Hi
After a Windows update I can no longer open Indesign. Nor can I open files created and saved with Indesign. I can, however, open Photoshop and Illustrator. My Adobe programs open from the Adobe Creative Cloud. Has the forum any suggestions?
Hope you can help -
The sad and lonely windows user
What happens? Is there a crash? A freeze?
Hi BobLevine
Thanks for your reply. When I try to open Indesign the usual splash pops up and after that also the dark frame. Then, it all shuts down; no error msg, nothing to guide me...
Rgds, Kristian
First thing to try is trashing your preferences:
Troubleshooting 101: Replace, or "trash" your InDesign preferences
Hi - the ctr+alt+shift kind of did the trick. It stopped the loading of the process somehow and allowed me to open and edit a previous document and thus solve my immediate need. However, I still cannot simply open a document. I am sure its the windows update...
Best rgds - Kristian
I doubt it. We’d be inundated with complaints.
Hi again
I understand that you dismiss the possibility of windows update creating this error considering all the negative response that you did not receive. The ctrl+alt+shift does'nt work anynore and I am effectively prevented from using the InDesign program. I do not really care abt the customisation and I have therefor uninstalled InDesign and reinstalled it - to no avail.
My PC is a standard lenovo T series with all relevant updates installed.
Thanks in advance, Kristian
Hi again - i have found an identical question and will follow that thread.
Adobe CC InDesign will not open
Rgds - Kristian
Hi kristiank,
According to your last reply after resetting preferences all the Indesign was opening fine, however, it is still not opening again.
Is there a particular file which is not working of Indesign itself is not opening.
Please try removing preferences manually.
Regards
Srishti
