Hi
So I've been getting this error when ever I try to start up Adobe Premiere. When I checked the Event Viewer, the following details are shown.
Faulting application name: Adobe Premiere Pro CC.exe, version: 11.1.2.22, time stamp: 0x592e1ca1
Faulting module name: dvaui.dll, version: 11.1.2.22, time stamp: 0x592df8c4
Exception code: 0xc0000005
Fault offset: 0x0000000000332611
Faulting process ID: 0x10e0
Faulting application start time: 0x01d32d00889966b8
Faulting application path: C:\Program Files\Adobe\Adobe Premiere Pro CC 2017\Adobe Premiere Pro CC.exe
Faulting module path: C:\Program Files\Adobe\Adobe Premiere Pro CC 2017\dvaui.dll
Report ID: c69c7640-98f3-11e7-829d-408d5cca2392
Faulting package full name:
Faulting package-relative application ID:
I've tried reinstalling it, but didn't fix the issue
Also I'm attaching the images of the error message I get.
Hi jasonm97605828,
Sorry for the issue with crash. It seems like an issue with GPU drivers. Please update the GPU drivers to latest version & let us know the status.
Vidya.
Hi Vidya
Hope you've received the message I sent on last Friday. Appreciate your earliest response on the same.
Sylvia
I have the same issue. Trying to run on a Lenovo Y50 laptop. Just tried updating my drivers and no luck. I will try some other fixes and see if anything helps.
Omri
Hi vidya
Thanks a lot for the reply. I did what you've mentioned above. Still did not fix the issue.
Sylvia
