Dive into Adobe Summit 2024! Explore curated list of AEM sessions & labs, register, connect with experts, ask questions, engage, and share insights. Don't miss the excitement.
SOLVED
Asset Editor Cropping in AEM 6.3
Avatar
Level 4
I have the same question as posted on Stack Overflow.
cq5 - AEM DAM apect ratio crop - Stack Overflow
When editing an Asset from http://localhost:4502/mnt/overlay/dam/gui/content/assets/assetedit.html
There are a certain number of crop aspect ratios.  I happen to require 4:3 which is not there.
How does one add a crop setting in 6.3?
1 Accepted Solution
Avatar
Correct answer by
Level 4
Okay. So editing this file
http://localhost:4502/crx/de/index.jsp#/libs/clientlibs/granite/coralui3/js/coral.js
by adding this file /apps/clientlibs/granite/coralui3/js/coral.js to my project did the trick. It would be much better if Adobe would engineer these features to be more easily customized. I don't like overlaying a js file that is over 71,000 lines to adjust 3 lines of code.
Also the ratios seem to be backwards. It was strange that the ratios need to height over width to come out properly. 4(w) : 3(h) should be a ratio of 1.3334, but needed to be coded as 0.75 in coral.js. Using the same process I had to fix the existing 2:3 crop, which should be a portrait.
Avatar
Administrator
Moving this question to AEM Assets topic.
~kautuk
Kautuk Sahni
Avatar
Administrator
Please find below some useful references:
1. Component Custom Aspect Ratios
2. Named Transform Image Servlet
3. Re: Set default crop aspect ratio on html5smartimage
I hope this would help you.
~kautuk
Kautuk Sahni
Avatar
Level 4
Hello. Thanks for the reply. I am familiar with these online documents. Unfortunately, they are not relevant to my question. Here are the steps to take;
1. start with /assets.html
2. find and select an image. then the path should be /assetdetails.html/content/dam/......
3. click the edit icon. then the path should be /mnt/overlay/dam/gui/content/assets/assetedit.html/content/dam/........
4. The upper left icon allow users to crop the DAM asset using different aspect ratios, 2:3, 5:3, 16:9, square, Free hand
The question is how to add and remove these crop options?
Avatar
Correct answer by
Level 4
Avatar
Level 1
Hi, it works for me too but it looks so ugly. Did you maybe found better solution for this? Did you contact Adobe what they recommend?
Avatar
Level 4
I wish there was a better solution. It's a huge pain.
Avatar
Level 1
There is another workaround which is a little bit less ugly:
Create a custom ClientLib with the category "coralui3"
<?xml version="1.0" encoding="UTF-8"?>
<jcr:root xmlns:sling="http://sling.apache.org/jcr/sling/1.0" xmlns:cq="http://www.day.com/jcr/cq/1.0" xmlns:jcr="http://www.jcp.org/jcr/1.0"
   jcr:primaryType="cq:ClientLibraryFolder"
   categories="[coralui3]"
   dependencies="[granite.jquery]"/>
Overwrite the global variables used in the coral.js file
(function () {
   "use strict";
   CUI.imageeditor.plugins.Crop.ASPECT_RATIOS = [
  {name: '16_to_10', ratio: 0.625},
   {name: '16_to_5', ratio: 0.3125},
   {name: '2_to_3', ratio: 1.5}
   for (var key in CUI.imageeditor.strings) {
   if (CUI.imageeditor.strings.hasOwnProperty(key)) {
  CUI.imageeditor.strings[key]["crop.aspect_ratios.16_to_5"] = "16 : 5";
   CUI.imageeditor.strings[key]["crop.aspect_ratios.16_to_10"] = "16 : 10";
