The Interactive PDF is an Export Format not an Adobe PDF(Print) preset—choose Adobe PDF (Interactive) when you export.
Hi Bradleya,
As per the description above, you are not getting the PDF export PDF presets in InDesign, Is that correct?
Please refer to the following threads which discuss the similar issue: My export presets for PDF(print) are missing. Link: https://forums.adobe.com/thread/1077016
Interactive pdf presets Link: https://forums.adobe.com/thread/1178693
You may also refer to the following KB doc: Export InDesign files to Adobe PDF Link: https://helpx.adobe.com/indesign/using/exporting-publishing-pdf.html
Hope this helps.
Anand Sri.
No, these threads are not helpful and do not answer the questions.
InDesigns help says there is an "Interactive PDF" preset option when
exporting an InDesign file. I don't have such an option in my list, only
the ones in the picture I shared.
Hi Bradleya,
I am moving this thread to the InDesign space. Editing & Exporting PDFs to InDesign
Anand Sri.
Based on your screen shot you've chosen the PDF (Print) option in Export, not the PDF (Interactive).
Re-export and choose the correct format.
