Can't explain but Photoshop is messed up (check image)
Guest
Oct 10, 2017 Oct 10, 2017
I can't explain the problem so I hope this image can:
This is (meant to be) Edit>Preferences>Interface
948
Community Expert , Oct 11, 2017 Oct 11, 2017
Hi
When Photoshop clearly misbehaves in some unusual way , then it is worth resetting preferences. These can get corrupted.
When you can't get to the button in the Preference dialogue, and you clearly cannot, then you can reset by closing Photoshop then holding down Alt+Control+Shift (Windows) or Option+Command+Shift (Mac ) whilst you click to start Photoshop. You will get a dialogue asking if you want to delete settings. Click on yes and Photoshop will rebuild its default settings.
Dave
Adobe
Does turning off »Use Graphics Processor« in the Performance Preferences (Photoshop > Preferences > Performance > Graphic Processor Settings) and restarting Photoshop have any bearing on the issue? (Even though it may be a bit difficult to identify it …)
Could you have removed a required System Font?
Also check these out:
https://helpx.adobe.com/photoshop/kb/troubleshoot-fonts-photoshop.html
Photoshop 2015 CC Blank dialogs Options Text Missing
Blank dialog boxes and missing text from Acrobat interface
Guest
Oct 12, 2017 Oct 12, 2017
Fonts are still visible but they are cut off
And turning off »Use Graphics Processor« does not fix
Hi
Dave
Guest
Tried doing this once (dialogue appeared), now the dialogue does not appear?
Guest
Oct 14, 2017 Oct 14, 2017
I didn't hold down Ctrl+Alt+Shift for long enough; you wave to keep holding it after the UAC alert pops up. Thanks, though!
