Good Afternoon Everyone,
Have an issue with a new installation of adobe acrobat standard 11 edition with office 2016 and windows 10. Whenever the user attempts to create a new pdf from an office document, say excel, she clicks on the Acrobat tab at the top of office and then clicks on create PDF. Immediately she gets an error "Unable to find "Adobe PDF" resource files. "Acrobat PDF Maker" You must have administrator privileges to install these files. Please contact your local system administrator."
This is a fresh install of windows 10 professional. The user is a local admin on the PC and the application was installed with an admin account. I've tried repairing the installation, doing a complete reinstall of the application, I've even tried upgrading the installer to one of our acrobat pro licenses and it gave the same problem. This occurs in any office application we try to create a PDF from. I've reinstalled office as well. I've seen a couple articles making sure that a reg key at HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Office\Word\Addins\PDFMaker.OfficeAddin to have its value set to 3, all of that is set already. I've also tried removing the plugin and repointing the plugin to the DLL file, that failed too. Office, adobe and windows are completely up to date.
Any suggestions?
Any suggestions?
While I don't have an answer to your question, I do urge you to put in a support request to Adobe asap. Acrobat XI support ends on October 15, 2017.
Thanks. Do you know where I can find contact information for adobe directly besides on the forums?
Make sure you have at least version 11.0.16. Previous versions before that
are not compatible with Office 2016.
On Mon, Oct 9, 2017 at 8:37 PM, system admin hmbay <forums_noreply@adobe.com
We are currently on 11.0.22.
Hello, I'm having the exact same problem you have described. Did you ever find a resolution?
