Hy,
I have create an pdf via Illustrator and size is 192 x 90 pixels.
When i open this file with photoshop it's open in a different size. Why ?
I have found to open in the good size but why it doesn't open immediately at the good size ?
Thanks a lot for your response
Please provide a more meaningful description, best including screenshots to demonstrate which settings you chose on the »Import PDF«-dialog for example.
Why do you convert the pdf, which may contain vector- and type-data after all, to a pixel image?
px is a problematic unit of measurement as it can be affected by resolution.
You cannot create a PDF with a size in pixels from Illustrator EVEN THOUGH YOU CAN CHOOSE OPTIONS THAT LOOK LIKE IT.
What size and resolution do you want in Photoshop? Or do you want it the same size ON SCREEN?
