Hi
I'm having trouble with my actions in PS cc..... I have some kelly Brown actions that are really good. They all work fine apart from the ones where I need to paint on with the brush, in these cases the actions don't apply at all.
Do you think its the actions that are the problem or my brush?
TIA
Impossible to tell without knowing what actions you use and conversely what brushes. Provide more info and screenshots.
Mylenium
Thank you, here's a screen shot
does this help at all?
I doubt it; you seem to have left out several pertinent Panels, I for one cannot discern at which point in the Action the the error occurs, …
Actually I am wondering what exactly you are trying to describe by
because the Brush. selection seems to happen near the end of the Action so it should not affect previous steps.
Could you be confused by a Layer Mask that hides the effect?
Edit: If so turn off the Layer Mask of the active Layer or paint on it with white as the foreground color.
I've tried turning the layers off but nothing seems to help. My knowledge of PS is fairly basic , I know what I need to for my work. So basically I click onto the creamy skin action, play it, select the brush as required, and when I paint on nothing happens, I've checked the opacity, the layers....all of the other actions work, its just the ones where I need to use the brush
Please post a meaningful screenshot – that means one that actually shows all pertinent Panels like, in this case, Layers and Channels.
Also please one in which the individual steps are expanded in the Actions Panel.
The foreground color is black.
Thank you, I am a novice with PS, where can you see this and how do I rectify it?
Press X on your keyboard to exchange background and foreground colors. Letter D will set defaults: black and white, letter X will exchange them.
this just saved my whole night my actions brush wasnt working and this solved it thanks soooo much!!!!
Additionally, in answer to "where can you see this" - you SEE the foreground and background colors at the bottom of the toolbar. The upper left box is the color with which you're painting (foreground color). Keep an eye on those boxes, as you follow Bojan's instructions.
So by now you hopefully have painted on the Layer Mask with White and made the Action’s effect visible?
Thank you this post is so helpful.
I have faced same issue.
Follow this step:
Click on this red are to get menu and click on Allow tool recording.
Best Wishes,
Shakib
