Intersecting shapes - cut out
Oct 04, 2017 Oct 04, 2017
Please HELP!! I'm sure there is an easy way to do this but I've been here and on google for the last 3 hours!
I am a NOOB but I can't imagine this should be hard!?
5.9K
Community Expert , Oct 04, 2017 Oct 04, 2017
Ha! I have my screen shots ready to go, but was waiting for the shape confirmation. Similar to yours, Dave, plus one final step:
This would be much easier in Illustrator (and you could add the shape to your PSD file) but in Photoshop:
  • Select the Elliptical shape tool. On the options bar, choose Shape and set the fill color. Draw an ellipse.
  • Select the Path Selection tool, hold Alt/Opt and drag down to duplicate the ellipse.
  • In the Properties panel, click Subtract Front Shape.
  • These are still editabl
Adobe
Is this the final shape?
Do you mean like this ?:
If so :
1.Set the ellipse shape tool to path, path operations to combine and draw the first ellipse
2. Draw the second ellipse and alter the path operations to subtract front shape
3. Click on Make Shape and set colour in properties
If that is not quite what you are after - please explain a bit further
Dave
davescm - i'm missing a critical step somewhere (on a PC)...
  1. created a new layer (had a bunch already)
  2. clicked ellipse tool, chose path and combine - click in layer and made it 698 x 913
  3. clicked again, path and subtract - this one is 639 x 913
  4. moved my Y cords to where I wanted them
now what?
I would say set the foreground color, select the work path and then Layer > New Fill Layer > Solid Color, OK.
Take a couple of steps back
Before drawing the first ellipse make sure path operations in the options bar are set to combine.
Now draw the second shape and set path operations to subtract front shape
Your paths panel will look like this :
Now go to the options bar and click on Make Shape
Dave
OK so...
OK finally got it!!!!!
Thank you guys - SOOO much!!!
I'm going to get my vodka now!
Haha - enjoy it
Dave
While you are sipping on your vodka, perhaps take a moment to reflect on your opening statement:
I'm sure there is an easy way to do this but I've been here and on google for the last 3 hours! I am a NOOB but I can't imagine this should be hard!?
This is nothing easy or intuitive about drawing that shape in Photoshop. Congrats on getting through it!
~Barb
What I didn't tell you is that I've been "trying" for 2 days in AI & PS!!!
How can something that seems so easy be so hard!?!?
(BTW - I'm a real estate agent, our brains do not function like Artist's )
Here is the finished product
I'll share the file if anyone wants it.
Used on www.REODifferent.com
It's a drone! very cool!
And if you knew about the Pathfinder panel in illustrator it would've been a piece a cake:
  • Draw the first ellipse.
  • Alt/Opt drag down to duplicate.
  • Click the minus front button in Windows > Pathfinder.
  • Draw a rectangle to lop off the bottom
  • Again on the minus front button.
  • Done!
It's Photoshop that makes it so difficult, because you're trying to create vector art in a program that was designed for bitmap images. Photoshop is using the Illustrator pathfinder technology, but it's just so much more complicated than it is in Illustrator.
Oct 05, 2017 Oct 05, 2017
Thanks again for your help! Figured AI was a (much) better solution but I know just enough PS to get into trouble and only just downloaded AI - SOOOO much to learn!
Most Intro to Ai classes will cover how to draw complex shapes by combining easy ones, using Pathfinder, Shapebuilder and the Shaper tool. I cover it the first day, because it's an important way for someone who hasn't mastered the Pen tool yet to start drawing.
~Barb
  • These are still editable objects, so you can adjust either as necessary but to remove the bottom part you will have to rasterize. Layer > Rasterize > Shape.
  • Then you can just draw a rectangular marquee over the part you want to remove and press Delete.
Haha
Interesting that you used shapes and I used paths then made a single shape
For the OP the key path  operation in both answers was "subtract front shape"
Actually no need to rasterize to remove the bottom - just use another "subtract shape" with a rectangle
Dave
Right? But I couldn't make it work. I'll go try it with paths...
You do have to return to the Eilipse tool if you were just moving your ellipses around with the Path Selection tool to see this option.
