Hi, I need to create another Heading 1, which is identical to the existing Heading 1 style, but with a different background colour. I assumed this would be straight forward but I can't get the style to display correctly in the Responsive HTML 5 output. I have tried copying the existing Heading 1 style in the Styles editor in RoboHelp, and have also tried changing the formatting of the existing Heading 6 style, but when I create the output, the style is not applied correctly. I think I must be making a simple mistake... I have added the existing Heading 1 style below. Any advice would be appreciated.
h1 {
font-family:Arial, sans-serif;
font-size:1.2em;
font-weight:bold;
min-height:1.2em;
color:#ffffff;
background-color:slategray;
padding:0.5em 0em 0.5em 0.65em;
margin:0.65em 0em 0.6em 0em;
After reading again, have you tried using RGB values?
See www.grainge.org for RoboHelp and Authoring information
In HTML and CSS there can only be one Heading 1, Heading 2 etc.
You will either have to set Heading 2 to be the alternative or use a paragraph style.
Either way, it will affect the hierarchy.
No, I am using Hex values
Something like
background-color: rgb(0, 84, 159);
Not in what you have shown.
Thanks for your advice. It works perfectly now. I just duplicated the existing Heading style, and changed the background colour using the RGB value, as you suggested, and it worked fine. As a general approach, is it best to use RGB values, rather than Hex in RoboHelp?
Hex is fine but that's not what you were using for the background colour.
I prefer RGB because it's easier to tweak it a little by altering which value needs it.
I see. Thanks again.
