The first link I provided is to a page on Peter Grainge's
site where he provides the two strings. Here are the basics:
1. Go to the place where RH is installed on your computer and
find the CSH API folder. Inside that folder is a file called
RoboHelp_CSH.js. Give that file to the developers so they can put
it in the application files somewhere convenient to the Java pages.
2. In the head of each Java file, the following string should
be placed:
<script language="JavaScript"
src="RoboHelp_CSH.js"></script>
where the entire path from the Java file to the JS file
should be included (but the developers should be familiar with
that).
3. For the help link, the developers need to do something
like this:
<a href="javascript:RH_ShowHelp(0, StrPathAndWindow,
HH_HELP_CONTEXT, 1);">Help</a>
where "StrPathAndWindow" is the path to the .htm start page
you specify in the first page of the WebHelp layout wizard; and "1"
is the map ID for the help topic you want to call.
You'll need to work out with the developers where in the app
the help lives so that the correct path ("StrPathAndWindow") is put
in the help call.
For example: RH_ShowHelp(0, "../help/index.htm",
HH_HELP_CONTEXT, 25);
