Hi, I need to be able to geotag and visualize spatially where photographic data has been taken. The map module works perfectly for me, except it doesn't show the base maps when working offline (no internet). However, Im doing this work onboard a oceanographic research vessel - limited if any internet connectivity. Can you download a basemap to use offline? Anyone else figure out a workaround for this?
cheers, Robin
Hi robina,
Yes, its doing the same thing at my end as well. As soon as I disconnect from the internet, Lightroom stop showing the basemap in Map module and I am not sure if there's any workaround available for this. I need to check with the team.
You can also do the feature request for the same: Feature Request/Bug Report Form
Mohit
