Need multiple Simplified Field Notations
Oct 03, 2017 Oct 03, 2017
I have a form that I need three different Simplified Field Notations. How do I do that?
General troubleshooting
2.2K
Community Expert , Oct 04, 2017 Oct 04, 2017
Use this code:
var a = Number(this.getField("M1").valueAsString);
var b = Number(this.getField("T1").valueAsString);
var c = Number(this.getField("A1").valueAsString);
if (c!= 0) {
  event.value=(a+b)/c;
} else {
  event.value = "";
For different fields? Just apply each calculation differently. It shouldn't be a problem.
I tried but it keeps writing over the first one.
Did you copy and paste the field? If so, you need to rename the copies so they have a unique name. Otherwise, they will remain exact copies of each other.
These are the two different ones. Does Locking the field make a difference?
No, it's only preventing you from editing it...
Those screenshots don't show that the fields are actually named differently.
The fields being:
Mealevent2 + tipevent2/AttendeesEvent2  This being the first Scripts
and
Refreshments+tip/Ateendees  this being the second Script.
Are these not different enough?
Can you share the file in question (via Dropbox, for example)?
On Wed, Oct 4, 2017 at 12:09 AM, beverlyh81967728 <forums_noreply@adobe.com>
Those are the calculations, not the names. What are the names?
Those are the names of the fields.
Maybe that's the problem. Try giving them normal names (letters and numbers only)
Will do. Let you know tomorrow if it makes any difference. Thank you for your help.
Well that worked but now I'm getting the Java script error that the value entered does not match the field that has the division in it. From what I've seen on the web if the field is blank or 0 I'm going to get this error unless I can write a custom calculation script. Have you done that? I just need field 1 ("M1") + field 2 ("T1") / field 3 ("A1")
This happens when you try to divide by zero (or an empty value). You can't
use the Simple Field Notation if that's the case. You must write a custom
calculation script.
On Wed, Oct 4, 2017 at 8:04 PM, beverlyh81967728 <forums_noreply@adobe.com>
Can you help with that? I saw on another post one that you worked on but of course it doesn't work specially with mine. I'm close but it doesn't pick up the two fields needing to be added before the division.
var a =this.getField("M1");
var b =this.getField("T1");
var c =this.getField("A1");
if(a.value != 0)
  // perform division;
   event.value=((a.value+b.value)/(c.value))
} else {
  // do not divide by zero;
   event.value = "";
You're almost there, you're just checking the wrong variable... It's "c" that must not be zero, not "a".
I made that change but it's still not calculating correcting.
Attendees (A1)=2
Meals (M1)=100.00
tip(T1)=5.00
Cost per person=502.50 should be 52.50
The formula works if I take out the tip.
Use this code:
if (c!= 0) {
} else {
  event.value = "";
Yes!! That worked. You are amazing! OK why didn't the other one work?
Because you didn't explicitly converting the values to numbers (as I did), they were being treated as strings and concatenated, instead of added up.
Thank You, Thank You!. One little field cost me a full day but with your help made it all worth it. Thanks again.
