so i recently got an error saying i dont have enough vRAM, but my graphics card, which is supported according to the website, has 3GB soo... and when i go into my prefrences and try to fix it nothing works. ive tried giving it almost double the vRAM it wants and it is so slow i literally cannot use it. it wont recognize my graphics card, and like i said on adobe's website it says its supported. the only way i was able to use photoshop was to download the 2014 version. someone help please!
Try setting that to 70% and restart PS.
jareds43974544 wrote
VRAM is on your Display adapter. The setting above is for system RAM it should not be set to 100% .
Please Post your menu Help>System Info copy and Past here there seem to be something wrong with your configuration Photoshop is not seeing your Display Adapter for I see Use Graphics Processor grayed out in your Photoshop Preferences Performance. You should not have two different GPU in you machine Photoshop is known to have problems with that, Does your Mac or PC have Intel HD graphics on board?
Adobe Photoshop Version: 2017.1.1 20170425.r.252 2017/04/25:23:00:00 CL 1113967 x64
Number of Launches: 0
Version: 10 or greater
System architecture: Intel CPU Family:6, Model:12, Stepping:3 with MMX, SSE Integer, SSE FP, SSE2, SSE3, SSE4.1, SSE4.2, AVX, AVX2
Physical processor count: 4
Processor speed: 2993 MHz
Built-in memory: 16281 MB
Free memory: 9327 MB
Memory available to Photoshop: 14436 MB
Memory used by Photoshop: 70 %
History Thumbnails: Enabled.
Touch Bar: Enabled.
Alias Layers: Disabled.
Modifier Palette: Enabled.
Highbeam: Enabled.
Image tile size: 1024K
Image cache levels: 4
Font Preview: Medium
TextComposer: Latin
Photoshop crashed on 9/29/2017 at 11:03:43 PM (GetImageViewResourceSharingGLContext)
Display: 1
Display Bounds: top=0, left=0, bottom=1050, right=1680
Display: 2
Display Bounds: top=143, left=1680, bottom=1043, right=3120
OpenGL Drawing: Disabled.
OpenGL Allow Old GPUs: Not Detected.
AIFCoreInitialized=1
AIFOGLInitialized=1
OGLContextCreated=1
License Type: Subscription
Serial number: 96040898416398363008
GUIDBucket:
bucket: 196
test: DocumentPanel
Application folder: C:\Program Files\Adobe\Adobe Photoshop CC 2017\
Temporary file path: C:\Users\Owner\AppData\Local\Temp\
Photoshop scratch has async I/O enabled
Scratch volume(s):
Startup, 297.6G, 10.6G free
Required Plug-ins folder: C:\Program Files\Adobe\Adobe Photoshop CC 2017\Required\Plug-ins\
Primary Plug-ins folder: C:\Program Files\Adobe\Adobe Photoshop CC 2017\Plug-ins\
Installed components:
A3DLIBS.dll A3DLIB Dynamic Link Library 9.2.0.112
ACE.dll ACE 2017/01/26-01:10:02 79.579975 79.579975
AdbePM.dll PatchMatch 2016/11/03:19:48:57 1.578146 1.578146
AdobeLinguistic.dll Adobe Linguisitc Library 10.0.0
AdobeOwl.dll Adobe Owl 5.2.11
AdobePDFL.dll PDFL 2016/08/10-16:53:20 79.195992 79.195992
AdobePIP.dll Adobe Product Improvement Program 7.4.1.60.45263
AdobeSVGAGM.dll AdobeSVGAGM 79.579975 79.579975
AdobeXMP.dll Adobe XMP Core 2016/09/14-01:09:01 79.159824 79.159824
AdobeXMPFiles.dll Adobe XMP Files 2016/09/14-01:09:01 79.159824 79.159824
AdobeXMPScript.dll Adobe XMP Script 2016/09/14-01:09:01 79.159824 79.159824
adobe_caps.dll Adobe CAPS 10,0,0,6
AGM.dll AGM 2017/01/26-01:10:02 79.579975 79.579975
ahclient.dll AdobeHelp Dynamic Link Library 2.2.0.1
AIDE.dll AIDE 2016/05/27-01:08:49 79.574279 79.574279
amtlib.dll AMTLib (64 Bit) 10.0.0.119 BuildVersion: 10.0; BuildDate: Thu Dec 22 2016 3:0:7) 1.000000
ARE.dll ARE 2017/01/26-01:10:02 79.579975 79.579975
AXE8SharedExpat.dll AXE8SharedExpat 2015/03/13-23:40:54 79.562390 79.562390
AXEDOMCore.dll AXEDOMCore 2015/03/13-23:40:54 79.562390 79.562390
Bib.dll BIB 2017/01/26-01:10:02 79.579975 79.579975
BIBUtils.dll BIBUtils 2017/01/26-01:10:02 79.579975 79.579975
boost_date_time.dll photoshopdva 10.0.0
boost_signals.dll photoshopdva 10.0.0
boost_system.dll photoshopdva 10.0.0
boost_threads.dll photoshopdva 10.0.0
cg.dll NVIDIA Cg Runtime 3.0.00007
cgGL.dll NVIDIA Cg Runtime 3.0.00007
CITThreading.dll Adobe CITThreading 2.1.0.1 2.1.0.1
CoolType.dll CoolType 2017/01/26-01:10:02 79.579975 79.579975
dnssd.dll Bonjour 3,0,0,2
dvaaudiodevice.dll photoshopdva 10.0.0
dvacore.dll photoshopdva 10.0.0
dvacrashhandler.dll Adobe Audition CC 2017 10.0.0
dvamarshal.dll photoshopdva 10.0.0
dvamediatypes.dll photoshopdva 10.0.0
dvametadata.dll photoshopdva 10.0.0
dvametadataapi.dll photoshopdva 10.0.0
dvametadataui.dll photoshopdva 10.0.0
dvaplayer.dll photoshopdva 10.0.0
dvatransport.dll photoshopdva 10.0.0
dvaui.dll photoshopdva 10.0.0
dvaunittesting.dll photoshopdva 10.0.0
dynamiclink.dll photoshopdva 10.0.0
ExtendScript.dll ExtendScript 2016/12/13-13:10:33 80.1089815 80.1089815
icucnv40.dll International Components for Unicode 2014/10/31-16:52:45 Build gtlib_6.0.21339
icudt40.dll International Components for Unicode 2014/10/31-16:52:45 Build gtlib_6.0.21339
icuuc40.dll International Components for Unicode 2014/10/31-16:52:45 Build gtlib_6.0.21339
igestep30.dll IGES Reader 9.3.0.113
imslib.dll IMSLib DLL 10.0.0.11
JP2KLib.dll JP2KLib 2017/04/05-14:24:38 79.266006 79.266006
libifcoremd.dll Intel(r) Visual Fortran Compiler 10.0 (Update A)
libiomp5md.dll Intel(R) OpenMP* Runtime Library 5.0
libmmd.dll Intel(r) C Compiler, Intel(r) C++ Compiler, Intel(r) Fortran Compiler 12.0
LogSession.dll LogSession 7.4.1.60.45263
mediacoreif.dll photoshopdva 10.0.0
MPS.dll MPS 2016/09/14-15:20:26 79.577269 79.577269
pdfsettings.dll Adobe PDFSettings 1.04
Photoshop.dll Adobe Photoshop CC 2017 18.1.1
Plugin.dll Adobe Photoshop CC 2017 18.1.1
PlugPlugExternalObject.dll Adobe(R) CEP PlugPlugExternalObject Standard Dll (64 bit) 7.0.0
PlugPlugOwl.dll Adobe(R) CSXS PlugPlugOwl Standard Dll (64 bit) 7.0.0.67
PSArt.dll Adobe Photoshop CC 2017 18.1.1
PSViews.dll Adobe Photoshop CC 2017 18.1.1
SCCore.dll ScCore 2016/12/13-13:10:33 80.1089815 80.1089815
SVGRE.dll SVGRE 79.579975 79.579975
svml_dispmd.dll Intel(r) C Compiler, Intel(r) C++ Compiler, Intel(r) Fortran Compiler 12.0
tbb.dll Intel(R) Threading Building Blocks for Windows 4, 4, 2016, 0412
tbbmalloc.dll Intel(R) Threading Building Blocks for Windows 4, 4, 2016, 0412
TfFontMgr.dll FontMgr 9.3.0.113
TfKernel.dll Kernel 9.3.0.113
TFKGEOM.dll Kernel Geom 9.3.0.113
TFUGEOM.dll Adobe, UGeom© 9.3.0.113
updaternotifications.dll Adobe Updater Notifications Library 10.0.0.1 (BuildVersion: 1.0; BuildDate: BUILDDATETIME) 10.0.0.1
VulcanControl.dll Vulcan Application Control Library 5.3.0.16
VulcanMessage5.dll Vulcan Message Library 5.3.0.16
WRServices.dll WRServices Thu Jan 07 2016 04:50:10 Build 0.21960 0.21960
wu3d.dll U3D Writer 9.3.0.113
Required plug-ins:
3D Studio 18.1.1 (2017.1.1 20170425.r.252 2017/04/25:23:00:00 CL 1113967) - from the file “U3D”
Accented Edges 18.1.1 - from the file “Filter Gallery”
Adaptive Wide Angle 18.1.1 - from the file “Adaptive Wide Angle”
Angled Strokes 18.1.1 - from the file “Filter Gallery”
Average 18.1.1 (2017.1.1 20170425.r.252 2017/04/25:23:00:00 CL 1113967) - from the file “Average”
Bas Relief 18.1.1 - from the file “Filter Gallery”
BMP 18.1.1 - from the file “Standard MultiPlugin”
Camera Raw 9.12.1 - from the file “Camera Raw”
Camera Raw Filter 9.12.1 - from the file “Camera Raw”
Chalk && Charcoal 18.1.1 - from the file “Filter Gallery”
Chrome 18.1.1 - from the file “Filter Gallery”
Cineon 18.1.1 (2017.1.1 20170425.r.252 2017/04/25:23:00:00 CL 1113967) - from the file “Cineon”
Clouds 18.1.1 (2017.1.1 20170425.r.252 2017/04/25:23:00:00 CL 1113967) - from the file “Clouds”
Collada 18.1.1 (2017.1.1 20170425.r.252 2017/04/25:23:00:00 CL 1113967) - from the file “U3D”
Color Halftone 18.1.1 - from the file “Standard MultiPlugin”
Colored Pencil 18.1.1 - from the file “Filter Gallery”
CompuServe GIF 18.1.1 - from the file “Standard MultiPlugin”
Conté Crayon 18.1.1 - from the file “Filter Gallery”
Craquelure 18.1.1 - from the file “Filter Gallery”
Crop and Straighten Photos 18.1.1 (2017.1.1 20170425.r.252 2017/04/25:23:00:00 CL 1113967) - from the file “CropPhotosAuto”
Crop and Straighten Photos Filter 18.1.1 - from the file “Standard MultiPlugin”
Crosshatch 18.1.1 - from the file “Filter Gallery”
Crystallize 18.1.1 - from the file “Standard MultiPlugin”
Cutout 18.1.1 - from the file “Filter Gallery”
Dark Strokes 18.1.1 - from the file “Filter Gallery”
De-Interlace 18.1.1 - from the file “Standard MultiPlugin”
Dicom 18.1.1 - from the file “Dicom”
Difference Clouds 18.1.1 (2017.1.1 20170425.r.252 2017/04/25:23:00:00 CL 1113967) - from the file “Clouds”
Diffuse Glow 18.1.1 - from the file “Filter Gallery”
Displace 18.1.1 - from the file “Standard MultiPlugin”
Dry Brush 18.1.1 - from the file “Filter Gallery”
Eazel Acquire 18.1.1 (2017.1.1 20170425.r.252 2017/04/25:23:00:00 CL 1113967) - from the file “EazelAcquire”
Entropy 18.1.1 (2017.1.1 20170425.r.252 2017/04/25:23:00:00 CL 1113967) - from the file “statistics”
Export Color Lookup Tables 18.1.1 (2017.1.1 20170425.r.252 2017/04/25:23:00:00 CL 1113967) - from the file “Export3DLUT”
Extrude 18.1.1 - from the file “Standard MultiPlugin”
FastCore Routines 18.1.1 (2017.1.1 20170425.r.252 2017/04/25:23:00:00 CL 1113967) - from the file “FastCore”
Fibers 18.1.1 - from the file “Standard MultiPlugin”
Film Grain 18.1.1 - from the file “Filter Gallery”
Filter Gallery 18.1.1 - from the file “Filter Gallery”
Flash 3D 18.1.1 (2017.1.1 20170425.r.252 2017/04/25:23:00:00 CL 1113967) - from the file “U3D”
Fresco 18.1.1 - from the file “Filter Gallery”
Glass 18.1.1 - from the file “Filter Gallery”
Glowing Edges 18.1.1 - from the file “Filter Gallery”
Google Earth 4 18.1.1 (2017.1.1 20170425.r.252 2017/04/25:23:00:00 CL 1113967) - from the file “U3D”
Graphic Pen 18.1.1 - from the file “Filter Gallery”
Halftone Pattern 18.1.1 - from the file “Filter Gallery”
HDRMergeUI 18.1.1 - from the file “HDRMergeUI”
HSB/HSL 18.1.1 - from the file “Standard MultiPlugin”
IFF Format 18.1.1 - from the file “Standard MultiPlugin”
IGES 18.1.1 (2017.1.1 20170425.r.252 2017/04/25:23:00:00 CL 1113967) - from the file “U3D”
Ink Outlines 18.1.1 - from the file “Filter Gallery”
JPEG 2000 18.1.1 - from the file “JPEG2000”
Kurtosis 18.1.1 (2017.1.1 20170425.r.252 2017/04/25:23:00:00 CL 1113967) - from the file “statistics”
Lens Blur 18.1.1 - from the file “Lens Blur”
Lens Correction 18.1.1 - from the file “Lens Correction”
Lens Flare 18.1.1 - from the file “Standard MultiPlugin”
Liquify 18.1.1 - from the file “Liquify”
Matlab Operation 18.1.1 (2017.1.1 20170425.r.252 2017/04/25:23:00:00 CL 1113967) - from the file “ChannelPort”
Maximum 18.1.1 (2017.1.1 20170425.r.252 2017/04/25:23:00:00 CL 1113967) - from the file “statistics”
Mean 18.1.1 (2017.1.1 20170425.r.252 2017/04/25:23:00:00 CL 1113967) - from the file “statistics”
Measurement Core 18.1.1 (2017.1.1 20170425.r.252 2017/04/25:23:00:00 CL 1113967) - from the file “MeasurementCore.8me”
Median 18.1.1 (2017.1.1 20170425.r.252 2017/04/25:23:00:00 CL 1113967) - from the file “statistics”
Mezzotint 18.1.1 - from the file “Standard MultiPlugin”
Minimum 18.1.1 (2017.1.1 20170425.r.252 2017/04/25:23:00:00 CL 1113967) - from the file “statistics”
MMXCore Routines 18.1.1 (2017.1.1 20170425.r.252 2017/04/25:23:00:00 CL 1113967) - from the file “MMXCore”
Mosaic Tiles 18.1.1 - from the file “Filter Gallery”
Multiprocessor Support 18.1.1 (2017.1.1 20170425.r.252 2017/04/25:23:00:00 CL 1113967) - from the file “MultiProcessor Support”
Neon Glow 18.1.1 - from the file “Filter Gallery”
Note Paper 18.1.1 - from the file “Filter Gallery”
NTSC Colors 18.1.1 (2017.1.1 20170425.r.252 2017/04/25:23:00:00 CL 1113967) - from the file “NTSC Colors”
Ocean Ripple 18.1.1 - from the file “Filter Gallery”
OpenEXR 18.1.1 - from the file “Standard MultiPlugin”
Paint Daubs 18.1.1 - from the file “Filter Gallery”
Palette Knife 18.1.1 - from the file “Filter Gallery”
Patchwork 18.1.1 - from the file “Filter Gallery”
Paths to Illustrator 18.1.1 - from the file “Standard MultiPlugin”
PCX 18.1.1 (2017.1.1 20170425.r.252 2017/04/25:23:00:00 CL 1113967) - from the file “PCX”
Photocopy 18.1.1 - from the file “Filter Gallery”
Photoshop 3D Engine 18.1.1 (2017.1.1 20170425.r.252 2017/04/25:23:00:00 CL 1113967) - from the file “Photoshop3DEngine”
Photoshop Touch 14.0 - from the file “PSDX”
Picture Package Filter 18.1.1 (2017.1.1 20170425.r.252 2017/04/25:23:00:00 CL 1113967) - from the file “ChannelPort”
Pinch 18.1.1 - from the file “Standard MultiPlugin”
Pixar 18.1.1 (2017.1.1 20170425.r.252 2017/04/25:23:00:00 CL 1113967) - from the file “Pixar”
Plaster 18.1.1 - from the file “Filter Gallery”
Plastic Wrap 18.1.1 - from the file “Filter Gallery”
PLY 18.1.1 (2017.1.1 20170425.r.252 2017/04/25:23:00:00 CL 1113967) - from the file “U3D”
PNG 18.1.1 - from the file “Standard MultiPlugin”
Pointillize 18.1.1 - from the file “Standard MultiPlugin”
Polar Coordinates 18.1.1 - from the file “Standard MultiPlugin”
Portable Bit Map 18.1.1 (2017.1.1 20170425.r.252 2017/04/25:23:00:00 CL 1113967) - from the file “PBM”
Poster Edges 18.1.1 - from the file “Filter Gallery”
PRC 18.1.1 (2017.1.1 20170425.r.252 2017/04/25:23:00:00 CL 1113967) - from the file “U3D”
Radial Blur 18.1.1 - from the file “Standard MultiPlugin”
Radiance 18.1.1 (2017.1.1 20170425.r.252 2017/04/25:23:00:00 CL 1113967) - from the file “Radiance”
Range 18.1.1 (2017.1.1 20170425.r.252 2017/04/25:23:00:00 CL 1113967) - from the file “statistics”
Render Color Lookup Grid 18.1.1 (2017.1.1 20170425.r.252 2017/04/25:23:00:00 CL 1113967) - from the file “Export3DLUT”
Reticulation 18.1.1 - from the file “Filter Gallery”
Ripple 18.1.1 - from the file “Standard MultiPlugin”
Rough Pastels 18.1.1 - from the file “Filter Gallery”
Save for Web 18.1.1 - from the file “Save for Web”
ScriptingSupport 18.1.1 - from the file “ScriptingSupport”
Shake Reduction 18.1.1 - from the file “Shake Reduction”
Shear 18.1.1 - from the file “Standard MultiPlugin”
Skewness 18.1.1 (2017.1.1 20170425.r.252 2017/04/25:23:00:00 CL 1113967) - from the file “statistics”
Smart Blur 18.1.1 - from the file “Standard MultiPlugin”
Smudge Stick 18.1.1 - from the file “Filter Gallery”
Solarize 18.1.1 (2017.1.1 20170425.r.252 2017/04/25:23:00:00 CL 1113967) - from the file “Solarize”
Spaces 18.1.1 - from the file “Spaces”
Spatter 18.1.1 - from the file “Filter Gallery”
Spherize 18.1.1 - from the file “Standard MultiPlugin”
Sponge 18.1.1 - from the file “Filter Gallery”
Sprayed Strokes 18.1.1 - from the file “Filter Gallery”
Stained Glass 18.1.1 - from the file “Filter Gallery”
Stamp 18.1.1 - from the file “Filter Gallery”
Standard Deviation 18.1.1 (2017.1.1 20170425.r.252 2017/04/25:23:00:00 CL 1113967) - from the file “statistics”
STL 18.1.1 (2017.1.1 20170425.r.252 2017/04/25:23:00:00 CL 1113967) - from the file “U3D”
Sumi-e 18.1.1 - from the file “Filter Gallery”
Summation 18.1.1 (2017.1.1 20170425.r.252 2017/04/25:23:00:00 CL 1113967) - from the file “statistics”
Targa 18.1.1 - from the file “Standard MultiPlugin”
Texturizer 18.1.1 - from the file “Filter Gallery”
Tiles 18.1.1 - from the file “Standard MultiPlugin”
Torn Edges 18.1.1 - from the file “Filter Gallery”
Twirl 18.1.1 - from the file “Standard MultiPlugin”
U3D 18.1.1 (2017.1.1 20170425.r.252 2017/04/25:23:00:00 CL 1113967) - from the file “U3D”
Underpainting 18.1.1 - from the file “Filter Gallery”
Vanishing Point 18.1.1 - from the file “VanishingPoint”
Variance 18.1.1 (2017.1.1 20170425.r.252 2017/04/25:23:00:00 CL 1113967) - from the file “statistics”
Virtual Reality Modeling Language | VRML 18.1.1 (2017.1.1 20170425.r.252 2017/04/25:23:00:00 CL 1113967) - from the file “U3D”
Water Paper 18.1.1 - from the file “Filter Gallery”
Watercolor 18.1.1 - from the file “Filter Gallery”
Wave 18.1.1 - from the file “Standard MultiPlugin”
Wavefront|OBJ 18.1.1 (2017.1.1 20170425.r.252 2017/04/25:23:00:00 CL 1113967) - from the file “U3D”
WIA Support 18.1.1 (2017.1.1 20170425.r.252 2017/04/25:23:00:00 CL 1113967) - from the file “WIASupport”
Wind 18.1.1 - from the file “Standard MultiPlugin”
Wireless Bitmap 18.1.1 (2017.1.1 20170425.r.252 2017/04/25:23:00:00 CL 1113967) - from the file “WBMP”
ZigZag 18.1.1 - from the file “Standard MultiPlugin”
Optional and third party plug-ins: NONE
Duplicate and Disabled plug-ins: NONE
Plug-ins that failed to load: NONE
Extensions:
com.adobe.inapp.purchase 2.10.56 - from the file “C:\Program Files (x86)\Common Files\Adobe\CEP\extensions\CC_LIBRARIES_PANEL_EXTENSION_2_10_56\purchase.html”
New Document 2.0.1 - from the file “C:\Users\Owner\AppData\Roaming\Adobe\CEP\extensions\CCX_CMDN_EXTENSION_2_0_1_001\fnft.html”
Libraries 2.10.56 - from the file “C:\Program Files (x86)\Common Files\Adobe\CEP\extensions\CC_LIBRARIES_PANEL_EXTENSION_2_10_56\index.html”
Start 2.0.1 - from the file “C:\Users\Owner\AppData\Roaming\Adobe\CEP\extensions\CCX_START_EXTENSION_2_0_1_044\index.html”
com.adobe.experimentation.extension 2.0.0 - from the file “C:\Program Files\Adobe\Adobe Photoshop CC 2017\Required\CEP\extensions\com.adobe.experimentation.extension\index.html”
Adobe Color Themes 6.1.0 - from the file “C:\Program Files\Adobe\Adobe Photoshop CC 2017\Required\CEP\extensions\com.adobe.KulerPanel.html\index.html”
Export As 3.0.8 - from the file “C:\Program Files\Adobe\Adobe Photoshop CC 2017\Required\CEP\extensions\com.adobe.photoshop.crema\PSPanel\dialog.html”
Device Preview 1.3.2 - from the file “C:\Program Files\Common Files\Adobe\CEP\extensions\com.adobe.previewHD\PSPanel\panel.html”
com.adobe.preview.loader 1.3.2 - from the file “C:\Program Files\Common Files\Adobe\CEP\extensions\com.adobe.previewHD\PSLoader\loader.html”
Installed TWAIN devices: NONE
It look like Photoshop has trouble getting your Display Adapter info. Do you have two GPU installed? Make sure you have the latest driver for your displays adapter installed.
Can you go to Photoshop Help > System info click copy and then paste the info into a post here. That will help us to see what is going on with your system
Dave
