When I make an edit on the image, no symbols appear indicating a change and when I try to mark a star rating no stars appear below the image. However when I assign a colour rating, it does appear.
Hi garryL,
Please select the options you'd like to see above timeline as shown in the screenshot below.
Let us know if that helps.
Akash
Hi Akash
Thank you for taking the time to respond. The screen shot was most useful. I have checked the Flagging, Rating, Color Label, Navigate. and the Stars and colors do show in the tool bar above the photo stream, however when I look at the photos below, it does not show below the photo in the time line, which it use to do. This is most helpful when I am gathering photos that have been rated and I do not have to go through each photo to look at the tab bar above to see if it is rated. Hope you understand my comment.
This is how it use to be, but I have touched something to cause that function to go away. Thank you for your patience.
<Removed by Staff, Please do not add signature while replying via Email.>
HI Akash
This is what I use to have. I do have it one of my computers but not the other. This shows that I have altered photos and has the rating below the photo.
Thank you.
<Removed by Staff>
Right click on any of the Image thumbnail and select all options under "View options".
~Akash
HI Akash
I did that, still no rating under the photo.
Sorry,
Dr. Garry Lunn
#402-1338 W. Broadway
Vancouver, BC V6H 1H2
Canada
garry@drlunn.ca
Could you please post a screenshot of the issue you are facing?
A screenshot of the image showing no star ratings in the timeline would be helpful.
~Akash
Thank you
Dr. Garry Lunn
Canada
garry@drlunn.ca
Screen shots cannot be attached using email.
You need to use the "insert image" button in the website editor.
Sorry, where would I find the “insert image” button in the Web in Lightroom/
Dr. Garry Lunn
Canada
garry@drlunn.ca
I am having the same problem. In the thumbnail images along the bottom of screen, you used to be able to see stars under each image, if you rated it 3 stars, then three stars would appear under photo. Mine just went away one day and I am unable to use it now? Please help as this is how I have always weeded out my images...
Jana
This is the filmstrip.
Mouse [Right-click] on one of the filmstrip thumbnails,
Select [View Options]
Click on [Show Badges] and other options, to place a check-mark that toggles these 'view' features on.
