Hello,
I am having some trouble with making an HDR image. When I go to bridge, select my 3 images, then tools, photoshop, merge to HDR pro....everything looks normal. The images start to open in Photoshop but then once they open photoshop closes them and goes to the open a file page. I have tried uninstalling and reinstalling but that didn't help. I also tried different pictures thinking it might be one of the files. I checked all the settings and i can't find any reason it would be doing this.
Any help would be great!!!
It look like Merge to HDR Pro is a Photoshop script that uses four other stack mode scripts and a plug-in. I would think then the script would open the images files and stack them as layer in a document. Not open to a put you into a open file dialog. So make sure you have the files that make up Merge to HDR Pro on your system in the right places and they have the correct date and size.
I checked that and they are in the right place and with the right date and time. The funny thing is that this worked last week then it just stopped.
If it worked last week. Try resetting all Photoshop's tools. If it still fails try resetting your Photoshop preferences
That worked with the exception of it won't open it in Camera Raw but I can work on that!
Thank you!!!!!
