Photoshop quits/crashes when I rotate the canvas
Oct 08, 2017 Oct 08, 2017
I've looked pretty extensively for a fix to this, but can't seem to find any other posts about it, at least with a simple Google search.
Essentially, since i updated CC a few months ago, if i rotate the canvas on a work and make a selection i can basically guarantee that the entire program with just crash and quit itself. If i try that same file again, no good; it'll crash any time i rotate the canvas. Ever. It's as if the file is 'infected'.
Has anyone experienced this?
I've tried reinstalling, restarting, going back to an earlier version, but no luck yet; perhaps it wasn't an early enough version and i should keep trying. Regardless, this is annihilating my productivity, and i'd love to not have to go back to cs6 over this.
2.2K
Adobe
Hi
Rotate view uses the Graphics Processor (GPU). It could be that you are hitting a bug in the driver and need to update that.
Can you go to Photoshop >Help >System Info and click copy.  Then paste the info here.
Dave
Thank you! I'm afraid i don't know much about messing with the GPU, but i've the information here:
Adobe Photoshop Version: 2017.0.0 20161012.r.53 2016/10/12:23:00:00 CL 1094006  x64
Number of Launches: 1
Operating System: Mac OS 10.12.5
System architecture: Intel CPU Family:6, Model:42, Stepping:7 with MMX, SSE Integer, SSE FP, SSE2, SSE3, SSE4.1, SSE4.2, AVX
Physical processor count: 4
Processor speed: 2700 MHz
Built-in memory: 12288 MB
Free memory: 5001 MB
Memory available to Photoshop: 9875 MB
Memory used by Photoshop: 70 %
Alias Layers: ^0
Modifier Palette: Disabled.
3D Multitone Printing: Disabled.
Highbeam: Enabled.
Image tile size: 1024K
Image cache levels: 4
Font Preview: Medium
TextComposer: Latin
Display: 1
Main Display
Display Bounds: top=0, left=0, bottom=800, right=1280
Display: 2
Display Bounds: top=0, left=-1920, bottom=1080, right=0
OpenGL Drawing: Enabled.
OpenGL Allow Old GPUs: Not Detected.
OpenGL Drawing Mode: Advanced
OpenGL Allow Normal Mode: True.
OpenGL Allow Advanced Mode: True.
AIFCoreInitialized=1
AIFOGLInitialized=1
OGLContextCreated=1
NumGLGPUs=1
NumCLGPUs=1
NumNativeGPUs=0
glgpu[0].GLVersion="2.1"
glgpu[0].IsIntegratedGLGPU=0
glgpu[0].GLMemoryMB=512
glgpu[0].GLName="AMD Radeon HD 6770M OpenGL Engine"
glgpu[0].GLVendor="ATI Technologies Inc."
glgpu[0].GLVendorID=4098
glgpu[0].GLRectTextureSize=16384
glgpu[0].GLRenderer="AMD Radeon HD 6770M OpenGL Engine"
glgpu[0].GLRendererID=16915206
glgpu[0].HasGLNPOTSupport=1
glgpu[0].CanCompileProgramGLSL=1
glgpu[0].GLFrameBufferOK=1
glgpu[0].glGetString[GL_SHADING_LANGUAGE_VERSION]="1.20"
glgpu[0].glGetProgramivARB[GL_FRAGMENT_PROGRAM_ARB][GL_MAX_PROGRAM_INSTRUCTIONS_ARB]=[4096]
glgpu[0].glGetIntegerv[GL_MAX_TEXTURE_UNITS]=[8]
glgpu[0].glGetIntegerv[GL_MAX_COMBINED_TEXTURE_IMAGE_UNITS]=[16]
glgpu[0].glGetIntegerv[GL_MAX_VERTEX_TEXTURE_IMAGE_UNITS]=[16]
glgpu[0].glGetIntegerv[GL_MAX_TEXTURE_IMAGE_UNITS]=[16]
glgpu[0].glGetIntegerv[GL_MAX_DRAW_BUFFERS]=[8]
glgpu[0].glGetIntegerv[GL_MAX_VERTEX_UNIFORM_COMPONENTS]=[3072]
glgpu[0].glGetIntegerv[GL_MAX_FRAGMENT_UNIFORM_COMPONENTS]=[3072]
glgpu[0].glGetIntegerv[GL_MAX_VARYING_FLOATS]=[128]
glgpu[0].glGetIntegerv[GL_MAX_VERTEX_ATTRIBS]=[16]
glgpu[0].extension[AIF::OGL::GL_ARB_VERTEX_PROGRAM]=1
glgpu[0].extension[AIF::OGL::GL_ARB_FRAGMENT_PROGRAM]=1
glgpu[0].extension[AIF::OGL::GL_ARB_VERTEX_SHADER]=1
glgpu[0].extension[AIF::OGL::GL_ARB_FRAGMENT_SHADER]=1
glgpu[0].extension[AIF::OGL::GL_EXT_FRAMEBUFFER_OBJECT]=1
glgpu[0].extension[AIF::OGL::GL_ARB_TEXTURE_RECTANGLE]=1
glgpu[0].extension[AIF::OGL::GL_ARB_TEXTURE_FLOAT]=1
glgpu[0].extension[AIF::OGL::GL_ARB_OCCLUSION_QUERY]=1
glgpu[0].extension[AIF::OGL::GL_ARB_VERTEX_BUFFER_OBJECT]=1
glgpu[0].extension[AIF::OGL::GL_ARB_SHADER_TEXTURE_LOD]=1
clgpu[0].CLPlatformVersion="1.2 (Apr  4 2017 19:07:42)"
clgpu[0].CLDeviceVersion="1.2 "
clgpu[0].IsIntegratedCLGPU=0
clgpu[0].CLMemoryMB=512
clgpu[0].CLName="ATI Radeon HD 6770M"
clgpu[0].CLVendor="AMD"
clgpu[0].CLVendorID=16915200
clgpu[0].CLDriverVersion="1.2 (Apr 27 2017 22:10:56)"
clgpu[0].CLBandwidth=2.28461e+10
clgpu[0].CLCompute=64.1081
License Type: Subscription
Serial number: 90970609799863397685
GUIDBucket:
  bucket: 238
  test: DocumentPanel
Application folder: /Applications/Adobe Photoshop CC 2017/
Photoshop scratch has async I/O enabled
Scratch volume(s):
  Startup, 930.7G, 317.8G free
Required Plug-ins folder: /Applications/Adobe Photoshop CC 2017/Adobe Photoshop CC 2017.app/Contents/Required/Plug-Ins/
Primary Plug-ins folder: /Applications/Adobe Photoshop CC 2017/Plug-ins/
Installed components:
   AdbePM.framework   AdbePM   2.5.00.37723   1.573920
   adobe_caps.framework   adobe_caps   10.0.0.6   1.584361
   AdobeACE.framework   AdobeACE   2.20.02.37194   79.577309
   AdobeAGM.framework   AdobeAGM   4.30.60.37194   79.577309
   AdobeAXE8SharedExpat.framework   AdobeAXE8SharedExpat   3.8.0.34320   79.562390
   AdobeAXEDOMCore.framework   AdobeAXEDOMCore   3.8.0.34320   79.562390
   AdobeBIB.framework   AdobeBIB   1.2.03.37194   79.577309
   AdobeBIBUtils.framework   AdobeBIBUtils   1.1.01   79.577309
   AdobeCoolType.framework   AdobeCoolType   5.15.00.37194   79.577309
   AdobeCrashReporter.framework   AdobeCrashReporter   7.3.2
   AdobeExtendScript.framework   AdobeExtendScript   4.5.6.4   80.1060872
   AdobeJP2K.framework   AdobeJP2K   1.2.2.36529   79.262945
   AdobeLinguistic.framework      21429
   AdobeMPS.framework   AdobeMPS   5.8.1.37174   79.577269
   AdobeOwl.framework   AdobeOwl   5.2.11
   AdobePDFL.framework   AdobePDFL   15.0.0.36975   79.195992
   AdobePDFSettings.framework   AdobePDFSettings   1.4
   AdobePIP.framework   AdobePIP   7.4.1.60.45263
   AdobeScCore.framework   AdobeScCore   4.5.6.4   80.1060872
   AdobeSVGAGM.framework   AdobeSVGAGM   1.0.0.37194   79.577309
   AdobeSVGRE.framework   AdobeSVGRE   6.0   79.577309
   AdobeUpdater.framework   AdobeUpdater   6.0.0.1452   "52.338651"
   AdobeXMP.framework   AdobeXMPCore   79.159824   79.159824
   AdobeXMPFiles.framework   AdobeXMPFiles   79.159824   79.159824
   AdobeXMPScript.framework   AdobeXMPScript   79.159824   79.159824
   ahclient.framework   ahclient   2.0.0.1
   AIDE.framework   AIDE   1.5.0.36540   79.574279
   aif.framework   aif   6.0.00.1   1.
   amtlib.framework   amtlib   10.0.0.47
   boost_date_time.framework   boost_date_time   10.0.0.0
   boost_filesystem.framework   boost_filesystem   10.0.0.0
   boost_signals.framework   boost_signals   10.0.0.0
   boost_system.framework   boost_system   10.0.0.0
   boost_threads.framework   boost_threads   10.0.0.0
   Cg.framework   NVIDIA Cg
   CIT.framework
   CITThreading.framework
   dvaaudiodevice.framework   dvaaudiodevice   10.0.0.0
   dvacore.framework   dvacore   10.0.0.0
   dvamarshal.framework   dvamarshal   10.0.0.0
   dvamediatypes.framework   dvamediatypes   10.0.0.0
   dvametadata.framework   dvametadata   10.0.0.0
   dvametadataapi.framework   dvametadataapi   10.0.0.0
   dvametadataUI.framework   dvametadataUI   10.0.0.0
   dvaplayer.framework   dvaplayer   10.0.0.0
   dvatransport.framework   dvatransport   10.0.0.0
   dvaui.framework   dvaui   10.0.0.0
   dvaunittesting.framework   dvaunittesting   10.0.0.0
   dynamiclink.framework   dynamiclink   10.0.0.0
   ICUConverter.framework   ICUConverter   3.61   "gtlib_6.0" "." "21287"
   ICUData.framework   ICUData   3.61   "gtlib_6.0" "." "21287"
   ICUUnicode.framework   ICUUnicode   3.61   "gtlib_6.0" "." "21287"
   LogSession.framework   LogSession   7.4.1.60.45263
   manta.framework   manta   2.0.00.1   1.
   mediacoreif.framework   mediacoreif   10.0.0.0
   PlugPlugExternalObject.framework      7.0.0.67
   PlugPlugOwl.framework   PlugPlugOwl   7.0.0.67
   UpdaterNotifications.framework   UpdaterNotifications   10.0.0.1   "10.0.0.1"
   WRServices.framework   WRServices   12.0.0   12.0.0.1000
Required plug-ins:
   3D Studio 18.0.0  ©2006-2016 Adobe Systems Incorporated - from the file “U3D.plugin”
   Accented Edges 18.0.0, Copyright © 1991-2016 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
   Adaptive Wide Angle 18.0.0, Copyright © 2014-2016 Adobe Systems Incorporated - from the file “Adaptive Wide Angle.plugin”
   Angled Strokes 18.0.0, Copyright © 1991-2016 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
   Average 18.0.0  ©1993-2016 Adobe Systems Incorporated - from the file “Average.plugin”
   Bas Relief 18.0.0, Copyright © 1991-2016 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
   BMP 18.0.0, Copyright © 2003-2016 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
   Camera Raw 9.12.1 (790), Copyright © 2017 Adobe Systems Incorporated - from the file “Camera Raw.plugin”
   Camera Raw Filter 9.12.1 (790), Copyright © 2017 Adobe Systems Incorporated - from the file “Camera Raw.plugin”
   Chalk & Charcoal 18.0.0, Copyright © 1991-2016 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
   Chrome 18.0.0, Copyright © 1991-2016 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
   Cineon 18.0.0  ©2002-2016 Adobe Systems Incorporated - from the file “Cineon.plugin”
   Clouds 18.0.0  ©1993-2016 Adobe Systems Incorporated - from the file “Clouds.plugin”
   Collada DAE 18.0.0  ©2006-2016 Adobe Systems Incorporated - from the file “U3D.plugin”
   Color Halftone 18.0.0, Copyright © 2003-2016 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
   Colored Pencil 18.0.0, Copyright © 1991-2016 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
   CompuServe GIF 18.0.0, Copyright © 2003-2016 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
   Conté Crayon 18.0.0, Copyright © 1991-2016 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
   Craquelure 18.0.0, Copyright © 1991-2016 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
   Crop and Straighten Photos 18.0.0  Copyright © 2003-2016 Adobe Systems Incorporated - from the file “CropPhotosAuto.plugin”
   Crop and Straighten Photos Filter 18.0.0, Copyright © 2003-2016 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
   Crosshatch 18.0.0, Copyright © 1991-2016 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
   Crystallize 18.0.0, Copyright © 2003-2016 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
   Cutout 18.0.0, Copyright © 1991-2016 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
   Dark Strokes 18.0.0, Copyright © 1991-2016 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
   De-Interlace 18.0.0, Copyright © 2003-2016 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
   Dicom 18.0.0, Copyright © 2003-2016 Adobe Systems Incorporated - from the file “dicom.plugin”
   Difference Clouds 18.0.0  ©1993-2016 Adobe Systems Incorporated - from the file “Clouds.plugin”
   Diffuse Glow 18.0.0, Copyright © 1991-2016 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
   Displace 18.0.0, Copyright © 2003-2016 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
   Dry Brush 18.0.0, Copyright © 1991-2016 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
   Eazel Acquire 18.0.0  Copyright © 2007-2016 Adobe Systems Incorporated - from the file “EazelAcquire.plugin”
   Entropy 18.0.0  ©2006-2016 Adobe Systems Incorporated - from the file “statistics.plugin”
   Export Color Lookup Tables 18.0.0  Copyright ©2012-2016 Adobe Systems Incorporated - from the file “Export3DLUT.plugin”
   Extrude 18.0.0, Copyright © 2003-2016 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
   FastCore Routines 18.0.0  ©1990-2016 Adobe Systems Incorporated - from the file “FastCore.plugin”
   Fibers 18.0.0, Copyright © 2003-2016 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
   Film Grain 18.0.0, Copyright © 1991-2016 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
   Filter Gallery 18.0.0, Copyright © 1991-2016 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
   Flash 3D 18.0.0  ©2006-2016 Adobe Systems Incorporated - from the file “U3D.plugin”
   Fresco 18.0.0, Copyright © 1991-2016 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
   Glass 18.0.0, Copyright © 1991-2016 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
   Glowing Edges 18.0.0, Copyright © 1991-2016 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
   Google Earth 4 KMZ 18.0.0  ©2006-2016 Adobe Systems Incorporated - from the file “U3D.plugin”
   Graphic Pen 18.0.0, Copyright © 1991-2016 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
   Halftone Pattern 18.0.0, Copyright © 1991-2016 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
   HDRMergeUI 18.0.0, Copyright © 2003-2016 Adobe Systems Incorporated - from the file “HDRMergeUI.plugin”
   HSB/HSL 18.0.0, Copyright © 2003-2016 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
   IFF Format 18.0.0, Copyright © 2003-2016 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
   IGES 18.0.0  ©2006-2016 Adobe Systems Incorporated - from the file “U3D.plugin”
   Ink Outlines 18.0.0, Copyright © 1991-2016 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
   JPEG 2000 18.0.0  Copyright © 2001-2016 Adobe Systems Incorporated - from the file “JPEG2000.plugin”
   Kurtosis 18.0.0  ©2006-2016 Adobe Systems Incorporated - from the file “statistics.plugin”
   Lens Blur 18.0.0, Copyright © 2002-2016 Adobe Systems Incorporated - from the file “Lens Blur.plugin”
   Lens Correction 18.0.0, Copyright © 2002-2016 Adobe Systems Incorporated - from the file “Lens Correct.plugin”
   Lens Flare 18.0.0, Copyright © 2003-2016 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
   Liquify 18.0.0, Copyright © 2001-2016 Adobe Systems Incorporated - from the file “Liquify.plugin”
   Matlab Operation 18.0.0  ©1993-2016 Adobe Systems Incorporated - from the file “ChannelPort.plugin”
   Maximum 18.0.0  ©2006-2016 Adobe Systems Incorporated - from the file “statistics.plugin”
   Mean 18.0.0  ©2006-2016 Adobe Systems Incorporated - from the file “statistics.plugin”
   Measurement Core 18.0.0  Copyright © 1993-2016 Adobe Systems Incorporated - from the file “MeasurementCore.plugin”
   Median 18.0.0  ©2006-2016 Adobe Systems Incorporated - from the file “statistics.plugin”
   Mezzotint 18.0.0, Copyright © 2003-2016 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
   Minimum 18.0.0  ©2006-2016 Adobe Systems Incorporated - from the file “statistics.plugin”
   MMXCore Routines 18.0.0  ©1990-2016 Adobe Systems Incorporated - from the file “MMXCore.plugin”
   Mosaic Tiles 18.0.0, Copyright © 1991-2016 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
   Multiprocessor Support 18.0.0  Copyright © 1990-2016 Adobe Systems Incorporated - from the file “MultiProcessor Support.plugin”
   Neon Glow 18.0.0, Copyright © 1991-2016 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
   Note Paper 18.0.0, Copyright © 1991-2016 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
   NTSC Colors 18.0.0  ©1993-2016 Adobe Systems Incorporated - from the file “NTSC Colors.plugin”
   Ocean Ripple 18.0.0, Copyright © 1991-2016 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
   OpenEXR 18.0.0, Copyright © 2003-2016 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
   Paint Daubs 18.0.0, Copyright © 1991-2016 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
   Palette Knife 18.0.0, Copyright © 1991-2016 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
   Patchwork 18.0.0, Copyright © 1991-2016 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
   Paths to Illustrator 18.0.0, Copyright © 2003-2016 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
   PCX 18.0.0  ©1989-2016 Adobe Systems Incorporated - from the file “PCX.plugin”
   Photocopy 18.0.0, Copyright © 1991-2016 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
   Photoshop 3D Engine 18.0.0  ©2006-2016 Adobe Systems Incorporated - from the file “Photoshop3DEngine.plugin”
   Photoshop Touch Copyright ©2013-2016 Adobe Systems Incorporated - from the file “PSDX.plugin”
   Picture Package Filter 18.0.0  ©1993-2016 Adobe Systems Incorporated - from the file “ChannelPort.plugin”
   Pinch 18.0.0, Copyright © 2003-2016 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
   Pixar 18.0.0  ©1989-2016 Adobe Systems Incorporated - from the file “Pixar.plugin”
   Plaster 18.0.0, Copyright © 1991-2016 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
   Plastic Wrap 18.0.0, Copyright © 1991-2016 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
   PLY 18.0.0  ©2006-2016 Adobe Systems Incorporated - from the file “U3D.plugin”
   PNG 18.0.0, Copyright © 2003-2016 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
   Pointillize 18.0.0, Copyright © 2003-2016 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
   Polar Coordinates 18.0.0, Copyright © 2003-2016 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
   Portable Bit Map 18.0.0  ©1989-2016 Adobe Systems Incorporated - from the file “PBM.plugin”
   Poster Edges 18.0.0, Copyright © 1991-2016 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
   PRC 18.0.0  ©2006-2016 Adobe Systems Incorporated - from the file “U3D.plugin”
   Radial Blur 18.0.0, Copyright © 2003-2016 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
   Radiance 18.0.0  ©2003-2016 Adobe Systems Incorporated - from the file “Radiance.plugin”
   Range 18.0.0  ©2006-2016 Adobe Systems Incorporated - from the file “statistics.plugin”
   Render Color Lookup Grid 18.0.0  Copyright ©2012-2016 Adobe Systems Incorporated - from the file “Export3DLUT.plugin”
   Reticulation 18.0.0, Copyright © 1991-2016 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
   Ripple 18.0.0, Copyright © 2003-2016 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
   Rough Pastels 18.0.0, Copyright © 1991-2016 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
   Save for Web 18.0.0, Copyright © 1999-2016 Adobe Systems Incorporated - from the file “Save for Web.plugin”
   ScriptingSupport 18.0.0, Copyright © 2016 Adobe Systems Incorporated - from the file “ScriptingSupport.plugin”
   Shake Reduction 18.0.0, Copyright © 2014-2016 Adobe Systems Incorporated - from the file “Shake Reduction.plugin”
   Shear 18.0.0, Copyright © 2003-2016 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
   Skewness 18.0.0  ©2006-2016 Adobe Systems Incorporated - from the file “statistics.plugin”
   Smart Blur 18.0.0, Copyright © 2003-2016 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
   Smudge Stick 18.0.0, Copyright © 1991-2016 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
   Solarize 18.0.0  Copyright © 1993-2016 Adobe Systems Incorporated - from the file “Solarize.plugin”
   Spaces 18.0.0, Copyright © 2015 Adobe Systems Incorporated - from the file “Spaces.plugin”
   Spatter 18.0.0, Copyright © 1991-2016 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
   Spherize 18.0.0, Copyright © 2003-2016 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
   Sponge 18.0.0, Copyright © 1991-2016 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
   Sprayed Strokes 18.0.0, Copyright © 1991-2016 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
   Stained Glass 18.0.0, Copyright © 1991-2016 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
   Stamp 18.0.0, Copyright © 1991-2016 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
   Standard Deviation 18.0.0  ©2006-2016 Adobe Systems Incorporated - from the file “statistics.plugin”
   STL 18.0.0  ©2006-2016 Adobe Systems Incorporated - from the file “U3D.plugin”
   Sumi-e 18.0.0, Copyright © 1991-2016 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
   Summation 18.0.0  ©2006-2016 Adobe Systems Incorporated - from the file “statistics.plugin”
   Targa 18.0.0, Copyright © 2003-2016 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
   Texturizer 18.0.0, Copyright © 1991-2016 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
   Tiles 18.0.0, Copyright © 2003-2016 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
   Torn Edges 18.0.0, Copyright © 1991-2016 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
   Twirl 18.0.0, Copyright © 2003-2016 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
   U3D 18.0.0  ©2006-2016 Adobe Systems Incorporated - from the file “U3D.plugin”
   Underpainting 18.0.0, Copyright © 1991-2016 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
   Vanishing Point 18.0.0, Copyright © 2003-2016 Adobe Systems Incorporated - from the file “VanishingPoint.plugin”
   Variance 18.0.0  ©2006-2016 Adobe Systems Incorporated - from the file “statistics.plugin”
   Virtual Reality Modeling Language | VRML 18.0.0  ©2006-2016 Adobe Systems Incorporated - from the file “U3D.plugin”
   Water Paper 18.0.0, Copyright © 1991-2016 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
   Watercolor 18.0.0, Copyright © 1991-2016 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
   Wave 18.0.0, Copyright © 2003-2016 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
   Wavefront|OBJ 18.0.0  ©2006-2016 Adobe Systems Incorporated - from the file “U3D.plugin”
   Wind 18.0.0, Copyright © 2003-2016 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
   Wireless Bitmap 18.0.0  ©1989-2016 Adobe Systems Incorporated - from the file “WBMP.plugin”
   ZigZag 18.0.0, Copyright © 2003-2016 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
Optional and third party plug-ins: NONE
Duplicate and Disabled plug-ins: NONE
Plug-ins that failed to load: NONE
Extensions:
   com.adobe.inapp.purchase  2.10.56 - from the file “/Library/Application Support/Adobe/CEP/extensions/CC_LIBRARIES_PANEL_EXTENSION_2_10_56/purchase.html”
   Libraries  2.10.56 - from the file “/Library/Application Support/Adobe/CEP/extensions/CC_LIBRARIES_PANEL_EXTENSION_2_10_56/index.html”
   New Document  2.0.1 - from the file “/Users/bwright/Library/Application Support/Adobe/CEP/extensions/CCX_CMDN_EXTENSION_2_0_1_001/fnft.html”
   com.adobe.experimentation.extension  2.0.0 - from the file “/Applications/Adobe Photoshop CC 2017/Adobe Photoshop CC 2017.app/Contents/Required/CEP/extensions/com.adobe.experimentation.extension/index.html”
   Start  2.0.1 - from the file “/Users/bwright/Library/Application Support/Adobe/CEP/extensions/CCX_START_EXTENSION_2_0_1_044/index.html”
   Adobe Color Themes  6.1.0 - from the file “/Applications/Adobe Photoshop CC 2017/Adobe Photoshop CC 2017.app/Contents/Required/CEP/extensions/com.adobe.KulerPanel.html/index.html”
   Export As  3.0.8 - from the file “/Applications/Adobe Photoshop CC 2017/Adobe Photoshop CC 2017.app/Contents/Required/CEP/extensions/com.adobe.photoshop.crema/PSPanel/dialog.html”
   Device Preview  1.3.2 - from the file “/Library/Application Support/Adobe/CEP/extensions/com.adobe.previewHD/PSPanel/panel.html”
   com.adobe.preview.loader  1.3.2 - from the file “/Library/Application Support/Adobe/CEP/extensions/com.adobe.previewHD/PSLoader/loader.html”
Installed TWAIN devices: NONE
Hi
A couple of things:
You are not using the latest version of Photoshop. The latest is CC2017.1.1 - you are still using 2017.0.0 you may wish to update.
According to the AMD site the last driver update for your GPU card was Crimson 16.2.1.No further updates were or will be issued after January 2016 However you appear to have GPU updates from 2017 so I it may be worth trying a roll back to the older driver.
AMD Radeon Software Crimson Edition 16.2.1 Beta for Non GCN Products Release Notes
The notes reference a bug where you would be notified of a further update but that update is not compatible with your card.
Also see this : Legacy
Dave
The problem with OSX and graphics adapters is that drivers are issued by Apple as part of OS updates and not the card maker. Only Windows users get to choose their drivers.
Hopefully the CC 2017 updates will solve the problem.
You have MacOS 10.12.5 and 10.12.6 is the latest I would recommend especially if you do not want to play with 10.13 High Sierra yet.
Gene
Ooops - forgot it was MAC - sorry
Slpw - please ignore those Windows driver references .
Dave
Yes, since this seemed to begin with my software update to CC, i keep wondering if there's going to be a new update that will simply solve the problem.
Let's start with the GPU. Adobe Camera Raw has a GPU function that has been known to cause problems in Photoshop, so first step is to uncheck it and restart your Mac. Uncheck "Use Graphics Processor."
If that does not solve it, you can uncheck Photoshop's Use Graphics Processor to isolate the card.
or keep the GPU checked on and tamp down the Advanced Settings to Basic.
Okay, I've done it, but unchecking the GPU option gives me the typical "Could not complete your request because it only works with OpenGL enabled document windows." error. Will next try the basic settings option.
Ok, let me know.
Sadly, neither works, unless I should restart my computer again after turning gpu back on and setting advanced settings to 'basic'. I had merely quit and restarted photoshop.
Will a crash report help?
Restart your Mac. One other trick is resetting Directory permissions.
You do this via Terminal
Copy and Paste this command into Terminal and execute it.
sudo chmod -R 777 /Library/Application\ Support/Adobe
Restart your Mac.
As for the crash report, post it. I can look at it, but I'm not very good at reading them.
Oct 09, 2017 Oct 09, 2017
Oh dear, i thought it had worked, but no good. Will next try updating my photoshop again and send a crash report if i can get one.
Process:               Adobe Photoshop CC 2017 [640]
Path:                  /Applications/Adobe Photoshop CC 2017/Adobe Photoshop CC 2017.app/Contents/MacOS/Adobe Photoshop CC 2017
Identifier:            com.adobe.Photoshop
Version:               18.1.1 (18.1.1.252)
Code Type:             X86-64 (Native)
Parent Process:        ??? [1]
Responsible:           Adobe Photoshop CC 2017 [640]
User ID:               501
Date/Time:             2017-10-09 15:58:40.990 -0500
OS Version:            Mac OS X 10.12.6 (16G29)
Report Version:        12
Anonymous UUID:        474ACEF9-B5A9-900B-5F94-F325108A1B5B
Time Awake Since Boot: 750 seconds
System Integrity Protection: enabled
Crashed Thread:        0  Dispatch queue: com.apple.main-thread
Exception Type:        EXC_BAD_ACCESS (SIGBUS)
Exception Codes:       KERN_PROTECTION_FAILURE at 0x0000000114122d40
Exception Note:        EXC_CORPSE_NOTIFY
Termination Signal:    Bus error: 10
Termination Reason:    Namespace SIGNAL, Code 0xa
Terminating Process:   exc handler [0]
VM Regions Near 0x114122d40:
    mapped file            0000000113f1f000-000000011400f000 [  960K] r--/rwx SM=COW
--> __TEXT                 000000011400f000-000000011415b000 [ 1328K] r-x/rwx SM=COW  /Applications/Adobe Photoshop CC 2017/Adobe Photoshop CC 2017.app/Contents/Frameworks/IMSLib.dylib
    __DATA                 000000011415b000-000000011416a000 [   60K] rw-/rwx SM=COW  /Applications/Adobe Photoshop CC 2017/Adobe Photoshop CC 2017.app/Contents/Frameworks/IMSLib.dylib
Thread 0 Crashed:: Dispatch queue: com.apple.main-thread
0   MMXCore                        0x0000000111bc724a 0x111b60000 + 422474
1   com.adobe.Photoshop            0x00000001021204f7 0x1017ea000 + 9659639
2   com.adobe.Photoshop            0x00000001021341ff 0x1017ea000 + 9740799
3   com.adobe.Photoshop            0x0000000101fb17ed 0x1017ea000 + 8157165
4   com.adobe.Photoshop            0x000000010246c03a 0x1017ea000 + 13115450
5   com.adobe.Photoshop            0x00000001018af79a 0x1017ea000 + 808858
6   com.adobe.Photoshop            0x0000000101887b70 0x1017ea000 + 646000
7   com.adobe.Photoshop            0x0000000101887c39 0x1017ea000 + 646201
8   com.adobe.Photoshop            0x000000010372b78d 0x1017ea000 + 32774029
9   com.apple.Foundation          0x00007fffacdd6e0f __NSFireTimer + 83
10  com.apple.CoreFoundation      0x00007fffab32ee04 __CFRUNLOOP_IS_CALLING_OUT_TO_A_TIMER_CALLBACK_FUNCTION__ + 20
11  com.apple.CoreFoundation      0x00007fffab32ea93 __CFRunLoopDoTimer + 1075
12  com.apple.CoreFoundation      0x00007fffab32e5ea __CFRunLoopDoTimers + 298
13  com.apple.CoreFoundation      0x00007fffab325fc1 __CFRunLoopRun + 2081
14  com.apple.CoreFoundation      0x00007fffab325544 CFRunLoopRunSpecific + 420
15  com.apple.HIToolbox            0x00007fffaa884ebc RunCurrentEventLoopInMode + 240
16  com.apple.HIToolbox            0x00007fffaa884cf1 ReceiveNextEventCommon + 432
17  com.apple.HIToolbox            0x00007fffaa884b26 _BlockUntilNextEventMatchingListInModeWithFilter + 71
18  com.apple.AppKit              0x00007fffa8e1da54 _DPSNextEvent + 1120
19  com.apple.AppKit              0x00007fffa95997ee -[NSApplication(NSEvent) _nextEventMatchingEventMask:untilDate:inMode:dequeue:] + 2796
20  com.adobe.Photoshop            0x000000010372a441 0x1017ea000 + 32769089
21  com.apple.AppKit              0x00007fffa8e123db -[NSApplication run] + 926
22  com.adobe.Photoshop            0x000000010372b5a2 0x1017ea000 + 32773538
23  com.adobe.Photoshop            0x000000010372c928 0x1017ea000 + 32778536
24  com.adobe.Photoshop            0x000000010188968d 0x1017ea000 + 652941
25  com.adobe.Photoshop            0x0000000101c017df 0x1017ea000 + 4290527
26  com.adobe.Photoshop            0x0000000101c01a69 0x1017ea000 + 4291177
27  libdyld.dylib                  0x00007fffc0ef0235 start + 1
Thread 1:
0   libsystem_kernel.dylib        0x00007fffc101f44e __workq_kernreturn + 10
1   libsystem_pthread.dylib        0x00007fffc1109621 _pthread_wqthread + 1426
2   libsystem_pthread.dylib        0x00007fffc110907d start_wqthread + 13
Thread 2:: MPSupport Worker
0   libsystem_kernel.dylib        0x00007fffc101ebf2 __psynch_cvwait + 10
1   libsystem_pthread.dylib        0x00007fffc110a7fa _pthread_cond_wait + 712
2   MultiProcessor Support        0x0000000111caa0fb 0x111c60000 + 303355
3   MultiProcessor Support        0x0000000111caa01b 0x111c60000 + 303131
4   MultiProcessor Support        0x0000000111ccb7a6 0x111c60000 + 440230
5   libsystem_pthread.dylib        0x00007fffc110993b _pthread_body + 180
6   libsystem_pthread.dylib        0x00007fffc1109887 _pthread_start + 286
7   libsystem_pthread.dylib        0x00007fffc110908d thread_start + 13
Thread 3:: MPSupport Worker
Thread 4:: MPSupport Worker
Thread 5:: VulcanMsgRecv
0   libsystem_kernel.dylib        0x00007fffc101edf6 __recvfrom + 10
1   VulcanMessage5.dylib          0x000000010d0e8308 vcfoundation::net::Bsd::Recv(int, void*, int, int) + 16
2   VulcanMessage5.dylib          0x000000010d0e76cc vcfoundation::io::BSDNamedPipe::Read(void*, unsigned long) + 20
3   VulcanMessage5.dylib          0x000000010d0e69c4 vcfoundation::io::BufferedReader::InternalRead(char*, long) + 100
4   VulcanMessage5.dylib          0x000000010d0e6888 vcfoundation::io::BufferedReader::Read(void*, unsigned long) + 50
5   VulcanMessage5.dylib          0x000000010d0e14c7 vcfoundation::io::IVCChannel::ReadFully(void*, unsigned long) + 57
6   VulcanMessage5.dylib          0x000000010d0e1f56 vcfoundation::io::Serializer::InternalDeserialize() + 30
7   VulcanMessage5.dylib          0x000000010d0e18ef vcfoundation::io::Serializer::Deserialize() + 9
8   VulcanMessage5.dylib          0x000000010d0e5974 vcfoundation::ncomm::Connection::ReadIn() + 22
9   VulcanMessage5.dylib          0x000000010d0e53cd vcfoundation::ncomm::NCService::ReadResponse(vcfoundation::ncomm::INCRequest*, vcfoundation::ncomm::INCListener&, vcfoundation::ncomm::NCService::ConRef&) + 41
10  VulcanMessage5.dylib          0x000000010d0e50ba vcfoundation::ncomm::NCService::Execute(vcfoundation::ncomm::INCRequest*, vcfoundation::ncomm::INCListener&) + 166
11  VulcanMessage5.dylib          0x000000010d0e500d vcfoundation::ncomm::NCService::Execute(vcfoundation::ncomm::INCRequest*) + 29
12  VulcanMessage5.dylib          0x000000010d0d8848 adobe::vulcan::servicemgr::CSIRequest::Execute() + 50
13  VulcanMessage5.dylib          0x000000010d0d7a86 adobe::vulcan::servicemgr::RegisterForEventsRequest::Run() + 622
14  VulcanMessage5.dylib          0x000000010d0e620c vcfoundation::thread::AbstractThread::Run() + 72
15  VulcanMessage5.dylib          0x000000010d0e8109 vcfoundation::thread::Thread::ThreadProc(void*) + 9
16  libsystem_pthread.dylib        0x00007fffc110993b _pthread_body + 180
17  libsystem_pthread.dylib        0x00007fffc1109887 _pthread_start + 286
18  libsystem_pthread.dylib        0x00007fffc110908d thread_start + 13
Thread 6:
0   libsystem_kernel.dylib        0x00007fffc1017386 semaphore_wait_trap + 10
1   libtbb.dylib                  0x0000000108fce100 tbb::internal::rml::private_worker::thread_routine(void*) + 448
2   libsystem_pthread.dylib        0x00007fffc110993b _pthread_body + 180
3   libsystem_pthread.dylib        0x00007fffc1109887 _pthread_start + 286
4   libsystem_pthread.dylib        0x00007fffc110908d thread_start + 13
Thread 7:
Thread 8:
Thread 9:: BridgeTalk
0   libsystem_kernel.dylib        0x00007fffc101ef46 __semwait_signal + 10
1   libsystem_c.dylib              0x00007fffc0fa5b72 nanosleep + 199
2   com.adobe.PSAutomate          0x00000001161a1ce8 0x115fce000 + 1916136
3   com.adobe.PSAutomate          0x0000000116183b5c 0x115fce000 + 1792860
4   com.adobe.PSAutomate          0x00000001161a1871 0x115fce000 + 1914993
Thread 10:: com.apple.NSEventThread
0   libsystem_kernel.dylib        0x00007fffc101734a mach_msg_trap + 10
1   libsystem_kernel.dylib        0x00007fffc1016797 mach_msg + 55
2   com.apple.CoreFoundation      0x00007fffab326874 __CFRunLoopServiceMachPort + 212
3   com.apple.CoreFoundation      0x00007fffab325cf1 __CFRunLoopRun + 1361
5   com.apple.AppKit              0x00007fffa8f6af02 _NSEventThread + 205
Thread 11:
2   com.adobe.headlights.LogSessionFramework 0x000000010c1fcccc boost::condition_variable::do_wait_until(boost::unique_lock<boost::mutex>&, timespec const&) + 76
3   com.adobe.headlights.LogSessionFramework 0x000000010c1fb5ef boost::this_thread::hiden::sleep_for(timespec const&) + 191
4   com.adobe.headlights.LogSessionFramework 0x000000010c1a9059 void boost::this_thread::sleep_for<long long, boost::ratio<1l, 1l> >(boost::chrono::duration<long long, boost::ratio<1l, 1l> > const&) + 107
5   com.adobe.headlights.LogSessionFramework 0x000000010c177cfb RealTimeProcessor::WorkerThread(int, int) + 3633
6   com.adobe.headlights.LogSessionFramework 0x000000010c1fa969 boost::(anonymous namespace)::thread_proxy(void*) + 185
7   libsystem_pthread.dylib        0x00007fffc110993b _pthread_body + 180
8   libsystem_pthread.dylib        0x00007fffc1109887 _pthread_start + 286
9   libsystem_pthread.dylib        0x00007fffc110908d thread_start + 13
Thread 12:: com.apple.NSURLConnectionLoader
5   com.apple.CFNetwork            0x00007fffaa461734 +[NSURLConnection(Loader) _resourceLoadLoop:] + 313
6   com.apple.Foundation          0x00007fffacd668ad __NSThread__start__ + 1243
Thread 13:
2   com.adobe.headlights.LogSessionFramework 0x000000010c1aa152 boost::condition_variable::wait_until(boost::unique_lock<boost::mutex>&, boost::chrono::time_point<boost::chrono::system_clock, boost::chrono::duration<long long, boost::ratio<1l, 1000000000l> > >) + 124
3   com.adobe.headlights.LogSessionFramework 0x000000010c1a90db void boost::this_thread::sleep_until<boost::chrono::system_clock, boost::chrono::duration<long long, boost::ratio<1l, 1000000000l> > >(boost::chrono::time_point<boost::chrono::system_clock, boost::chrono::duration<long long, boost::ratio<1l, 1000000000l> > > const&) + 124
4   com.adobe.headlights.LogSessionFramework 0x000000010c1a8bae IdleTimeLogger::IdleTimeWorkerThread() + 2804
5   com.adobe.headlights.LogSessionFramework 0x000000010c1fa969 boost::(anonymous namespace)::thread_proxy(void*) + 185
Thread 14:: Update Activation Menu Items
2   com.adobe.Photoshop            0x0000000101b4d3a2 0x1017ea000 + 3552162
3   CITThreading                  0x000000010968605e boost::(anonymous namespace)::thread_proxy(void*) + 130
4   libsystem_pthread.dylib        0x00007fffc110993b _pthread_body + 180
5   libsystem_pthread.dylib        0x00007fffc1109887 _pthread_start + 286
6   libsystem_pthread.dylib        0x00007fffc110908d thread_start + 13
Thread 15:
2   libc++.1.dylib                0x00007fffbfa8c4cd std::__1::condition_variable::wait(std::__1::unique_lock<std::__1::mutex>&) + 47
3   com.adobe.Photoshop            0x00000001017ef2fd 0x1017ea000 + 21245
4   com.adobe.Photoshop            0x00000001017eff5b 0x1017ea000 + 24411
5   com.adobe.Photoshop            0x00000001017efd4e 0x1017ea000 + 23886
Thread 16:
Thread 17:
Thread 18:
Thread 19:: com.apple.CFSocket.private
0   libsystem_kernel.dylib        0x00007fffc101eeb6 __select + 10
1   com.apple.CoreFoundation      0x00007fffab361939 __CFSocketManager + 729
Thread 20:: NetworkConfigWatcher
5   com.apple.Foundation          0x00007fffacd56252 -[NSRunLoop(NSRunLoop) runMode:beforeDate:] + 277
6   org.chromium.ContentShell.framework 0x00000001492d1eee 0x147d31000 + 22679278
7   org.chromium.ContentShell.framework 0x00000001492d172c 0x147d31000 + 22677292
8   org.chromium.ContentShell.framework 0x00000001492ea113 0x147d31000 + 22778131
9   org.chromium.ContentShell.framework 0x000000014930d7d2 0x147d31000 + 22923218
10  org.chromium.ContentShell.framework 0x00000001493092f7 0x147d31000 + 22905591
11  libsystem_pthread.dylib        0x00007fffc110993b _pthread_body + 180
12  libsystem_pthread.dylib        0x00007fffc1109887 _pthread_start + 286
13  libsystem_pthread.dylib        0x00007fffc110908d thread_start + 13
Thread 21:: DnsConfigService
0   libsystem_kernel.dylib        0x00007fffc101fd96 kevent + 10
1   org.chromium.ContentShell.framework 0x00000001493413e7 0x147d31000 + 23135207
2   org.chromium.ContentShell.framework 0x000000014933eebd 0x147d31000 + 23125693
3   org.chromium.ContentShell.framework 0x00000001492d0e2f 0x147d31000 + 22674991
4   org.chromium.ContentShell.framework 0x00000001492ea113 0x147d31000 + 22778131
5   org.chromium.ContentShell.framework 0x000000014930d7d2 0x147d31000 + 22923218
6   org.chromium.ContentShell.framework 0x00000001493092f7 0x147d31000 + 22905591
Thread 22:: WorkerPool/89863
1   libsystem_pthread.dylib        0x00007fffc110a833 _pthread_cond_wait + 769
2   org.chromium.ContentShell.framework 0x00000001492fa64b 0x147d31000 + 22845003
3   org.chromium.ContentShell.framework 0x000000014930f5d9 0x147d31000 + 22930905
4   org.chromium.ContentShell.framework 0x000000014930fb57 0x147d31000 + 22932311
5   org.chromium.ContentShell.framework 0x00000001493092f7 0x147d31000 + 22905591
Thread 23:: WorkerPool/90115
Thread 24:: Chrome_DBThread
5   org.chromium.ContentShell.framework 0x00000001492d1c4f 0x147d31000 + 22678607
6   org.chromium.ContentShell.framework 0x00000001492d172c 0x147d31000 + 22677292
7   org.chromium.ContentShell.framework 0x00000001492ea113 0x147d31000 + 22778131
8   org.chromium.ContentShell.framework 0x0000000148a07354 0x147d31000 + 13460308
9   org.chromium.ContentShell.framework 0x0000000148a074c3 0x147d31000 + 13460675
10  org.chromium.ContentShell.framework 0x000000014930d7d2 0x147d31000 + 22923218
11  org.chromium.ContentShell.framework 0x00000001493092f7 0x147d31000 + 22905591
12  libsystem_pthread.dylib        0x00007fffc110993b _pthread_body + 180
13  libsystem_pthread.dylib        0x00007fffc1109887 _pthread_start + 286
14  libsystem_pthread.dylib        0x00007fffc110908d thread_start + 13
Thread 25:: Chrome_FileThread
5   org.chromium.ContentShell.framework 0x0000000148a07384 0x147d31000 + 13460356
6   org.chromium.ContentShell.framework 0x0000000148a074d0 0x147d31000 + 13460688
7   org.chromium.ContentShell.framework 0x000000014930d7d2 0x147d31000 + 22923218
8   org.chromium.ContentShell.framework 0x00000001493092f7 0x147d31000 + 22905591
9   libsystem_pthread.dylib        0x00007fffc110993b _pthread_body + 180
10  libsystem_pthread.dylib        0x00007fffc1109887 _pthread_start + 286
11  libsystem_pthread.dylib        0x00007fffc110908d thread_start + 13
Thread 26:: Chrome_FileUserBlockingThread
8   org.chromium.ContentShell.framework 0x0000000148a073b4 0x147d31000 + 13460404
9   org.chromium.ContentShell.framework 0x0000000148a074dd 0x147d31000 + 13460701
Thread 27:: Chrome_ProcessLauncherThread
8   org.chromium.ContentShell.framework 0x0000000148a073e4 0x147d31000 + 13460452
9   org.chromium.ContentShell.framework 0x0000000148a074ea 0x147d31000 + 13460714
Thread 28:: Chrome_CacheThread
8   org.chromium.ContentShell.framework 0x0000000148a07414 0x147d31000 + 13460500
9   org.chromium.ContentShell.framework 0x0000000148a074f7 0x147d31000 + 13460727
Thread 29:: Chrome_IOThread
3   org.chromium.ContentShell.framework 0x00000001492d0e16 0x147d31000 + 22674966
5   org.chromium.ContentShell.framework 0x0000000148a07444 0x147d31000 + 13460548
6   org.chromium.ContentShell.framework 0x0000000148a07504 0x147d31000 + 13460740
Thread 30:: BrowserBlockingWorker1/101635
2   org.chromium.ContentShell.framework 0x000000014930a2cf 0x147d31000 + 22909647
3   org.chromium.ContentShell.framework 0x0000000149309976 0x147d31000 + 22907254
4   org.chromium.ContentShell.framework 0x000000014930cc5d 0x147d31000 + 22920285
Thread 31:: IndexedDB
8   org.chromium.ContentShell.framework 0x000000014930d7d2 0x147d31000 + 22923218
9   org.chromium.ContentShell.framework 0x00000001493092f7 0x147d31000 + 22905591
10  libsystem_pthread.dylib        0x00007fffc110993b _pthread_body + 180
11  libsystem_pthread.dylib        0x00007fffc1109887 _pthread_start + 286
12  libsystem_pthread.dylib        0x00007fffc110908d thread_start + 13
Thread 32:: CompositorTileWorker1/104451
2   org.chromium.ContentShell.framework 0x00000001493c0698 0x147d31000 + 23656088
3   org.chromium.ContentShell.framework 0x000000014930cc5d 0x147d31000 + 22920285
4   org.chromium.ContentShell.framework 0x00000001493092f7 0x147d31000 + 22905591
Thread 33:: AudioThread
Thread 34:: NetworkConfigWatcher
Thread 35:: Chrome_DevToolsHandlerThread
Thread 36:
5   com.apple.Foundation          0x00007ffface69eed -[NSConnection run] + 144
Thread 37:: CEPMonitorThread
5   com.apple.Foundation          0x00007fffacdfc051 -[NSConcreteTask waitUntilExit] + 213
6   com.adobe.PlugPlugOwl          0x00000001099afc4b -[HtmlEngineMonitor monitorThreadProc] + 160
7   com.apple.Foundation          0x00007fffacd668ad __NSThread__start__ + 1243
8   libsystem_pthread.dylib        0x00007fffc110993b _pthread_body + 180
9   libsystem_pthread.dylib        0x00007fffc1109887 _pthread_start + 286
10  libsystem_pthread.dylib        0x00007fffc110908d thread_start + 13
Thread 38:: General Background Service
2   com.adobe.Photoshop            0x0000000101bccfb1 0x1017ea000 + 4075441
3   com.adobe.Photoshop            0x0000000103ad681c 0x1017ea000 + 36620316
4   com.adobe.Photoshop            0x0000000103ad5cac 0x1017ea000 + 36617388
5   com.adobe.Photoshop            0x0000000103ad7ba6 0x1017ea000 + 36625318
6   CITThreading                  0x000000010968605e boost::(anonymous namespace)::thread_proxy(void*) + 130
Thread 39:
Thread 40:
Thread 41:: CEPMonitorThread
Thread 42:
Thread 43:: BrowserBlockingWorker2/147511
Thread 44:: BrowserBlockingWorker3/85051
Thread 45:
2   com.apple.CoreServices.CarbonCore 0x00007fffac277984 TSWaitOnConditionTimedRelative + 147
3   com.apple.CoreServices.CarbonCore 0x00007fffac277585 TSWaitOnSemaphoreCommon + 433
4   com.apple.CoreServices.CarbonCore 0x00007fffac23fa8f AsyncFileThread(void*) + 261
Thread 46:
0   libsystem_pthread.dylib        0x00007fffc1109070 start_wqthread + 0
1   ???                            0x6e69740000000000 0 + 7956017760075513856
Thread 47:
1   ???                            0x0000000108fbb000 0 + 4445679616
Thread 48:: Font Initialization
Thread 49:: DeepFont
Thread 50:
1   ???                            0x0000700014d9fbe0 0 + 123145652141024
Thread 0 crashed with X86 Thread State (64-bit):
  rax: 0x0000000000000003  rbx: 0x00000000fffffcbd  rcx: 0x0000000000000001  rdx: 0x0000000000000000
  rdi: 0x0000000114122d40  rsi: 0x00000000000001b0  rbp: 0x00007fff5e412c30  rsp: 0x00007fff5e412988
   r8: 0x0000000114122d40   r9: 0x00000000000001b0  r10: 0x0000000114122dc0  r11: 0x0000000000000000
  r12: 0x00007fde4cd1bc00  r13: 0x00000000fffa7d40  r14: 0x00000000000001b0  r15: 0x00000000000001b0
  rip: 0x0000000111bc724a  rfl: 0x0000000000010206  cr2: 0x0000000114122d40
Logical CPU:     2
Error Code:      0x00000007
Trap Number:     14
Binary Images:
       0x1017ea000 -        0x107fd7f87 +com.adobe.Photoshop (18.1.1 - 18.1.1.252) <B684F32F-915C-3BEA-B7EC-8B5F5820FAAC> /Applications/Adobe Photoshop CC 2017/Adobe Photoshop CC 2017.app/Contents/MacOS/Adobe Photoshop CC 2017
       0x108fbf000 -        0x108ff6fef +libtbb.dylib (0) <3441EB5B-2632-3B4C-B76C-9AE5849E7353> /Applications/Adobe Photoshop CC 2017/Adobe Photoshop CC 2017.app/Contents/Frameworks/libtbb.dylib
       0x10903b000 -        0x10905efe7 +libtbbmalloc.dylib (0) <81117D6A-D8E4-37C2-9766-0DC0BF86C06C> /Applications/Adobe Photoshop CC 2017/Adobe Photoshop CC 2017.app/Contents/Frameworks/libtbbmalloc.dylib
       0x109097000 -        0x10913ffff +com.adobe.AdobeExtendScript (ExtendScript 4.5.6 - 4.5.6.5) <0AE6FE3B-AD77-3C9E-AD1B-CEE881FEF5C2> /Applications/Adobe Photoshop CC 2017/Adobe Photoshop CC 2017.app/Contents/Frameworks/AdobeExtendScript.framework/Versions/A/AdobeExtendScript
       0x1091a3000 -        0x109241fff +com.adobe.AdobeScCore (ScCore 4.5.6 - 4.5.6.5) <678BE576-32AB-3958-9C04-2504856330E5> /Applications/Adobe Photoshop CC 2017/Adobe Photoshop CC 2017.app/Contents/Frameworks/AdobeScCore.framework/Versions/A/AdobeScCore
       0x109291000 -        0x109414ff7 +com.adobe.aif (Adobe Image Foundation Library 6.0.00.1 - 6.0.00.1) <EB941620-7550-301A-98C4-69CDB0577834> /Applications/Adobe Photoshop CC 2017/Adobe Photoshop CC 2017.app/Contents/Frameworks/aif.framework/Versions/A/aif
       0x109574000 -        0x1095e3ff7 +com.adobe.manta (Adobe Manta Library 2.0.00.1 - 2.0.00.1) <48E3C4F3-461F-3F9F-B83A-11BC5D103508> /Applications/Adobe Photoshop CC 2017/Adobe Photoshop CC 2017.app/Contents/Frameworks/manta.framework/Versions/A/manta
       0x109676000 -        0x10968ffff +CITThreading (???) <F6746740-68D1-3F47-9714-94B42B132BD9> /Applications/Adobe Photoshop CC 2017/Adobe Photoshop CC 2017.app/Contents/Frameworks/CITThreading.framework/Versions/A/CITThreading
       0x1096ce000 -        0x1097ccff3 +ZXPSignLib-minimal-dylib.dylib (0) <B50C7884-6179-3925-AF15-0013257D0F6B> /Applications/Adobe Photoshop CC 2017/Adobe Photoshop CC 2017.app/Contents/Frameworks/ZXPSignLib-minimal-dylib.dylib
       0x1097fa000 -        0x109900fff +com.adobe.amtlib (10.0.0.119 - 10.0.0.119) <53139645-73AD-3787-AEE6-579FABE39250> /Applications/Adobe Photoshop CC 2017/Adobe Photoshop CC 2017.app/Contents/Frameworks/amtlib.framework/Versions/A/amtlib
       0x109916000 -        0x109b8cff3 +com.adobe.PlugPlugOwl (7.0.0.67 - 7.0.0.67) <255982DC-96E4-3C40-AF5A-B46F23B5D372> /Applications/Adobe Photoshop CC 2017/Adobe Photoshop CC 2017.app/Contents/Frameworks/PlugPlugOwl.framework/Versions/A/PlugPlugOwl
       0x109e62000 -        0x109ed8fff +com.adobe.AdobeSVGAGM (1.0.0 - 1.0.0.37848) <387CF9B9-B873-35B7-8D5E-7ACB4EA61AE7> /Applications/Adobe Photoshop CC 2017/Adobe Photoshop CC 2017.app/Contents/Frameworks/AdobeSVGAGM.framework/Versions/A/AdobeSVGAGM
       0x109fc1000 -        0x10a06aff7 +com.adobe.ICUConverter (4.0 - 3.61) <E20E390A-9BAF-3454-BA16-7B9CCD4CA8F0> /Applications/Adobe Photoshop CC 2017/Adobe Photoshop CC 2017.app/Contents/Frameworks/ICUConverter.framework/Versions/4.0/ICUConverter
       0x10a097000 -        0x10a09cffb  org.twain.dsm (1.9.5 - 1.9.5) <870046C5-F052-3F7C-BB2B-452392CAC599> /System/Library/Frameworks/TWAIN.framework/Versions/A/TWAIN
       0x10a0a6000 -        0x10a0c4fff +com.adobe.ahclientframework (2.2.0.1 - 2.2.0.1) <78C9396E-DBAE-3C68-9B67-95B28F2BEC76> /Applications/Adobe Photoshop CC 2017/Adobe Photoshop CC 2017.app/Contents/Frameworks/ahclient.framework/Versions/A/ahclient
       0x10a0d8000 -        0x10a26aff7 +com.adobe.owl (AdobeOwl version 5.2.11 - 5.2.11) <CDF9E325-6035-3EF9-8E03-980CD33D6582> /Applications/Adobe Photoshop CC 2017/Adobe Photoshop CC 2017.app/Contents/Frameworks/AdobeOwl.framework/Versions/A/AdobeOwl
       0x10a2b7000 -        0x10a61dff3 +com.adobe.MPS (AdobeMPS 5.8.1.37174 - 5.8.1.37174) <88508A43-6228-39B1-9377-B49EC9BBE1DE> /Applications/Adobe Photoshop CC 2017/Adobe Photoshop CC 2017.app/Contents/Frameworks/AdobeMPS.framework/Versions/A/AdobeMPS
       0x10a690000 -        0x10a691ffb  libCyrillicConverter.dylib (69) <D4DAFAFD-2465-3769-994B-B476E55CE85F> /System/Library/CoreServices/Encodings/libCyrillicConverter.dylib
       0x10a697000 -        0x10a6bbfff +VulcanControl.dylib (5.3.0.16 - 5.3.0.16 Copyright 2016, Adobe Systems Incorporated. All rights reserved.) <32AA6861-E0A7-37F8-8CE9-FCE97E3BFD07> /Applications/Adobe Photoshop CC 2017/Adobe Photoshop CC 2017.app/Contents/Frameworks/VulcanControl.dylib
       0x10a6e7000 -        0x10a9b0ffb +com.adobe.AGM (AdobeAGM 4.30.87.37848 - 4.30.87.37848) <7DAE22B9-2F91-385B-B4EA-9EC75CBEE0EF> /Applications/Adobe Photoshop CC 2017/Adobe Photoshop CC 2017.app/Contents/Frameworks/AdobeAGM.framework/Versions/A/AdobeAGM
       0x10aa25000 -        0x10ad22ffb +com.adobe.CoolType (AdobeCoolType 5.15.00.37848 - 5.15.00.37848) <46381E3C-77F9-3842-8A13-33BDEFA6E1D7> /Applications/Adobe Photoshop CC 2017/Adobe Photoshop CC 2017.app/Contents/Frameworks/AdobeCoolType.framework/Versions/A/AdobeCoolType
       0x10ad74000 -        0x10ad97ff3 +com.adobe.BIBUtils (AdobeBIBUtils 1.1.01 - 1.1.01) <B71D4C22-E568-3088-AED2-7D14B810D74A> /Applications/Adobe Photoshop CC 2017/Adobe Photoshop CC 2017.app/Contents/Frameworks/AdobeBIBUtils.framework/Versions/A/AdobeBIBUtils
       0x10ada6000 -        0x10adcaff7 +com.adobe.AXE8SharedExpat (AdobeAXE8SharedExpat 3.8.0.34320 - 3.8.0.34320) <674F1792-D790-3E12-8C0F-85CAF9D848B1> /Applications/Adobe Photoshop CC 2017/Adobe Photoshop CC 2017.app/Contents/Frameworks/AdobeAXE8SharedExpat.framework/Versions/A/AdobeAXE8SharedExpat
       0x10adf0000 -        0x10af1aff7 +com.winsoft.wrservices (WRServices 12.1.0 - 12.1.0) <75B95734-75E4-3E7E-B8E3-DB51C053E4DC> /Applications/Adobe Photoshop CC 2017/Adobe Photoshop CC 2017.app/Contents/Frameworks/WRServices.framework/Versions/A/WRServices
       0x10af73000 -        0x10b0bdff7 +com.adobe.ACE (AdobeACE 2.20.02.37848 - 2.20.02.37848) <3236E6F5-C286-3C46-AD03-9838AFE1D751> /Applications/Adobe Photoshop CC 2017/Adobe Photoshop CC 2017.app/Contents/Frameworks/AdobeACE.framework/Versions/A/AdobeACE
       0x10b0da000 -        0x10b0f6ffb +com.adobe.BIB (AdobeBIB 1.2.03.37848 - 1.2.03.37848) <28247879-8E7A-3B40-9012-FF1E849D7236> /Applications/Adobe Photoshop CC 2017/Adobe Photoshop CC 2017.app/Contents/Frameworks/AdobeBIB.framework/Versions/A/AdobeBIB
       0x10b0ff000 -        0x10b1bfff7 +com.adobe.JP2K (1.2.2 - 1.2.2.38234) <FA7EDCFB-62E7-33C2-89C9-8D745921518F> /Applications/Adobe Photoshop CC 2017/Adobe Photoshop CC 2017.app/Contents/Frameworks/AdobeJP2K.framework/Versions/A/AdobeJP2K
       0x10b207000 -        0x10b381fff +com.adobe.AdobeXMPCore (Adobe XMP Core 5.6 -c 138 - 79.159824) <A870682F-0A58-38CB-B15E-E983C131AC32> /Applications/Adobe Photoshop CC 2017/Adobe Photoshop CC 2017.app/Contents/Frameworks/AdobeXMP.framework/Versions/A/AdobeXMP
       0x10b4db000 -        0x10ba33fef +com.nvidia.cg (2.2.0006 - 0) /Applications/Adobe Photoshop CC 2017/Adobe Photoshop CC 2017.app/Contents/Frameworks/Cg.framework/Cg
       0x10c0a4000 -        0x10c23efff +com.adobe.headlights.LogSessionFramework (7.4.1.60.45263) <2116CCCF-BA38-366C-8BCE-91827BA52E6D> /Applications/Adobe Photoshop CC 2017/Adobe Photoshop CC 2017.app/Contents/Frameworks/LogSession.framework/Versions/A/LogSession
       0x10c319000 -        0x10d05efff +com.adobe.ICUData (4.0 - 3.61) <B9864D01-126E-3C56-B04C-993F9890F6AD> /Applications/Adobe Photoshop CC 2017/Adobe Photoshop CC 2017.app/Contents/Frameworks/ICUData.framework/Versions/4.0/ICUData
       0x10d077000 -        0x10d0a0ff7 +com.adobe.PDFSettings (AdobePDFSettings 1.04.0 - 1.4) <E07D101E-E47A-392A-8A44-005B49393DEC> /Applications/Adobe Photoshop CC 2017/Adobe Photoshop CC 2017.app/Contents/Frameworks/AdobePDFSettings.framework/Versions/A/AdobePDFSettings
       0x10d0b9000 -        0x10d0bcfff +com.adobe.AdobeCrashReporter (7.3 - 7.3.2) <F09CBDBF-D0F2-3E8B-A039-EC311CD1CCA1> /Applications/Adobe Photoshop CC 2017/Adobe Photoshop CC 2017.app/Contents/Frameworks/AdobeCrashReporter.framework/Versions/A/AdobeCrashReporter
       0x10d0ca000 -        0x10d105ff7 +VulcanMessage5.dylib (5.3.0.16 - 5.3.0.16 Copyright 2016, Adobe Systems Incorporated. All rights reserved.) <4B054DF8-614C-39A7-AC19-CBBA847B9014> /Applications/Adobe Photoshop CC 2017/Adobe Photoshop CC 2017.app/Contents/Frameworks/VulcanMessage5.dylib
       0x10d14f000 -        0x10d24bfff +com.adobe.AXEDOMCore (AdobeAXEDOMCore 3.8.0.34320 - 3.8.0.34320) <AFDCC2CF-EF73-323E-A2FA-3034F26F97B9> /Applications/Adobe Photoshop CC 2017/Adobe Photoshop CC 2017.app/Contents/Frameworks/AdobeAXEDOMCore.framework/Versions/A/AdobeAXEDOMCore
       0x10d2f5000 -        0x10d444ff3 +com.adobe.linguistic.LinguisticManager (10.1.0 - 22175) <CEC41C30-5517-3C8E-9998-A2F72308D548> /Applications/Adobe Photoshop CC 2017/Adobe Photoshop CC 2017.app/Contents/Frameworks/AdobeLinguistic.framework/Versions/3/AdobeLinguistic
       0x10d49a000 -        0x10d594ff7 +com.adobe.adobe_caps (adobe_caps 10.0.0.6 - 10.0.0.6) <F42B5047-A935-3B78-9F9A-F4841C6DEE88> /Applications/Adobe Photoshop CC 2017/Adobe Photoshop CC 2017.app/Contents/Frameworks/adobe_caps.framework/Versions/A/adobe_caps
       0x10d5ac000 -        0x10d6afff7 +com.adobe.ICUUnicode (4.0 - 3.61) <CE487901-E84A-3E54-95AB-91F2EAF57F6A> /Applications/Adobe Photoshop CC 2017/Adobe Photoshop CC 2017.app/Contents/Frameworks/ICUUnicode.framework/Versions/4.0/ICUUnicode
       0x10d6fb000 -        0x10d842fef +com.adobe.PM (AdbePM 2.5.00.377243 - 2.5.00.377243) <BA6D73F8-6235-30DA-81C9-A5CA7F54A963> /Applications/Adobe Photoshop CC 2017/Adobe Photoshop CC 2017.app/Contents/Frameworks/AdbePM.framework/Versions/A/AdbePM
       0x10d99c000 -        0x10dbbeff7 +libopencv_core.2.4.9.dylib (0) <305D6C41-9F88-3A40-97D4-DAF5BA2D46EF> /Applications/Adobe Photoshop CC 2017/Adobe Photoshop CC 2017.app/Contents/Frameworks/libopencv_core.2.4.9.dylib
       0x10dc16000 -        0x10ddf3ff7 +libopencv_imgproc.2.4.9.dylib (0) <E5EE040B-2890-35B2-89DB-AA4DADBFDC03> /Applications/Adobe Photoshop CC 2017/Adobe Photoshop CC 2017.app/Contents/Frameworks/libopencv_imgproc.2.4.9.dylib
       0x10dedc000 -        0x10e16effb +com.adobe.SVGRE (AdobeSVGRE 6.0 - 6.0) <6A2AF438-1448-33BB-81F2-7058E8E3E1F2> /Applications/Adobe Photoshop CC 2017/Adobe Photoshop CC 2017.app/Contents/Frameworks/AdobeSVGRE.framework/Versions/A/AdobeSVGRE
       0x10e1f0000 -        0x10e324fff +com.adobe.AIDE (1.5.0 - 1.5.0.36540) <0E2D02C2-0459-3C81-B9F4-AA5D9A2F9000> /Applications/Adobe Photoshop CC 2017/Adobe Photoshop CC 2017.app/Contents/Frameworks/AIDE.framework/Versions/A/AIDE
       0x10e612000 -        0x10e614ffb  com.apple.textencoding.unicode (3.0 - 3.0) <450E3370-B9E4-3179-89E5-98858FD25F23> /System/Library/TextEncodings/Unicode Encodings.bundle/Contents/MacOS/Unicode Encodings
       0x1105a6000 -        0x1105c2ffb  libJapaneseConverter.dylib (69) <57C00257-C544-3842-BD50-B79B239BCED5> /System/Library/CoreServices/Encodings/libJapaneseConverter.dylib
       0x1105c8000 -        0x1105eafff  libKoreanConverter.dylib (69) <4CDBC2E2-E8AC-33E5-A4BF-CD0B7C757B30> /System/Library/CoreServices/Encodings/libKoreanConverter.dylib
       0x1105f0000 -        0x1105ffffb  libSimplifiedChineseConverter.dylib (69) <0047A988-B6F7-38F5-936A-EAFDE8A47490> /System/Library/CoreServices/Encodings/libSimplifiedChineseConverter.dylib
       0x110604000 -        0x110616ff3  libTraditionalChineseConverter.dylib (69) <62B80E34-CB09-360D-9CD0-959C59756869> /System/Library/CoreServices/Encodings/libTraditionalChineseConverter.dylib
       0x110649000 -        0x110651fff +FastCore (18.1.1 - 18.1.1) <F20E2338-3B28-3C34-BB07-CE946978B58B> /Applications/Adobe Photoshop CC 2017/Adobe Photoshop CC 2017.app/Contents/Required/Plug-Ins/Extensions/FastCore.plugin/Contents/MacOS/FastCore
       0x111b60000 -        0x111bdcfef +MMXCore (18.1.1 - 18.1.1) <A6B54ABB-D74E-39C7-A606-35B8F3FCDAF4> /Applications/Adobe Photoshop CC 2017/Adobe Photoshop CC 2017.app/Contents/Required/Plug-Ins/Extensions/MMXCore.plugin/Contents/MacOS/MMXCore
       0x111c60000 -        0x111cd9ff7 +MultiProcessor Support (18.1.1 - 18.1.1) <A53DC4D5-BB48-3608-94A6-6C839B409A51> /Applications/Adobe Photoshop CC 2017/Adobe Photoshop CC 2017.app/Contents/Required/Plug-Ins/Extensions/MultiProcessor Support.plugin/Contents/MacOS/MultiProcessor Support
       0x11400f000 -        0x11415afff +IMSLib.dylib (10.0.0.11 - 10.0.0.11) <21D0C981-4447-364F-AAAA-F64A310F55B4> /Applications/Adobe Photoshop CC 2017/Adobe Photoshop CC 2017.app/Contents/Frameworks/IMSLib.dylib
       0x115409000 -        0x1154acff7  ColorSyncDeprecated.dylib (502.2) <FDB3BCCA-7C71-3DAA-9AB2-528E0CC60616> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ColorSync.framework/Versions/A/Resources/ColorSyncDeprecated.dylib
       0x11579d000 -        0x1157e0ff7 +com.adobe.AAM.AdobeUpdaterNotificationFramework (UpdaterNotifications 10.0.0.1 - 10.0.0.1) <624E6E8F-ACC9-3802-83A3-51970E64F769> /Applications/Adobe Photoshop CC 2017/Adobe Photoshop CC 2017.app/Contents/Frameworks/UpdaterNotifications.framework/Versions/A/UpdaterNotifications
       0x115a8e000 -        0x115a9fff7 +MeasurementCore (18.1.1 - 18.1.1) <E5DCB5F1-79E2-3B56-B4A9-6A650EE8B6B4> /Applications/Adobe Photoshop CC 2017/Adobe Photoshop CC 2017.app/Contents/Required/Plug-Ins/Measurements/MeasurementCore.plugin/Contents/MacOS/MeasurementCore
       0x115abb000 -        0x115abffff  libFontRegistryUI.dylib (196.4) <4EEE5715-A024-3A4B-BF0E-D55325B8E129> /System/Library/Frameworks/ApplicationServices.framework/Frameworks/ATS.framework/Resources/libFontRegistryUI.dylib
       0x115fce000 -        0x116403fff +com.adobe.PSAutomate (18.1.1 - 18.1.1) <54B32ED4-0367-3E12-837F-06413A5FF034> /Applications/Adobe Photoshop CC 2017/Adobe Photoshop CC 2017.app/Contents/Required/Plug-Ins/Extensions/ScriptingSupport.plugin/Contents/MacOS/ScriptingSupport
       0x1166f0000 -        0x1167d0ff7 +com.adobe.ps.spaces (18.1.1 - 18.1.1) <976B6154-C2DD-39C4-BF65-9A8AA2EAEB34> /Applications/Adobe Photoshop CC 2017/Adobe Photoshop CC 2017.app/Contents/Required/Plug-Ins/Spaces/Spaces.plugin/Contents/MacOS/Spaces
       0x1167f8000 -        0x116836ff7  com.apple.audio.midi.CoreMIDI (1.10 - 88) <5E2D1F53-B466-312E-AEA7-117B68C9A7F0> /System/Library/Frameworks/CoreMIDI.framework/Versions/A/CoreMIDI
       0x11685e000 -        0x116877ffb  libexpat.1.dylib (15) <F48F1B7B-BEB4-32EE-8C5D-0370096F3864> /usr/lib/libexpat.1.dylib
       0x117678000 -        0x117732ff3  com.apple.AMDRadeonX3000GLDriver (1.51.8 - 1.5.1) <A643313F-AD3F-31FD-B4A1-4F30DB3BFC71> /System/Library/Extensions/AMDRadeonX3000GLDriver.bundle/Contents/MacOS/AMDRadeonX3000GLDriver
       0x117759000 -        0x11795ffff  ATIRadeonX3000SCLib.dylib (1.51.8.1) <ADF9910B-EBC5-30A8-B2BA-CCA9AA740F2E> /System/Library/Extensions/AMDRadeonX3000GLDriver.bundle/Contents/MacOS/ATIRadeonX3000SCLib.dylib
       0x117c64000 -        0x117c96ff7 +com.adobe.pip (7.4.1.60.45263) <B0E15E67-5403-3159-8A4F-6D3BDB11D77C> /Applications/Adobe Photoshop CC 2017/Adobe Photoshop CC 2017.app/Contents/Frameworks/AdobePIP.framework/AdobePIP
       0x117ca6000 -        0x117ce3dc7  dyld (433.5) <322C06B7-8878-311D-888C-C8FD2CA96FF3> /usr/lib/dyld
       0x147d31000 -        0x14d7b3faf +org.chromium.ContentShell.framework (99.77.34.5 - 34.5) <42663479-0F87-37B7-8694-E2701B2A59B6> /Applications/Adobe Photoshop CC 2017/Adobe Photoshop CC 2017.app/Contents/Required/Plug-Ins/Spaces/Frameworks/Chromium Embedded Framework.framework/Chromium Embedded Framework
       0x14e4fb000 -        0x14e524fff +libSLCacheWrapper.dylib (1) <AB5FD9B1-D26B-3599-820A-6E1238597C86> /Applications/Adobe Photoshop CC 2017/Adobe Photoshop CC 2017.app/Contents/Frameworks/LogSession.framework/Libraries/libSLCacheWrapper.dylib
       0x14e536000 -        0x14e5affff  com.apple.xquery (1.3.1 - 30) <031D5366-8C48-3124-93EC-3AB4A5758460> /System/Library/PrivateFrameworks/XQuery.framework/XQuery
       0x15574c000 -        0x15576cfff  com.apple.CoreNLP (1.0 - 78.2) <B686BDA2-A162-3D70-9257-FEB0592DBD7E> /System/Library/PrivateFrameworks/CoreNLP.framework/Versions/A/CoreNLP
    0x7fffa5def000 -     0x7fffa6134ff7  com.apple.RawCamera.bundle (7.04 - 914) <86A67D11-9791-3CE6-9FF5-3387C0AB925B> /System/Library/CoreServices/RawCamera.bundle/Contents/MacOS/RawCamera
    0x7fffa7966000 -     0x7fffa796affb  com.apple.agl (3.3.1 - AGL-3.3.1) <752FDB92-EF67-3D04-BF40-A352BF1075CF> /System/Library/Frameworks/AGL.framework/Versions/A/AGL
    0x7fffa796b000 -     0x7fffa7b2cfff  com.apple.avfoundation (2.0 - 1187.36) <2F390EAD-07BB-3788-9E73-13104C2E04CD> /System/Library/Frameworks/AVFoundation.framework/Versions/A/AVFoundation
    0x7fffa7b2d000 -     0x7fffa7bcfff7  com.apple.audio.AVFAudio (1.0 - ???) <7997D588-B542-3EBB-B822-D719C1114BB4> /System/Library/Frameworks/AVFoundation.framework/Versions/A/Frameworks/AVFAudio.framework/Versions/A/AVFAudio
    0x7fffa7c9a000 -     0x7fffa7c9afff  com.apple.Accelerate (1.11 - Accelerate 1.11) <D6A08A72-7758-3CA8-813D-105F6E313E67> /System/Library/Frameworks/Accelerate.framework/Versions/A/Accelerate
    0x7fffa7c9b000 -     0x7fffa7cb2ff3  libCGInterfaces.dylib (331.5) <02E9DD16-C5CB-3482-84EF-AA6188A0D28C> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vImage.framework/Versions/A/Libraries/libCGInterfaces.dylib
    0x7fffa7cb3000 -     0x7fffa82f3fe3  com.apple.vImage (8.1 - ???) <4C535C25-EF87-35BE-9BE8-D080A5C24084> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vImage.framework/Versions/A/vImage
    0x7fffa82f4000 -     0x7fffa84bbfef  libBLAS.dylib (1185.50.4) <7AF8DB9A-E33B-30EB-8767-87AFB951E231> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libBLAS.dylib
    0x7fffa84bc000 -     0x7fffa84d3fff  libBNNS.dylib (15) <26F32264-148E-35E5-A280-CA035CB3D6F0> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libBNNS.dylib
    0x7fffa84d4000 -     0x7fffa88dffff  libLAPACK.dylib (1185.50.4) <51B2BABA-F736-3663-885A-65A8991D3560> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libLAPACK.dylib
    0x7fffa88e0000 -     0x7fffa88f6fff  libLinearAlgebra.dylib (1185.50.4) <0EC25E70-05DC-3615-85B6-81721566CF1D> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libLinearAlgebra.dylib
    0x7fffa88f7000 -     0x7fffa88fdfff  libQuadrature.dylib (3) <EF56C8E6-DE22-3C69-B543-A8648F335FDD> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libQuadrature.dylib
    0x7fffa88fe000 -     0x7fffa8911ff7  libSparseBLAS.dylib (1185.50.4) <0BDCF6A7-0228-3719-81C7-B6EBC7911320> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libSparseBLAS.dylib
    0x7fffa8912000 -     0x7fffa8a5fff7  libvDSP.dylib (600.60.1) <F46DF4CB-864D-3541-9913-60521FCBBF4A> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libvDSP.dylib
    0x7fffa8a60000 -     0x7fffa8b17fe3  libvMisc.dylib (600.60.1) <F8770D18-FD5D-31C3-9FBA-D9E39B14247A> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libvMisc.dylib
    0x7fffa8b18000 -     0x7fffa8b18fff  com.apple.Accelerate.vecLib (3.11 - vecLib 3.11) <A2FC8240-F62F-3A23-AB10-8CE6B56AF476> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/vecLib
    0x7fffa8b19000 -     0x7fffa8b56ffb  com.apple.Accounts (113 - 113) <8550BD08-7D05-3AC4-A0CC-B67ECB2DE950> /System/Library/Frameworks/Accounts.framework/Versions/A/Accounts
    0x7fffa8b57000 -     0x7fffa8dd6ff7  com.apple.AddressBook.framework (10.0 - 1756.20) <E512B69B-8DBE-3085-95BE-750B8EFC97FD> /System/Library/Frameworks/AddressBook.framework/Versions/A/AddressBook
    0x7fffa8dd7000 -     0x7fffa9bb0ff3  com.apple.AppKit (6.9 - 1504.83.101) <AE51ACB3-D501-3F91-B369-3D3711F24D0A> /System/Library/Frameworks/AppKit.framework/Versions/C/AppKit
    0x7fffa9bc2000 -     0x7fffa9bc2fff  com.apple.ApplicationServices (48 - 48) <DA687F9A-7B2D-342B-8796-16E45344F853> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/ApplicationServices
    0x7fffa9bc3000 -     0x7fffa9c31ff7  com.apple.ApplicationServices.ATS (377 - 422.2) <A31D17BE-F747-39FB-9A84-5F2F8891204C> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framework/Versions/A/ATS
    0x7fffa9ccb000 -     0x7fffa9dfaff7  libFontParser.dylib (194.12) <73C3946D-EF92-3AC1-89C3-0E75B2A85325> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framework/Versions/A/Resources/libFontParser.dylib
    0x7fffa9dfb000 -     0x7fffa9e45fff  libFontRegistry.dylib (196.4) <EA96AE47-3369-3DEA-BB82-98348ADBD85B> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framework/Versions/A/Resources/libFontRegistry.dylib
    0x7fffa9ea2000 -     0x7fffa9ed5fff  libTrueTypeScaler.dylib (194.12) <8944A23A-EE36-3657-9B4F-933231C8FDEC> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framework/Versions/A/Resources/libTrueTypeScaler.dylib
    0x7fffa9f42000 -     0x7fffa9fecff7  com.apple.ColorSync (4.12.0 - 502.2) <ACA4001E-A0E3-33F6-9CD6-EEC2AA15E322> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ColorSync.framework/Versions/A/ColorSync
    0x7fffa9fed000 -     0x7fffaa03efff  com.apple.HIServices (1.22 - 593) <045870A9-1D92-3FEF-8722-671E99A35E71> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/HIServices.framework/Versions/A/HIServices
    0x7fffaa03f000 -     0x7fffaa04eff3  com.apple.LangAnalysis (1.7.0 - 1.7.0) <2CBE7F61-2056-3F96-99A1-0D527796AFA6> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/LangAnalysis.framework/Versions/A/LangAnalysis
    0x7fffaa04f000 -     0x7fffaa09cfff  com.apple.print.framework.PrintCore (12 - 491) <5027FD58-F0EE-33E4-8577-934CA06CD2AF> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/PrintCore.framework/Versions/A/PrintCore
    0x7fffaa09d000 -     0x7fffaa0d8fff  com.apple.QD (3.12 - 313) <B339C41D-8CDF-3342-8414-F9717DCCADD4> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/QD.framework/Versions/A/QD
    0x7fffaa0d9000 -     0x7fffaa0e4fff  com.apple.speech.synthesis.framework (6.6.2 - 6.6.2) <7853EFF4-62B9-394E-B7B8-41A645656820> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/SpeechSynthesis.framework/Versions/A/SpeechSynthesis
    0x7fffaa0e5000 -     0x7fffaa2f1ff7  com.apple.audio.toolbox.AudioToolbox (1.14 - 1.14) <01518CAB-7DAD-3F09-83F8-B9FE0ABE998F> /System/Library/Frameworks/AudioToolbox.framework/Versions/A/AudioToolbox
    0x7fffaa2f2000 -     0x7fffaa2f2fff  com.apple.audio.units.AudioUnit (1.14 - 1.14) <B92868F8-2F15-32C0-A5BE-4ABA546B8BE1> /System/Library/Frameworks/AudioUnit.framework/Versions/A/AudioUnit
    0x7fffaa45b000 -     0x7fffaa835fff  com.apple.CFNetwork (811.5.4 - 811.5.4) <46B1227B-F38C-3F8E-B0B5-5D9861ABF36B> /System/Library/Frameworks/CFNetwork.framework/Versions/A/CFNetwork
    0x7fffaa84f000 -     0x7fffaa84ffff  com.apple.Carbon (154 - 157) <69F403C7-F0CB-34E6-89B0-235CF4978C17> /System/Library/Frameworks/Carbon.framework/Versions/A/Carbon
    0x7fffaa850000 -     0x7fffaa853fff  com.apple.CommonPanels (1.2.6 - 98) <BF04BB22-D54C-309E-9F5C-897D969CAF70> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/CommonPanels.framework/Versions/A/CommonPanels
    0x7fffaa854000 -     0x7fffaab5dfff  com.apple.HIToolbox (2.1.1 - 857.8) <5367366E-747E-32CF-8E76-93CD8E7424C7> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/HIToolbox.framework/Versions/A/HIToolbox
    0x7fffaab5e000 -     0x7fffaab61ff7  com.apple.help (1.3.5 - 49) <B1A930E3-5907-3677-BACD-858EF68B172D> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Help.framework/Versions/A/Help
    0x7fffaab62000 -     0x7fffaab67fff  com.apple.ImageCapture (9.0 - 9.0) <341252B4-E082-361A-B756-6A330259C741> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/ImageCapture.framework/Versions/A/ImageCapture
    0x7fffaab68000 -     0x7fffaabffff3  com.apple.ink.framework (10.9 - 219) <1BD40B45-FD33-3177-A935-565EE5FC79D7> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Ink.framework/Versions/A/Ink
    0x7fffaac00000 -     0x7fffaac1afff  com.apple.openscripting (1.7 - 172) <31CFBB35-24BD-3E12-9B6B-1FA842FB605B> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/OpenScripting.framework/Versions/A/OpenScripting
    0x7fffaac1b000 -     0x7fffaac1cff3  com.apple.print.framework.Print (12 - 267) <E2F82F1F-DC27-3EF0-9F75-B354F701450A> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Print.framework/Versions/A/Print
    0x7fffaac1d000 -     0x7fffaac1fff7  com.apple.securityhi (9.0 - 55006) <DBD65629-535D-3669-8218-7F074D61638C> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/SecurityHI.framework/Versions/A/SecurityHI
    0x7fffaac20000 -     0x7fffaac26ff7  com.apple.speech.recognition.framework (6.0.1 - 6.0.1) <082895DC-3AC7-3DEF-ADCA-5B018C19C9D3> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/SpeechRecognition.framework/Versions/A/SpeechRecognition
    0x7fffaac27000 -     0x7fffaad06ffb  com.apple.cloudkit.CloudKit (651.14 - 651.14) <9F901E45-23E3-3F45-B66F-1BAB3AFC4462> /System/Library/Frameworks/CloudKit.framework/Versions/A/CloudKit
    0x7fffaad07000 -     0x7fffaad07fff  com.apple.Cocoa (6.11 - 22) <85EDFBE1-75F0-369E-8CA8-C6A639B98FA6> /System/Library/Frameworks/Cocoa.framework/Versions/A/Cocoa
    0x7fffaae51000 -     0x7fffaaedefff  com.apple.audio.CoreAudio (4.3.0 - 4.3.0) <78767F88-91D4-31CE-AAC6-1F9407F479BB> /System/Library/Frameworks/CoreAudio.framework/Versions/A/CoreAudio
    0x7fffaaedf000 -     0x7fffaaef2fff  com.apple.CoreBluetooth (1.0 - 1) <BCB78777-76F0-3CC1-8443-9E61AEF7EF63> /System/Library/Frameworks/CoreBluetooth.framework/Versions/A/CoreBluetooth
    0x7fffaaef3000 -     0x7fffab1f2ff3  com.apple.CoreData (120 - 754.2) <0C9D9D78-758D-318F-9049-D42CC7944363> /System/Library/Frameworks/CoreData.framework/Versions/A/CoreData
    0x7fffab1f3000 -     0x7fffab2a0ff7  com.apple.CoreDisplay (1.0 - 1) <53D1EAFE-23A4-398D-BF52-E4299E670DB6> /System/Library/Frameworks/CoreDisplay.framework/Versions/A/CoreDisplay
    0x7fffab2a1000 -     0x7fffab734fff  com.apple.CoreFoundation (6.9 - 1349.8) <36385A3A-60D3-32DB-BF55-C6D8931A7AA6> /System/Library/Frameworks/CoreFoundation.framework/Versions/A/CoreFoundation
    0x7fffab735000 -     0x7fffabdd8ff7  com.apple.CoreGraphics (2.0 - 1070.22) <A680AD1F-F65A-3C0D-ACD5-4E5B5B8AD23A> /System/Library/Frameworks/CoreGraphics.framework/Versions/A/CoreGraphics
    0x7fffabdd9000 -     0x7fffac01cffb  com.apple.CoreImage (12.4.0 - 451.4.9) <BE4303C9-C9D9-361D-AC94-DBE40EB6700E> /System/Library/Frameworks/CoreImage.framework/Versions/A/CoreImage
    0x7fffac01d000 -     0x7fffac082ff7  com.apple.corelocation (2101.0.63) <C4C6BE27-85E2-34D5-AEDC-EBB5A7CB78D1> /System/Library/Frameworks/CoreLocation.framework/Versions/A/CoreLocation
    0x7fffac083000 -     0x7fffac134fff  com.apple.CoreMedia (1.0 - 1907.59.1.6) <570690D8-A956-3629-9E46-4F8BDDB8A82C> /System/Library/Frameworks/CoreMedia.framework/Versions/A/CoreMedia
    0x7fffac135000 -     0x7fffac180ff7  com.apple.CoreMediaIO (805.0 - 4932) <03F2B863-BF99-36DF-9A14-1DB534A289F3> /System/Library/Frameworks/CoreMediaIO.framework/Versions/A/CoreMediaIO
    0x7fffac181000 -     0x7fffac181fff  com.apple.CoreServices (775.19 - 775.19) <7255917D-EFBB-3BE2-A8FD-DAD631BC0949> /System/Library/Frameworks/CoreServices.framework/Versions/A/CoreServices
    0x7fffac182000 -     0x7fffac1d3fff  com.apple.AE (712.5 - 712.5) <61F2AE2C-E04E-3FDF-9E88-201325136C83> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/AE.framework/Versions/A/AE
    0x7fffac1d4000 -     0x7fffac4afff7  com.apple.CoreServices.CarbonCore (1159.6 - 1159.6) <08AC074C-965B-3EDF-8E45-0707C8DE9EAD> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/CarbonCore.framework/Versions/A/CarbonCore
    0x7fffac4b0000 -     0x7fffac4e3fff  com.apple.DictionaryServices (1.2 - 274) <D23866E2-F7C8-3984-A9D4-96552CCDE573> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/DictionaryServices.framework/Versions/A/DictionaryServices
    0x7fffac4e4000 -     0x7fffac4ecff3  com.apple.CoreServices.FSEvents (1230.50.1 - 1230.50.1) <2AD1B0E5-7214-37C4-8D11-A27C9CAC0F74> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/FSEvents.framework/Versions/A/FSEvents
    0x7fffac4ed000 -     0x7fffac659ff7  com.apple.LaunchServices (775.19 - 775.19) <B75A0C49-E376-358C-81EE-6EFB0F605801> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/LaunchServices.framework/Versions/A/LaunchServices
    0x7fffac65a000 -     0x7fffac70affb  com.apple.Metadata (10.7.0 - 1075.40) <B2FFCC10-5A9E-396B-B495-3D6C867669EE> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/Metadata.framework/Versions/A/Metadata
    0x7fffac70b000 -     0x7fffac76afff  com.apple.CoreServices.OSServices (775.19 - 775.19) <4140569A-1848-3765-A52B-BB61C35CF88F> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/OSServices.framework/Versions/A/OSServices
    0x7fffac76b000 -     0x7fffac7dbfff  com.apple.SearchKit (1.4.0 - 1.4.0) <7A6DDA2B-03F1-3137-BA9E-1CC211973E26> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/SearchKit.framework/Versions/A/SearchKit
    0x7fffac7dc000 -     0x7fffac821ff7  com.apple.coreservices.SharedFileList (38 - 38) <DA096678-93AB-3291-BDE2-482F1D544589> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/SharedFileList.framework/Versions/A/SharedFileList
    0x7fffac8aa000 -     0x7fffac9f7ffb  com.apple.CoreText (352.0 - 544.15) <BF0EE575-BB7E-3BF9-9029-232B4ADC24E4> /System/Library/Frameworks/CoreText.framework/Versions/A/CoreText
    0x7fffac9f8000 -     0x7fffaca2dff3  com.apple.CoreVideo (1.8 - 235.3) <AC11D5FB-C77B-34F5-B942-F698E84C229F> /System/Library/Frameworks/CoreVideo.framework/Versions/A/CoreVideo
    0x7fffaca2e000 -     0x7fffaca9fffb  com.apple.framework.CoreWLAN (11.0 - 1200.31) <E47C0568-E37B-3052-9E77-F0F371DCDE7F> /System/Library/Frameworks/CoreWLAN.framework/Versions/A/CoreWLAN
    0x7fffacad2000 -     0x7fffacaddff3  com.apple.DirectoryService.Framework (10.12 - 194) <45BEA292-4550-3082-8CE7-5D6CE7E0052A> /System/Library/Frameworks/DirectoryService.framework/Versions/A/DirectoryService
    0x7fffacb9d000 -     0x7fffacba2fff  com.apple.DiskArbitration (2.7 - 2.7) <70F56042-EF04-3BAF-9E04-90F423FB2BCC> /System/Library/Frameworks/DiskArbitration.framework/Versions/A/DiskArbitration
    0x7fffacd34000 -     0x7fffad0dafff  com.apple.Foundation (6.9 - 1349.91) <A37CB4EC-0730-3DD6-9358-60491BF40EF2> /System/Library/Frameworks/Foundation.framework/Versions/C/Foundation
    0x7fffad0db000 -     0x7fffad105ff7  com.apple.GLKit (1.0 - 87) <5131A2B1-86DD-319E-9D78-A3B3D7F6DE3F> /System/Library/Frameworks/GLKit.framework/Versions/A/GLKit
    0x7fffad106000 -     0x7fffad137ff7  com.apple.GSS (4.0 - 2.0) <6FADED0B-0425-3567-A75A-040C5A4638EB> /System/Library/Frameworks/GSS.framework/Versions/A/GSS
    0x7fffad138000 -     0x7fffad150ff7  com.apple.GameController (1.0 - 1) <DAC8C83B-7EC8-3A88-A725-E13DD905BF4F> /System/Library/Frameworks/GameController.framework/Versions/A/GameController
    0x7fffad1f7000 -     0x7fffad29afff  com.apple.Bluetooth (5.0.5 - 5.0.5f1) <913B97A6-9E18-3F15-992D-D522AA22EDE9> /System/Library/Frameworks/IOBluetooth.framework/Versions/A/IOBluetooth
    0x7fffad29b000 -     0x7fffad331ff7  com.apple.framework.IOKit (2.0.2 - 1324.60.3) <7CE4C98B-107C-3AAA-B49A-F2ACFCBBF526> /System/Library/Frameworks/IOKit.framework/Versions/A/IOKit
    0x7fffad332000 -     0x7fffad338ffb  com.apple.IOSurface (159.9 - 159.9) <08F1A246-1367-32EC-B3CE-724379409729> /System/Library/Frameworks/IOSurface.framework/Versions/A/IOSurface
    0x7fffad339000 -     0x7fffad38aff7  com.apple.ImageCaptureCore (7.0 - 7.0) <A640CA2F-8093-34AB-947C-26679ECB8A6D> /System/Library/Frameworks/ImageCaptureCore.framework/Versions/A/ImageCaptureCore
    0x7fffad38b000 -     0x7fffad4eeff7  com.apple.ImageIO.framework (3.3.0 - 1599.12) <7D624511-9E38-323E-86AA-A37BCECE61B0> /System/Library/Frameworks/ImageIO.framework/Versions/A/ImageIO
    0x7fffad4ef000 -     0x7fffad4f3fff  libGIF.dylib (1599.12) <7D9B14DA-F2A9-3803-A10D-AF7330D4CD53> /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libGIF.dylib
    0x7fffad4f4000 -     0x7fffad5e5ff7  libJP2.dylib (1599.12) <A02ACBD4-662D-382E-A969-C6FEF3963D54> /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libJP2.dylib
    0x7fffad5e6000 -     0x7fffad609fff  libJPEG.dylib (1599.12) <10AD5A15-5891-30CF-B003-671724C49070> /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libJPEG.dylib
    0x7fffad60a000 -     0x7fffad630fff  libPng.dylib (1599.12) <6782415F-2B06-34FD-ACC6-61D91FB23FCF> /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libPng.dylib
    0x7fffad631000 -     0x7fffad633ff3  libRadiance.dylib (1599.12) <2BE02AC8-2D9A-3554-82AE-D577E9540B1B> /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libRadiance.dylib
    0x7fffad634000 -     0x7fffad682ff7  libTIFF.dylib (1599.12) <845B70BE-6432-32D1-9655-6DAF0639BF9A> /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libTIFF.dylib
    0x7fffad7e0000 -     0x7fffae3eafff  com.apple.JavaScriptCore (12603 - 12603.3.8) <9557271A-1838-38DD-93E3-D8A9ECDE3B6B> /System/Library/Frameworks/JavaScriptCore.framework/Versions/A/JavaScriptCore
    0x7fffae3eb000 -     0x7fffae404ff7  com.apple.Kerberos (3.0 - 1) <B9D242EB-E325-3A21-9812-C77CBBFB0D51> /System/Library/Frameworks/Kerberos.framework/Versions/A/Kerberos
    0x7fffae405000 -     0x7fffae43bfff  com.apple.LDAPFramework (2.4.28 - 194.5) <492ACA22-373E-3DD9-BAEB-9EF6AA962FD5> /System/Library/Frameworks/LDAP.framework/Versions/A/LDAP
    0x7fffae68e000 -     0x7fffae694fff  com.apple.MediaAccessibility (1.0 - 97.1.1) <0BD82735-6644-37CE-B13D-8E7CC59A1752> /System/Library/Frameworks/MediaAccessibility.framework/Versions/A/MediaAccessibility
    0x7fffae6aa000 -     0x7fffaebe3ff7  com.apple.MediaToolbox (1.0 - 1907.59.1.6) <FA068C6F-0506-35C3-A637-C4AFF82411DB> /System/Library/Frameworks/MediaToolbox.framework/Versions/A/MediaToolbox
    0x7fffaebe4000 -     0x7fffaec3ffff  com.apple.Metal (87.18 - 87.18) <E3618B54-C728-34CA-9E8A-9BD33A295D31> /System/Library/Frameworks/Metal.framework/Versions/A/Metal
    0x7fffaec59000 -     0x7fffaf4d8fff  com.apple.ModelIO (1.0 - 1) <366820F9-6795-3D93-AAF2-630D94B395E6> /System/Library/Frameworks/ModelIO.framework/Versions/A/ModelIO
    0x7fffaf528000 -     0x7fffaf530fff  com.apple.NetFS (6.0 - 4.0) <14A24D00-5673-330A-959D-87F72040DEFF> /System/Library/Frameworks/NetFS.framework/Versions/A/NetFS
    0x7fffaf707000 -     0x7fffaf70fff7  libcldcpuengine.dylib (2.8.5) <81563526-886E-37E4-BF85-4A6D75F93C65> /System/Library/Frameworks/OpenCL.framework/Versions/A/Libraries/libcldcpuengine.dylib
    0x7fffaf8d8000 -     0x7fffaf926ff3  com.apple.opencl (2.8.6 - 2.8.6) <E78463D3-73B6-3002-BD71-9CC1D6722968> /System/Library/Frameworks/OpenCL.framework/Versions/A/OpenCL
    0x7fffaf927000 -     0x7fffaf940ffb  com.apple.CFOpenDirectory (10.12 - 194) <A64E9A01-3F6E-36EA-9C10-88C564A68C9D> /System/Library/Frameworks/OpenDirectory.framework/Versions/A/Frameworks/CFOpenDirectory.framework/Versions/A/CFOpenDirectory
    0x7fffaf941000 -     0x7fffaf94cff7  com.apple.OpenDirectory (10.12 - 194) <4298FFD0-B1A7-3064-AF5B-708B3FA38671> /System/Library/Frameworks/OpenDirectory.framework/Versions/A/OpenDirectory
    0x7fffaf94d000 -     0x7fffaf94ffff  libCVMSPluginSupport.dylib (14.0.16) <9E12EB67-6630-39A0-AB93-77405F5EC2A7> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libCVMSPluginSupport.dylib
    0x7fffaf950000 -     0x7fffaf953ff7  libCoreFSCache.dylib (156.3) <687C4CC3-6537-344B-8BE1-5234C8CB2864> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libCoreFSCache.dylib
    0x7fffaf954000 -     0x7fffaf958fff  libCoreVMClient.dylib (156.3) <E7AEFCBE-B6BF-3C7C-9A4E-E78CB04DB794> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libCoreVMClient.dylib
    0x7fffaf959000 -     0x7fffaf962ff7  libGFXShared.dylib (14.0.16) <D10C7A01-8A11-3A42-A9FA-C411AE453B27> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGFXShared.dylib
    0x7fffaf963000 -     0x7fffaf96efff  libGL.dylib (14.0.16) <0801F3B9-A525-32BB-9BC0-478947CE21D9> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGL.dylib
    0x7fffaf96f000 -     0x7fffaf9abff7  libGLImage.dylib (14.0.16) <FE39C57B-056C-3CBF-B653-A8F2005631C1> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGLImage.dylib
    0x7fffaf9ac000 -     0x7fffafb22ff3  libGLProgrammability.dylib (14.0.16) <A95F26AD-D496-3581-A310-5131F61CFB4A> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGLProgrammability.dylib
    0x7fffafb23000 -     0x7fffafb64ff7  libGLU.dylib (14.0.16) <B285EAD6-B3AA-3753-BB85-75864BD6E76C> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGLU.dylib
    0x7fffb04cc000 -     0x7fffb04dafff  com.apple.opengl (14.0.16 - 14.0.16) <167C9883-A79E-3B7F-AFED-8CD6683B291D> /System/Library/Frameworks/OpenGL.framework/Versions/A/OpenGL
    0x7fffb04db000 -     0x7fffb0681fff  GLEngine (14.0.16) <08F2E804-13D2-3E80-9322-1A23A84A55F3> /System/Library/Frameworks/OpenGL.framework/Versions/A/Resources/GLEngine.bundle/GLEngine
    0x7fffb0682000 -     0x7fffb06acfff  GLRendererFloat (14.0.16) <6B57F70A-EFAC-3DB2-B9BA-E55D05D44DB5> /System/Library/Frameworks/OpenGL.framework/Versions/A/Resources/GLRendererFloat.bundle/GLRendererFloat
    0x7fffb0749000 -     0x7fffb0890fff  com.apple.QTKit (7.7.3 - 2978.7) <49F88771-52FE-3989-AAB7-10A7494C4419> /System/Library/Frameworks/QTKit.framework/Versions/A/QTKit
    0x7fffb0891000 -     0x7fffb0afbff7  com.apple.imageKit (3.0 - 1023) <9C547565-CBAA-3ACB-A3F6-1366A0DCDCB4> /System/Library/Frameworks/Quartz.framework/Versions/A/Frameworks/ImageKit.framework/Versions/A/ImageKit
    0x7fffb0afc000 -     0x7fffb0bc3fff  com.apple.PDFKit (1.0 - 1) <BE82F14C-B20C-3771-B16C-F0723F6552AD> /System/Library/Frameworks/Quartz.framework/Versions/A/Frameworks/PDFKit.framework/Versions/A/PDFKit
    0x7fffb0bc4000 -     0x7fffb10eaff7  com.apple.QuartzComposer (5.1 - 356) <C66293F6-EF05-3B36-8524-081CEB9FADD7> /System/Library/Frameworks/Quartz.framework/Versions/A/Frameworks/QuartzComposer.framework/Versions/A/QuartzComposer
    0x7fffb10eb000 -     0x7fffb110effb  com.apple.quartzfilters (1.10.0 - 1.10.0) <365342ED-7A1A-3C75-AE60-90764E96034C> /System/Library/Frameworks/Quartz.framework/Versions/A/Frameworks/QuartzFilters.framework/Versions/A/QuartzFilters
    0x7fffb110f000 -     0x7fffb11fcfff  com.apple.QuickLookUIFramework (5.0 - 720.7) <3136C23E-399E-3296-928A-B18EC9FC423C> /System/Library/Frameworks/Quartz.framework/Versions/A/Frameworks/QuickLookUI.framework/Versions/A/QuickLookUI
    0x7fffb11fd000 -     0x7fffb11fdfff  com.apple.quartzframework (1.5 - 21) <09455972-8A33-3D61-B193-BA7E7CF984CA> /System/Library/Frameworks/Quartz.framework/Versions/A/Quartz
    0x7fffb11fe000 -     0x7fffb13fefff  com.apple.QuartzCore (1.11 - 453.39.4) <A45AFBC4-87D4-3533-A0AC-1D6629C77984> /System/Library/Frameworks/QuartzCore.framework/Versions/A/QuartzCore
    0x7fffb13ff000 -     0x7fffb1454fff  com.apple.QuickLookFramework (5.0 - 720.7) <3BD7BA2F-924C-3EFF-B26E-3F930E62E6B4> /System/Library/Frameworks/QuickLook.framework/Versions/A/QuickLook
    0x7fffb1455000 -     0x7fffb146bfff  com.apple.SafariServices.framework (12604 - 12604.1.38.1.7) <88D1F7A2-5FC3-3A97-9F7D-28D5D84394B6> /System/Library/Frameworks/SafariServices.framework/Versions/A/SafariServices
    0x7fffb1966000 -     0x7fffb1c68ff7  com.apple.security (7.0 - 57740.60.18) <005E8C96-40B6-35E3-B58B-888A5F5957C2> /System/Library/Frameworks/Security.framework/Versions/A/Security
    0x7fffb1c69000 -     0x7fffb1cdefff  com.apple.securityfoundation (6.0 - 55132.50.7) <15C53957-A9DE-31AE-A192-949244F47CD7> /System/Library/Frameworks/SecurityFoundation.framework/Versions/A/SecurityFoundation
    0x7fffb1cdf000 -     0x7fffb1d08fff  com.apple.securityinterface (10.0 - 55079.50.4) <C9B0E11A-362B-3C0D-8B2E-B06510BCE20A> /System/Library/Frameworks/SecurityInterface.framework/Versions/A/SecurityInterface
    0x7fffb1d09000 -     0x7fffb1d0cff3  com.apple.xpc.ServiceManagement (1.0 - 1) <BE0F9708-0B55-3E78-A15E-C287B8ED13BA> /System/Library/Frameworks/ServiceManagement.framework/Versions/A/ServiceManagement
    0x7fffb2093000 -     0x7fffb2102ff7  com.apple.SystemConfiguration (1.14 - 1.14) <3FFD3930-B307-3E31-9FA6-12221EB0F969> /System/Library/Frameworks/SystemConfiguration.framework/Versions/A/SystemConfiguration
    0x7fffb2103000 -     0x7fffb24b1fff  com.apple.VideoToolbox (1.0 - 1907.59.1.6) <EB2577A4-DCDF-3FD1-B5FA-42A55653A74D> /System/Library/Frameworks/VideoToolbox.framework/Versions/A/VideoToolbox
    0x7fffb4959000 -     0x7fffb4974ff3  com.apple.AppContainer (4.0 - 307.50.21) <C2E6BA3D-81FF-39C3-B4BF-DBB9A17DE078> /System/Library/PrivateFrameworks/AppContainer.framework/Versions/A/AppContainer
    0x7fffb4975000 -     0x7fffb4982ff3  com.apple.AppSandbox (4.0 - 307.50.21) <BF9FA426-8C11-358B-9E1F-A3901E3F2B14> /System/Library/PrivateFrameworks/AppSandbox.framework/Versions/A/AppSandbox
    0x7fffb4983000 -     0x7fffb49a5ffb  com.apple.framework.Apple80211 (12.0 - 1200.47) <C3033EEE-771A-3664-BBDD-BE1F6D075FC7> /System/Library/PrivateFrameworks/Apple80211.framework/Versions/A/Apple80211
    0x7fffb49a6000 -     0x7fffb49b5feb  com.apple.AppleFSCompression (88.50.3 - 1.0) <478E8BFF-8BA2-375E-BE02-BA27F115C15A> /System/Library/PrivateFrameworks/AppleFSCompression.framework/Versions/A/AppleFSCompression
    0x7fffb4aa7000 -     0x7fffb4b3297f  com.apple.AppleJPEG (1.0 - 1) <B9E9570D-04A4-34E4-B756-D200043B25B8> /System/Library/PrivateFrameworks/AppleJPEG.framework/Versions/A/AppleJPEG
    0x7fffb4b46000 -     0x7fffb4b61fff  com.apple.aps.framework (4.0 - 4.0) <6CA07CDF-1E35-34E9-95BF-BD565FF42BAD> /System/Library/PrivateFrameworks/ApplePushService.framework/Versions/A/ApplePushService
    0x7fffb4b62000 -     0x7fffb4b6affb  com.apple.AppleSRP (5.0 - 1) <6AAE93B6-9816-35B2-9C59-D5C3218065AF> /System/Library/PrivateFrameworks/AppleSRP.framework/Versions/A/AppleSRP
    0x7fffb4b6b000 -     0x7fffb4b6eff3  com.apple.AppleSystemInfo (3.1.5 - 3.1.5) <42A1731A-A576-307A-B07C-9F8F64696CB7> /System/Library/PrivateFrameworks/AppleSystemInfo.framework/Versions/A/AppleSystemInfo
    0x7fffb4b6f000 -     0x7fffb4bc1fff  com.apple.AppleVAFramework (5.0.36 - 5.0.36) <7352078D-C230-397C-81A5-57A48CF218C0> /System/Library/PrivateFrameworks/AppleVA.framework/Versions/A/AppleVA
    0x7fffb4bcb000 -     0x7fffb4bd2ff7  com.apple.AssetCacheServices (48.3 - 48.3) <C59F7295-36D8-3109-A910-C83D884CC92C> /System/Library/PrivateFrameworks/AssetCacheServices.framework/Versions/A/AssetCacheServices
    0x7fffb4f65000 -     0x7fffb4fe3ff7  com.apple.backup.framework (1.8.5 - 1.8.5) <CC679891-E8F5-3166-8EB6-AEA06954A52D> /System/Library/PrivateFrameworks/Backup.framework/Versions/A/Backup
    0x7fffb567f000 -     0x7fffb56a6fff  com.apple.CalendarAgentLink (8.0 - 250) <E50E29F6-2BAB-3B8B-BBEA-7DC0B8B077AD> /System/Library/PrivateFrameworks/CalendarAgentLink.framework/Versions/A/CalendarAgentLink
    0x7fffb5c6e000 -     0x7fffb5c95ff3  com.apple.ChunkingLibrary (173 - 173) <FC2165F9-FC93-39C0-8323-C2F43A5E00A3> /System/Library/PrivateFrameworks/ChunkingLibrary.framework/Versions/A/ChunkingLibrary
    0x7fffb5c96000 -     0x7fffb5d22ff7  com.apple.CloudDocs (1.0 - 486.29) <392B87EC-0317-313F-8FE2-F571831C7F35> /System/Library/PrivateFrameworks/CloudDocs.framework/Versions/A/CloudDocs
    0x7fffb65ba000 -     0x7fffb65c3ffb  com.apple.CommonAuth (4.0 - 2.0) <216950CB-269F-3476-BA17-D6363AC49FBC> /System/Library/PrivateFrameworks/CommonAuth.framework/Versions/A/CommonAuth
    0x7fffb668a000 -     0x7fffb66dbff7  com.apple.AddressBook.ContactsFoundation (8.0 - 2250.11) <1324A70E-A093-3DB9-A802-07B8F4A499B5> /System/Library/PrivateFrameworks/ContactsFoundation.framework/Versions/A/ContactsFoundation
    0x7fffb66dc000 -     0x7fffb66fefff  com.apple.contacts.ContactsPersistence (1.0 - 2250.11) <7CDEB852-B3B7-328F-9537-DFB3A58B882C> /System/Library/PrivateFrameworks/ContactsPersistence.framework/Versions/A/ContactsPersistence
    0x7fffb6748000 -     0x7fffb6b27ff7  com.apple.CoreAUC (226.0.0 - 226.0.0) <FBF6C5BC-5937-3957-B6BA-E101DF9B0DF6> /System/Library/PrivateFrameworks/CoreAUC.framework/Versions/A/CoreAUC
    0x7fffb6b28000 -     0x7fffb6b58fff  com.apple.CoreAVCHD (5.9.0 - 5900.4.1) <3F6857D1-AE7C-3593-B064-930F5BB7269E> /System/Library/PrivateFrameworks/CoreAVCHD.framework/Versions/A/CoreAVCHD
    0x7fffb6bf3000 -     0x7fffb6bfbffb  com.apple.frameworks.CoreDaemon (1.3 - 1.3) <2AB86FAF-37B3-3323-9EF0-CA591B6E357C> /System/Library/PrivateFrameworks/CoreDaemon.framework/Versions/B/CoreDaemon
    0x7fffb6d0c000 -     0x7fffb6d1cfff  com.apple.CoreEmoji (1.0 - 40.3.3) <E9A28301-2D79-3A97-A046-028258A6ABE5> /System/Library/PrivateFrameworks/CoreEmoji.framework/Versions/A/CoreEmoji
    0x7fffb6de1000 -     0x7fffb6df7ff3  com.apple.CoreMediaAuthoring (2.2 - 956) <AEBFF55F-BF1E-3CA5-AA9C-1CE22218A665> /System/Library/PrivateFrameworks/CoreMediaAuthoring.framework/Versions/A/CoreMediaAuthoring
    0x7fffb6dfe000 -     0x7fffb6e8effb  com.apple.CorePDF (4.0 - 4) <7F50E4A6-940C-33F5-BE4E-7E01AFE98A8F> /System/Library/PrivateFrameworks/CorePDF.framework/Versions/A/CorePDF
    0x7fffb7057000 -     0x7fffb7087ff3  com.apple.CoreServicesInternal (276.2 - 276.2) <05EB7D45-DD4C-3A0F-AC63-A0C2A68E6481> /System/Library/PrivateFrameworks/CoreServicesInternal.framework/Versions/A/CoreServicesInternal
    0x7fffb7318000 -     0x7fffb73a7ff7  com.apple.CoreSymbolication (62046) <7839CD8E-011D-3567-88DE-3D472C661136> /System/Library/PrivateFrameworks/CoreSymbolication.framework/Versions/A/CoreSymbolication
    0x7fffb73a8000 -     0x7fffb74e7fe7  com.apple.coreui (2.1 - 431.3) <2E8FEC10-FC5B-3782-92DA-A85C24B7BF7C> /System/Library/PrivateFrameworks/CoreUI.framework/Versions/A/CoreUI
    0x7fffb74e8000 -     0x7fffb75b8ff3  com.apple.CoreUtils (5.1 - 510.31) <E68BB8ED-8874-36EC-A7C5-1017C0E727CB> /System/Library/PrivateFrameworks/CoreUtils.framework/Versions/A/CoreUtils
    0x7fffb7608000 -     0x7fffb766dff3  com.apple.framework.CoreWiFi (12.0 - 1200.31) <DF0972EF-F817-3FD3-8C00-2D57B8738D8C> /System/Library/PrivateFrameworks/CoreWiFi.framework/Versions/A/CoreWiFi
    0x7fffb766e000 -     0x7fffb767cff7  com.apple.CrashReporterSupport (10.12 - 827) <802A9B81-E349-348B-90AB-10E40B654250> /System/Library/PrivateFrameworks/CrashReporterSupport.framework/Versions/A/CrashReporterSupport
    0x7fffb76ee000 -     0x7fffb76f8ffb  com.apple.framework.DFRFoundation (1.0 - 104.25) <7CFF896C-EF22-3941-BB3D-F3615CE4C908> /System/Library/PrivateFrameworks/DFRFoundation.framework/Versions/A/DFRFoundation
    0x7fffb76f9000 -     0x7fffb76fdff3  com.apple.DSExternalDisplay (3.1 - 380) <4B5E3FF0-E8C3-38CC-BF72-418C928956AB> /System/Library/PrivateFrameworks/DSExternalDisplay.framework/Versions/A/DSExternalDisplay
    0x7fffb7733000 -     0x7fffb77a8ffb  com.apple.datadetectorscore (7.0 - 539.1) <74595F6C-8283-3C73-9F56-C6FA957F8B94> /System/Library/PrivateFrameworks/DataDetectorsCore.framework/Versions/A/DataDetectorsCore
    0x7fffb77e4000 -     0x7fffb7823fff  com.apple.DebugSymbols (137 - 137) <58A70B66-2628-3CFE-B103-2200D95FC5F7> /System/Library/PrivateFrameworks/DebugSymbols.framework/Versions/A/DebugSymbols
    0x7fffb7824000 -     0x7fffb7935fff  com.apple.desktopservices (1.11.5 - 1.11.5) <46A9D4F3-1EF8-373C-98A4-AD48D285E484> /System/Library/PrivateFrameworks/DesktopServicesPriv.framework/Versions/A/DesktopServicesPriv
    0x7fffb7a78000 -     0x7fffb7a83fff  com.apple.DisplayServicesFW (3.1 - 380) <0BDF6C17-5E5F-33F8-8E99-C7350C6F9667> /System/Library/PrivateFrameworks/DisplayServices.framework/Versions/A/DisplayServices
    0x7fffb7c1d000 -     0x7fffb804eff7  com.apple.vision.FaceCore (3.3.2 - 3.3.2) <9391D5A3-738C-3136-9D07-518CB43DBADA> /System/Library/PrivateFrameworks/FaceCore.framework/Versions/A/FaceCore
    0x7fffb93a5000 -     0x7fffb93a5fff  libmetal_timestamp.dylib (600.0.49.9) <E5EED927-1671-3390-BCBB-D76201D63C73> /System/Library/PrivateFrameworks/GPUCompiler.framework/libmetal_timestamp.dylib
    0x7fffb93b2000 -     0x7fffb93bdff3  libGPUSupportMercury.dylib (14.0.16) <7EE3DA75-2F9D-3C6D-AECD-F73EA47BE81B> /System/Library/PrivateFrameworks/GPUSupport.framework/Versions/A/Libraries/libGPUSupportMercury.dylib
    0x7fffb9676000 -     0x7fffb9692fff  com.apple.GenerationalStorage (2.0 - 267.1) <3DE1C580-D089-362D-8582-8DE68A3C5F13> /System/Library/PrivateFrameworks/GenerationalStorage.framework/Versions/A/GenerationalStorage
    0x7fffb96ab000 -     0x7fffb9d5dfff  com.apple.GeoServices (1.0 - 1228.24.9.30.34) <96BF97F6-8FF2-3FC4-A8C1-498CB7B0D9A0> /System/Library/PrivateFrameworks/GeoServices.framework/Versions/A/GeoServices
    0x7fffb9da3000 -     0x7fffb9e19ff3  com.apple.Heimdal (4.0 - 2.0) <8F9C9041-66D5-36C9-8A4C-1658035C311D> /System/Library/PrivateFrameworks/Heimdal.framework/Versions/A/Heimdal
    0x7fffb9e1a000 -     0x7fffb9e2bfff  com.apple.HelpData (2.1.12 - 100.1) <EEB8CC44-9AFF-3005-A25D-18FE46574FD5> /System/Library/PrivateFrameworks/HelpData.framework/Versions/A/HelpData
    0x7fffba434000 -     0x7fffba43bffb  com.apple.IOAccelerator (311.14 - 311.14) <278124AF-02DC-3785-9FA9-14EDB8E5FD56> /System/Library/PrivateFrameworks/IOAccelerator.framework/Versions/A/IOAccelerator
    0x7fffba43d000 -     0x7fffba451ff7  com.apple.IOPresentment (1.0 - 29.10) <30DF04EE-10E2-353F-845F-A97B87DF3207> /System/Library/PrivateFrameworks/IOPresentment.framework/Versions/A/IOPresentment
    0x7fffba452000 -     0x7fffba474fff  com.apple.IconServices (74.4 - 74.4) <218DDD05-35F4-3833-B98D-471ED0EBC031> /System/Library/PrivateFrameworks/IconServices.framework/Versions/A/IconServices
    0x7fffba510000 -     0x7fffba520ff3  com.apple.IntlPreferences (2.0 - 216) <77C9C2E7-EF9F-34BB-A5E3-B8BEA4226B5F> /System/Library/PrivateFrameworks/IntlPreferences.framework/Versions/A/IntlPreferences
    0x7fffba55b000 -     0x7fffba712fff  com.apple.LanguageModeling (1.0 - 123.2.5) <A8CA965F-0399-310D-91C3-B93DDDE9A442> /System/Library/PrivateFrameworks/LanguageModeling.framework/Versions/A/LanguageModeling
    0x7fffba80e000 -     0x7fffba8d0ff3  com.apple.MMCS (1.3 - 385.4) <D3D76CE0-DE05-373E-B757-9E4B4920565D> /System/Library/PrivateFrameworks/MMCS.framework/Versions/A/MMCS
    0x7fffbad82000 -     0x7fffbad85fff  com.apple.Mangrove (1.0 - 1) <98814966-FD65-302B-B47E-00928DC34E5C> /System/Library/PrivateFrameworks/Mangrove.framework/Versions/A/Mangrove
    0x7fffbb033000 -     0x7fffbb0acff7  com.apple.MetalPerformanceShaders.MetalPerformanceShaders (1.0 - 1) <C323FC94-FFA5-3EE6-B2AC-7E61EA92F304> /System/Library/PrivateFrameworks/MetalPerformanceShaders.framework/Versions/A/MetalPerformanceShaders
    0x7fffbb210000 -     0x7fffbb21efff  com.apple.MobileKeyBag (2.0 - 1.0) <D0983DB7-EF9D-3E19-A084-21319ECE5846> /System/Library/PrivateFrameworks/MobileKeyBag.framework/Versions/A/MobileKeyBag
    0x7fffbb22f000 -     0x7fffbb257ff7  com.apple.MultitouchSupport.framework (368.16 - 368.16) <9E602B4A-22CD-3CF3-B284-78D5123C9AE8> /System/Library/PrivateFrameworks/MultitouchSupport.framework/Versions/A/MultitouchSupport
    0x7fffbb309000 -     0x7fffbb314fff  com.apple.NetAuth (6.2 - 6.2) <97F487D6-8089-31A8-B68C-6C1EAC6ED1B5> /System/Library/PrivateFrameworks/NetAuth.framework/Versions/A/NetAuth
    0x7fffbb761000 -     0x7fffbb763fff  com.apple.OAuth (25 - 25) <D6E5F36D-71B8-3E12-9601-CE2A1D6ED60B> /System/Library/PrivateFrameworks/OAuth.framework/Versions/A/OAuth
    0x7fffbbbec000 -     0x7fffbbc2dff3  com.apple.PerformanceAnalysis (1.148.3 - 148.3) <4E468BC7-F863-3674-909D-417231EB8C28> /System/Library/PrivateFrameworks/PerformanceAnalysis.framework/Versions/A/PerformanceAnalysis
    0x7fffbbc70000 -     0x7fffbbc77ff3  com.apple.phonenumbers (1.1.1 - 105) <B8EFDDD3-BA26-39B8-9EA0-3649184BF527> /System/Library/PrivateFrameworks/PhoneNumbers.framework/Versions/A/PhoneNumbers
    0x7fffbc2da000 -     0x7fffbc314ffb  com.apple.ProtectedCloudStorage (1.0 - 1) <8B32A7EC-D371-38E3-A286-F1BE1307F1E1> /System/Library/PrivateFrameworks/ProtectedCloudStorage.framework/Versions/A/ProtectedCloudStorage
    0x7fffbc315000 -     0x7fffbc32ffff  com.apple.ProtocolBuffer (1 - 249.1) <A1F1B0F3-078F-378F-A9A9-0DEEA70E816A> /System/Library/PrivateFrameworks/ProtocolBuffer.framework/Versions/A/ProtocolBuffer
    0x7fffbc330000 -     0x7fffbc33fff7  com.apple.QuickLookThumbnailing (1.0 - 1) <173EE873-1700-3FCA-9782-C060FBB5BCAD> /System/Library/PrivateFrameworks/QuickLookThumbnailing.framework/Versions/A/QuickLookThumbnailing
    0x7fffbc348000 -     0x7fffbc36bff3  com.apple.RemoteViewServices (2.0 - 124) <6B967FDA-6591-302C-BA0A-76C4856E584E> /System/Library/PrivateFrameworks/RemoteViewServices.framework/Versions/A/RemoteViewServices
    0x7fffbd035000 -     0x7fffbd038fff  com.apple.SecCodeWrapper (4.0 - 307.50.21) <F8E957B2-D3F0-3B73-B38C-AE8868F00939> /System/Library/PrivateFrameworks/SecCodeWrapper.framework/Versions/A/SecCodeWrapper
    0x7fffbd0c7000 -     0x7fffbd154fff  com.apple.Sharing (696.2.67 - 696.2.67) <F681EE28-153F-3216-97A6-6F5E4148AB2E> /System/Library/PrivateFrameworks/Sharing.framework/Versions/A/Sharing
    0x7fffbd155000 -     0x7fffbd174ff7  com.apple.shortcut (2.16 - 98) <6C0435B1-83DD-3254-B0D3-3B86C6CE606A> /System/Library/PrivateFrameworks/Shortcut.framework/Versions/A/Shortcut
    0x7fffbd175000 -     0x7fffbd3eaffb  com.apple.SkyLight (1.600.0 - 170.3) <02648329-DEBD-387D-A065-D62A8C0294F5> /System/Library/PrivateFrameworks/SkyLight.framework/Versions/A/SkyLight
    0x7fffbd5c9000 -     0x7fffbd5d5ff7  com.apple.SpeechRecognitionCore (3.3.2 - 3.3.2) <684BD1EA-8268-331C-A5A9-080EB375C658> /System/Library/PrivateFrameworks/SpeechRecognitionCore.framework/Versions/A/SpeechRecognitionCore
    0x7fffbdcc1000 -     0x7fffbdd35fdf  com.apple.Symbolication (62048.1) <1A30ED19-7532-3F46-9DD3-9879A973D0CF> /System/Library/PrivateFrameworks/Symbolication.framework/Versions/A/Symbolication
    0x7fffbe174000 -     0x7fffbe17aff7  com.apple.TCC (1.0 - 1) <911B534B-4AC7-34E4-935E-E42ECD008CBC> /System/Library/PrivateFrameworks/TCC.framework/Versions/A/TCC
    0x7fffbe206000 -     0x7fffbe2ccff7  com.apple.TextureIO (2.8 - 2.8) <3D61E533-4156-3B21-B7ED-CB823E680DFC> /System/Library/PrivateFrameworks/TextureIO.framework/Versions/A/TextureIO
    0x7fffbe315000 -     0x7fffbe32aff3  com.apple.ToneKit (1.0 - 1) <B709293D-0A79-398A-8AA9-50F6340C227C> /System/Library/PrivateFrameworks/ToneKit.framework/Versions/A/ToneKit
    0x7fffbe32b000 -     0x7fffbe339ffb  com.apple.ToneLibrary (1.0 - 1) <F2ED5DFC-5F11-3012-BCD7-17753413141F> /System/Library/PrivateFrameworks/ToneLibrary.framework/Versions/A/ToneLibrary
    0x7fffbe340000 -     0x7fffbe341fff  com.apple.TrustEvaluationAgent (2.0 - 28.50.1) <EBE65DD5-1732-3747-8C6C-7BECEBF089A4> /System/Library/PrivateFrameworks/TrustEvaluationAgent.framework/Versions/A/TrustEvaluationAgent
    0x7fffbe342000 -     0x7fffbe4d2ff3  com.apple.UIFoundation (1.0 - 490.7) <2A3063FE-1790-3510-8A0E-AEC581D42B7E> /System/Library/PrivateFrameworks/UIFoundation.framework/Versions/A/UIFoundation
    0x7fffbefa1000 -     0x7fffbf061fff  com.apple.ViewBridge (283 - 283) <25A635B3-C87C-3D3A-ADF3-539713FA1048> /System/Library/PrivateFrameworks/ViewBridge.framework/Versions/A/ViewBridge
    0x7fffbf4ac000 -     0x7fffbf4b2fff  com.apple.XPCService (2.0 - 1) <4B28B225-2105-33F4-9ED0-F04288FF4FB1> /System/Library/PrivateFrameworks/XPCService.framework/Versions/A/XPCService
    0x7fffbf583000 -     0x7fffbf585ffb  com.apple.loginsupport (1.0 - 1) <F3140B97-12C3-35A7-9D3D-43DA2D13C113> /System/Library/PrivateFrameworks/login.framework/Versions/A/Frameworks/loginsupport.framework/Versions/A/loginsupport
    0x7fffbf5b1000 -     0x7fffbf5d8ff7  com.apple.contacts.vCard (1.0 - 2250.11) <DD615DAF-AF34-3AB4-9CB4-DA0A882D59A5> /System/Library/PrivateFrameworks/vCard.framework/Versions/A/vCard
    0x7fffbf5da000 -     0x7fffbf5f5ff7  libCRFSuite.dylib (34) <F78B7F5F-0B4F-35C6-AA2F-84EE9CB22137> /usr/lib/libCRFSuite.dylib
    0x7fffbf5f6000 -     0x7fffbf601fff  libChineseTokenizer.dylib (21) <0886E908-A825-36AF-B94B-2361FD8BC2A1> /usr/lib/libChineseTokenizer.dylib
    0x7fffbf693000 -     0x7fffbf694ff3  libDiagnosticMessagesClient.dylib (102) <84A04D24-0E60-3810-A8C0-90A65E2DF61A> /usr/lib/libDiagnosticMessagesClient.dylib
    0x7fffbf695000 -     0x7fffbf8a8fff  libFosl_dynamic.dylib (16.39) <E22A4243-D148-3C74-BA15-2D906A3D1F9E> /usr/lib/libFosl_dynamic.dylib
    0x7fffbf8c4000 -     0x7fffbf8cbfff  libMatch.1.dylib (27) <70D4BD2A-9383-37F2-B0D6-9B592D236601> /usr/lib/libMatch.1.dylib
    0x7fffbf8cc000 -     0x7fffbf8ccfff  libOpenScriptingUtil.dylib (172) <90743888-C1E8-34E3-924E-1A754B2B63B9> /usr/lib/libOpenScriptingUtil.dylib
    0x7fffbf8cd000 -     0x7fffbf8d1ffb  libScreenReader.dylib (477.40.6) <CBE6420C-EF60-3ACD-A0B6-7CBE936BA3B8> /usr/lib/libScreenReader.dylib
    0x7fffbf8d2000 -     0x7fffbf8d3ffb  libSystem.B.dylib (1238.60.2) <F18AC1E7-C6F1-34B1-8069-BE571B3231D4> /usr/lib/libSystem.B.dylib
    0x7fffbf93f000 -     0x7fffbf96aff3  libarchive.2.dylib (41.70.1) <A3FA7D6E-3D68-3524-8B48-EB2ECA44B13B> /usr/lib/libarchive.2.dylib
    0x7fffbf96b000 -     0x7fffbfa60fef  libate.dylib (1.12.13) <DB9881C3-E24A-3984-91E0-77F6F13F795C> /usr/lib/libate.dylib
    0x7fffbfa64000 -     0x7fffbfa64ff3  libauto.dylib (187) <34388D0B-C539-3C1B-9408-2BC152162E43> /usr/lib/libauto.dylib
    0x7fffbfa65000 -     0x7fffbfa75ff3  libbsm.0.dylib (34) <20084796-B04D-3B35-A003-EA11459557A9> /usr/lib/libbsm.0.dylib
    0x7fffbfa76000 -     0x7fffbfa84ff7  libbz2.1.0.dylib (38) <ADFA329A-DCE7-356D-8F09-A3168DFC6610> /usr/lib/libbz2.1.0.dylib
    0x7fffbfa85000 -     0x7fffbfadbff7  libc++.1.dylib (307.5) <0B43BB5D-E6EB-3464-8DE9-B41AC8ED9D1C> /usr/lib/libc++.1.dylib
    0x7fffbfadc000 -     0x7fffbfb05ff7  libc++abi.dylib (307.4) <BC271AD3-831B-362A-9DA7-E8C51F285FE4> /usr/lib/libc++abi.dylib
    0x7fffbfb06000 -     0x7fffbfb16ffb  libcmph.dylib (6) <2B5D405E-2D0B-3320-ABD6-622934C86ABE> /usr/lib/libcmph.dylib
    0x7fffbfb17000 -     0x7fffbfb2dff7  libcompression.dylib (39) <BDAA8CC7-0BFC-36EC-9E75-58BDC15AC3B6> /usr/lib/libcompression.dylib
    0x7fffbfb2e000 -     0x7fffbfb2eff7  libcoretls.dylib (121.50.4) <64B1001E-10F6-3542-A3B2-C4B49F51817F> /usr/lib/libcoretls.dylib
    0x7fffbfb2f000 -     0x7fffbfb30ff3  libcoretls_cfhelpers.dylib (121.50.4) <1A10303E-5EB0-3C7C-9165-021FCDFD934D> /usr/lib/libcoretls_cfhelpers.dylib
    0x7fffbfbea000 -     0x7fffbfccfff7  libcrypto.0.9.8.dylib (64.50.6) <D34E16A7-990A-37A9-933A-DFAA46554EAA> /usr/lib/libcrypto.0.9.8.dylib
    0x7fffbfe6d000 -     0x7fffbfec0ff7  libcups.2.dylib (450) <9950BFCB-7882-33C9-9ECF-CE66773C5657> /usr/lib/libcups.2.dylib
    0x7fffbff14000 -     0x7fffbff1bff3  libdscsym.dylib (148.3) <EF99B991-18D9-3A73-BE88-4DC55F036DEF> /usr/lib/libdscsym.dylib
    0x7fffbff3d000 -     0x7fffbff3dfff  libenergytrace.dylib (15) <A1B040A2-7977-3097-9ADF-34FF181EB970> /usr/lib/libenergytrace.dylib
    0x7fffbff4d000 -     0x7fffbff52ff7  libheimdal-asn1.dylib (498.50.8) <A40E3196-235E-34CE-AD9A-8D1AFC5DE004> /usr/lib/libheimdal-asn1.dylib
    0x7fffbff53000 -     0x7fffc0045ff7  libiconv.2.dylib (50) <42125B35-81D7-3FC4-9475-A26DBE10884D> /usr/lib/libiconv.2.dylib
    0x7fffc0046000 -     0x7fffc026bffb  libicucore.A.dylib (57166.0.1) <CCD2ED24-3071-383B-925D-8D763BB12A6F> /usr/lib/libicucore.A.dylib
    0x7fffc0271000 -     0x7fffc0272fff  liblangid.dylib (126) <2085E7A7-9A34-3735-87F4-F174EF8EABF0> /usr/lib/liblangid.dylib
    0x7fffc0273000 -     0x7fffc028cffb  liblzma.5.dylib (10) <44BD0279-99DD-36B5-8A6E-C11432E2098D> /usr/lib/liblzma.5.dylib
    0x7fffc028d000 -     0x7fffc02a3ff7  libmarisa.dylib (5) <9030D214-5D0F-30CB-AC03-902C63909362> /usr/lib/libmarisa.dylib
    0x7fffc02a4000 -     0x7fffc054cff7  libmecabra.dylib (744.8) <D429FCC9-42A4-38B3-8784-44024BC859EF> /usr/lib/libmecabra.dylib
    0x7fffc057f000 -     0x7fffc05f9ff3  libnetwork.dylib (856.60.1) <191E99F5-4723-3180-8013-02AF2F9AE4B8> /usr/lib/libnetwork.dylib
    0x7fffc05fa000 -     0x7fffc09cfbc7  libobjc.A.dylib (709.1) <4DF3C25C-52C2-3F01-A3EF-0D9D53A73C1C> /usr/lib/libobjc.A.dylib
    0x7fffc09d2000 -     0x7fffc09d6fff  libpam.2.dylib (21.30.1) <71EB0D88-DE84-3C8D-A2C5-58AA282BC5BC> /usr/lib/libpam.2.dylib
    0x7fffc09d7000 -     0x7fffc0a08fff  libpcap.A.dylib (67.60.1) <F6BC6ED6-AEE4-3520-B248-0C342636E2B0> /usr/lib/libpcap.A.dylib
    0x7fffc0a25000 -     0x7fffc0a41ffb  libresolv.9.dylib (64) <A244AE4C-00B0-396C-98FF-97FE4DB3DA30> /usr/lib/libresolv.9.dylib
    0x7fffc0a42000 -     0x7fffc0a7bfff  libsandbox.1.dylib (592.70.1) <9C428C49-9D9A-3F9F-9573-BF5202D1F933> /usr/lib/libsandbox.1.dylib
    0x7fffc0a7c000 -     0x7fffc0a8effb  libsasl2.2.dylib (209) <32107C59-22C6-3049-B86E-9C2F85FF549B> /usr/lib/libsasl2.2.dylib
    0x7fffc0a8f000 -     0x7fffc0a90ff3  libspindump.dylib (231.3) <C7CEEB64-06F4-3ACA-AAC1-30ECA909501A> /usr/lib/libspindump.dylib
    0x7fffc0a91000 -     0x7fffc0bd7fff  libsqlite3.dylib (254.8) <058036FD-6EF3-3F9C-BF9B-2CB7A57205D7> /usr/lib/libsqlite3.dylib
    0x7fffc0c33000 -     0x7fffc0c83fff  libstdc++.6.dylib (104.1) <A980E08C-A511-3D19-9881-1D79B7CFF2BA> /usr/lib/libstdc++.6.dylib
    0x7fffc0ccc000 -     0x7fffc0cd9fff  libxar.1.dylib (357) <69547C64-E811-326F-BBED-490C6361BDCB> /usr/lib/libxar.1.dylib
    0x7fffc0cda000 -     0x7fffc0dc9fff  libxml2.2.dylib (30.17) <D4C3E467-37C6-34DE-8A1B-E7BFC29985E9> /usr/lib/libxml2.2.dylib
    0x7fffc0dca000 -     0x7fffc0df3fff  libxslt.1.dylib (15.9) <00735AD5-B62D-3E83-86AC-5533E4E2B102> /usr/lib/libxslt.1.dylib
    0x7fffc0df4000 -     0x7fffc0e05ff3  libz.1.dylib (67) <46E3FFA2-4328-327A-8D34-A03E20BFFB8E> /usr/lib/libz.1.dylib
    0x7fffc0e14000 -     0x7fffc0e18ff7  libcache.dylib (79) <093A4DAB-8385-3D47-A350-E20CB7CCF7BF> /usr/lib/system/libcache.dylib
    0x7fffc0e19000 -     0x7fffc0e23fff  libcommonCrypto.dylib (60092.50.5) <8A64D1B0-C70E-385C-92F0-E669079FDA90> /usr/lib/system/libcommonCrypto.dylib
    0x7fffc0e24000 -     0x7fffc0e2bfff  libcompiler_rt.dylib (62) <55D47421-772A-32AB-B529-1A46C2F43B4D> /usr/lib/system/libcompiler_rt.dylib
    0x7fffc0e2c000 -     0x7fffc0e34fff  libcopyfile.dylib (138) <819BEA3C-DF11-3E3D-A1A1-5A51C5BF1961> /usr/lib/system/libcopyfile.dylib
    0x7fffc0e35000 -     0x7fffc0eb8fdf  libcorecrypto.dylib (442.50.19) <65D7165E-2E71-335D-A2D6-33F78E2DF0C1> /usr/lib/system/libcorecrypto.dylib
    0x7fffc0eb9000 -     0x7fffc0eeafff  libdispatch.dylib (703.50.37) <6582BAD6-ED27-3B30-B620-90B1C5A4AE3C> /usr/lib/system/libdispatch.dylib
    0x7fffc0eeb000 -     0x7fffc0ef0ffb  libdyld.dylib (433.5) <9B2AC56D-107C-3541-A127-9094A751F2C9> /usr/lib/system/libdyld.dylib
    0x7fffc0ef1000 -     0x7fffc0ef1ffb  libkeymgr.dylib (28) <7AA011A9-DC21-3488-BF73-3B5B14D1FDD6> /usr/lib/system/libkeymgr.dylib
    0x7fffc0ef2000 -     0x7fffc0efefff  libkxld.dylib (3789.70.16) <BD02EF3F-6E09-3A64-AB21-553D5B1D2859> /usr/lib/system/libkxld.dylib
    0x7fffc0eff000 -     0x7fffc0efffff  liblaunch.dylib (972.70.1) <B856ABD2-896E-3DE0-B2C8-146A6AF8E2A7> /usr/lib/system/liblaunch.dylib
    0x7fffc0f00000 -     0x7fffc0f05ff3  libmacho.dylib (898) <17D5D855-F6C3-3B04-B680-E9BF02EF8AED> /usr/lib/system/libmacho.dylib
    0x7fffc0f06000 -     0x7fffc0f08ff3  libquarantine.dylib (85.50.1) <12448CC2-378E-35F3-BE33-9DC395A5B970> /usr/lib/system/libquarantine.dylib
    0x7fffc0f09000 -     0x7fffc0f0affb  libremovefile.dylib (45) <38D4CB9C-10CD-30D3-8B7B-A515EC75FE85> /usr/lib/system/libremovefile.dylib
    0x7fffc0f0b000 -     0x7fffc0f23ff7  libsystem_asl.dylib (349.50.5) <096E4228-3B7C-30A6-8B13-EC909A64499A> /usr/lib/system/libsystem_asl.dylib
    0x7fffc0f24000 -     0x7fffc0f24ff7  libsystem_blocks.dylib (67) <10DC5404-73AB-35B3-A277-A8AFECB476EB> /usr/lib/system/libsystem_blocks.dylib
    0x7fffc0f25000 -     0x7fffc0fb2fef  libsystem_c.dylib (1158.50.2) <E5AE5244-7D0C-36AC-8BB6-C7AE7EA52A4B> /usr/lib/system/libsystem_c.dylib
    0x7fffc0fb3000 -     0x7fffc0fb6ffb  libsystem_configuration.dylib (888.60.2) <BECC01A2-CA8D-31E6-BCDF-D452965FA976> /usr/lib/system/libsystem_configuration.dylib
    0x7fffc0fb7000 -     0x7fffc0fbafff  libsystem_coreservices.dylib (41.4) <7D26DE79-B424-3450-85E1-F7FAB32714AB> /usr/lib/system/libsystem_coreservices.dylib
    0x7fffc0fbb000 -     0x7fffc0fd3fff  libsystem_coretls.dylib (121.50.4) <EC6FCF07-DCFB-3A03-9CC9-6DD3709974C6> /usr/lib/system/libsystem_coretls.dylib
    0x7fffc0fd4000 -     0x7fffc0fdafff  libsystem_dnssd.dylib (765.50.9) <CC960215-0B1B-3822-A13A-3DDE96FA796F> /usr/lib/system/libsystem_dnssd.dylib
    0x7fffc0fdb000 -     0x7fffc1004ff7  libsystem_info.dylib (503.50.4) <611DB84C-BF70-3F92-8702-B9F28A900920> /usr/lib/system/libsystem_info.dylib
    0x7fffc1005000 -     0x7fffc1027ff7  libsystem_kernel.dylib (3789.70.16) <34B1F16C-BC9C-3C5F-9045-0CAE91CB5914> /usr/lib/system/libsystem_kernel.dylib
    0x7fffc1028000 -     0x7fffc106ffe7  libsystem_m.dylib (3121.6) <86D499B5-BBDC-3D3B-8A4E-97AE8E6672A4> /usr/lib/system/libsystem_m.dylib
    0x7fffc1070000 -     0x7fffc108eff7  libsystem_malloc.dylib (116.50.8) <A3D15F17-99A6-3367-8C7E-4280E8619C95> /usr/lib/system/libsystem_malloc.dylib
    0x7fffc108f000 -     0x7fffc10e8ffb  libsystem_network.dylib (856.60.1) <369D0221-56CA-3C3E-9EDE-94B41CAE77B7> /usr/lib/system/libsystem_network.dylib
    0x7fffc10e9000 -     0x7fffc10f2ff3  libsystem_networkextension.dylib (563.60.2) <B021F2B3-8A75-3633-ABB0-FC012B8E9B0C> /usr/lib/system/libsystem_networkextension.dylib
    0x7fffc10f3000 -     0x7fffc10fcff3  libsystem_notify.dylib (165.20.1) <B8160190-A069-3B3A-BDF6-2AA408221FAE> /usr/lib/system/libsystem_notify.dylib
    0x7fffc10fd000 -     0x7fffc1105fe7  libsystem_platform.dylib (126.50.8) <897462FD-B318-321B-A554-E61982630F7E> /usr/lib/system/libsystem_platform.dylib
    0x7fffc1106000 -     0x7fffc1110ff7  libsystem_pthread.dylib (218.60.3) <B8FB5E20-3295-39E2-B5EB-B464D1D4B104> /usr/lib/system/libsystem_pthread.dylib
    0x7fffc1111000 -     0x7fffc1114ff7  libsystem_sandbox.dylib (592.70.1) <4B92EC49-ACD0-36AE-B07A-A2B8152EAF9D> /usr/lib/system/libsystem_sandbox.dylib
    0x7fffc1115000 -     0x7fffc1116ff3  libsystem_secinit.dylib (24.50.4) <F78B847B-3565-3E4B-98A6-F7AD40392E2D> /usr/lib/system/libsystem_secinit.dylib
    0x7fffc1117000 -     0x7fffc111effb  libsystem_symptoms.dylib (532.50.47) <3390E07C-C1CE-348F-ADBD-2C5440B45EAA> /usr/lib/system/libsystem_symptoms.dylib
    0x7fffc111f000 -     0x7fffc1132ff7  libsystem_trace.dylib (518.70.1) <AC63A7FE-50D9-3A30-96E6-F6B7FF16E465> /usr/lib/system/libsystem_trace.dylib
    0x7fffc1133000 -     0x7fffc1138ffb  libunwind.dylib (35.3) <3D50D8A8-C460-334D-A519-2DA841102C6B> /usr/lib/system/libunwind.dylib
    0x7fffc1139000 -     0x7fffc1162ff7  libxpc.dylib (972.70.1) <BF896DF0-D8E9-31A8-A4B3-01120BFEEE52> /usr/lib/system/libxpc.dylib
External Modification Summary:
  Calls made by other processes targeting this process:
    task_for_pid: 0
    thread_create: 0
    thread_set_state: 0
  Calls made by this process:
    task_for_pid: 0
    thread_create: 0
    thread_set_state: 0
  Calls made by all processes on this machine:
    task_for_pid: 383
    thread_create: 0
    thread_set_state: 0
VM Region Summary:
ReadOnly portion of Libraries: Total=600.5M resident=0K(0%) swapped_out_or_unallocated=600.5M(100%)
Writable regions: Total=2.2G written=0K(0%) resident=0K(0%) swapped_out=0K(0%) unallocated=2.2G(100%)
                                VIRTUAL   REGION
REGION TYPE                        SIZE    COUNT (non-coalesced)
Accelerate framework               512K        4
Activity Tracing                   256K        2
CG backing stores                 21.1M       18
CG image                           652K       55
CoreAnimation                      112K       18
CoreUI image data                 1248K       14
CoreUI image file                  184K        5
Foundation                          28K        3
Image IO                           432K       41
Kernel Alloc Once                    8K        2
MALLOC                           500.8M      217
MALLOC guard page                   64K       13
MALLOC_LARGE (reserved)            824K        2         reserved VM address space (unallocated)
Memory Tag 242                      12K        2
OpenGL GLSL                        256K        4
SQLite page cache                   64K        2
STACK GUARD                       56.2M       52
Stack                            178.9M       60
VM_ALLOCATE                        1.4G       89
__DATA                            61.2M      379
__GLSLBUILTINS                    2588K        2
__IMAGE                            528K        2
__LINKEDIT                       135.0M       72
__TEXT                           465.5M      348
__UNICODE                          556K        2
mapped file                      122.6M       44
shared memory                     16.5M       26
TOTAL                              3.0G     1451
TOTAL, minus reserved VM space     3.0G     1451
Oct 08, 2017 Oct 08, 2017
I am aware I am not using the latest version. This problem began when i updated CC a while back, so thinking it was a bug that came with the update and hadn't been fixed yet, i went back to an older version. No luck, unfortunately.
Should I just update again? I think the problem will remain if i do, but nothing has been gained from going backwards.
Oct 09, 2017 Oct 09, 2017
Just curious, do you have a Automatic switching graphics option in Energy Saver Preferences?
So nothing I can really pick out. This post comes close in crash report similarities. The artist was running a browser at the same time.
https://feedback.photoshop.com/photoshop_family/topics/photoshop-cc-crash-report-10-11-6
But right now I suggest submitting the crash report to Adobe: Submit a crash report for Adobe Photoshop and Lightroom
And contact Customer Care via chat. They can remotely check for problems and they are official support you are entitled to.
Contact Customer Care
Gene
Oct 10, 2017 Oct 10, 2017
Sadly, it doesn't look like it.
Thank you for helping, regardless, and i will be getting in touch with Adobe, as best i can.
Sure. If they are able to resolve the case, would you let us know what you found out? Hopefully we can save the next Mac user a lot of time.
Gene
Absolutely.
