1 2 Previous Next 42 Replies Latest reply on Nov 14, 2018 10:27 AM by fredricksbrooke
    Caps Lock error message
    ugoharris Level 1
      Hi all,
         I'm using adobe after effects cs3, and sometimes I get the error message as show on the red line at the lower section of my image in my attachment  image file which reads:
      "Refresh Disabled(release Caps Lock to refresh view)"
      This error message actually affects some actions my after effects project.
      Please, does anyone know how I can solve this problem or how to  "release Caps Lock to refresh view "
      Thanks and hope some can help
      Ugoharris.
        • 1. Re: Caps Lock error message
          Adolfo Rozenfeld Adobe Employee
          That's not an error message. It's a warning.
          Caps lock is the key you use... to lock caps, ie the shift key (SO EVERYTHING WORKS AS IF YOU KEPT THE SHIFT KEY PRESSED).
          In After Effects, pressing the Caps Lock key makes the application stop trying to render/update the contents of the active Composition. Why would someone would do that? For example, when the app starts rendering a Composition frame that you know will take a very long time, and you want to interrupt that to make a change, for example. Or when the Comp panel becomes very sluggish for some reason, and you just want to make a minor adjustment, you can press Caps lock, adjust a parameter and then see the results when you release caps lock.
          To exit this state, just press the Caps lock key again (it's usually located above the left shift key).
          • 2. Re: Caps Lock error message
            yoranr18520874
            Everytime I move something in my composition in happens, so basically, everything I do, before I can see what I do, I need to press caps lock two times..
            • 3. Re: Caps Lock error message
              Szalam Adobe Community Professional & MVP
              What, exact, version number of AE are you using?
              What OS?
              What are your system specs?
              What kind of keyboard and how is it connected?
              • 4. Re: Caps Lock error message
                yoranr18520874 Level 1
                I am using mac os , the latest version and I were also running the latest version of AE. Now that the new update came out, the problem had disappeared. Thanks for the service !
                • 5. Re: Caps Lock error message
                  DanielFriend
                  Well, I'm still having this same problem and no solution. Any advice?
                  • 6. Re: Caps Lock error message
                    I re-installed the application and removed the update. Then I updated again and it worked for me. Hope this was helpful !
                    • 7. Re: Caps Lock error message
                      carlac28579492
                      Hi Adolfo,
                      I am having the same issue, every time i move something or any other action (caps lock is not even on), I get the error, my art board becomes black, and I need to click at least 3 times in the "caps lock" button to go back to normal view. It is really annoying and it slows my work sooooo much, as I need to be clicking caps lock many times every 2 sec.
                      I have already uninstall and installed "after effects cc 2017" back, and the issue is still on. But this issue started only after i installed the "Bodymoving" plugin from Airbnb Lottie, and unfortunately there is no option to uninstall this plugin, is like a parasite , i can't even find it in the "plugins" folder :O.
                      I don't know what to do anymore to fix this annoying issue, please HELP!!
                      • 8. Re: Caps Lock error message
                        jamesb4610536
                        I too have this same problem. I have noticed that it is intermittent- I worked most of last night without it, but this morning, on opening the same file, it's back. I have de-activated and re-activated Live Update, but to no avail.
                        It makes working in AE very difficult!
                        • 9. Re: Caps Lock error message
                          Werefie
                          I am having this issue as well. It started randomly today. I opened one of my unfinished projects and it started to act odd and the caps lock message kept coming up even when caps lock was not pressed and active. I even uninstalled and reinstalled AE and it did not seem to resolve the issue. Hopefully Adobe can figure out a solution to this in an upcoming update. It makes working in the program extremely difficult. I can live with it, but it is extremely annoying and frustrating and makes me not even want to continue working on my projects :/
                          • 10. Re: Caps Lock error message
                            Werefie Level 1
                            Also I am currently using AE CC 2017, hopefully this issue gets fixed... it seems that quite a few people are having this issue
                            • 11. Re: Caps Lock error message
                              There is likely something other than After Effects happening here. This isn't a widespread issue; I've only seen this thread about it in all the forums I frequent.
                              The thing we need to figure out is what is causing it. It could be a hardware issue or a software issue.
                              What input devices are you using? Exact model of keyboard, mouse, tablet, 3d mouse, etc.
                              Besides Adobe software, what else do you have installed?
                              Any OS modification stuff running?
                              • 12. Re: Caps Lock error message
                                Werefie Level 1
                                Hi. Thanks for the response. I am on a Mac from around 2011ish and I use a non-wireless keyboard that came with it as well a standard Mac mouse that is plugged in also. I don't have a tablet or other things. I don't really have much else installed on my computer, I have the game Minecraft, Skype, Discord, nothing really intensive besides some anti virus stuff that my dad put on there since it's his computer that I use. I haven't installed any other software after getting after effects also so I wouldn't think it would be other software affecting it since it started yesterday. I'm not sure if any other added on plugins would affect it as I only have Red Giant Universe and Video Copilot and I have had those since I first got AE and it's worked fine the whole time until yesterday. I'll see if I can figure anything out when I get home today I'll try reinstalling it again and rebooting my computer possibly. You  know rebooting might fix it lol.
                                • 13. Re: Caps Lock error message
                                  Dave LaRonde Level 7
                                  ...and don't use the wireless keyboard, either.  I've read reports that they can cause problems.  It's a bluetooth thing.
                                  • 14. Re: Caps Lock error message
                                    Werefie Level 1
                                    Yeah my keyboard isnt wireless it's plugged. We got rid of our wireless one a while back
                                    • 15. Re: Caps Lock error message
                                      anaïtas40789790
                                      Has anyone found a solution? All of sudden, I have this same problem, it seems really random and I don't know what to do...
                                      I'm on a Macbook, OS is up to date, as well as AE... !
                                      Note: I started a new composition and the problem appeared just then and it seems to happen every time I want to move, for instance, a layer of text in the composition, or if I move the marker on the timeline manually - when I hit the spacebar it works fine.
                                      Anaïta
                                      • 16. Re: Caps Lock error message
                                        Gutterfish Adobe Community Professional
                                        Interesting that not one person having this problem has offered what exact model of keyboards they are using even though Szalam asked,  TWICE, for the exact make and model of the keyboard. The closes we got was
                                        I wonder have any of you tested multiple keyboards to see if it is the keyboard?
                                        Wouldn't it be wacky if it turned out you're all using the same keyboard?
                                        How on earth will we ever find out?
                                        • 17. Re: Caps Lock error message
                                          xxxxx54321 Level 1
                                          Adobe CC 2017 Ae
                                          This question is Assumed Answered.
                                          01. This question is not answered at all, not even close.
                                          02. I am now having the same issue after leaving my computer for a night with CAPS LOCK turned on; now the CAPS LOCK IS OFF; disability to preview is random, the message "Anzeige-Beschleunigung deaktiviert" (German Win7) is showing all the time, however some grouped compositions/modules are being previewed, while the others are not; the reason behind this is unknown;
                                          03. The whole "CAPS LOCK" idea to disable preview while rendering does not make sense; Adobe developers made this possibly from a presumption that the machine will be used exclusively for rendering, which is not true with today's powerful computers; I DO NOT HAVE TO WRITE LIKE THIS DURING 8 HOURS WHILE RENDERING; a checkbox in the render queue would suffice;
                                          04. I have tried reloading project file, using another project file, restarting Ae, rebooting Win7 - it is all the same;
                                          05. The request for the Keyboard model and make does not make any sense as well and has no grounds; the software should work as expected with any keyboard, with any make, with on screen keyboard on or off it is irrelevant;
                                          06. Why should I keep "Shift" while going to Edit -> Preferences to improve performance? Do you think it is fun and we professionals have so plenty of time to seek for features like that? Grow up, Adobe. We want a software that works.
                                          Basically Ae was the only reason why I have kept Mac and Win machines. Now this reason is gone.
                                          There is a much better choice for Linux these days.
                                          Good luck, Adobe.
                                          • 18. Re: Caps Lock error message
                                            Assumed Answered is a system generate error... fixed
                                            • 19. Re: Caps Lock error message
                                              That's all super and yes, in a perfect world software would work with every hardware configuration.  However, the problem is obviously a compatibility issue.  If it weren't, more people would be experiencing the problem.
                                              To me, plugging in a different keyboard seems like a simple enough thing to do, even if it makes no difference.  I just find it interesting that nobody on this thread has indicated that they tried plugging in other keyboards.  It's probably the first thing i would do.  That's just me.
                                              • 20. Re: Caps Lock error message
                                                xxxxx54321 Level 1
                                                I do not know what "super world" you are talking about. We live in the world that we have now. In this world a commercial grade software priced at start. USD 300 per annum per user is expected to work on any hardware with any keyboard.
                                                I have 2 keyboards - one laptop built-in anti-ghosting gaming keyboard, 2nd one RAPOO Ultraslim E9070, 3d - onscreen windows keyboard in Tablet mode (Wacom 27QHD). I have no idea how that might be helpful, but just in case - turning off / unplugging this usb wireless keyboard does not change a thing.
                                                I find it indeed interesting why on Earth someone is expected to publish their hardware specs in order to resolve a Software bug with all this CAPS LOCK nonsense. I could understand if that was on Linux platform, but we are talking about Win/Mac boxes where hardware is irrelevant and abstracted (on Mac/iOS it is all standard, so why are you asking? just to ask something and take time even more?).
                                                Are you an Adobe developer / team lead / project owner / product manager / quality assurance engineer / support staff?
                                                How would you comment on these CAPS LOCK issues being open since CC 2014 and still not addressed?
                                                CreativeCOW  - Isn't the caps-lock solution stupid?
                                                refresh disabled is on when my caps lock is off? : Adobe After Effects
                                                • 21. Re: Caps Lock error message
                                                  xxxxx54321
                                                  I would explain by saying that they've not figured out how to fix it, that pretty obvious.
                                                  I was not asking for your hardware specs here. That would be for a bug report.
                                                  I was just commenting on the FACT..that quite often software bugs are directly related to hardware.
                                                  Maybe things are getting lost in translation.
                                                  And I was not the one speaking of some perfect world, you were.
                                                  You say that $300 a year software should work on any hardware.
                                                  I say that's simply not reality.  Sometimes things don't work perfectly.  Sometimes things are even inexplicably unfair .
                                                  Anyway...you (and everyone else with the issue) could file bug reports that include all of the hardware information you
                                                  feel is irrelevant, or not.
                                                  I was merely offering a suggestion, as stupid as it may have been.
                                                  As for your "feelings" about Adobe and how things "should be"...I couldn't care less.
                                                  • 22. Re: Caps Lock error message
                                                    xxxxx54321 Level 1
                                                    Gutterfish  wrote
                                                    xxxxx54321
                                                    Since you have ignored this sentence:
                                                    "Are you an Adobe developer / team lead / project owner / product manager / quality assurance engineer / support staff?"
                                                    your suggestions are irrelevant.
                                                    "Maybe things are getting lost in translation."
                                                    • 23. Re: Caps Lock error message
                                                      Good luck, Adobe.
                                                      Since you no longer use Adobe software your comments, & in fact your presence here, is irrelevant.
                                                      Good luck,  ALXHK
                                                      • 24. Re: Caps Lock error message
                                                        wcreamer3 Level 1
                                                        I just started using After Effects this month. I am getting these errors. I have an Alienware laptop. I am almost certain that it's not sticky keys or some other hardware issue. If my caps lock were to accidentally turn on it would be indicated by a light. I haven't tried to hook up another keyboard to my laptop because I don't have another keyboard. I hope this issue is resolved because, I'm very new and I am having trouble learning because of this.
                                                        • 25. Re: Caps Lock error message
                                                          brendanflanigan
                                                          I just had the same problem and it was also a wireless keyboard issue. I often use an Apple Wireless Keyboard with a larger external monitor and my Macbook closed. However, when I was having the Caps Lock issue, I had my computer open but the wireless keyboard was still connected. I think having the double keyboard input confused After Effects. I disabled it from the Bluetooth Preferences and now it works fine. If you have multiple keyboard inputs at the same time, I would try removing one.
                                                          • 26. Re: Caps Lock error message
                                                            MiguelPetersen
                                                            I do have the same issue man im running newest client update. It's super annoying, it comes with the error message even if the Caps Lock isn't turned on, and we all have to double click on caps lock for refresh it. Please go take a closer a look at it, and try debunk it
                                                            • 27. Re: Caps Lock error message
                                                              sillybomb Level 1
                                                              I too have this problem, started this exact moment.
                                                              AE CC version up to date on cloud
                                                              info about the mac
                                                              Hardware I am on a macbook pro. its a keyboard built into the laptop no other keyboard to try but certain it should work with this standard mac keyboard inbuilt.
                                                              Also I don't agree with xxxxx54321 but I do that the price of the software should come with some kind of quality assurance.
                                                              does anyone have the link to submit a bug to adobe? looks like that might be the productive solution atm
                                                              • 28. Re: Caps Lock error message
        Sure! You can file bug reports here.
        • 29. Re: Caps Lock error message
        mishkaa1
        please help, i am having the same issue. whenever i want to preview my project it says that i have my caps lock on but they aren't? i have deleted the application and am not sure whether i should re-install it (it was the up to date version of after effects)
        please help me!
        • 30. Re: Caps Lock error message
        mishkaa1 Level 1
        could you please help me? i am having the same problem?
        • 31. Re: Caps Lock error message
        sillybomb Level 1
        hey all
        silly question but have you tried restarting the computer?
        After some research I found that at least in the instances where it is happening on a mac, it may not even be related to adobe but something that just happens on a mac sometimes.The suggestion was to restart the computer.
        I did that and haven't had the problem again since.
        see if it works for you
        1 person found this helpful
        • 32. Re: Caps Lock error message
        wiedenu
        Restarting fixed this for me. iMac 27" 5k, AE CC2017.
        • 33. Re: Caps Lock error message
        annao63363184 Level 1
        I had the same problem after updating to AE CC 18. I thought it was blue tooth related, I switched out my keyboard and it didn't fix it.  I ended up restarting the my computer, uninstalling and reinstalling aftereffects and emptying the disk cache folder and it fixed the problem.
        Hope that helps!
        • 34. Re: Caps Lock error message
        ugoharris  wrote
        Hi all,
        I'm using adobe after effects cs3......
        Y'know, that piece of software is just about ten years old.  I's a 32-bit application.
        Is your computer ALSO about ten years old, and comfortable with running 32-bit apps?
        • 35. Re: Caps Lock error message
        labsv67792186 Level 1
        I am using: CC 2018, w/ my macbook pro 2015.
        When I using my wireless keyboard, the problem appears: the cap lock warning always pop out...
        So I firstly turned off keyboard, then restart my AE, then turn on and reconnect my wireless keyboard, the problem temporarily disappeared...
        But I hope Adobe can fix this bug soon, to be honest that is super inconvenience...
        • 36. Re: Caps Lock error message
        cocoua Level 1
        Can I change the CAPS shortcut behaviour as I can change other shortcutS? I can't find how!
        but this would be the best to me
        • 37. Re: Caps Lock error message
        Roland Kahlenberg Adobe Community Professional
        No. CAPLOCK and the ESC keys are not selectable in the Keyboard Shortcuts Visualizer.
        • 38. Re: Caps Lock error message
        cocoua Level 1
        still having this issue, everything updated  F***K
        • 39. Re: Caps Lock error message
        What is the exact issue that you're experiencing?
        1 2 Previous Next
