Vector Mask Problems
Oct 11, 2017 Oct 11, 2017
I have a particularly vexing problem that popped up recently, hope someone can help. I have a client image with a path for the exterior of their product. I am using a vector mask to Free Transform the image and the path simultaneously, so that I may straighten the verticals of the product that was photographed from above. I then put the product on a new layer via cut, floating it over a white layer and then change the path to a clipping path. After successfully transforming 6 images, suddenly the last three images will not correctly transform the image and vector path simultaneously! Aargh! I often use keyboard shortcuts, etc... to change tools and perform different often performed operations, which I suspect I may have changed some setting by hitting a wrong combination that affects the Free Transform of the image and the Vector Mask. Unfortunately, myself and some serious PS peeps I know have no idea what it is. Any ideas?
Photoshop CS6 13.0.6 x64 on Mac os X El Capitan 10.11.6
527
Adobe
Could you please post screenshots with the pertinent Panels (Layers, Paths, Options Bar, …) visible?
If you believe you may have changed the KB shortcuts, you can choose Edit > Keyboard Shortcuts. Ensure you have the Default Shortcuts set selected.
HTH
Oct 12, 2017 Oct 12, 2017
Are Layer and Vector Mask linked, is a Selection active, …?
And once again: Please post a meaningful screenshot.
Oct 13, 2017 Oct 13, 2017
Maybe not easy to see is that after making a vector mask I Select All, then Free Transform. When it works correctly the Free Transform gives me the corners of the entire image, now it just gives me the machine (as pictured) and it only moves the path itself, not the path and the machine that the path encompasses. Hope this is what you are looking to see, and thank you for your attention!!!!
Oct 14, 2017 Oct 14, 2017
Deselect.
And deselect the Vector Mask in the Paths Panel, too.
Unfortunately if I deselect the layer I am not offered Free Transform, if I deselect the vector mask, the machine moves but then I do not have a path that is around the machine. Thanks though!
Oct 15, 2017 Oct 15, 2017
I did not say to deselect the Layer, deselect the Selection!
Select > Deselect
