I have an image of a character that is supposed to walk into a building by using a combination of the left-to-right motion path and then zoom out effects. The problem is the character returns to her original size after the effect has finished. Is there a way I can get her to maintain the the "zoomed out" size?
Thanks for any help!
I solved it by changing Zoom To 0% to Zoom To 1% and then immediately covering the 1% with another object.
I am not sure if I am correct please could you see the timing of effect start in Zoom Out it is something visually look like 7,6 which is not 7.6 so try to give number like 7 or 8 if it works. Please check it even I am not sure about this.
I tried that, but it didn't work. Thanks for the idea, though!
