pci1b4b,91a4, IDE Controller, Slot-2@9,0,1
PCI Card: pci1b4b,91a4, IDE Controller, Slot-2@8,0,1
Serial ATA Device: HL-DT-ST DVD-RW GH41N
Serial ATA Device: HL-DT-ST BD-RE WH16NS40
Serial ATA Device: Samsung SSD 850 PRO 2TB, 2.05 TB
Serial ATA Device: Samsung SSD 840 EVO 1TB, 1 TB
Serial ATA Device: ElitePro Qx2, 9 TB
Serial ATA Device: 2.74 TB HD Glyph, 3 TB
Serial ATA Device: OWC Mercury Accelsior PCIe SSD, 960.04 GB
Serial ATA Device: MARVELL VIRTUAL
USB Device: USB Bus
USB Device: USB Bus
USB Device: USB Bus
USB Device: BRCM2046 Hub
USB Device: Bluetooth USB Host Controller
USB Device: USB Bus
USB Device: USB Bus
USB Device: USB Bus
USB Device: Intuos5 touch L
USB Device: USB 2.0 Bus
USB Device: HZD
USB Device: USB2.0 Hub
USB Device: Apple Watch Magnetic Charging Cable
USB Device: GL3220
USB Device: SoundSticks
USB Device: Hub
USB Device: Keyboard Hub
USB Device: Apple Keyboard
USB Device: Apple LED Cinema Display
USB Device: Display iSight
USB Device: Display Audio
USB Device: USB 3.0 Bus
FireWire Device: built-in_hub, Up to 800 Mb/sec
Thunderbolt Bus:
Hi
I am not a Mac user so could only test on Windows and could not get the problem to occur. However I do notice that you are not using the latest version of Photoshop which is CC2017.1.1 r252.
You may want to update to that latest version and see if the problem still occurs
Dave
Hi davescm,
Thanks for the reply. In the first crash report I posted, I was using an older version of Photoshop, and a different user suggested I update.
I updated to CC2017.1.1 r252 and sadly, the problem still occurred (I posted the 2nd crash report above).
Oops -sorry my mistake - I missed the second crash report . Hopefully a Mac user will come along soon to offer advice.
Dave
Another user on a different forum recommended that I disable GPU acceleration (I will try that next and see if it helps).
And another user mentioned that they were able to replicate the error on their machine, but that they're beta testing a new version of Photoshop and the problem has been fixed. I'm not sure when this version will get released, though, so still hoping that there's something I can adjust on my end to resolve the issue. Hopefully Adobe (or a Mac user) can check out the crash report(s) I've posted -- can anything be learned from them?
Really appreciate any advice anyone has to offer.
Went to Preferences/Performace/Advanced Settings and unchecked "Use Graphics Processor to Accelerate Computation" and restarted.
Just like in the previous instances, I was able to rotate the view, make a selection, and invert and delete the selection without any problems for the first 5 or so minutes of my session.
Then the software crashed again. The only difference was, I was able to invert the selection, hit "delete", and the program didn't instantly crash -- it took maybe 2 full seconds for the program to crash. (But the cause was still the same -- making a selection with the view rotated, inverting it, and then hitting "delete".
Here is the latest crash report:
Process: Adobe Photoshop CC 2017 [894]
Path: /Applications/Adobe Photoshop CC 2017/Adobe Photoshop CC 2017.app/Contents/MacOS/Adobe Photoshop CC 2017
Identifier: com.adobe.Photoshop
Version: 18.1.1 (18.1.1.252)
Code Type: X86-64 (Native)
Parent Process: ??? [1]
Responsible: Adobe Photoshop CC 2017 [894]
User ID: 501
Date/Time: 2017-10-02 16:10:06.307 -0700
OS Version: Mac OS X 10.11.6 (15G1611)
Report Version: 11
Anonymous UUID: 056FB863-13B4-6410-D572-383FF35796D5
Time Awake Since Boot: 7400 seconds
System Integrity Protection: enabled
Crashed Thread: 0 Dispatch queue: com.apple.main-thread
Exception Type: EXC_BAD_ACCESS (SIGBUS)
Exception Codes: KERN_PROTECTION_FAILURE at 0x0000000125593bd8
Exception Note: EXC_CORPSE_NOTIFY
VM Regions Near 0x125593bd8:
mapped file 000000012540e000-00000001254ed000 [ 892K] r--/rwx SM=COW
--> __TEXT 00000001254ed000-0000000125639000 [ 1328K] r-x/rwx SM=COW /Applications/Adobe Photoshop CC 2017/Adobe Photoshop CC 2017.app/Contents/Frameworks/IMSLib.dylib
__DATA 0000000125639000-0000000125648000 [ 60K] rw-/rwx SM=COW /Applications/Adobe Photoshop CC 2017/Adobe Photoshop CC 2017.app/Contents/Frameworks/IMSLib.dylib
Thread 0 Crashed:: Dispatch queue: com.apple.main-thread
0 MMXCore 0x00000001230843cd 0x123067000 + 119757
1 com.adobe.Photoshop 0x000000010e8744f7 0x10df3e000 + 9659639
2 com.adobe.Photoshop 0x000000010e8881ff 0x10df3e000 + 9740799
3 com.adobe.Photoshop 0x000000010e7057ed 0x10df3e000 + 8157165
4 com.adobe.Photoshop 0x000000010ebc003a 0x10df3e000 + 13115450
5 com.adobe.Photoshop 0x000000010e00379a 0x10df3e000 + 808858
6 com.adobe.Photoshop 0x000000010dfdbb70 0x10df3e000 + 646000
7 com.adobe.Photoshop 0x000000010dfdbc39 0x10df3e000 + 646201
8 com.adobe.Photoshop 0x000000010fe7f78d 0x10df3e000 + 32774029
9 com.apple.Foundation 0x00007fff90c3ae2c __NSFireTimer + 95
10 com.apple.CoreFoundation 0x00007fff950ecae4 __CFRUNLOOP_IS_CALLING_OUT_TO_A_TIMER_CALLBACK_FUNCTION__ + 20
11 com.apple.CoreFoundation 0x00007fff950ec773 __CFRunLoopDoTimer + 1075
12 com.apple.CoreFoundation 0x00007fff950ec2ca __CFRunLoopDoTimers + 298
13 com.apple.CoreFoundation 0x00007fff950e37c1 __CFRunLoopRun + 1841
14 com.apple.CoreFoundation 0x00007fff950e2e28 CFRunLoopRunSpecific + 296
15 com.apple.HIToolbox 0x00007fff95548935 RunCurrentEventLoopInMode + 235
16 com.apple.HIToolbox 0x00007fff9554876f ReceiveNextEventCommon + 432
17 com.apple.HIToolbox 0x00007fff955485af _BlockUntilNextEventMatchingListInModeWithFilter + 71
18 com.apple.AppKit 0x00007fff8afe8df6 _DPSNextEvent + 1067
19 com.apple.AppKit 0x00007fff8afe8226 -[NSApplication _nextEventMatchingEventMask:untilDate:inMode:dequeue:] + 454
20 com.adobe.Photoshop 0x000000010fe7e441 0x10df3e000 + 32769089
21 com.apple.AppKit 0x00007fff8afdcd80 -[NSApplication run] + 682
22 com.adobe.Photoshop 0x000000010fe7f5a2 0x10df3e000 + 32773538
23 com.adobe.Photoshop 0x000000010fe80928 0x10df3e000 + 32778536
24 com.adobe.Photoshop 0x000000010dfdd68d 0x10df3e000 + 652941
25 com.adobe.Photoshop 0x000000010e3557df 0x10df3e000 + 4290527
26 com.adobe.Photoshop 0x000000010e355a69 0x10df3e000 + 4291177
27 libdyld.dylib 0x00007fff90fd45ad start + 1
Thread 1:: Dispatch queue: com.apple.libdispatch-manager
0 libsystem_kernel.dylib 0x00007fff8e8a7efa kevent_qos + 10
1 libdispatch.dylib 0x00007fff89723165 _dispatch_mgr_invoke + 216
2 libdispatch.dylib 0x00007fff89722dcd _dispatch_mgr_thread + 52
Thread 2:: MPSupport Worker
0 libsystem_kernel.dylib 0x00007fff8e8a6db6 __psynch_cvwait + 10
1 libsystem_pthread.dylib 0x00007fff908e8728 _pthread_cond_wait + 767
2 MultiProcessor Support 0x00000001231b10fb 0x123167000 + 303355
3 MultiProcessor Support 0x00000001231b101b 0x123167000 + 303131
4 MultiProcessor Support 0x00000001231d27a6 0x123167000 + 440230
5 libsystem_pthread.dylib 0x00007fff908e799d _pthread_body + 131
6 libsystem_pthread.dylib 0x00007fff908e791a _pthread_start + 168
7 libsystem_pthread.dylib 0x00007fff908e5351 thread_start + 13
Thread 3:: MPSupport Worker
Thread 4:: MPSupport Worker
Thread 5:: MPSupport Worker
Thread 6:: MPSupport Worker
Thread 7:: MPSupport Worker
Thread 8:: MPSupport Worker
Thread 9:: MPSupport Worker
Thread 10:: MPSupport Worker
Thread 11:: MPSupport Worker
Thread 12:: MPSupport Worker
Thread 13:: MPSupport Worker
Thread 14:: MPSupport Worker
Thread 15:: MPSupport Worker
Thread 16:: MPSupport Worker
Thread 17:: MPSupport Worker
Thread 18:: MPSupport Worker
Thread 19:: MPSupport Worker
Thread 20:: MPSupport Worker
Thread 21:: MPSupport Worker
Thread 22:: MPSupport Worker
Thread 23:: MPSupport Worker
Thread 24:: MPSupport Worker
Thread 25:: VulcanMsgRecv
0 libsystem_kernel.dylib 0x00007fff8e8a6fba __recvfrom + 10
1 VulcanMessage5.dylib 0x000000011982f308 vcfoundation::net::Bsd::Recv(int, void*, int, int) + 16
2 VulcanMessage5.dylib 0x000000011982e6cc vcfoundation::io::BSDNamedPipe::Read(void*, unsigned long) + 20
3 VulcanMessage5.dylib 0x000000011982d9c4 vcfoundation::io::BufferedReader::InternalRead(char*, long) + 100
4 VulcanMessage5.dylib 0x000000011982d888 vcfoundation::io::BufferedReader::Read(void*, unsigned long) + 50
5 VulcanMessage5.dylib 0x00000001198284c7 vcfoundation::io::IVCChannel::ReadFully(void*, unsigned long) + 57
6 VulcanMessage5.dylib 0x0000000119828f56 vcfoundation::io::Serializer::InternalDeserialize() + 30
7 VulcanMessage5.dylib 0x00000001198288ef vcfoundation::io::Serializer::Deserialize() + 9
8 VulcanMessage5.dylib 0x000000011982c974 vcfoundation::ncomm::Connection::ReadIn() + 22
9 VulcanMessage5.dylib 0x000000011982c3cd vcfoundation::ncomm::NCService::ReadResponse(vcfoundation::ncomm::INCRequest*, vcfoundation::ncomm::INCListener&, vcfoundation::ncomm::NCService::ConRef&) + 41
10 VulcanMessage5.dylib 0x000000011982c0ba vcfoundation::ncomm::NCService::Execute(vcfoundation::ncomm::INCRequest*, vcfoundation::ncomm::INCListener&) + 166
11 VulcanMessage5.dylib 0x000000011982c00d vcfoundation::ncomm::NCService::Execute(vcfoundation::ncomm::INCRequest*) + 29
12 VulcanMessage5.dylib 0x000000011981f848 adobe::vulcan::servicemgr::CSIRequest::Execute() + 50
13 VulcanMessage5.dylib 0x000000011981ea86 adobe::vulcan::servicemgr::RegisterForEventsRequest::Run() + 622
14 VulcanMessage5.dylib 0x000000011982d20c vcfoundation::thread::AbstractThread::Run() + 72
15 VulcanMessage5.dylib 0x000000011982f109 vcfoundation::thread::Thread::ThreadProc(void*) + 9
16 libsystem_pthread.dylib 0x00007fff908e799d _pthread_body + 131
17 libsystem_pthread.dylib 0x00007fff908e791a _pthread_start + 168
18 libsystem_pthread.dylib 0x00007fff908e5351 thread_start + 13
Thread 26:
0 libsystem_kernel.dylib 0x00007fff8e8a0fae semaphore_wait_trap + 10
1 libtbb.dylib 0x000000011571c100 tbb::internal::rml::private_worker::thread_routine(void*) + 448
2 libsystem_pthread.dylib 0x00007fff908e799d _pthread_body + 131
3 libsystem_pthread.dylib 0x00007fff908e791a _pthread_start + 168
4 libsystem_pthread.dylib 0x00007fff908e5351 thread_start + 13
Thread 27:
Thread 28:
Thread 29:
Thread 30:
Thread 31:
Thread 32:
Thread 33:
Thread 34:
Thread 35:
Thread 36:
Thread 37:
Thread 38:
Thread 39:
Thread 40:
Thread 41:
Thread 42:
Thread 43:
Thread 44:
Thread 45:
Thread 46:
Thread 47:
Thread 48:
Thread 49:: BridgeTalk
0 libsystem_kernel.dylib 0x00007fff8e8a710a __semwait_signal + 10
1 libsystem_c.dylib 0x00007fff9a2ccd0f nanosleep + 199
2 com.adobe.PSAutomate 0x0000000158000ce8 0x157e2d000 + 1916136
3 com.adobe.PSAutomate 0x0000000157fe2b5c 0x157e2d000 + 1792860
4 com.adobe.PSAutomate 0x0000000158000871 0x157e2d000 + 1914993
Thread 50:: Bristle Physics
2 com.adobe.Photoshop 0x000000010e98348b 0x10df3e000 + 10769547
3 com.adobe.Photoshop 0x000000010fd19c65 0x10df3e000 + 31308901
4 com.adobe.Photoshop 0x000000010fd11583 0x10df3e000 + 31274371
5 CITThreading 0x0000000115dca05e boost::(anonymous namespace)::thread_proxy(void*) + 130
Thread 51:: Font Initialization
2 com.adobe.Photoshop 0x000000010e320fb1 0x10df3e000 + 4075441
3 com.adobe.Photoshop 0x000000011022a81c 0x10df3e000 + 36620316
4 com.adobe.Photoshop 0x0000000110229cac 0x10df3e000 + 36617388
5 com.adobe.Photoshop 0x000000011022bba6 0x10df3e000 + 36625318
6 CITThreading 0x0000000115dca05e boost::(anonymous namespace)::thread_proxy(void*) + 130
7 libsystem_pthread.dylib 0x00007fff908e799d _pthread_body + 131
8 libsystem_pthread.dylib 0x00007fff908e791a _pthread_start + 168
9 libsystem_pthread.dylib 0x00007fff908e5351 thread_start + 13
Thread 52:: DeepFont
Thread 53:: com.apple.NSEventThread
0 libsystem_kernel.dylib 0x00007fff8e8a0f72 mach_msg_trap + 10
1 libsystem_kernel.dylib 0x00007fff8e8a03b3 mach_msg + 55
2 com.apple.CoreFoundation 0x00007fff950e4114 __CFRunLoopServiceMachPort + 212
3 com.apple.CoreFoundation 0x00007fff950e35dc __CFRunLoopRun + 1356
5 com.apple.AppKit 0x00007fff8b13ed95 _NSEventThread + 149
Thread 54:
2 com.adobe.headlights.LogSessionFramework 0x0000000118944ccc boost::condition_variable::do_wait_until(boost::unique_lock<boost::mutex>&, timespec const&) + 76
3 com.adobe.headlights.LogSessionFramework 0x00000001189435ef boost::this_thread::hiden::sleep_for(timespec const&) + 191
4 com.adobe.headlights.LogSessionFramework 0x00000001188f1059 void boost::this_thread::sleep_for<long long, boost::ratio<1l, 1l> >(boost::chrono::duration<long long, boost::ratio<1l, 1l> > const&) + 107
5 com.adobe.headlights.LogSessionFramework 0x00000001188bfcfb RealTimeProcessor::WorkerThread(int, int) + 3633
6 com.adobe.headlights.LogSessionFramework 0x0000000118942969 boost::(anonymous namespace)::thread_proxy(void*) + 185
Thread 55:: com.apple.NSURLConnectionLoader
5 com.apple.CFNetwork 0x00007fff97652a6d +[NSURLConnection(Loader) _resourceLoadLoop:] + 412
6 com.apple.Foundation 0x00007fff90bc6c84 __NSThread__start__ + 1351
Thread 56:
2 com.adobe.headlights.LogSessionFramework 0x00000001188f2152 boost::condition_variable::wait_until(boost::unique_lock<boost::mutex>&, boost::chrono::time_point<boost::chrono::system_clock, boost::chrono::duration<long long, boost::ratio<1l, 1000000000l> > >) + 124
3 com.adobe.headlights.LogSessionFramework 0x00000001188f10db void boost::this_thread::sleep_until<boost::chrono::system_clock, boost::chrono::duration<long long, boost::ratio<1l, 1000000000l> > >(boost::chrono::time_point<boost::chrono::system_clock, boost::chrono::duration<long long, boost::ratio<1l, 1000000000l> > > const&) + 124
4 com.adobe.headlights.LogSessionFramework 0x00000001188f0bae IdleTimeLogger::IdleTimeWorkerThread() + 2804
5 com.adobe.headlights.LogSessionFramework 0x0000000118942969 boost::(anonymous namespace)::thread_proxy(void*) + 185
Thread 57:: General Background Service
Thread 58:: Update Activation Menu Items
2 com.adobe.Photoshop 0x000000010e2a13a2 0x10df3e000 + 3552162
3 CITThreading 0x0000000115dca05e boost::(anonymous namespace)::thread_proxy(void*) + 130
4 libsystem_pthread.dylib 0x00007fff908e799d _pthread_body + 131
5 libsystem_pthread.dylib 0x00007fff908e791a _pthread_start + 168
6 libsystem_pthread.dylib 0x00007fff908e5351 thread_start + 13
Thread 59:
2 libc++.1.dylib 0x00007fff8a26068f std::__1::condition_variable::wait(std::__1::unique_lock<std::__1::mutex>&) + 47
3 com.adobe.Photoshop 0x000000010df432fd 0x10df3e000 + 21245
4 com.adobe.Photoshop 0x000000010df43f5b 0x10df3e000 + 24411
5 com.adobe.Photoshop 0x000000010df43d4e 0x10df3e000 + 23886
Thread 60:
Thread 61:
Thread 62:
Thread 63:: com.apple.CFSocket.private
0 libsystem_kernel.dylib 0x00007fff8e8a707a __select + 10
1 com.apple.CoreFoundation 0x00007fff9512145a __CFSocketManager + 762
Thread 64:: NetworkConfigWatcher
5 com.apple.Foundation 0x00007fff90bb5cf9 -[NSRunLoop(NSRunLoop) runMode:beforeDate:] + 270
6 org.chromium.ContentShell.framework 0x0000000159bf7eee 0x158657000 + 22679278
7 org.chromium.ContentShell.framework 0x0000000159bf772c 0x158657000 + 22677292
8 org.chromium.ContentShell.framework 0x0000000159c10113 0x158657000 + 22778131
9 org.chromium.ContentShell.framework 0x0000000159c337d2 0x158657000 + 22923218
10 org.chromium.ContentShell.framework 0x0000000159c2f2f7 0x158657000 + 22905591
11 libsystem_pthread.dylib 0x00007fff908e799d _pthread_body + 131
12 libsystem_pthread.dylib 0x00007fff908e791a _pthread_start + 168
13 libsystem_pthread.dylib 0x00007fff908e5351 thread_start + 13
Thread 65:: DnsConfigService
0 libsystem_kernel.dylib 0x00007fff8e8a7eca kevent + 10
1 org.chromium.ContentShell.framework 0x0000000159c673e7 0x158657000 + 23135207
2 org.chromium.ContentShell.framework 0x0000000159c64ebd 0x158657000 + 23125693
3 org.chromium.ContentShell.framework 0x0000000159bf6e2f 0x158657000 + 22674991
4 org.chromium.ContentShell.framework 0x0000000159c10113 0x158657000 + 22778131
5 org.chromium.ContentShell.framework 0x0000000159c337d2 0x158657000 + 22923218
6 org.chromium.ContentShell.framework 0x0000000159c2f2f7 0x158657000 + 22905591
Thread 66:: Chrome_DBThread
5 org.chromium.ContentShell.framework 0x0000000159bf7c4f 0x158657000 + 22678607
6 org.chromium.ContentShell.framework 0x0000000159bf772c 0x158657000 + 22677292
7 org.chromium.ContentShell.framework 0x0000000159c10113 0x158657000 + 22778131
8 org.chromium.ContentShell.framework 0x000000015932d354 0x158657000 + 13460308
9 org.chromium.ContentShell.framework 0x000000015932d4c3 0x158657000 + 13460675
10 org.chromium.ContentShell.framework 0x0000000159c337d2 0x158657000 + 22923218
11 org.chromium.ContentShell.framework 0x0000000159c2f2f7 0x158657000 + 22905591
12 libsystem_pthread.dylib 0x00007fff908e799d _pthread_body + 131
13 libsystem_pthread.dylib 0x00007fff908e791a _pthread_start + 168
14 libsystem_pthread.dylib 0x00007fff908e5351 thread_start + 13
Thread 67:: Chrome_FileThread
5 org.chromium.ContentShell.framework 0x000000015932d384 0x158657000 + 13460356
6 org.chromium.ContentShell.framework 0x000000015932d4d0 0x158657000 + 13460688
7 org.chromium.ContentShell.framework 0x0000000159c337d2 0x158657000 + 22923218
8 org.chromium.ContentShell.framework 0x0000000159c2f2f7 0x158657000 + 22905591
9 libsystem_pthread.dylib 0x00007fff908e799d _pthread_body + 131
10 libsystem_pthread.dylib 0x00007fff908e791a _pthread_start + 168
11 libsystem_pthread.dylib 0x00007fff908e5351 thread_start + 13
Thread 68:: Chrome_FileUserBlockingThread
8 org.chromium.ContentShell.framework 0x000000015932d3b4 0x158657000 + 13460404
9 org.chromium.ContentShell.framework 0x000000015932d4dd 0x158657000 + 13460701
Thread 69:: Chrome_ProcessLauncherThread
8 org.chromium.ContentShell.framework 0x000000015932d3e4 0x158657000 + 13460452
9 org.chromium.ContentShell.framework 0x000000015932d4ea 0x158657000 + 13460714
Thread 70:: Chrome_CacheThread
8 org.chromium.ContentShell.framework 0x000000015932d414 0x158657000 + 13460500
9 org.chromium.ContentShell.framework 0x000000015932d4f7 0x158657000 + 13460727
Thread 71:: Chrome_IOThread
5 org.chromium.ContentShell.framework 0x000000015932d444 0x158657000 + 13460548
6 org.chromium.ContentShell.framework 0x000000015932d504 0x158657000 + 13460740
Thread 72:: BrowserBlockingWorker1/168707
2 org.chromium.ContentShell.framework 0x0000000159c302cf 0x158657000 + 22909647
3 org.chromium.ContentShell.framework 0x0000000159c2f976 0x158657000 + 22907254
4 org.chromium.ContentShell.framework 0x0000000159c32c5d 0x158657000 + 22920285
5 org.chromium.ContentShell.framework 0x0000000159c2f2f7 0x158657000 + 22905591
Thread 73:: IndexedDB
8 org.chromium.ContentShell.framework 0x0000000159c337d2 0x158657000 + 22923218
9 org.chromium.ContentShell.framework 0x0000000159c2f2f7 0x158657000 + 22905591
10 libsystem_pthread.dylib 0x00007fff908e799d _pthread_body + 131
11 libsystem_pthread.dylib 0x00007fff908e791a _pthread_start + 168
12 libsystem_pthread.dylib 0x00007fff908e5351 thread_start + 13
Thread 74:: CompositorTileWorker1/171523
2 org.chromium.ContentShell.framework 0x0000000159ce6698 0x158657000 + 23656088
3 org.chromium.ContentShell.framework 0x0000000159c32c5d 0x158657000 + 22920285
4 org.chromium.ContentShell.framework 0x0000000159c2f2f7 0x158657000 + 22905591
Thread 75:: AudioThread
Thread 76:: NetworkConfigWatcher
Thread 77:: Chrome_DevToolsHandlerThread
Thread 78:: BrowserBlockingWorker2/180239
Thread 79:: BrowserBlockingWorker3/181043
Thread 80:
5 com.apple.Foundation 0x00007fff90ccdf99 -[NSConnection run] + 149
Thread 81:: CEPMonitorThread
5 com.apple.Foundation 0x00007fff90c5fdda -[NSConcreteTask waitUntilExit] + 205
6 com.adobe.PlugPlugOwl 0x00000001160f4c4b -[HtmlEngineMonitor monitorThreadProc] + 160
7 com.apple.Foundation 0x00007fff90bc6c84 __NSThread__start__ + 1351
8 libsystem_pthread.dylib 0x00007fff908e799d _pthread_body + 131
9 libsystem_pthread.dylib 0x00007fff908e791a _pthread_start + 168
10 libsystem_pthread.dylib 0x00007fff908e5351 thread_start + 13
Thread 82:: CachePoolWorker1/191235
Thread 83:
Thread 84:: CEPMonitorThread
Thread 85:: Background Save
3 com.adobe.Photoshop 0x000000010ff6898c 0x10df3e000 + 33728908
4 com.adobe.Photoshop 0x000000010ff666a9 0x10df3e000 + 33719977
Thread 86:
0 libsystem_kernel.dylib 0x00007fff8e8a75e2 __workq_kernreturn + 10
1 libsystem_pthread.dylib 0x00007fff908e7578 _pthread_wqthread + 1283
2 libsystem_pthread.dylib 0x00007fff908e5341 start_wqthread + 13
Thread 87:
Thread 88:
Thread 89:
Thread 90:
Thread 91:
Thread 92:
Thread 93:
Thread 94:
Thread 95:
Thread 96:
Thread 97:
Thread 98:
Thread 99:
Thread 100:
Thread 101:
Thread 102:
Thread 103:
Thread 104:
Thread 105:
Thread 106:
Thread 107:
Thread 108:
1 libsystem_pthread.dylib 0x00007fff908e875e _pthread_cond_wait + 821
2 com.apple.CoreServices.CarbonCore 0x00007fff9a3bda93 TSWaitOnConditionTimedRelative + 147
3 com.apple.CoreServices.CarbonCore 0x00007fff9a3bd66e TSWaitOnSemaphoreCommon + 406
4 com.apple.CoreServices.CarbonCore 0x00007fff9a3846ea AsyncFileThread(void*) + 275
Thread 109:: Dispatch queue: NSCGSDisableUpdates
2 com.apple.CoreGraphics 0x00007fff84650a42 _CGSReenableUpdateForConnection + 92
3 com.apple.CoreGraphics 0x00007fff8465070d CGSReenableUpdateToken + 469
4 libdispatch.dylib 0x00007fff8972893d _dispatch_call_block_and_release + 12
5 libdispatch.dylib 0x00007fff8971d40b _dispatch_client_callout + 8
6 libdispatch.dylib 0x00007fff8972203b _dispatch_queue_drain + 754
7 libdispatch.dylib 0x00007fff89728707 _dispatch_queue_invoke + 549
8 libdispatch.dylib 0x00007fff8971d40b _dispatch_client_callout + 8
9 libdispatch.dylib 0x00007fff8972129b _dispatch_root_queue_drain + 1890
10 libdispatch.dylib 0x00007fff89720b00 _dispatch_worker_thread3 + 91
11 libsystem_pthread.dylib 0x00007fff908e74de _pthread_wqthread + 1129
12 libsystem_pthread.dylib 0x00007fff908e5341 start_wqthread + 13
Thread 110:
Thread 0 crashed with X86 Thread State (64-bit):
rax: 0x00000000000006e6 rbx: 0x0000000000000008 rcx: 0x00000000000006e8 rdx: 0x0000000000000000
rdi: 0x0000000125593bd8 rsi: 0x0000000000000001 rbp: 0x00007fff51cbebd0 rsp: 0x00007fff51cbe928
r8: 0x0000000000000000 r9: 0x00000000000006e6 r10: 0x0000000000000000 r11: 0x0000000000000006
r12: 0x00000000000006e6 r13: 0x0000000000000008 r14: 0x00000000000006e8 r15: 0x00000000000006e6
rip: 0x00000001230843cd rfl: 0x0000000000010203 cr2: 0x0000000125593bd8
Logical CPU: 10
Error Code: 0x00000007
Trap Number: 14
Binary Images:
0x10df3e000 - 0x11472bf87 +com.adobe.Photoshop (18.1.1 - 18.1.1.252) <B684F32F-915C-3BEA-B7EC-8B5F5820FAAC> /Applications/Adobe Photoshop CC 2017/Adobe Photoshop CC 2017.app/Contents/MacOS/Adobe Photoshop CC 2017
0x11570d000 - 0x115744fef +libtbb.dylib (0) <3441EB5B-2632-3B4C-B76C-9AE5849E7353> /Applications/Adobe Photoshop CC 2017/Adobe Photoshop CC 2017.app/Contents/Frameworks/libtbb.dylib
0x115785000 - 0x1157a8fe7 +libtbbmalloc.dylib (0) <81117D6A-D8E4-37C2-9766-0DC0BF86C06C> /Applications/Adobe Photoshop CC 2017/Adobe Photoshop CC 2017.app/Contents/Frameworks/libtbbmalloc.dylib
0x1157e2000 - 0x11588afff +com.adobe.AdobeExtendScript (ExtendScript 4.5.6 - 4.5.6.5) <0AE6FE3B-AD77-3C9E-AD1B-CEE881FEF5C2> /Applications/Adobe Photoshop CC 2017/Adobe Photoshop CC 2017.app/Contents/Frameworks/AdobeExtendScript.framework/Versions/A/AdobeExtendScript
0x1158e9000 - 0x115987fff +com.adobe.AdobeScCore (ScCore 4.5.6 - 4.5.6.5) <678BE576-32AB-3958-9C04-2504856330E5> /Applications/Adobe Photoshop CC 2017/Adobe Photoshop CC 2017.app/Contents/Frameworks/AdobeScCore.framework/Versions/A/AdobeScCore
0x1159d7000 - 0x115b5aff7 +com.adobe.aif (Adobe Image Foundation Library 6.0.00.1 - 6.0.00.1) <EB941620-7550-301A-98C4-69CDB0577834> /Applications/Adobe Photoshop CC 2017/Adobe Photoshop CC 2017.app/Contents/Frameworks/aif.framework/Versions/A/aif
0x115cb9000 - 0x115d28ff7 +com.adobe.manta (Adobe Manta Library 2.0.00.1 - 2.0.00.1) <48E3C4F3-461F-3F9F-B83A-11BC5D103508> /Applications/Adobe Photoshop CC 2017/Adobe Photoshop CC 2017.app/Contents/Frameworks/manta.framework/Versions/A/manta
0x115dba000 - 0x115dd3fff +CITThreading (???) <F6746740-68D1-3F47-9714-94B42B132BD9> /Applications/Adobe Photoshop CC 2017/Adobe Photoshop CC 2017.app/Contents/Frameworks/CITThreading.framework/Versions/A/CITThreading
0x115e11000 - 0x115f0fff3 +ZXPSignLib-minimal-dylib.dylib (0) <B50C7884-6179-3925-AF15-0013257D0F6B> /Applications/Adobe Photoshop CC 2017/Adobe Photoshop CC 2017.app/Contents/Frameworks/ZXPSignLib-minimal-dylib.dylib
0x115f40000 - 0x116046fff +com.adobe.amtlib (10.0.0.119 - 10.0.0.119) <53139645-73AD-3787-AEE6-579FABE39250> /Applications/Adobe Photoshop CC 2017/Adobe Photoshop CC 2017.app/Contents/Frameworks/amtlib.framework/Versions/A/amtlib
0x11605b000 - 0x1162d1ff3 +com.adobe.PlugPlugOwl (7.0.0.67 - 7.0.0.67) <255982DC-96E4-3C40-AF5A-B46F23B5D372> /Applications/Adobe Photoshop CC 2017/Adobe Photoshop CC 2017.app/Contents/Frameworks/PlugPlugOwl.framework/Versions/A/PlugPlugOwl
0x1165a1000 - 0x116617fff +com.adobe.AdobeSVGAGM (1.0.0 - 1.0.0.37848) <387CF9B9-B873-35B7-8D5E-7ACB4EA61AE7> /Applications/Adobe Photoshop CC 2017/Adobe Photoshop CC 2017.app/Contents/Frameworks/AdobeSVGAGM.framework/Versions/A/AdobeSVGAGM
0x116701000 - 0x1167aaff7 +com.adobe.ICUConverter (4.0 - 3.61) <E20E390A-9BAF-3454-BA16-7B9CCD4CA8F0> /Applications/Adobe Photoshop CC 2017/Adobe Photoshop CC 2017.app/Contents/Frameworks/ICUConverter.framework/Versions/4.0/ICUConverter
0x1167d9000 - 0x1167defff org.twain.dsm (1.9.5 - 1.9.5) <F7AA3C5E-4FB0-379D-8F79-AD06669D087E> /System/Library/Frameworks/TWAIN.framework/Versions/A/TWAIN
0x1167e7000 - 0x116805fff +com.adobe.ahclientframework (2.2.0.1 - 2.2.0.1) <78C9396E-DBAE-3C68-9B67-95B28F2BEC76> /Applications/Adobe Photoshop CC 2017/Adobe Photoshop CC 2017.app/Contents/Frameworks/ahclient.framework/Versions/A/ahclient
0x11681a000 - 0x11681efff com.apple.agl (3.3.1 - AGL-3.3.1) <2FC3E30C-5370-3369-B8D1-1C7050A4A85A> /System/Library/Frameworks/AGL.framework/Versions/A/AGL
0x11682c000 - 0x1169beff7 +com.adobe.owl (AdobeOwl version 5.2.11 - 5.2.11) <CDF9E325-6035-3EF9-8E03-980CD33D6582> /Applications/Adobe Photoshop CC 2017/Adobe Photoshop CC 2017.app/Contents/Frameworks/AdobeOwl.framework/Versions/A/AdobeOwl
0x116a0e000 - 0x116d74ff3 +com.adobe.MPS (AdobeMPS 5.8.1.37174 - 5.8.1.37174) <88508A43-6228-39B1-9377-B49EC9BBE1DE> /Applications/Adobe Photoshop CC 2017/Adobe Photoshop CC 2017.app/Contents/Frameworks/AdobeMPS.framework/Versions/A/AdobeMPS
0x116deb000 - 0x116e0ffff +VulcanControl.dylib (5.3.0.16 - 5.3.0.16 Copyright 2016, Adobe Systems Incorporated. All rights reserved.) <32AA6861-E0A7-37F8-8CE9-FCE97E3BFD07> /Applications/Adobe Photoshop CC 2017/Adobe Photoshop CC 2017.app/Contents/Frameworks/VulcanControl.dylib
0x116e3c000 - 0x117105ffb +com.adobe.AGM (AdobeAGM 4.30.87.37848 - 4.30.87.37848) <7DAE22B9-2F91-385B-B4EA-9EC75CBEE0EF> /Applications/Adobe Photoshop CC 2017/Adobe Photoshop CC 2017.app/Contents/Frameworks/AdobeAGM.framework/Versions/A/AdobeAGM
0x117175000 - 0x117472ffb +com.adobe.CoolType (AdobeCoolType 5.15.00.37848 - 5.15.00.37848) <46381E3C-77F9-3842-8A13-33BDEFA6E1D7> /Applications/Adobe Photoshop CC 2017/Adobe Photoshop CC 2017.app/Contents/Frameworks/AdobeCoolType.framework/Versions/A/AdobeCoolType
0x1174c0000 - 0x1174e3ff3 +com.adobe.BIBUtils (AdobeBIBUtils 1.1.01 - 1.1.01) <B71D4C22-E568-3088-AED2-7D14B810D74A> /Applications/Adobe Photoshop CC 2017/Adobe Photoshop CC 2017.app/Contents/Frameworks/AdobeBIBUtils.framework/Versions/A/AdobeBIBUtils
0x1174f1000 - 0x117515ff7 +com.adobe.AXE8SharedExpat (AdobeAXE8SharedExpat 3.8.0.34320 - 3.8.0.34320) <674F1792-D790-3E12-8C0F-85CAF9D848B1> /Applications/Adobe Photoshop CC 2017/Adobe Photoshop CC 2017.app/Contents/Frameworks/AdobeAXE8SharedExpat.framework/Versions/A/AdobeAXE8SharedExpat
0x11753d000 - 0x117667ff7 +com.winsoft.wrservices (WRServices 12.1.0 - 12.1.0) <75B95734-75E4-3E7E-B8E3-DB51C053E4DC> /Applications/Adobe Photoshop CC 2017/Adobe Photoshop CC 2017.app/Contents/Frameworks/WRServices.framework/Versions/A/WRServices
0x1176bc000 - 0x117806ff7 +com.adobe.ACE (AdobeACE 2.20.02.37848 - 2.20.02.37848) <3236E6F5-C286-3C46-AD03-9838AFE1D751> /Applications/Adobe Photoshop CC 2017/Adobe Photoshop CC 2017.app/Contents/Frameworks/AdobeACE.framework/Versions/A/AdobeACE
0x11781c000 - 0x117838ffb +com.adobe.BIB (AdobeBIB 1.2.03.37848 - 1.2.03.37848) <28247879-8E7A-3B40-9012-FF1E849D7236> /Applications/Adobe Photoshop CC 2017/Adobe Photoshop CC 2017.app/Contents/Frameworks/AdobeBIB.framework/Versions/A/AdobeBIB
0x117846000 - 0x117906ff7 +com.adobe.JP2K (1.2.2 - 1.2.2.38234) <FA7EDCFB-62E7-33C2-89C9-8D745921518F> /Applications/Adobe Photoshop CC 2017/Adobe Photoshop CC 2017.app/Contents/Frameworks/AdobeJP2K.framework/Versions/A/AdobeJP2K
0x117951000 - 0x117acbfff +com.adobe.AdobeXMPCore (Adobe XMP Core 5.6 -c 138 - 79.159824) <A870682F-0A58-38CB-B15E-E983C131AC32> /Applications/Adobe Photoshop CC 2017/Adobe Photoshop CC 2017.app/Contents/Frameworks/AdobeXMP.framework/Versions/A/AdobeXMP
0x117c1f000 - 0x118177fef +com.nvidia.cg (2.2.0006 - 0) /Applications/Adobe Photoshop CC 2017/Adobe Photoshop CC 2017.app/Contents/Frameworks/Cg.framework/Cg
0x1187e5000 - 0x1187e6fff libCyrillicConverter.dylib (68) <79F5CFEF-92E4-30FE-A650-41F07B6D31B9> /System/Library/CoreServices/Encodings/libCyrillicConverter.dylib
0x1187ec000 - 0x118986fff +com.adobe.headlights.LogSessionFramework (7.4.1.60.45263) <2116CCCF-BA38-366C-8BCE-91827BA52E6D> /Applications/Adobe Photoshop CC 2017/Adobe Photoshop CC 2017.app/Contents/Frameworks/LogSession.framework/Versions/A/LogSession
0x118a60000 - 0x1197a5fff +com.adobe.ICUData (4.0 - 3.61) <B9864D01-126E-3C56-B04C-993F9890F6AD> /Applications/Adobe Photoshop CC 2017/Adobe Photoshop CC 2017.app/Contents/Frameworks/ICUData.framework/Versions/4.0/ICUData
0x1197bb000 - 0x1197e4ff7 +com.adobe.PDFSettings (AdobePDFSettings 1.04.0 - 1.4) <E07D101E-E47A-392A-8A44-005B49393DEC> /Applications/Adobe Photoshop CC 2017/Adobe Photoshop CC 2017.app/Contents/Frameworks/AdobePDFSettings.framework/Versions/A/AdobePDFSettings
0x119801000 - 0x119804fff +com.adobe.AdobeCrashReporter (7.3 - 7.3.2) <F09CBDBF-D0F2-3E8B-A039-EC311CD1CCA1> /Applications/Adobe Photoshop CC 2017/Adobe Photoshop CC 2017.app/Contents/Frameworks/AdobeCrashReporter.framework/Versions/A/AdobeCrashReporter
0x119811000 - 0x11984cff7 +VulcanMessage5.dylib (5.3.0.16 - 5.3.0.16 Copyright 2016, Adobe Systems Incorporated. All rights reserved.) <4B054DF8-614C-39A7-AC19-CBBA847B9014> /Applications/Adobe Photoshop CC 2017/Adobe Photoshop CC 2017.app/Contents/Frameworks/VulcanMessage5.dylib
0x11989b000 - 0x119997fff +com.adobe.AXEDOMCore (AdobeAXEDOMCore 3.8.0.34320 - 3.8.0.34320) <AFDCC2CF-EF73-323E-A2FA-3034F26F97B9> /Applications/Adobe Photoshop CC 2017/Adobe Photoshop CC 2017.app/Contents/Frameworks/AdobeAXEDOMCore.framework/Versions/A/AdobeAXEDOMCore
0x119a41000 - 0x119b90ff3 +com.adobe.linguistic.LinguisticManager (10.1.0 - 22175) <CEC41C30-5517-3C8E-9998-A2F72308D548> /Applications/Adobe Photoshop CC 2017/Adobe Photoshop CC 2017.app/Contents/Frameworks/AdobeLinguistic.framework/Versions/3/AdobeLinguistic
0x119beb000 - 0x119ce5ff7 +com.adobe.adobe_caps (adobe_caps 10.0.0.6 - 10.0.0.6) <F42B5047-A935-3B78-9F9A-F4841C6DEE88> /Applications/Adobe Photoshop CC 2017/Adobe Photoshop CC 2017.app/Contents/Frameworks/adobe_caps.framework/Versions/A/adobe_caps
0x119cfb000 - 0x119dfeff7 +com.adobe.ICUUnicode (4.0 - 3.61) <CE487901-E84A-3E54-95AB-91F2EAF57F6A> /Applications/Adobe Photoshop CC 2017/Adobe Photoshop CC 2017.app/Contents/Frameworks/ICUUnicode.framework/Versions/4.0/ICUUnicode
0x119e4e000 - 0x119f95fef +com.adobe.PM (AdbePM 2.5.00.377243 - 2.5.00.377243) <BA6D73F8-6235-30DA-81C9-A5CA7F54A963> /Applications/Adobe Photoshop CC 2017/Adobe Photoshop CC 2017.app/Contents/Frameworks/AdbePM.framework/Versions/A/AdbePM
0x11a0f3000 - 0x11a315ff7 +libopencv_core.2.4.9.dylib (0) <305D6C41-9F88-3A40-97D4-DAF5BA2D46EF> /Applications/Adobe Photoshop CC 2017/Adobe Photoshop CC 2017.app/Contents/Frameworks/libopencv_core.2.4.9.dylib
0x11a36a000 - 0x11a547ff7 +libopencv_imgproc.2.4.9.dylib (0) <E5EE040B-2890-35B2-89DB-AA4DADBFDC03> /Applications/Adobe Photoshop CC 2017/Adobe Photoshop CC 2017.app/Contents/Frameworks/libopencv_imgproc.2.4.9.dylib
0x11a62e000 - 0x11a8c0ffb +com.adobe.SVGRE (AdobeSVGRE 6.0 - 6.0) <6A2AF438-1448-33BB-81F2-7058E8E3E1F2> /Applications/Adobe Photoshop CC 2017/Adobe Photoshop CC 2017.app/Contents/Frameworks/AdobeSVGRE.framework/Versions/A/AdobeSVGRE
0x11a940000 - 0x11aa74fff +com.adobe.AIDE (1.5.0 - 1.5.0.36540) <0E2D02C2-0459-3C81-B9F4-AA5D9A2F9000> /Applications/Adobe Photoshop CC 2017/Adobe Photoshop CC 2017.app/Contents/Frameworks/AIDE.framework/Versions/A/AIDE
0x11ad10000 - 0x11ad12ff7 com.apple.textencoding.unicode (3.0 - 3.0) <B8CEE380-5919-3519-8088-119C65562EE9> /System/Library/TextEncodings/Unicode Encodings.bundle/Contents/MacOS/Unicode Encodings
0x11ade3000 - 0x11adf2ff7 libSimplifiedChineseConverter.dylib (68) <DCFEA0D3-593E-3E5C-B311-53B8ACF8A318> /System/Library/CoreServices/Encodings/libSimplifiedChineseConverter.dylib
0x1222c0000 - 0x1222dcff7 libJapaneseConverter.dylib (68) <D80D1583-1F6F-32A5-A683-F504A0DF973A> /System/Library/CoreServices/Encodings/libJapaneseConverter.dylib
0x1222e2000 - 0x122304ff7 libKoreanConverter.dylib (68) <F29010B7-FABC-3CDA-95F5-85DC12B6C91B> /System/Library/CoreServices/Encodings/libKoreanConverter.dylib
0x122309000 - 0x12231bfff libTraditionalChineseConverter.dylib (68) <62CEE84C-366B-3E43-821B-EE072DBF33D7> /System/Library/CoreServices/Encodings/libTraditionalChineseConverter.dylib
0x12245c000 - 0x12249fff7 +com.adobe.AAM.AdobeUpdaterNotificationFramework (UpdaterNotifications 10.0.0.1 - 10.0.0.1) <624E6E8F-ACC9-3802-83A3-51970E64F769> /Applications/Adobe Photoshop CC 2017/Adobe Photoshop CC 2017.app/Contents/Frameworks/UpdaterNotifications.framework/Versions/A/UpdaterNotifications
0x1224bb000 - 0x1224c3fff +FastCore (18.1.1 - 18.1.1) <F20E2338-3B28-3C34-BB07-CE946978B58B> /Applications/Adobe Photoshop CC 2017/Adobe Photoshop CC 2017.app/Contents/Required/Plug-Ins/Extensions/FastCore.plugin/Contents/MacOS/FastCore
0x123067000 - 0x1230e3fef +MMXCore (18.1.1 - 18.1.1) <A6B54ABB-D74E-39C7-A606-35B8F3FCDAF4> /Applications/Adobe Photoshop CC 2017/Adobe Photoshop CC 2017.app/Contents/Required/Plug-Ins/Extensions/MMXCore.plugin/Contents/MacOS/MMXCore
0x123167000 - 0x1231e0ff7 +MultiProcessor Support (18.1.1 - 18.1.1) <A53DC4D5-BB48-3608-94A6-6C839B409A51> /Applications/Adobe Photoshop CC 2017/Adobe Photoshop CC 2017.app/Contents/Required/Plug-Ins/Extensions/MultiProcessor Support.plugin/Contents/MacOS/MultiProcessor Support
0x1254ed000 - 0x125638fff +IMSLib.dylib (10.0.0.11 - 10.0.0.11) <21D0C981-4447-364F-AAAA-F64A310F55B4> /Applications/Adobe Photoshop CC 2017/Adobe Photoshop CC 2017.app/Contents/Frameworks/IMSLib.dylib
0x12ad93000 - 0x12ad97fff libFontRegistryUI.dylib (155.2) <8346E80E-5832-3944-A750-FBB9D328C2FE> /System/Library/Frameworks/ApplicationServices.framework/Frameworks/ATS.framework/Resources/libFontRegistryUI.dylib
0x12add2000 - 0x12ae77fff ColorSyncDeprecated.dylib (470.3) <A30CB963-667F-39D0-8537-66FCC820F5A6> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ColorSync.framework/Versions/A/Resources/ColorSyncDeprecated.dylib
0x12b2c7000 - 0x12b2d2fff com.apple.iokit.IOHIDLib (2.0.0 - 2.0.0) <B46E04B4-EB85-3436-82C4-158DF1A2AB36> /System/Library/Extensions/IOHIDFamily.kext/Contents/PlugIns/IOHIDLib.plugin/Contents/MacOS/IOHIDLib
0x14740f000 - 0x147414fff libgermantok.dylib (17) <B230A9A9-EC4C-306C-8C65-7143285DA142> /usr/lib/libgermantok.dylib
0x157687000 - 0x157698ff7 +MeasurementCore (18.1.1 - 18.1.1) <E5DCB5F1-79E2-3B56-B4A9-6A650EE8B6B4> /Applications/Adobe Photoshop CC 2017/Adobe Photoshop CC 2017.app/Contents/Required/Plug-Ins/Measurements/MeasurementCore.plugin/Contents/MacOS/MeasurementCore
0x157832000 - 0x157864ff7 +com.adobe.pip (7.4.1.60.45263) <B0E15E67-5403-3159-8A4F-6D3BDB11D77C> /Applications/Adobe Photoshop CC 2017/Adobe Photoshop CC 2017.app/Contents/Frameworks/AdobePIP.framework/AdobePIP
0x157870000 - 0x157899fff +libSLCacheWrapper.dylib (1) <AB5FD9B1-D26B-3599-820A-6E1238597C86> /Applications/Adobe Photoshop CC 2017/Adobe Photoshop CC 2017.app/Contents/Frameworks/LogSession.framework/Libraries/libSLCacheWrapper.dylib
0x157b74000 - 0x157d67fff com.nvidia.web.GeForceMTLDriverWeb (10.11.14 - 10.1.1) <293ED998-72BF-33D0-AC42-282B8122F6A1> /System/Library/Extensions/GeForceMTLDriverWeb.bundle/Contents/MacOS/GeForceMTLDriverWeb
0x157e2d000 - 0x158262fff +com.adobe.PSAutomate (18.1.1 - 18.1.1) <54B32ED4-0367-3E12-837F-06413A5FF034> /Applications/Adobe Photoshop CC 2017/Adobe Photoshop CC 2017.app/Contents/Required/Plug-Ins/Extensions/ScriptingSupport.plugin/Contents/MacOS/ScriptingSupport
0x15854f000 - 0x15862fff7 +com.adobe.ps.spaces (18.1.1 - 18.1.1) <976B6154-C2DD-39C4-BF65-9A8AA2EAEB34> /Applications/Adobe Photoshop CC 2017/Adobe Photoshop CC 2017.app/Contents/Required/Plug-Ins/Spaces/Spaces.plugin/Contents/MacOS/Spaces
0x158657000 - 0x15e0d9faf +org.chromium.ContentShell.framework (99.77.34.5 - 34.5) <42663479-0F87-37B7-8694-E2701B2A59B6> /Applications/Adobe Photoshop CC 2017/Adobe Photoshop CC 2017.app/Contents/Required/Plug-Ins/Spaces/Frameworks/Chromium Embedded Framework.framework/Chromium Embedded Framework
0x15e7d9000 - 0x15e810fff com.apple.audio.midi.CoreMIDI (1.10 - 88) <51E79766-51D8-3A95-A7FD-18E7E11528F3> /System/Library/Frameworks/CoreMIDI.framework/Versions/A/CoreMIDI
0x15e839000 - 0x15e84cff7 com.apple.GameController (1.0 - 1) <5B98EABB-D27C-3381-9487-21B1C91BF9E8> /System/Library/Frameworks/GameController.framework/Versions/A/GameController
0x15e85e000 - 0x15e877fff libexpat.1.dylib (12.60.1) <6BF318AC-F90F-3F16-99C2-6ADDE404E280> /usr/lib/libexpat.1.dylib
0x160a72000 - 0x1613dffff com.nvidia.web.GeForceGLDriverWeb (10.11.14 - 10.1.1) <0D0C682E-CE22-3724-B251-05A6736FC883> /System/Library/Extensions/GeForceGLDriverWeb.bundle/Contents/MacOS/GeForceGLDriverWeb
0x161ee5000 - 0x1629f2ff7 libclhWeb.dylib (0) <4FB1DBC0-6E02-3B9A-A6B4-F225B0CDCD75> /System/Library/Extensions/GeForceGLDriverWeb.bundle/Contents/MacOS/libclhWeb.dylib
0x1669aa000 - 0x166a24ff7 com.apple.xquery (1.3.1 - 30) <C1020441-B131-3995-86D9-9D0B725D3FAD> /System/Library/PrivateFrameworks/XQuery.framework/XQuery
0x16b730000 - 0x16b730ff7 +cl_kernels (???) <EA673946-537D-49E6-9B7C-D8DBDEEB2D06> cl_kernels
0x7fff6943c000 - 0x7fff69473a47 dyld (360.22) <C8E77F6D-CE86-3C5B-8576-2584A799B51E> /usr/lib/dyld
0x7fff843d4000 - 0x7fff843e0fff com.apple.SpeechRecognitionCore (2.2.7 - 2.2.7) <6BA06290-D4A3-351C-87F9-B61EF61FF055> /System/Library/PrivateFrameworks/SpeechRecognitionCore.framework/Versions/A/SpeechRecognitionCore
0x7fff843e1000 - 0x7fff845eefff libicucore.A.dylib (551.51.5) <2D3634CA-A87A-37A9-A3F4-C3E3106C2A33> /usr/lib/libicucore.A.dylib
0x7fff845ef000 - 0x7fff85855fff com.apple.CoreGraphics (1.600.0 - 960.7) <82D77440-30B2-3DCF-9414-88EC57CAD6CD> /System/Library/Frameworks/CoreGraphics.framework/Versions/A/CoreGraphics
0x7fff85884000 - 0x7fff8592bfff com.apple.LanguageModeling (1.0 - 1) <58C18A47-BDE7-3CBE-81C0-797029D170A1> /System/Library/PrivateFrameworks/LanguageModeling.framework/Versions/A/LanguageModeling
0x7fff8592c000 - 0x7fff8593efff libsasl2.2.dylib (209) <11C7D200-0CA5-30F4-A19A-178CA81D48FE> /usr/lib/libsasl2.2.dylib
0x7fff85a97000 - 0x7fff85af5fff com.apple.SystemConfiguration (1.14 - 1.14) <ACAEDA14-FAA0-3F14-B476-DE492A52D383> /System/Library/Frameworks/SystemConfiguration.framework/Versions/A/SystemConfiguration
0x7fff85c1f000 - 0x7fff85c59ff7 com.apple.DebugSymbols (132 - 132) <23A42C53-B941-3871-9EE2-4C87A46005B5> /System/Library/PrivateFrameworks/DebugSymbols.framework/Versions/A/DebugSymbols
0x7fff85cb7000 - 0x7fff85ed8ff7 com.apple.CoreImage (11.4.0 - 366.4.20) <7721BA55-A10E-3425-8392-C5D7C510EAAB> /System/Library/Frameworks/CoreImage.framework/Versions/A/CoreImage
0x7fff85f38000 - 0x7fff85f3bff7 com.apple.AppleSystemInfo (3.1.5 - 3.1.5) <6932B5EC-0EA9-333D-BF7E-665047392FEC> /System/Library/PrivateFrameworks/AppleSystemInfo.framework/Versions/A/AppleSystemInfo
0x7fff86046000 - 0x7fff86173fff com.apple.CoreText (352.0 - 494.14) <93E0D8C3-D5DD-3EBB-9CC1-831C46572133> /System/Library/Frameworks/CoreText.framework/Versions/A/CoreText
0x7fff861d5000 - 0x7fff861f0ff7 libCRFSuite.dylib (34) <078B4CD8-6A8C-3067-B2BA-0C2A0BAB8AC3> /usr/lib/libCRFSuite.dylib
0x7fff861f1000 - 0x7fff86280fff com.apple.CorePDF (4.0 - 4) <849BBFF6-0700-3ED1-98DF-A6E93B9B707F> /System/Library/PrivateFrameworks/CorePDF.framework/Versions/A/CorePDF
0x7fff86311000 - 0x7fff86311fff com.apple.Cocoa (6.11 - 22) <807787AB-D231-3F51-A99B-A9314623C571> /System/Library/Frameworks/Cocoa.framework/Versions/A/Cocoa
0x7fff86562000 - 0x7fff865b4fff com.apple.CloudDocs (1.0 - 383.13) <5FD9138D-09D9-3B97-BBAD-5692E1687F30> /System/Library/PrivateFrameworks/CloudDocs.framework/Versions/A/CloudDocs
0x7fff865ba000 - 0x7fff8660aff7 com.apple.Symbolication (1.4 - 58044) <F70BF765-FBE9-3F1E-85CA-BB2F8E53E8C2> /System/Library/PrivateFrameworks/Symbolication.framework/Versions/A/Symbolication
0x7fff8660d000 - 0x7fff8666bfff com.apple.CoreServices.OSServices (728.13 - 728.13) <477EA3F9-D13E-3D83-ABAD-4DC7DB134CF0> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/OSServices.framework/Versions/A/OSServices
0x7fff86698000 - 0x7fff866a6fff com.apple.IntlPreferences (2.0 - 192) <388C5784-7713-36B0-B08B-5163E6B04002> /System/Library/PrivateFrameworks/IntlPreferences.framework/Versions/A/IntlPreferences
0x7fff866a7000 - 0x7fff866a9ff7 libquarantine.dylib (80) <B3B7B630-9012-3DA3-9458-5C009625E606> /usr/lib/system/libquarantine.dylib
0x7fff86af0000 - 0x7fff87bd9ff3 com.apple.WebCore (11601 - 11601.7.5) <9153DA7E-1625-382A-8257-8D4293F06F7F> /System/Library/Frameworks/WebKit.framework/Versions/A/Frameworks/WebCore.framework/Versions/A/WebCore
0x7fff87bda000 - 0x7fff87fb2fef com.apple.CoreAUC (214.0.0 - 214.0.0) <F80C19CA-6CD0-3052-9C22-0288A257CCC8> /System/Library/PrivateFrameworks/CoreAUC.framework/Versions/A/CoreAUC
0x7fff87fb3000 - 0x7fff88002ff7 com.apple.opencl (2.7.0 - 2.7.0) <DAEC71D4-E0E7-3E24-BB44-C977A798C575> /System/Library/Frameworks/OpenCL.framework/Versions/A/OpenCL
0x7fff88003000 - 0x7fff8804fff7 com.apple.corelocation (1486.17 - 1615.38) <6336CFC5-9D7D-3B76-B263-56DD6EBD0B8D> /System/Library/Frameworks/CoreLocation.framework/Versions/A/CoreLocation
0x7fff88050000 - 0x7fff8805afff com.apple.NetAuth (6.0 - 6.0) <D692B1EF-534F-3892-8E2F-2BBA7C8AFD74> /System/Library/PrivateFrameworks/NetAuth.framework/Versions/A/NetAuth
0x7fff8805c000 - 0x7fff88067fff com.apple.CrashReporterSupport (10.11 - 718) <05892B57-F2CD-3C84-B984-0417F6B361DB> /System/Library/PrivateFrameworks/CrashReporterSupport.framework/Versions/A/CrashReporterSupport
0x7fff88096000 - 0x7fff88096fff com.apple.audio.units.AudioUnit (1.13 - 1.13) <378B5292-F216-32AB-B628-8C33A72D7052> /System/Library/Frameworks/AudioUnit.framework/Versions/A/AudioUnit
0x7fff88097000 - 0x7fff880fefff com.apple.framework.CoreWiFi (11.0 - 1101.20) <993592F1-B3F1-3FAD-87BD-EA83C361BCCF> /System/Library/PrivateFrameworks/CoreWiFi.framework/Versions/A/CoreWiFi
0x7fff88112000 - 0x7fff88113fff liblangid.dylib (122) <9CC4F0D1-5C51-3B69-BC8F-EE3A51FD0822> /usr/lib/liblangid.dylib
0x7fff88114000 - 0x7fff88117ff7 com.apple.help (1.3.3 - 46) <35DA4D48-0BC2-35A1-8D7C-40905CDF4F64> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Help.framework/Versions/A/Help
0x7fff88118000 - 0x7fff88126ff7 libbz2.1.0.dylib (38) <28E54258-C0FE-38D4-AB76-1734CACCB344> /usr/lib/libbz2.1.0.dylib
0x7fff88155000 - 0x7fff885f0ffb com.apple.GeoServices (1.0 - 1151.49.1) <2D887517-B73D-30FF-91DC-AF6AD91F96B9> /System/Library/PrivateFrameworks/GeoServices.framework/Versions/A/GeoServices
0x7fff885f1000 - 0x7fff886e3ff7 libiconv.2.dylib (44) <F05A0A5A-92A9-3668-8F20-F27CBDA26BE9> /usr/lib/libiconv.2.dylib
0x7fff8873f000 - 0x7fff8873fff7 libunc.dylib (29) <DDB1E947-C775-33B8-B461-63E5EB698F0E> /usr/lib/system/libunc.dylib
0x7fff88748000 - 0x7fff8874fff7 com.apple.phonenumbers (1.1.1 - 105) <A616AFB5-2336-385A-B058-16A423D2B21B> /System/Library/PrivateFrameworks/PhoneNumbers.framework/Versions/A/PhoneNumbers
0x7fff8880d000 - 0x7fff88b78657 libobjc.A.dylib (680) <D55D5807-1FBE-32A5-9105-44D7AFE68C27> /usr/lib/libobjc.A.dylib
0x7fff88b79000 - 0x7fff88b8ffff com.apple.CoreMediaAuthoring (2.2 - 953) <A8F1B6EE-8ABE-3DC2-9829-A268D016648E> /System/Library/PrivateFrameworks/CoreMediaAuthoring.framework/Versions/A/CoreMediaAuthoring
0x7fff88c92000 - 0x7fff88f24ffb com.apple.RawCamera.bundle (6.21 - 879) <4F0A10FB-7C96-31E8-9A70-E30F615B2565> /System/Library/CoreServices/RawCamera.bundle/Contents/MacOS/RawCamera
0x7fff88f25000 - 0x7fff88f27fff libsystem_coreservices.dylib (19.2) <1B3F5AFC-FFCD-3ECB-8B9A-5538366FB20D> /usr/lib/system/libsystem_coreservices.dylib
0x7fff88f28000 - 0x7fff88f2afff libCVMSPluginSupport.dylib (12.1) <20BA72AF-C7C5-3551-8F59-E1AED5FC69F0> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libCVMSPluginSupport.dylib
0x7fff88fae000 - 0x7fff88fd0fff com.apple.IconServices (68.1 - 68.1) <CDEEDBE6-F53B-3BA1-82D4-23BCA3DD8949> /System/Library/PrivateFrameworks/IconServices.framework/Versions/A/IconServices
0x7fff88fd1000 - 0x7fff88ff3ff7 com.apple.Sharing (442.13.6 - 442.13.6) <DDD2811C-6ECB-32F2-8EE1-69BF9657B4A8> /System/Library/PrivateFrameworks/Sharing.framework/Versions/A/Sharing
0x7fff89330000 - 0x7fff89475fff com.apple.QTKit (7.7.3 - 2943.13) <3E3DB3DD-8D7E-3478-B020-F975CCAAE522> /System/Library/Frameworks/QTKit.framework/Versions/A/QTKit
0x7fff8947a000 - 0x7fff89485ff7 libkxld.dylib (3248.70.3) <BAD04BB1-5BFE-3D88-ADDE-23FED2DD2942> /usr/lib/system/libkxld.dylib
0x7fff89486000 - 0x7fff8948afff libGIF.dylib (1463) <3F84E60B-18E5-3897-8494-DFB1ACE76829> /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libGIF.dylib
0x7fff896f0000 - 0x7fff896f0ff7 liblaunch.dylib (765.70.1) <96D7C3EE-82E2-39AB-870F-B317A030E86D> /usr/lib/system/liblaunch.dylib
0x7fff896f1000 - 0x7fff8970dff7 libextension.dylib (78) <FD952DA6-BBEC-3CB6-98B3-E1D111C5C54E> /usr/lib/libextension.dylib
0x7fff8971b000 - 0x7fff89748fff libdispatch.dylib (501.40.12) <C7499857-61A5-3D7D-A5EA-65DCC8C3DF92> /usr/lib/system/libdispatch.dylib
0x7fff89749000 - 0x7fff89757fff libxar.1.dylib (302) <03207F66-2C4A-3DBD-8D81-70F4C85903C4> /usr/lib/libxar.1.dylib
0x7fff8976e000 - 0x7fff8978afff com.apple.GenerationalStorage (2.0 - 239.1) <8C821448-4294-3736-9CEF-467C93785CB9> /System/Library/PrivateFrameworks/GenerationalStorage.framework/Versions/A/GenerationalStorage
0x7fff8978b000 - 0x7fff897ccff7 libGLU.dylib (12.1) <CD7A5916-3E3C-3EF3-A275-B281016B99CB> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGLU.dylib
0x7fff89924000 - 0x7fff8a258f5f libLLVMContainer.dylib (119.5) <09A35A20-7CDD-3E5A-94B4-5F1E5CFBC3D9> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libLLVMContainer.dylib
0x7fff8a259000 - 0x7fff8a2acff7 libc++.1.dylib (120.1) <8FC3D139-8055-3498-9AC5-6467CB7F4D14> /usr/lib/libc++.1.dylib
0x7fff8a2ad000 - 0x7fff8a3bffef libvDSP.dylib (563.5) <5702650E-DF08-3D58-B16F-9EF0A28702B3> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libvDSP.dylib
0x7fff8a3c0000 - 0x7fff8a3c6ff7 com.apple.speech.recognition.framework (5.1.1 - 5.1.1) <9E5A980A-F455-32D5-BBEE-3BD6018CC45E> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/SpeechRecognition.framework/Versions/A/SpeechRecognition
0x7fff8a49a000 - 0x7fff8a49efff com.apple.CommonPanels (1.2.6 - 96) <4AE7E5AE-55B3-37FA-9BDE-B23147ADA2E9> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/CommonPanels.framework/Versions/A/CommonPanels
0x7fff8a4a8000 - 0x7fff8a4a9ff3 com.apple.print.framework.Print (10.0 - 266) <3E85F70C-D7D4-34E1-B88A-C1F503F99CDA> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Print.framework/Versions/A/Print
0x7fff8a4e6000 - 0x7fff8a664fff com.apple.UIFoundation (1.0 - 436.1) <AABB5267-E7B7-3D75-B051-E665BDA8DEF4> /System/Library/PrivateFrameworks/UIFoundation.framework/Versions/A/UIFoundation
0x7fff8a798000 - 0x7fff8a807fff com.apple.SearchKit (1.4.0 - 1.4.0) <F159A888-34CA-36F1-AC8E-EB1B38C9DFB3> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/SearchKit.framework/Versions/A/SearchKit
0x7fff8a808000 - 0x7fff8a925fff libsqlite3.dylib (216.4) <DC3D59E7-91A3-374F-957C-6699729CD82B> /usr/lib/libsqlite3.dylib
0x7fff8a956000 - 0x7fff8ae78fff com.apple.QuartzComposer (5.1 - 334) <80235264-CA1B-3E3F-96F7-5F6F52FDC5B6> /System/Library/Frameworks/Quartz.framework/Versions/A/Frameworks/QuartzComposer.framework/Versions/A/QuartzComposer
0x7fff8ae79000 - 0x7fff8ae7efff com.apple.MediaAccessibility (1.0 - 79) <C5E61B45-1967-3602-A48C-31E132B998B2> /System/Library/Frameworks/MediaAccessibility.framework/Versions/A/MediaAccessibility
0x7fff8aefb000 - 0x7fff8af4dfff com.apple.AppleVAFramework (5.0.32 - 5.0.32) <4F5F5CD6-631F-3C97-AA62-7DF19BD5EC15> /System/Library/PrivateFrameworks/AppleVA.framework/Versions/A/AppleVA
0x7fff8af4e000 - 0x7fff8af9ffff com.apple.audio.CoreAudio (4.3.0 - 4.3.0) <EA7D4F3B-062B-3C81-A98C-C89264D00D48> /System/Library/Frameworks/CoreAudio.framework/Versions/A/CoreAudio
0x7fff8afa0000 - 0x7fff8bbc9ff7 com.apple.AppKit (6.9 - 1404.47) <F3411F6E-DD87-34D0-8C68-C69B2205E41D> /System/Library/Frameworks/AppKit.framework/Versions/C/AppKit
0x7fff8bbcc000 - 0x7fff8bc85ff7 libvMisc.dylib (563.5) <BF612F7D-FA3B-3F9F-8BE7-8D1BCB21ECC5> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libvMisc.dylib
0x7fff8bd1e000 - 0x7fff8bd4cff7 com.apple.CoreServicesInternal (248.2 - 248.2) <6E111F0A-D7F1-3738-ADE7-CF983BD4EC8B> /System/Library/PrivateFrameworks/CoreServicesInternal.framework/Versions/A/CoreServicesInternal
0x7fff8bf3c000 - 0x7fff8bfe7fff com.apple.PDFKit (3.1 - 3.1) <27AF3C85-1C0B-389C-856C-2E527620C195> /System/Library/Frameworks/Quartz.framework/Versions/A/Frameworks/PDFKit.framework/Versions/A/PDFKit
0x7fff8c04a000 - 0x7fff8c069ff7 com.apple.framework.Apple80211 (11.0 - 1121.34.2) <90477FAE-B835-3931-80FB-FDFF02B21D9D> /System/Library/PrivateFrameworks/Apple80211.framework/Versions/A/Apple80211
0x7fff8c06a000 - 0x7fff8c093ff7 libxpc.dylib (765.70.1) <4FB1311F-4032-3F56-BF0B-CFF45D78FB01> /usr/lib/system/libxpc.dylib
0x7fff8c094000 - 0x7fff8c174ff7 unorm8_rgba.dylib (2.7.3) <9EB6C346-CFF6-32D7-B4A1-2409DFBCB216> /System/Library/Frameworks/OpenCL.framework/Versions/A/Libraries/ImageFormats/unorm8_rgba.dylib
0x7fff8c175000 - 0x7fff8c264ff7 libxml2.2.dylib (29.14) <02077D26-0AB0-347A-8AF2-FADE3CFC296C> /usr/lib/libxml2.2.dylib
0x7fff8c265000 - 0x7fff8c298ff7 com.apple.MediaKit (16 - 809) <BF8032FE-6645-37F6-A622-BC7EEE3EAABF> /System/Library/PrivateFrameworks/MediaKit.framework/Versions/A/MediaKit
0x7fff8c2ce000 - 0x7fff8c2d6fff com.apple.AppleSRP (5.0 - 1) <840A5C20-6452-36BB-ACF7-29BA6CBF7C48> /System/Library/PrivateFrameworks/AppleSRP.framework/Versions/A/AppleSRP
0x7fff8c2da000 - 0x7fff8c2e2fff libcopyfile.dylib (127) <A48637BC-F3F2-34F2-BB68-4C65FD012832> /usr/lib/system/libcopyfile.dylib
0x7fff8c2e6000 - 0x7fff8c2ecfff com.apple.IOAccelerator (205.11 - 205.11) <3E86AB1B-C1CF-307D-900F-385C8D8C534A> /System/Library/PrivateFrameworks/IOAccelerator.framework/Versions/A/IOAccelerator
0x7fff8c2ed000 - 0x7fff8c302ff3 libCGInterfaces.dylib (317.9) <473434E1-5269-3077-A047-D05E024AE631> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vImage.framework/Versions/A/Libraries/libCGInterfaces.dylib
0x7fff8c303000 - 0x7fff8c31dff3 liblzma.5.dylib (10) <CC03591B-FA57-3CA5-AC81-0D76033AC0CE> /usr/lib/liblzma.5.dylib
0x7fff8c320000 - 0x7fff8c322fff libCGXType.A.dylib (970) <A931200A-B248-39EF-8A8B-311D881BE372> /System/Library/Frameworks/CoreGraphics.framework/Versions/A/Resources/libCGXType.A.dylib
0x7fff8c334000 - 0x7fff8c342fff com.apple.opengl (12.1.0 - 12.1.0) <12EBDE6A-2F44-3429-8337-2BB36870BFD8> /System/Library/Frameworks/OpenGL.framework/Versions/A/OpenGL
0x7fff8c354000 - 0x7fff8c692ff7 com.apple.WebKit (11601 - 11601.7.8) <58A8B070-2AE4-3909-AE1D-7A7DF34AA268> /System/Library/Frameworks/WebKit.framework/Versions/A/WebKit
0x7fff8c6c4000 - 0x7fff8c710fff com.apple.print.framework.PrintCore (11.2 - 472.2) <5AE8AA6B-CE09-397D-B0D4-0F9CCBF1F77D> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/PrintCore.framework/Versions/A/PrintCore
0x7fff8c711000 - 0x7fff8c97efff com.apple.imageKit (2.6 - 932) <FAE317B8-DF15-3096-AFAC-464913BF2F3B> /System/Library/Frameworks/Quartz.framework/Versions/A/Frameworks/ImageKit.framework/Versions/A/ImageKit
0x7fff8c97f000 - 0x7fff8c990ff7 libz.1.dylib (61.20.1) <B3EBB42F-48E3-3287-9F0D-308E04D407AC> /usr/lib/libz.1.dylib
0x7fff8c991000 - 0x7fff8c991fff com.apple.ApplicationServices (48 - 48) <ADD57D3A-142F-3EF5-BFD8-EACD82164884> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/ApplicationServices
0x7fff8c992000 - 0x7fff8c9c4ff7 libTrueTypeScaler.dylib (158.7) <020536E5-C032-30B5-864C-920D5F7DB6DA> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framework/Versions/A/Resources/libTrueTypeScaler.dylib
0x7fff8c9c5000 - 0x7fff8c9dcff7 libsystem_coretls.dylib (83.40.5) <C90DAE38-4082-381C-A185-2A6A8B677628> /usr/lib/system/libsystem_coretls.dylib
0x7fff8cc79000 - 0x7fff8d0a7fff com.apple.vision.FaceCore (3.3.1 - 3.3.1) <E54028EA-4217-3078-A2B1-C52E4214D59E> /System/Library/PrivateFrameworks/FaceCore.framework/Versions/A/FaceCore
0x7fff8d0a8000 - 0x7fff8d0d9ff7 libtidy.A.dylib (15.17) <6859415D-7A43-384E-ABDD-AA6B2AA9FDCD> /usr/lib/libtidy.A.dylib
0x7fff8d111000 - 0x7fff8d112fff libsystem_blocks.dylib (65) <1244D9D5-F6AA-35BB-B307-86851C24B8E5> /usr/lib/system/libsystem_blocks.dylib
0x7fff8d113000 - 0x7fff8d11efff libGL.dylib (12.1) <70D51643-04AC-3400-8F11-A6FC25985289> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGL.dylib
0x7fff8d21e000 - 0x7fff8d223fff com.apple.DiskArbitration (2.7 - 2.7) <8CB47F4A-0FD2-343A-93C8-965174F6F24F> /System/Library/Frameworks/DiskArbitration.framework/Versions/A/DiskArbitration
0x7fff8d224000 - 0x7fff8d239fff com.apple.ToneKit (1.0 - 1) <6D5AD263-308F-3F70-8D86-7027569D2694> /System/Library/PrivateFrameworks/ToneKit.framework/Versions/A/ToneKit
0x7fff8d23a000 - 0x7fff8d2a0ff7 libsystem_network.dylib (583.50.1) <B52DAB73-92DC-3DA7-B9F4-B899D66445C1> /usr/lib/system/libsystem_network.dylib
0x7fff8d2a1000 - 0x7fff8d2a1fff com.apple.CoreServices (728.13 - 728.13) <CFE3EE73-A3F5-3824-9210-0790C07120F3> /System/Library/Frameworks/CoreServices.framework/Versions/A/CoreServices
0x7fff8d2b5000 - 0x7fff8d2befff com.apple.icloud.FindMyDevice (1.0 - 1) <B9C741F2-6FAC-3BA7-B6E0-9A910C6E8D4E> /System/Library/PrivateFrameworks/FindMyDevice.framework/Versions/A/FindMyDevice
0x7fff8d2d7000 - 0x7fff8d36dfff com.apple.ColorSync (4.9.0 - 4.9.0) <8FC37E20-6579-3CB2-9D49-BC39FC38DF87> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ColorSync.framework/Versions/A/ColorSync
0x7fff8d962000 - 0x7fff8da06fff com.apple.Bluetooth (4.4.6 - 4.4.6f1) <D8ED953B-AD7D-3FE2-8631-E9CBCF6EBAB9> /System/Library/Frameworks/IOBluetooth.framework/Versions/A/IOBluetooth
0x7fff8da07000 - 0x7fff8da07fff libmetal_timestamp.dylib (600.0.44.2) <DEEA1127-7A5D-3EF2-A4B2-AE125CBA5DB5> /System/Library/PrivateFrameworks/GPUCompiler.framework/libmetal_timestamp.dylib
0x7fff8da08000 - 0x7fff8da0efff com.apple.XPCService (2.0 - 1) <5E2122D6-FFA2-3552-BF16-9FD3F36B40DB> /System/Library/PrivateFrameworks/XPCService.framework/Versions/A/XPCService
0x7fff8da5a000 - 0x7fff8dc23ff7 com.apple.ImageIO.framework (3.3.0 - 1462) <1D8FF28C-5DBB-3D23-8CF0-75269C1CE84D> /System/Library/Frameworks/ImageIO.framework/Versions/A/ImageIO
0x7fff8dc24000 - 0x7fff8dc40ff7 libsystem_malloc.dylib (67.40.1) <5748E8B2-F81C-34C6-8B13-456213127678> /usr/lib/system/libsystem_malloc.dylib
0x7fff8dc83000 - 0x7fff8dc84fff libsystem_secinit.dylib (20) <32B1A8C6-DC84-3F4F-B8CE-9A52B47C3E6B> /usr/lib/system/libsystem_secinit.dylib
0x7fff8dc85000 - 0x7fff8dc8afff com.apple.ImageCapture (9.0 - 9.0) <ACECF0B7-7D92-3A22-BF47-E8FADF4C5378> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/ImageCapture.framework/Versions/A/ImageCapture
0x7fff8dd4c000 - 0x7fff8dd51ff7 libmacho.dylib (875.1) <318264FA-58F1-39D8-8285-1F6254EE410E> /usr/lib/system/libmacho.dylib
0x7fff8ddd9000 - 0x7fff8de34ff7 libTIFF.dylib (1463) <5C02D055-02D3-37FE-AABC-487301080941> /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libTIFF.dylib
0x7fff8de44000 - 0x7fff8de4dff3 libsystem_notify.dylib (150.40.1) <D48BDE34-0F7E-34CA-A0FF-C578E39987CC> /usr/lib/system/libsystem_notify.dylib
0x7fff8deee000 - 0x7fff8def6fff com.apple.CoreServices.FSEvents (1223.10.1 - 1223.10.1) <7F5B7A23-BC1D-3FA9-A9B8-D534F1E1979A> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/FSEvents.framework/Versions/A/FSEvents
0x7fff8def7000 - 0x7fff8df49fff com.apple.ImageCaptureCore (7.0 - 7.0) <9F3123D8-29D2-332F-AD6B-AB9BF1A58022> /System/Library/Frameworks/ImageCaptureCore.framework/Versions/A/ImageCaptureCore
0x7fff8df4a000 - 0x7fff8df52fef libcldcpuengine.dylib (2.7.3) <745C41A3-CEC0-3BF5-91DC-FCB140A3DACE> /System/Library/Frameworks/OpenCL.framework/Versions/A/Libraries/libcldcpuengine.dylib
0x7fff8df53000 - 0x7fff8df55ff7 libRadiance.dylib (1463) <11392BBE-6DAC-3ADD-A0C0-CD653B9AEDE3> /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libRadiance.dylib
0x7fff8df56000 - 0x7fff8df66fff libSparseBLAS.dylib (1162.2) <6F591A0F-80D0-384D-8304-B035C4ED1BBD> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libSparseBLAS.dylib
0x7fff8df98000 - 0x7fff8dfc6ff7 libsandbox.1.dylib (460.60.3) <C8B9F633-EA0C-35CF-9207-1AFDF694EEAD> /usr/lib/libsandbox.1.dylib
0x7fff8e04e000 - 0x7fff8e069fff com.apple.aps.framework (4.0 - 4.0) <CAD47B6E-A581-3B35-885B-67B206F41D5E> /System/Library/PrivateFrameworks/ApplePushService.framework/Versions/A/ApplePushService
0x7fff8e2da000 - 0x7fff8e2e2fff com.apple.frameworks.CoreDaemon (1.3 - 1.3) <CC53DC12-9231-3C4F-921B-9A770D463323> /System/Library/PrivateFrameworks/CoreDaemon.framework/Versions/B/CoreDaemon
0x7fff8e327000 - 0x7fff8e32cff3 libunwind.dylib (35.3) <F6EB48E5-4D12-359A-AB54-C937FBBE9043> /usr/lib/system/libunwind.dylib
0x7fff8e32d000 - 0x7fff8e356ff7 libxslt.1.dylib (14.5) <8E03110E-1529-3BE8-B5F4-052A47A1674C> /usr/lib/libxslt.1.dylib
0x7fff8e4cb000 - 0x7fff8e5f2fff com.apple.LaunchServices (728.13 - 728.13) <91147A89-9D0D-3272-AD05-48E2835BD8D5> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/LaunchServices.framework/Versions/A/LaunchServices
0x7fff8e5f3000 - 0x7fff8e5f4fff libDiagnosticMessagesClient.dylib (100) <4243B6B4-21E9-355B-9C5A-95A216233B96> /usr/lib/libDiagnosticMessagesClient.dylib
0x7fff8e5f5000 - 0x7fff8e88fff3 com.apple.security (7.0 - 57337.60.3) <4BF5CF26-6E34-35EC-8D41-58ED65F9BFB8> /System/Library/Frameworks/Security.framework/Versions/A/Security
0x7fff8e890000 - 0x7fff8e8aeff7 libsystem_kernel.dylib (3248.70.3) <69D68230-7793-3D11-B49E-BA3A6D5137B8> /usr/lib/system/libsystem_kernel.dylib
0x7fff8ea70000 - 0x7fff8ea9bff7 com.apple.AddressBook.ContactsFoundation (8.0 - 2137.1) <BAE70E9D-BCC8-3650-B554-6D646388EDEF> /System/Library/PrivateFrameworks/ContactsFoundation.framework/Versions/A/ContactsFoundation
0x7fff8ea9c000 - 0x7fff8eaa7ff7 libcommonCrypto.dylib (60075.50.1) <93732261-34B4-3914-B7A2-90A81A182DBA> /usr/lib/system/libcommonCrypto.dylib
0x7fff8eaae000 - 0x7fff8eaddffb libsystem_m.dylib (3105) <08E1A4B2-6448-3DFE-A58C-ACC7335BE7E4> /usr/lib/system/libsystem_m.dylib
0x7fff8ee01000 - 0x7fff8efc1ffb libBLAS.dylib (1162.2) <B4C21826-5EB3-3C6D-B75D-CA4886E2B6A6> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libBLAS.dylib
0x7fff8efee000 - 0x7fff8eff9ff7 libChineseTokenizer.dylib (16) <79B8C67A-3061-3C78-92CD-4650719E68D4> /usr/lib/libChineseTokenizer.dylib
0x7fff8effa000 - 0x7fff8f068ff7 com.apple.ApplicationServices.ATS (377 - 394.4) <CB64C2B7-828A-3C4C-8F3C-72B78630CD94> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framework/Versions/A/ATS
0x7fff8f069000 - 0x7fff8f094ffb libarchive.2.dylib (33.20.2.1.1) <BC764A1E-573A-3D95-A3CC-1758935ADC56> /usr/lib/libarchive.2.dylib
0x7fff8f095000 - 0x7fff8f0a6ff7 libsystem_trace.dylib (201.10.3) <4F626911-011B-3E9C-8D61-C5EBA79013F0> /usr/lib/system/libsystem_trace.dylib
0x7fff8f0b0000 - 0x7fff8f0c6ff7 libLinearAlgebra.dylib (1162.2) <FFE54EDF-F06F-3C0A-864A-4CA7BBFD4B2D> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libLinearAlgebra.dylib
0x7fff8f0c7000 - 0x7fff8f0c9ff7 libsystem_configuration.dylib (802.40.13) <3DEB7DF9-6804-37E1-BC83-0166882FF0FF> /usr/lib/system/libsystem_configuration.dylib
0x7fff8f0ca000 - 0x7fff8f0cdfff libspindump.dylib (197.1) <B86EE257-4429-32E9-B98D-B12BFF2A373B> /usr/lib/libspindump.dylib
0x7fff8f0ce000 - 0x7fff8f11cfff libcurl.4.dylib (90) <12E01E4B-24C9-394C-9D2C-85CF85D5F459> /usr/lib/libcurl.4.dylib
0x7fff8f11d000 - 0x7fff8f11ffff com.apple.SecCodeWrapper (4.0 - 261.40.2) <1F832591-59A8-3B3F-943F-D6D827463782> /System/Library/PrivateFrameworks/SecCodeWrapper.framework/Versions/A/SecCodeWrapper
0x7fff8f120000 - 0x7fff8f14aff7 GLRendererFloat (12.1) <0412B850-BB25-33B1-AF0D-8E6297D4620E> /System/Library/Frameworks/OpenGL.framework/Versions/A/Resources/GLRendererFloat.bundle/GLRendererFloat
0x7fff8f18d000 - 0x7fff8f1b2ff7 libPng.dylib (1463) <17F67BF3-4A78-3587-AAE4-E50A71BDD4CB> /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libPng.dylib
0x7fff8f1b3000 - 0x7fff8f1b5fff com.apple.EFILogin (2.0 - 2) <38150198-DD7F-3C73-BCAA-C74BB376393A> /System/Library/PrivateFrameworks/EFILogin.framework/Versions/A/EFILogin
0x7fff8f1b6000 - 0x7fff8f1ddfff com.apple.ChunkingLibrary (167 - 167) <AD7F285C-005E-36BB-98A3-5826413533BE> /System/Library/PrivateFrameworks/ChunkingLibrary.framework/Versions/A/ChunkingLibrary
0x7fff8f20a000 - 0x7fff8f212fef libsystem_platform.dylib (74.40.2) <29A905EF-6777-3C33-82B0-6C3A88C4BA15> /usr/lib/system/libsystem_platform.dylib
0x7fff8f213000 - 0x7fff8f22aff7 libsystem_asl.dylib (323.50.1) <41F8E11F-1BD0-3F1D-BA3A-AA1577ED98A9> /usr/lib/system/libsystem_asl.dylib
0x7fff8f2cd000 - 0x7fff8f64bff3 com.apple.VideoToolbox (1.0 - 1731.15.207) <6C7C261F-CB65-3AF1-92E7-16ACAD371EF4> /System/Library/Frameworks/VideoToolbox.framework/Versions/A/VideoToolbox
0x7fff8f6b0000 - 0x7fff8f6c1fff libcmph.dylib (6) <BA4BF2C6-7F4E-33B8-9DD7-619C9EB83ECF> /usr/lib/libcmph.dylib
0x7fff8f6ca000 - 0x7fff8f6e7ff7 com.apple.AppleVPAFramework (2.1.2 - 2.1.2) <707C6ED6-B8C0-38D4-B45A-7F2F689BD157> /System/Library/PrivateFrameworks/AppleVPA.framework/Versions/A/AppleVPA
0x7fff8f9b9000 - 0x7fff8fb14ff3 com.apple.WebKitLegacy (11601 - 11601.7.8) <F41E6CAF-1157-3868-9FAC-D074FCE74BB9> /System/Library/Frameworks/WebKit.framework/Versions/A/Frameworks/WebKitLegacy.framework/Versions/A/WebKitLegacy
0x7fff904b4000 - 0x7fff904f9ff7 com.apple.coreservices.SharedFileList (24.4 - 24.5) <1D2AD77B-778F-3253-A295-3D0A32A8121C> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/SharedFileList.framework/Versions/A/SharedFileList
0x7fff904fa000 - 0x7fff90571feb libcorecrypto.dylib (335.50.1) <B5C05FD7-A540-345A-87BF-8E41848A3C17> /usr/lib/system/libcorecrypto.dylib
0x7fff90572000 - 0x7fff90572fff com.apple.Accelerate (1.10 - Accelerate 1.10) <5831771A-C1C3-3625-9FE9-2CCB6B2E7EE1> /System/Library/Frameworks/Accelerate.framework/Versions/A/Accelerate
0x7fff90573000 - 0x7fff9057efff libcsfde.dylib (517.50.1) <52F0DB6A-13B8-355E-ADFD-72834D3CA183> /usr/lib/libcsfde.dylib
0x7fff9057f000 - 0x7fff906c9ff7 com.apple.coreui (2.1 - 366.1) <8138636F-A0A7-31C7-896C-5F5747FA1B2A> /System/Library/PrivateFrameworks/CoreUI.framework/Versions/A/CoreUI
0x7fff906cf000 - 0x7fff907c1ff7 libJP2.dylib (1463) <D107FF52-7FD6-3A5E-B40E-F3D0F1FF651D> /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libJP2.dylib
0x7fff907c2000 - 0x7fff907c2fff com.apple.Accelerate.vecLib (3.10 - vecLib 3.10) <848125D3-AF14-3526-8745-FFCDB200CD76> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/vecLib
0x7fff907c3000 - 0x7fff907d6fff com.apple.SafariServices.framework (11604 - 11604.1.38.1.7) <5B649F4B-09D3-3AAC-9801-B6084B91E7D7> /System/Library/PrivateFrameworks/SafariServices.framework/Versions/A/SafariServices
0x7fff908e4000 - 0x7fff908edff7 libsystem_pthread.dylib (138.10.4) <3DD1EF4C-1D1B-3ABF-8CC6-B3B1CEEE9559> /usr/lib/system/libsystem_pthread.dylib
0x7fff908ee000 - 0x7fff90b84fff libmecabra.dylib (696.5) <EF6C0BD4-5FE8-34FB-8ADF-69A53CEC97A9> /usr/lib/libmecabra.dylib
0x7fff90b91000 - 0x7fff90ee5ff7 com.apple.Foundation (6.9 - 1259.31) <EBB5BE3F-1FE9-3231-B53B-149CDEE8BCA9> /System/Library/Frameworks/Foundation.framework/Versions/C/Foundation
0x7fff90f34000 - 0x7fff90fbcfff com.apple.CoreSymbolication (3.1 - 58048.1) <C1A1A8DB-8A51-3A21-865A-3CEF22A0E67A> /System/Library/PrivateFrameworks/CoreSymbolication.framework/Versions/A/CoreSymbolication
0x7fff90fd1000 - 0x7fff90fd4ffb libdyld.dylib (360.22) <7C1BBC59-FA8A-3BDF-B209-02167832E7D1> /usr/lib/system/libdyld.dylib
0x7fff90fd5000 - 0x7fff91161ff7 libGLProgrammability.dylib (12.1) <6D4C193C-5F7B-3E82-81D9-D14D25BBD962> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGLProgrammability.dylib
0x7fff9118a000 - 0x7fff91193ff7 com.apple.CommonAuth (4.0 - 2.0) <4B8673E1-3697-3FE2-8D30-AC7AC5D4F8BF> /System/Library/PrivateFrameworks/CommonAuth.framework/Versions/A/CommonAuth
0x7fff91194000 - 0x7fff911a7fff com.apple.contacts.ContactsPersistence (1.0 - 2137.1) <71232F20-11BD-370D-9F43-F262BFE46C93> /System/Library/PrivateFrameworks/ContactsPersistence.framework/Versions/A/ContactsPersistence
0x7fff911a8000 - 0x7fff911c1fe7 libcompression.dylib (28) <F83F421D-115D-3457-A9AA-1BEB5070A30B> /usr/lib/libcompression.dylib
0x7fff911c2000 - 0x7fff911cdfff com.apple.AppSandbox (4.0 - 261.40.2) <52766210-B6EB-3B73-AB1B-42E0A9AD2EE8> /System/Library/PrivateFrameworks/AppSandbox.framework/Versions/A/AppSandbox
0x7fff919d8000 - 0x7fff919dbffb libScreenReader.dylib (426.42) <16FC79D1-4573-3E90-945F-CBA22D5185FD> /usr/lib/libScreenReader.dylib
0x7fff919dc000 - 0x7fff919e4fff libMatch.1.dylib (27) <3AC0BFB8-7E69-3DBE-A175-7F3946FC4554> /usr/lib/libMatch.1.dylib
0x7fff919e6000 - 0x7fff91abffff com.apple.CoreMedia (1.0 - 1731.15.207) <70CAD4A7-3F8B-3767-A420-98BE1062C230> /System/Library/Frameworks/CoreMedia.framework/Versions/A/CoreMedia
0x7fff9231f000 - 0x7fff9236dff7 libstdc++.6.dylib (104.1) <76E2AFB1-07E5-3F19-B692-F6E21B7E470D> /usr/lib/libstdc++.6.dylib
0x7fff925c8000 - 0x7fff92b06ff7 com.apple.MediaToolbox (1.0 - 1731.15.207) <63AD3FB7-BAD3-3040-8A99-843033F24CF6> /System/Library/Frameworks/MediaToolbox.framework/Versions/A/MediaToolbox
0x7fff92b29000 - 0x7fff92cd5ff7 com.apple.avfoundation (2.0 - 1046.9.12) <41BDD03F-5545-3B9F-8DD7-7106485BAE8B> /System/Library/Frameworks/AVFoundation.framework/Versions/A/AVFoundation
0x7fff92cdb000 - 0x7fff92cffff7 libJPEG.dylib (1463) <11227D36-EA80-3D5B-A7D3-F2AC6C7497EC> /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libJPEG.dylib
0x7fff92e6d000 - 0x7fff92f53ff7 libcrypto.0.9.8.dylib (59.60.1) <D68067AD-D1E0-3196-9796-51BE9B969C8E> /usr/lib/libcrypto.0.9.8.dylib
0x7fff92f54000 - 0x7fff92fb4fff com.apple.QuickLookFramework (5.0 - 696.7) <ECD33169-5EB1-3783-AF9E-1AB9240F8358> /System/Library/Frameworks/QuickLook.framework/Versions/A/QuickLook
0x7fff931cf000 - 0x7fff931e8fff com.apple.openscripting (1.7.1 - 169.1) <36EBF6A7-334A-3197-838F-E8C7B27FCDBB> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/OpenScripting.framework/Versions/A/OpenScripting
0x7fff931ef000 - 0x7fff9323bffb com.apple.HIServices (1.22 - 550) <6B76B41C-CF5A-34C4-89F4-EFD7CA3D1C9D> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/HIServices.framework/Versions/A/HIServices
0x7fff9323c000 - 0x7fff93256fff com.apple.Kerberos (3.0 - 1) <1B4744BF-E5AE-38E2-AA56-E22D3270F2E8> /System/Library/Frameworks/Kerberos.framework/Versions/A/Kerberos
0x7fff93257000 - 0x7fff9327efff com.apple.shortcut (2.16 - 93) <2BA6DF3E-04C7-39C8-B311-3413E9FC9022> /System/Library/PrivateFrameworks/Shortcut.framework/Versions/A/Shortcut
0x7fff932b3000 - 0x7fff932c8fff com.apple.AppContainer (4.0 - 261.40.2) <F220E702-1C00-3BD2-9943-C7E75C3B4418> /System/Library/PrivateFrameworks/AppContainer.framework/Versions/A/AppContainer
0x7fff932c9000 - 0x7fff93382ff7 com.apple.cloudkit.CloudKit (482.29 - 482.29) <E235B37E-1491-3857-BDE8-38450D4FE8D0> /System/Library/Frameworks/CloudKit.framework/Versions/A/CloudKit
0x7fff933e3000 - 0x7fff93472ff7 libCoreStorage.dylib (517.50.1) <E6283FE9-B5AC-3110-8D4C-8E2BF185983E> /usr/lib/libCoreStorage.dylib
0x7fff934dd000 - 0x7fff93522ff3 libFontRegistry.dylib (155.2) <A70DD497-35F3-34DA-9C19-F4B90080E961> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framework/Versions/A/Resources/libFontRegistry.dylib
0x7fff93530000 - 0x7fff9395afff com.apple.ModelIO (1.0 - 1) <8838E0E1-ACB3-3CE8-ABDC-C787D8B3F247> /System/Library/Frameworks/ModelIO.framework/Versions/A/ModelIO
0x7fff9395d000 - 0x7fff93974fff libmarisa.dylib (4) <E4919B03-D9BD-3AF8-B436-C415C98E3F0A> /usr/lib/libmarisa.dylib
0x7fff9397a000 - 0x7fff93a2afff com.apple.backup.framework (1.7.4 - 1.7.4) <F304E9D1-991A-379E-9659-BF85C35B4808> /System/Library/PrivateFrameworks/Backup.framework/Versions/A/Backup
0x7fff93a67000 - 0x7fff93a86ff7 com.apple.contacts.vCard (1.0 - 2137.1) <41529BD9-1BCC-3A62-92BA-2A7110867355> /System/Library/PrivateFrameworks/vCard.framework/Versions/A/vCard
0x7fff93a92000 - 0x7fff93c9dfff libFosl_dynamic.dylib (16.24) <5F9DB82D-FD4B-3952-8531-CE020F93ED49> /usr/lib/libFosl_dynamic.dylib
0x7fff93c9e000 - 0x7fff93cc7fff com.apple.ProtectedCloudStorage (1.0 - 1) <7436B2B3-943A-3500-B099-80F133B3E002> /System/Library/PrivateFrameworks/ProtectedCloudStorage.framework/Versions/A/ProtectedCloudStorage
0x7fff93e3c000 - 0x7fff93e6dfff com.apple.GSS (4.0 - 2.0) <B490333A-3B3E-397A-AD75-68846E9A9140> /System/Library/Frameworks/GSS.framework/Versions/A/GSS
0x7fff93e6e000 - 0x7fff93e7afff com.apple.speech.synthesis.framework (5.4.12 - 5.4.12) <71DA00B8-5EA2-326B-8814-59DB25512F65> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/SpeechSynthesis.framework/Versions/A/SpeechSynthesis
0x7fff93e7d000 - 0x7fff94028ffb GLEngine (12.1) <278B3208-B0D0-3FAE-AC23-A4FA06837311> /System/Library/Frameworks/OpenGL.framework/Versions/A/Resources/GLEngine.bundle/GLEngine
0x7fff94029000 - 0x7fff94029fff com.apple.Carbon (154 - 157) <8F6ED602-5943-3E29-A793-BC331E2C183D> /System/Library/Frameworks/Carbon.framework/Versions/A/Carbon
0x7fff9402a000 - 0x7fff94038fff com.apple.ToneLibrary (1.0 - 1) <AF05AF34-9BC4-3BA6-81C1-7420F22C9D7D> /System/Library/PrivateFrameworks/ToneLibrary.framework/Versions/A/ToneLibrary
0x7fff94047000 - 0x7fff94077ff3 com.apple.CoreAVCHD (5.8.0 - 5800.4.2) <4AAFB1C4-3708-30F9-ACFA-90564347204C> /System/Library/PrivateFrameworks/CoreAVCHD.framework/Versions/A/CoreAVCHD
0x7fff94a39000 - 0x7fff94a77ff7 libGLImage.dylib (12.1) <BB1F1A93-5101-3906-AB17-8D83FCB200F9> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGLImage.dylib
0x7fff94a78000 - 0x7fff94aedfff com.apple.framework.IOKit (2.0.2 - 1179.50.2) <A509D3AE-9D48-31B7-89C7-326A7A2007B2> /System/Library/Frameworks/IOKit.framework/Versions/A/IOKit
0x7fff94af1000 - 0x7fff94b91fff com.apple.ViewBridge (159 - 159) <D8131B7E-DFC9-3FDD-9D56-49821C1D1521> /System/Library/PrivateFrameworks/ViewBridge.framework/Versions/A/ViewBridge
0x7fff94dab000 - 0x7fff94dadfff com.apple.loginsupport (1.0 - 1) <9B2F5F9B-ED38-313F-B798-D2B667BCD6B5> /System/Library/PrivateFrameworks/login.framework/Versions/A/Frameworks/loginsupport.framework/Versions/A/loginsupport
0x7fff94dae000 - 0x7fff94db7ff7 com.apple.DisplayServicesFW (3.0 - 378) <45BE1B99-8E10-32F0-A180-A6B6CB5883AE> /System/Library/PrivateFrameworks/DisplayServices.framework/Versions/A/DisplayServices
0x7fff94db8000 - 0x7fff94e09ff7 libcups.2.dylib (435.2) <91584A40-214D-33E8-A613-CE22289037C8> /usr/lib/libcups.2.dylib
0x7fff94e0a000 - 0x7fff94e0afff libenergytrace.dylib (10.40.1) <0A491CA7-3451-3FD5-999A-58AB4362682B> /usr/lib/libenergytrace.dylib
0x7fff94e25000 - 0x7fff94e59ff7 com.apple.CoreVideo (1.8 - 191.3) <1AA24A1B-CB84-3F6B-B6DE-11494542649C> /System/Library/Frameworks/CoreVideo.framework/Versions/A/CoreVideo
0x7fff94e5a000 - 0x7fff94e5cff7 com.apple.xpc.ServiceManagement (1.0 - 1) <B4181284-D588-3A20-93F3-B4FA882BC9A8> /System/Library/Frameworks/ServiceManagement.framework/Versions/A/ServiceManagement
0x7fff94e5d000 - 0x7fff94eb2fff com.apple.AE (701 - 701) <AD492742-F884-386B-A450-FAC281B9FFA4> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/AE.framework/Versions/A/AE
0x7fff94eb3000 - 0x7fff94ef5ff7 com.apple.Metal (56.6 - 56.6) <30518711-8D00-3759-AA19-800D3C88E693> /System/Library/Frameworks/Metal.framework/Versions/A/Metal
0x7fff94ef6000 - 0x7fff94ef7ffb libremovefile.dylib (41) <552EF39E-14D7-363E-9059-4565AC2F894E> /usr/lib/system/libremovefile.dylib
0x7fff94f1c000 - 0x7fff94f1effb libutil.dylib (43) <4C9BFE8B-563B-3EEA-A323-8F4F14E0A46C> /usr/lib/libutil.dylib
0x7fff94f2c000 - 0x7fff94f2efff com.apple.CoreDuetDebugLogging (1.0 - 1) <7C932160-AC9C-3173-900F-98138E829CB3> /System/Library/PrivateFrameworks/CoreDuetDebugLogging.framework/Versions/A/CoreDuetDebugLogging
0x7fff94f8c000 - 0x7fff94f90fff libcache.dylib (75) <9548AAE9-2AB7-3525-9ECE-A2A7C4688447> /usr/lib/system/libcache.dylib
0x7fff9505a000 - 0x7fff954d0fff com.apple.CoreFoundation (6.9 - 1259.11) <B8056BE3-151B-3003-91C9-6720CF04937B> /System/Library/Frameworks/CoreFoundation.framework/Versions/A/CoreFoundation
0x7fff954d1000 - 0x7fff954d4ff7 libCoreFSCache.dylib (119.5) <2389D7DA-B8EF-3EB4-AAAF-FBEDE01CDECA> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libCoreFSCache.dylib
0x7fff954d5000 - 0x7fff954e9fff com.apple.CoreDuetDaemonProtocol (1.0 - 1) <1D60D60C-914A-3BAB-8607-79F68F4C712E> /System/Library/PrivateFrameworks/CoreDuetDaemonProtocol.framework/Versions/A/CoreDuetDaemonProtocol
0x7fff95517000 - 0x7fff95517fff libOpenScriptingUtil.dylib (169.1) <AD0DAC8A-9849-3077-999F-9AEC6112BDAB> /usr/lib/libOpenScriptingUtil.dylib
0x7fff95518000 - 0x7fff9580dfff com.apple.HIToolbox (2.1.1 - 807.2) <36413C45-36AF-34EF-9C0E-F18B31D1E565> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/HIToolbox.framework/Versions/A/HIToolbox
0x7fff9580e000 - 0x7fff95816ffb libsystem_dnssd.dylib (625.60.4) <80189998-32B0-316C-B5C5-53857486713D> /usr/lib/system/libsystem_dnssd.dylib
0x7fff95817000 - 0x7fff958edffb com.apple.DiskImagesFramework (10.11.4 - 417.4) <FB30D069-648F-3FB2-AA55-FC603606C49E> /System/Library/PrivateFrameworks/DiskImages.framework/Versions/A/DiskImages
0x7fff958ee000 - 0x7fff958fdffb com.apple.LangAnalysis (1.7.0 - 1.7.0) <18D21123-A3E7-3851-974A-08E5D4540475> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/LangAnalysis.framework/Versions/A/LangAnalysis
0x7fff95fed000 - 0x7fff95ff8fff com.apple.DirectoryService.Framework (10.11 - 194) <6F827D0E-0F02-3B09-B2A8-252865EECA7F> /System/Library/Frameworks/DirectoryService.framework/Versions/A/DirectoryService
0x7fff96012000 - 0x7fff96015fff com.apple.IOSurface (108.2.4 - 108.2.4) <E7A63C0D-2FDA-3BC6-947D-07E3C4A13110> /System/Library/Frameworks/IOSurface.framework/Versions/A/IOSurface
0x7fff96220000 - 0x7fff96233fff com.apple.CoreBluetooth (1.0 - 1) <E54CA9A2-A5C6-30C5-9D6E-8472DBA9371E> /System/Library/Frameworks/CoreBluetooth.framework/Versions/A/CoreBluetooth
0x7fff9623b000 - 0x7fff96243fff libsystem_networkextension.dylib (385.40.36) <66095DC7-6539-38F2-95EE-458F15F6D014> /usr/lib/system/libsystem_networkextension.dylib
0x7fff96244000 - 0x7fff962cdff7 com.apple.PerformanceAnalysis (1.0 - 1) <9C57BB91-46D6-3FB6-A5A2-8DB1CFE86B72> /System/Library/PrivateFrameworks/PerformanceAnalysis.framework/Versions/A/PerformanceAnalysis
0x7fff962ce000 - 0x7fff963cafff libFontParser.dylib (158.7) <393EFEA3-42B7-38DA-99DA-D01DEAA734CF> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framework/Versions/A/Resources/libFontParser.dylib
0x7fff9656a000 - 0x7fff965e1ff7 com.apple.MMCS (1.3 - 357.1) <549FBEFC-55F7-3101-BF51-A0B1F7CF2B46> /System/Library/PrivateFrameworks/MMCS.framework/Versions/A/MMCS
0x7fff965e2000 - 0x7fff96c81ffb com.apple.JavaScriptCore (11601 - 11601.7.8) <38585ADC-1AD4-3BD2-8972-B90344CE57C0> /System/Library/Frameworks/JavaScriptCore.framework/Versions/A/JavaScriptCore
0x7fff96c82000 - 0x7fff96c92ff3 com.apple.ProtocolBuffer (1 - 243) <BAE5E5C9-DD59-3BB8-9741-EEFC5E3046EE> /System/Library/PrivateFrameworks/ProtocolBuffer.framework/Versions/A/ProtocolBuffer
0x7fff96cbc000 - 0x7fff96cf6fff com.apple.QD (3.12 - 302) <0FE53180-2895-3D14-A1E7-F82DE1D106E1> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/QD.framework/Versions/A/QD
0x7fff9711a000 - 0x7fff9711ffff com.apple.TCC (1.0 - 1) <F5EEB2D3-9517-3975-97BE-22CB8E11B8A3> /System/Library/PrivateFrameworks/TCC.framework/Versions/A/TCC
0x7fff97120000 - 0x7fff9714aff7 libc++abi.dylib (307.4) <D24E06BF-6522-3C4A-BD0C-11C42BA4D8E8> /usr/lib/libc++abi.dylib
0x7fff9715b000 - 0x7fff9718afff com.apple.securityinterface (10.0 - 55065.40.1) <1BB39B19-DD74-347E-A344-0E6781773577> /System/Library/Frameworks/SecurityInterface.framework/Versions/A/SecurityInterface
0x7fff9719a000 - 0x7fff97227dd7 com.apple.AppleJPEG (1.0 - 1) <BF7EDBDB-A52D-37F7-BDE4-EAD49310D7A9> /System/Library/PrivateFrameworks/AppleJPEG.framework/Versions/A/AppleJPEG
0x7fff97228000 - 0x7fff97336ff3 com.apple.desktopservices (1.10.3 - 1.10.3) <3A6906D4-C0B8-30D1-B589-0466E5E42B69> /System/Library/PrivateFrameworks/DesktopServicesPriv.framework/Versions/A/DesktopServicesPriv
0x7fff97337000 - 0x7fff9733cff7 com.apple.AssetCacheServices (14.1 - 14.1) <5F249F84-660A-3E94-B073-6729E7ED56D9> /System/Library/PrivateFrameworks/AssetCacheServices.framework/Versions/A/AssetCacheServices
0x7fff9733d000 - 0x7fff97349fff com.apple.HelpData (2.1.4 - 90) <10608EEC-B613-309C-96E6-5A40AB951FA4> /System/Library/PrivateFrameworks/HelpData.framework/Versions/A/HelpData
0x7fff9734a000 - 0x7fff97518ff3 com.apple.QuartzCore (1.11 - 410.14) <06A2BE20-38CB-3A89-9629-A782829DF977> /System/Library/Frameworks/QuartzCore.framework/Versions/A/QuartzCore
0x7fff97519000 - 0x7fff9758dff7 com.apple.Heimdal (4.0 - 2.0) <5D365381-8B5E-3259-8867-FC4A7D307BDE> /System/Library/PrivateFrameworks/Heimdal.framework/Versions/A/Heimdal
0x7fff9758e000 - 0x7fff97591fff libsystem_sandbox.dylib (460.60.3) <2DDCB4AF-3037-34E5-A451-6846AFB9B85C> /usr/lib/system/libsystem_sandbox.dylib
0x7fff97592000 - 0x7fff975d8ff7 libauto.dylib (186) <999E610F-41FC-32A3-ADCA-5EC049B65DFB> /usr/lib/libauto.dylib
0x7fff9764b000 - 0x7fff978d2fff com.apple.CFNetwork (760.6.5 - 760.6.5) <8A36BBA6-F100-3F39-9711-2FA49D412987> /System/Library/Frameworks/CFNetwork.framework/Versions/A/CFNetwork
0x7fff978e6000 - 0x7fff978eafff libpam.2.dylib (20) <CFCD19BD-87BC-3F2B-BB1C-4C23E8E55F1A> /usr/lib/libpam.2.dylib
0x7fff978f4000 - 0x7fff979dafef unorm8_bgra.dylib (2.7.3) <B315AE9C-9E09-3D9F-9513-EC2195908516> /System/Library/Frameworks/OpenCL.framework/Versions/A/Libraries/ImageFormats/unorm8_bgra.dylib
0x7fff979db000 - 0x7fff97a46ff7 com.apple.framework.CoreWLAN (11.0 - 1101.20) <3B35C543-7FCE-333F-80C1-432FA41DDCDE> /System/Library/Frameworks/CoreWLAN.framework/Versions/A/CoreWLAN
0x7fff97b52000 - 0x7fff97f54fff libLAPACK.dylib (1162.2) <42238ED4-6B7A-39D0-BFF2-304A0C287213> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libLAPACK.dylib
0x7fff97f55000 - 0x7fff9800dff7 com.apple.CoreDuet (1.0 - 1) <FC1EAEE1-73A4-3B13-A634-1D2A94D0C0B7> /System/Library/PrivateFrameworks/CoreDuet.framework/Versions/A/CoreDuet
0x7fff9800e000 - 0x7fff98032fff com.apple.quartzfilters (1.10.0 - 1.10.0) <F5C482E2-5AFB-3959-8C01-C149D48E7583> /System/Library/Frameworks/Quartz.framework/Versions/A/Frameworks/QuartzFilters.framework/Versions/A/QuartzFilters
0x7fff98068000 - 0x7fff98153ff7 com.apple.QuickLookUIFramework (5.0 - 696.7) <5A4AAFEC-D38C-3DA0-9361-CBF1D4C6B376> /System/Library/Frameworks/Quartz.framework/Versions/A/Frameworks/QuickLookUI.framework/Versions/A/QuickLookUI
0x7fff98154000 - 0x7fff98155fff com.apple.TrustEvaluationAgent (2.0 - 25) <0239494E-FEFE-39BC-9FC7-E251BA5128F1> /System/Library/PrivateFrameworks/TrustEvaluationAgent.framework/Versions/A/TrustEvaluationAgent
0x7fff98156000 - 0x7fff98172ff3 libresolv.9.dylib (60) <A650B5C8-1950-36A0-86D1-0B2465318BFA> /usr/lib/libresolv.9.dylib
0x7fff981d3000 - 0x7fff9820aff7 com.apple.LDAPFramework (2.4.28 - 194.5) <9AE33BF2-FB17-342D-8F1E-5F83C6E6EB69> /System/Library/Frameworks/LDAP.framework/Versions/A/LDAP
0x7fff98276000 - 0x7fff98279fff libCoreVMClient.dylib (119.5) <560D70FB-709F-3030-96C9-F249FCB7DA6D> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libCoreVMClient.dylib
0x7fff9827a000 - 0x7fff98738fcf com.apple.vImage (8.0 - 8.0) <85FB412E-EB30-3433-A79B-B3970FC83580> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vImage.framework/Versions/A/vImage
0x7fff9873d000 - 0x7fff9876cff7 com.apple.DictionaryServices (1.2 - 250.3) <30250542-CBAA-39C1-91AA-B57A5DE17594> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/DictionaryServices.framework/Versions/A/DictionaryServices
0x7fff987f0000 - 0x7fff98800fff libbsm.0.dylib (34) <7E14504C-A8B0-3574-B6EB-5D5FABC72926> /usr/lib/libbsm.0.dylib
0x7fff98801000 - 0x7fff98875ff3 com.apple.securityfoundation (6.0 - 55126) <3FF6D6E0-0C5D-385A-A97E-441D3947EFAB> /System/Library/Frameworks/SecurityFoundation.framework/Versions/A/SecurityFoundation
0x7fff98876000 - 0x7fff9889afff com.apple.MultitouchSupport.framework (304.12 - 304.12) <598A8689-E97E-3C8D-AACD-8A0EB1956CA6> /System/Library/PrivateFrameworks/MultitouchSupport.framework/Versions/A/MultitouchSupport
0x7fff9889b000 - 0x7fff988d3ff7 com.apple.RemoteViewServices (2.0 - 101) <B2881449-8CFE-3D1C-B4BF-155640392533> /System/Library/PrivateFrameworks/RemoteViewServices.framework/Versions/A/RemoteViewServices
0x7fff988d6000 - 0x7fff988e2ff7 com.apple.OpenDirectory (10.11 - 194) <31A67AD5-5CC2-350A-96D7-821DF4BC4196> /System/Library/Frameworks/OpenDirectory.framework/Versions/A/OpenDirectory
0x7fff98906000 - 0x7fff9892fffb libRIP.A.dylib (970) <BA17C96B-83CC-3835-8AFD-CB5A69D3D26F> /System/Library/Frameworks/CoreGraphics.framework/Versions/A/Resources/libRIP.A.dylib
0x7fff9896c000 - 0x7fff9896cfff com.apple.quartzframework (1.5 - 21) <5DC3D0D9-9E3F-3AA5-92F1-F229907A49B9> /System/Library/Frameworks/Quartz.framework/Versions/A/Quartz
0x7fff99876000 - 0x7fff9987efff com.apple.NetFS (6.0 - 4.0) <842A5346-24C3-3F22-9ECF-E586A10EA1F2> /System/Library/Frameworks/NetFS.framework/Versions/A/NetFS
0x7fff9987f000 - 0x7fff99acbff7 com.apple.AddressBook.framework (9.0 - 1679.10) <24F823D3-C3FC-3AF9-B8B3-C166539DBD11> /System/Library/Frameworks/AddressBook.framework/Versions/A/AddressBook
0x7fff99aed000 - 0x7fff99b1cffb com.apple.datadetectors (5.0 - 308) <1949868C-BDCD-3772-BDBD-D7E9F2CC1451> /System/Library/PrivateFrameworks/DataDetectors.framework/Versions/A/DataDetectors
0x7fff99b1d000 - 0x7fff99b1dff7 libkeymgr.dylib (28) <8371CE54-5FDD-3CE9-B3DF-E98C761B6FE0> /usr/lib/system/libkeymgr.dylib
0x7fff99b1e000 - 0x7fff99bb3fff com.apple.ink.framework (10.9 - 214) <1F76CF36-3F79-36B8-BC37-C540AF34B338> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Ink.framework/Versions/A/Ink
0x7fff99d18000 - 0x7fff99d41fff libsystem_info.dylib (477.50.4) <FAA9226D-64DE-3769-A6D8-6CABA4B7FF4D> /usr/lib/system/libsystem_info.dylib
0x7fff99fe2000 - 0x7fff9a09cfff com.apple.DiscRecording (9.0.1 - 9010.4.3) <540853B2-B123-3560-8023-C92EE229051A> /System/Library/Frameworks/DiscRecording.framework/Versions/A/DiscRecording
0x7fff9a09d000 - 0x7fff9a243ff7 com.apple.audio.toolbox.AudioToolbox (1.13 - 1.13) <370E95BC-956C-3962-86CC-0A14CF6A0389> /System/Library/Frameworks/AudioToolbox.framework/Versions/A/AudioToolbox
0x7fff9a244000 - 0x7fff9a24cfff libGFXShared.dylib (12.1) <22F78420-D92E-3B5F-BA86-918A34289FCD> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGFXShared.dylib
0x7fff9a24d000 - 0x7fff9a2dafef libsystem_c.dylib (1082.60.1) <28733D22-553E-3CBC-8D2C-EDCEB46E46AF> /usr/lib/system/libsystem_c.dylib
0x7fff9a318000 - 0x7fff9a5fdffb com.apple.CoreServices.CarbonCore (1136.2 - 1136.2) <2DBAFC9A-6CD6-351D-B1F4-87D81AA6D640> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/CarbonCore.framework/Versions/A/CarbonCore
0x7fff9a662000 - 0x7fff9a6adff7 com.apple.CoreMediaIO (703.0 - 4791) <E49D0C36-295A-311A-9470-706455EA6F80> /System/Library/Frameworks/CoreMediaIO.framework/Versions/A/CoreMediaIO
0x7fff9a6ae000 - 0x7fff9a6b3ff7 libheimdal-asn1.dylib (453.40.10) <981DE40B-FA16-36F7-BE92-8C8A115D6CD9> /usr/lib/libheimdal-asn1.dylib
0x7fff9a6ba000 - 0x7fff9a960ff7 com.apple.CoreData (120 - 641.3) <A29A5491-6169-372B-828F-84EE0CFD4BC4> /System/Library/Frameworks/CoreData.framework/Versions/A/CoreData
0x7fff9a97f000 - 0x7fff9aa1ffff com.apple.Metadata (10.7.0 - 972.34) <B0137597-158A-3503-85C8-F55DB5D21BE1> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/Metadata.framework/Versions/A/Metadata
0x7fff9aa8d000 - 0x7fff9aa8effb libSystem.B.dylib (1226.10.1) <160608FD-B79D-3B49-AFEA-53A10C0C86B3> /usr/lib/libSystem.B.dylib
0x7fff9aa8f000 - 0x7fff9aa96ff7 libcompiler_rt.dylib (62) <A13ECF69-F59F-38AE-8609-7B731450FBCD> /usr/lib/system/libcompiler_rt.dylib
0x7fff9aaac000 - 0x7fff9ab1bfff com.apple.datadetectorscore (7.0 - 460) <233A8FBF-B22F-3177-A328-781588D95D69> /System/Library/PrivateFrameworks/DataDetectorsCore.framework/Versions/A/DataDetectorsCore
0x7fff9ab81000 - 0x7fff9abe4fff libAVFAudio.dylib (161.2) <1A98DBF3-490B-37FB-928A-AB1E36E6E5DD> /System/Library/Frameworks/AVFoundation.framework/Versions/A/Resources/libAVFAudio.dylib
0x7fff9ac3f000 - 0x7fff9ac4afff libGPUSupportMercury.dylib (12.1) <97C7C8A3-234B-3C7C-8777-611E3D3EE63D> /System/Library/PrivateFrameworks/GPUSupport.framework/Versions/A/Libraries/libGPUSupportMercury.dylib
0x7fff9ac4b000 - 0x7fff9ac4dff7 com.apple.securityhi (9.0 - 55006) <AC151C58-A7AD-3ECF-B15D-5E09FF94FC23> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/SecurityHI.framework/Versions/A/SecurityHI
0x7fff9ac4e000 - 0x7fff9ac67fff com.apple.CFOpenDirectory (10.11 - 194) <11F95672-55E0-3F9D-9171-5E8C56AEE948> /System/Library/Frameworks/OpenDirectory.framework/Versions/A/Frameworks/CFOpenDirectory.framework/Versions/A/CFOpenDirectory
0x7fff9ace0000 - 0x7fff9ad08fff com.apple.GLKit (1.0 - 56) <820F61C9-B74D-3604-BA6E-F20235E2E5B4> /System/Library/Frameworks/GLKit.framework/Versions/A/GLKit
0x7fff9ad3b000 - 0x7fff9ad3efff com.apple.Mangrove (1.0 - 1) <2D86B3AD-64C3-3BB4-BC66-1CFD0C90E844> /System/Library/PrivateFrameworks/Mangrove.framework/Versions/A/Mangrove
External Modification Summary:
Calls made by other processes targeting this process:
task_for_pid: 18
thread_create: 0
thread_set_state: 0
Calls made by this process:
task_for_pid: 0
thread_create: 0
thread_set_state: 0
Calls made by all processes on this machine:
task_for_pid: 5383
thread_create: 0
thread_set_state: 0
VM Region Summary:
ReadOnly portion of Libraries: Total=618.8M resident=0K(0%) swapped_out_or_unallocated=618.8M(100%)
Writable regions: Total=15.6G written=0K(0%) resident=0K(0%) swapped_out=0K(0%) unallocated=15.6G(100%)
VIRTUAL REGION
REGION TYPE SIZE COUNT (non-coalesced)
ATS (font support) 32.3M 9
ATS (font support) (reserved) 8K 3 reserved VM address space (unallocated)
Accelerate.framework 256K 3
Activity Tracing 2048K 2
CG backing stores 40.0M 16
CG image 196.5M 115
CG shared images 1008K 21
CoreAnimation 256K 46
CoreUI image data 2236K 26
CoreUI image file 320K 5
Dispatch continuations 48.0M 2
Foundation 24K 3
Image IO 1208K 101
Kernel Alloc Once 8K 3
MALLOC 937.5M 1017
MALLOC guard page 48K 11
MALLOC_LARGE (reserved) 5176K 36 reserved VM address space (unallocated)
Memory Tag 242 12K 2
OpenCL 8K 2
OpenGL GLSL 256K 4
Process Corpse Info 2048K 2
STACK GUARD 56.4M 112
Stack 271.5M 118
VM_ALLOCATE 14.1G 79
__DATA 70.9M 380
__GLSLBUILTINS 2588K 2
__IMAGE 528K 2
__LINKEDIT 116.9M 77
__TEXT 501.9M 352
__UNICODE 552K 2
mapped file 227.2M 64
shared memory 16.4M 13
TOTAL 16.6G 2598
TOTAL, minus reserved VM space 16.6G 2598
Model: MacPro5,1, BootROM MP51.007F.B03, 12 processors, 6-Core Intel Xeon, 2.66 GHz, 64 GB, SMC 1.39f11
Graphics: NVIDIA GeForce GTX 980 TI, NVIDIA GeForce GTX 980 TI, PCIe, 6144 MB
Memory Module: DIMM 1, 8 GB, DDR3 ECC, 1333 MHz, 0x857F, 0x463732314752363546393333334700000000
Memory Module: DIMM 2, 8 GB, DDR3 ECC, 1333 MHz, 0x857F, 0x463732314752363546393333334700000000
Memory Module: DIMM 3, 8 GB, DDR3 ECC, 1333 MHz, 0x857F, 0x463732314752363546393333334700000000
Memory Module: DIMM 4, 8 GB, DDR3 ECC, 1333 MHz, 0x857F, 0x463732314752363546393333334700000000
Memory Module: DIMM 5, 8 GB, DDR3 ECC, 1333 MHz, 0x857F, 0x463732314752363546393333334700000000
Memory Module: DIMM 6, 8 GB, DDR3 ECC, 1333 MHz, 0x857F, 0x463732314752363546393333334700000000
Memory Module: DIMM 7, 8 GB, DDR3 ECC, 1333 MHz, 0x857F, 0x463732314752363546393333334700000000
Memory Module: DIMM 8, 8 GB, DDR3 ECC, 1333 MHz, 0x857F, 0x463732314752363546393333334700000000
AirPort: spairport_wireless_card_type_airport_extreme (0x14E4, 0x8E), Broadcom BCM43xx 1.0 (5.106.98.100.24)
Bluetooth: Version 4.4.6f1 17910, 3 services, 27 devices, 1 incoming serial ports
Network Service: Ethernet 1, Ethernet, en0
PCI Card: NVIDIA GeForce GTX 980 TI, Display Controller, Slot-1
PCI Card: pci10b5,8609, Slot-2
PCI Card: NVIDIA GeForce GTX 980 TI, NVDA,Parent, Slot-1
PCI Card: pci1b4b,9230, AHCI Controller, Slot-3
PCI Card: pci1b21,1142, USB eXtensible Host Controller, Slot-2@10,0,0
PCI Card: pci1b4b,9230, AHCI Controller, Slot-4
PCI Card: pci1b4b,9120, AHCI Controller, Slot-2@8,0,0
PCI Card: pci1b4b,9120, AHCI Controller, Slot-2@9,0,0
PCI Card: pci1b21,1142, USB eXtensible Host Controller, Slot-2@11,0,0
PCI Card: pci1b4b,91a4, IDE Controller, Slot-2@9,0,1
PCI Card: pci1b4b,91a4, IDE Controller, Slot-2@8,0,1
Serial ATA Device: HL-DT-ST DVD-RW GH41N
Serial ATA Device: HL-DT-ST BD-RE WH16NS40
Serial ATA Device: Samsung SSD 850 PRO 2TB, 2.05 TB
Serial ATA Device: Samsung SSD 840 EVO 1TB, 1 TB
Serial ATA Device: 2.74 TB HD Glyph, 3 TB
Serial ATA Device: ElitePro Qx2, 9 TB
Serial ATA Device: OWC Mercury Accelsior PCIe SSD, 960.04 GB
Serial ATA Device: MARVELL VIRTUAL
USB Device: USB Bus
USB Device: USB Bus
USB Device: USB Bus
USB Device: BRCM2046 Hub
USB Device: Bluetooth USB Host Controller
USB Device: USB Bus
USB Device: Intuos5 touch L
USB Device: USB Bus
USB Device: USB Bus
USB Device: USB 2.0 Bus
USB Device: HZD
USB Device: USB2.0 Hub
USB Device: Apple Watch Magnetic Charging Cable
USB Device: GL3220
USB Device: SoundSticks
USB Device: Hub
USB Device: Keyboard Hub
USB Device: Apple Keyboard
USB Device: Apple LED Cinema Display
USB Device: Display iSight
USB Device: Display Audio
USB Device: USB 3.0 Bus
FireWire Device: built-in_hub, Up to 800 Mb/sec
Thunderbolt Bus:
