I'm trying to add 3D models of furniture into a photo of a vacant room. I am able to use the vanishing point filter and match the "current view" to it in 3D for certain photos. It works when the camera is pointed perpendicular to a wall (one point perspective.) But I can't find a way to line up the vanishing points so furniture looks correct on it. Here is an example of the photo I'm trying to use.
https://i.imgur.com/ymlirdo.jpg
Thanks in advance
Hi
The vanishing point plane does not have to be straight on to work.
In vanishing point just select an area of the floor and layout a plane that matches the tiles
When you take that into Photoshop you may need to adjust the camera FOV. Normally this is automatic but with the angled plane I found this step necessary. Just adjust the FOV value to match the "floor" plane with the background (don't move the camera). I needed to make FOV 13mm for your example.
Finally - turn off the opacity of the tem
...Copy link to clipboard
There is no such thing as a two-point perspective in real life. Two-point is merely a drawing technique - a camera always has only a single focal point. In your case the killer is the extreme wide/ fisheye lens effect, so unless you start to unwarp your image, use better lenses or use a more sophisticated 3D tool that can deal with this stuff, this won't work.
Mylenium
Thanks for your reply but there is a work around. You can change the FOV to match the mm of the wide angle lens and also use lens correction to fix any barrel distortion in the image.
Also there totally is two point perspective in real life
Hi
Finally - turn off the opacity of the temp floor material and change scene to solid rather than unlit texture.
Place your objects
Light and render. Rough and ready below but hopefully you get the idea.
Dave
Thank you Dave!
You're right 13mm works best. Which is very curious because the photo was taken at 16mm.
