Numbering in Camera RAW
Oct 09, 2017 Oct 09, 2017
I'm looking for help in regards to numbering, when saving files in Camera RAW.  I want the first file saved to start with the number 1 rather than have no number, so that I can keep the order of images in tact.  It's a pain having to relabel that one file so that it appears first.  I've looked within CC and on this forum for answers but to no avail.  I can see the "Start Numbering With" option but it's grayed out and it's not accessible. Any help would be greatly appreciated. Thanks!
828
Adobe Employee ,
Oct 12, 2017 Oct 12, 2017
Hi Baiancaf,
Could you please follow the steps mentioned below:
You can create an action to automate the processing of image files with Camera Raw. You can automate the editing process, and the process of saving the files in formats such as PSD, DNG, JPEG, Large Document Format (PSB), TIFF, and PDF. In Photoshop, you can also use the Batch command, the Image Processor, or the Create Droplet command to process one or more image files. The Image Processor is especially useful for saving image files in different file formats during the same processing session.
Here are some tips for automating the processing of camera raw image files:
  • When you record an action, first select Image Settings from the Camera Raw Settings menu in the Camera Raw dialog box. In this way, the settings particular to each image (from the Camera Raw database or sidecar XMP files) are used to play back the action.
  • If you plan to use the action with the Batch command, you may want to use the Save As command and choose the file format when saving the camera raw image.
  • When you use an action to open a camera raw file, the Camera Raw dialog box reflects the settings that were in effect when the action was recorded. You may want to create different actions for opening camera raw image files with different settings.
  • When using the Batch command, select Override Action “Open” Commands. Any Open commands in the action will then operate on the batched files rather than the files specified by name in the action. Deselect Override Action “Open” Commands only if you want the action to operate on open files or if the action uses the Open command to retrieve needed information.
  • When using the Batch command, select Suppress File Open Options Dialogs to prevent the display of the Camera Raw dialog box as each camera raw image is processed.
  • When using the Batch command, select Override Action “Save As” Commands if you want to use the Save As instructions from the Batch command instead of the Save As instructions in the action. If you select this option, the action must contain a Save As command, because the Batch command does not automatically save the source files. Deselect Override ActionSave As” Commands to save the files processed by the Batch command in the location specified in the Batch dialog box.
  • When creating a droplet, select Suppress File Open Options Dialog in the Play area of the Create Droplet dialog box. This prevents the display of the Camera Raw dialog box as each camera raw image is processed.
Sahil
I personally would use the batch tools built into ACR:
Jan 20, 2022 Jan 20, 2022
"Start numbering with" is grayed out unless you do this. In the "Save Options" box put your chosen file name as previous and then in the dropdown box to the immediate right, select one of the 1-6 digit numbers options. "Start Numbering With" can now be used. Phil.
Jan 21, 2022 Jan 21, 2022
You could also just use batch rename options in Bridge or Lightroom before you process files.
